Marantz SR4001/5001/7001/8001 - Page 95 - AVS Forum | Home Theater Discussions And Reviews
post #2821 of 2845 Old 03-24-2011, 01:10 PM
jluros's Avatar
Originally Posted by djos View Post
I use the IR flasher in on my sr8001 from my MRF-350 IR basestation and it works perfectly even using a stereo cable.
I'm sure it does. Not quite ready to spend $200 on a remote extender. Maybe after my significant other gets tired of the cheap one not working properly.
jluros is offline
post #2822 of 2845 Old 03-24-2011, 08:42 PM
hansangb's Avatar
I too use MX900 and MRF350 combo. Yes, it'll cost you about $350 for both, but remote is *the one* piece of equipment you use *the most*
Even my wife now admits it was a good buy!
Hansang
hansangb is offline
post #2823 of 2845 Old 03-24-2011, 09:32 PM
djos's Avatar
Quoted: 28 Post(s)
Liked: 24
So well worth the money, the WAF at my place is also massive!!
The impossible often has a kind of integrity which the merely improbable lacks.
djos is offline
post #2824 of 2845 Old 03-25-2011, 10:18 AM
adrman's Avatar
ditto that. I wish more pieces of gear had direct flasher inputs.
adrman is offline
post #2825 of 2845 Old 03-26-2011, 05:49 AM
heftydude's Avatar
Where are you getting both for $350? A quick search shows $275+$200 = $475.
heftydude is offline
post #2826 of 2845 Old 03-26-2011, 06:09 AM
regal's Avatar
With the SR5002, is there an inexpensive method to convert the HDMI output to S-video. I have a HDMI output only video card but a S-video only input TV.
regal is offline
post #2827 of 2845 Old 03-26-2011, 07:17 AM
hansangb's Avatar
No, you can get them a lot cheaper than that. Amazon has had the MRF for about $125 in the past (I bought five! - two for me and three for my family)
Hansang
hansangb is offline
post #2828 of 2845 Old 05-23-2011, 02:28 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
Is a used SR7001 worth $200.00? Saw it on CL and thinking of getting as a backup/spare receiver. I unfamiliar with Marantz products of the last few years.
vcrpro3 is offline
post #2829 of 2845 Old 05-23-2011, 02:37 PM
markhyams's Avatar
Quoted: 26 Post(s)
Definitely. I own one and paid $500 for a refurbished unit 18 months ago. The unit is awesome, and accepts multichannel PCM over HDMI, so just make sure your blu-ray player can decode the lossless formats and send them that way. It applies the Audyssey EQ to that signal as well. Plus it has a killer sound!
Samsung LN46A550, Denon 4520, Sony BDP-S5100, Google Chromecast, Logitech Squeezebox
SVS Prime Bookshelf (LCR), JBL E10 (x2 Surround), SVS-SB2000 (Dual Subs)
markhyams is offline
post #2830 of 2845 Old 05-23-2011, 02:41 PM
afrogt's Avatar
Quoted: 1363 Post(s)
Liked: 944
You need to upgrade your TV or use a different video card. You can't down convert HDMI to an analog signal like s-video.
Afro GT
afrogt is online now
post #2831 of 2845 Old 05-24-2011, 07:55 AM
audiodane's Avatar
Quoted: 115 Post(s)
Liked: 77
possible: certainly
expensive: varies
quality: don't know
Here's one on "sale" for $80: (svideo.com)
But I don't know anything about it, quality, reliability, etc.
Atlona also makes one but it's significantly more expensive ($300?)
Well, you can throw more money at the problem (converters, new TV, etc), but my question is, why not just downgrade your source to 480i/p instead? Bluray players, computers, etc. can all output 480 pictures. Why go through all the HASSLE of HDMI when you don't even need it!
..dane
audiodane is offline
post #2832 of 2845 Old 12-01-2011, 07:34 PM
Will2007's Avatar
Quoted: 14 Post(s)
Liked: 135
Sorry for resurrecting on old thread, but I still own an SR7001 and have a new issue with it.
It is capable of receiving a DSD signal from a universal player that plays SACDs. I recently changed the setting on my Oppo BD-80 to output DSD instead of converting it to PCM in the player. I wanted to try and see if there was any discernible difference in letting the player do the conversion, or letting the AVR do it.
At first the AVR will accept the DSD signal and play it just fine, and it sounds great. Intermittently, however, sometimes it suddenly starts emitting a horrible, overwhelming high-pitched squeal that drowns out the music and cries out to you to turn it off immediately. Turning the AVR back on again causing the same squeal. The only remedy is to change the setting in the Oppo BD player back to outputting PCM. Then, everything's fine again.
Changing back to DSD output starts out fine again later, but after an album or so, it starts squealing.
Anyone else encountered this issue? What, if anything, do you do about it?
I know the obvious answer is to keep the output of the BD Player set to PCM and not DSD, but I'd like to keep outputting DSD if possible with a fix.
Thanks in advance for any responses.
Will2007 is offline
post #2833 of 2845 Old 12-24-2011, 09:48 PM
regal's Avatar
Ok because new (good) video cards don't offer S-video output (only HDMI) I went and bought an HD LCD TV.
Now I can run the cable box HDMI-Marantz->SR5002->TV HDMI no problem, HD channels look fine.
And I can run my HD6850(computer) HDMI -> TV HMDI and all is well.
But HD6850(computer) HDMI -> SR5002 is a fail , the SR5002 doesn't recognize the ATI video card as an HDMI input.
Any suggestions? or is this probably just something I will have to live with (run the computer to hdmi input 2 of the TV instead of the SR5002.)
regal is offline
post #2834 of 2845 Old 02-23-2012, 06:30 AM
davedelite's Avatar
I have an SR8001 and have recently moved residences. My new configuration will no longer use the 7.1 in the main room, rather, the 5.1 in main room and use the last two remaining amps for 2 channel on my patio. I know its overkill, but I am going to put a subwoofer on my patio My question is the following. If I use the LFE (by splitting the signal for two subwoofers, one for the main room and a small one for the patio) will the LFE crossover I set in the main setup (say 80 Hz) also apply to zone two speaker signal output? If not, I will obviously have to wire the subwoofer on my patio up to the speaker wires so that I can use its internal crossover if the SR8001 won't do it.
davedelite is offline
post #2835 of 2845 Old 05-01-2012, 01:19 AM
jeppe's Avatar
Hi,is there anyone who know's how to shift between the two HDMI inputs on the SR4001?
Kind regards / jeppe
jeppe is offline
post #2836 of 2845 Old 05-01-2012, 07:51 AM
afrogt's Avatar
Liked: 944
I bought a used SR4001 recently, what do you mean shift between the HDMI inputs? They can easily be assigned.
you can download the user manual here if you don't have it.
http://newmedia.engl.iastate.edu/tut..._Final_eng.pdf
Afro GT
post #2837 of 2845 Old 05-02-2012, 02:00 PM
jeppe's Avatar
Ok,thank you
jeppe is offline
post #2838 of 2845 Old 07-23-2013, 05:13 AM
statona's Avatar
Hi all.... I recently shut down the home theater in my home, a 7.2 system that was designed originally for the room specifically for a home theater.. and like the rest of the world, I have brought my tv out to my living room and I"m repurposing some of the equipment, which includes:
  • SR7001
  • Comcast Scientifica Atlantica Cable Box
  • Center, two fronts, and a sub.
  • I will be adding two rears in the form of in wall built ins over the next few weeks.
  • LG LA7400 55" smart tv
  • Secondary receiver to drive 6 speakers (three rooms) that come into the receiver and serves as the multi-room, with a separate volume control for the three rooms.
  • I am not using a BR on purpose, as I don't buy/rent DVDs, nor do I need the smart apps because the tv has them.
In the new setup, from behind the TV I was aggressive and ran a ton of cables including two cat 6, two hdmi, and a toslink. I'm currently using only the HDMI cable to receiver, which is receiving from the cable box via hdmi, and it all seems to work.
butttttttttttttttttttttttttttt, I'm trying to do a couple of things and have no idea how to setup, and hope you can help:
1) The equipment is located to far away for the microphone to setup the sound, so its still set to my old setup in now a very open room. Any thoughts on how to extend the mic to do an autosound test would be great.
2) Using the smart apps, while still using cable. For example, if I want to run pandora music on multi-room, but display the cable image, I can't know how to do that... or run comcast music throughout the house and display my picasa pics through the smart apps... I"m not sure if I should be directing the TV to send the signal to the receiver via the toslink for pandora via the toslink, and the tv will display cable or not. any thoughts on this would be appreciated.
3) In the land of HD, I'm only getting 5.1 on HD channels, any other channels go to "stereo" and only uses the two fronts. THIS IS THE BIGGIE. How do I set the receiver to force it to go 5.1 all the time?
Finally, at some point, I will add the new Xbox, and I'm sure I will have questions.
Thoughts, comments, help would be really appreciated.
statona is offline
post #2839 of 2845 Old 12-06-2013, 10:23 AM
rmcole1's Avatar
Hello all. Sorry to bring up a post from the past but after about 30 pages of reading I need to confirm a couple of things.
I recently purchased a Sr-8001 and thought I was all set. I am running my Direct Tv into the HDMI on the 8001 as well as my BluRay player. Using my 1080p Tv as a monitor.   My Tv is saying 1080p 60hz when I hit the info button on it. (LGPlasma).
Is my TV playing in 1080p through the HDMI pass through? Or am I just viewing it in 720? Could I use a HDMI splitter to send Blu Ray and DirectTv Directly to my Plasma? From What I have read maybe just the audio is passing through but not all the video.
Or should I just go and get the Emotiva PreAmp Amp special?
Thanks for all the help.
rmcole1 is offline
post #2840 of 2845 Old 12-02-2014, 10:00 AM
tannerjr's Avatar
So, I'm sure that this has happened to all of you at some point.
You create a space that's amazing, the theater-man cave of awesome land. You stick this gorgeous marantz at the helm of your theater ship, so to speak, and then every device that ever dreamed of connecting to your beautiful projector or plasma is begging to get it's HDMI plugged into the mother ship - the big ol' Marantz.
Now, while I can't keep a metaphor straight for even a single sentence, I CAN troubleshoot some HDMI. I mean if we're honest, isn't that what we all wind up doing with TWO switchable HDMI outputs?! I've tried my fair share of REALLY Cheap cables (Yes, cheaper than monoprice) and found them wanting and settled on two MONSTERous cables from Monoprice - did you really think I was gonna buy that really overpriced cable from best buy?!? NEVER!!! HAHA!
So I'm stuck in HDIM handshake land with the following devices seeking connectivity to the SR6003:
  • AppleTV
  • XBOX360
  • BLURay Player
  • TiVo
  • Wii U
BUT, as you all well know, I'm limited by only 3 inputs. So, I swap cables - rather the kids swap cables - which is NOT ok b/c you know the more they jack around with it the more likely they are to break something - so let's just stop this disaster before it happens - right?
So I've tried using this guy from Monoprice with no luck. Just black screen no matter which HDMI input it's on, which device is switched on, which device is switched on first - not a single ounce of luck
Has anyone used anything similar, especially from Monoprice and ESPECIALLY with auto switching
I'd love to hear some good reviews from something out there
tannerjr is offline
post #2841 of 2845 Old 12-02-2014, 10:14 PM
REVNU's Avatar
I used one very similar to that one you have pictured with my SR4001. It's very picky about which HDMI input you plug it into. I forgot where I got it, but it was cheap and it works perfect. I had mine plugged into HDMI 3 IIRC.
Mine has a single button and does not have the integrated HDMI cable. I has 3 females on the switch and 1 female on the output.
I'll do some more research to see where I got it. It has no branding or markings unfortunately. I do remember it was pretty cheap though.
Name:	2014-12-02 22.11.02.jpg
~ REVNU
REVNU is offline
post #2842 of 2845 Old 03-02-2015, 07:04 PM
Quoted: 96 Post(s)
Hey all.
I have a Marantz SR8001, and just recently got a UD5005 Blu-Ray player. I'm a little confused about what the settings should be on each unit to properly decode some of the latest formats. Am I correct in saying that the Blu Ray player can decode the latest formats, then send to the 8001 as uncompressed video? If so, what should the settings be on both?
I'm just getting "multichannel 5.1" on the 8001. No idea if it's been firmware updated yet...I'm going to check tonight.
This Week: Paradigm Prestige 85F mains | Paradigm Prestige 45c center | Paradigm Monitor 3 surrounds | Marantz SR7009 | Emotiva XPA-5 | Marantz 5005 Blu-Ray | Apple TV 4 | REGA DAC.
emptyo is offline
post #2843 of 2845 Old 04-27-2015, 04:57 PM
Liked: 0
I currently have the SR7001 running my Def Tech Center and Surrounds. I have DEf Tech L& R mains going from the Pre out into a Rotel RB 1080 2 channel amp. I listen to music via 2 channel about 90% of the time. I'm impressed with the SR7001's sound and not as impressed with the HDMI handshake issue with my BR. I have an opportunity to acquire a Rotel RSX 1058 and am curious if anyone has had experience with both receivers and can comment on the quality of both in a head to head comparison. I'm very curious to know if the Rotel lives up to the hype. Any feedback anyone can provide will be greatly aprreciated.
Trev
BigTrev72 is offline
post #2844 of 2845 Old 01-02-2016, 05:20 AM
tbase1's Avatar
Quoted: 47 Post(s)
Liked: 70
Anyone have a "front input cover" that they're not using I can buy?
tony4k
tbase1 is offline
post #2845 of 2845 Old 11-18-2016, 12:05 PM
bern43's Avatar
I've got an 8001. No output to sub. Checked the sub and it's working fine. Tried a factory reset and it didn't help. My left surround channel is also cutting out sometimes. Unplugging the receiver for a while seems to temporarily fix this. Any thoughts as to what might be going on? Might be time for a new receiver is my guess.
bern43 is offline
Marantz Sr 4001 Home Theater Receiver , Marantz Sr5001 Xm Ready Surround Sound Receiver
