Panasonic SA-XR700 Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 12-11-2006, 06:07 AM
DAFTEK's Avatar
Also, i notice a picture quality difference in the two connections, DVI to HDMI on receiver then tv looks somewhat worse then DVI to HDMI on TV... This was one of the reasons i returned my Sony 800 back and went with the XR700.
My PS3-Name: DAFTEK add me if u want :)
Click to Join the AVS Forum Folding@Home Team #55280
IMPORTANT! Change your Donor Name from "PS3" to your AVS Handle!
DAFTEK is offline
Old 12-17-2006, 04:37 PM
SlackerX's Avatar
Does this receiver have any virtual surround modes for use with 2 speakers or L,R,C and sub?
SlackerX is offline
Old 12-17-2006, 07:19 PM
WeApOn's Avatar
Quoted: 35 Post(s)
I am looking to buy a 1080p receiver, but this one is very expensive. I just bought a Samsung 1080p TV, and a PS3. I am looking for a receiver to take advantage of the PS3. Is this my BEST choice? Can I expect a price drop soon?
WeApOn is offline
Old 12-18-2006, 10:11 AM
Dermott's Avatar
I have read a little more about this receiver and see that it can actually tri-amp the fronts. What I wasn't clear on was if you can do this with 3.1 (mains, center and sub) or if that function was in stereo mode only. I have Maggie MMG's, my stereo amp took a dump and was looking at another option to power them. The Maggies like power, so I thought six channels of 100 W at 6 ohms running into 2 channels might get the job done. Has anyone tried the tri-amp feature?
"What brings you to this nape of the woods, neck of the wape; How come you're here?"
Dermott is offline
Old 12-18-2006, 11:13 AM
shamus's Avatar
Quoted: 23 Post(s)
If your not using surround back speakers you can do it.
shamus is offline
Old 12-28-2006, 08:35 AM
x016872's Avatar
Does the Panny SA-XR700 run hot?
x016872 is offline
Old 12-28-2006, 10:49 AM
drbonbi's Avatar
No. It's barely warm to the touch when it's on.
Dana
"If you think you can, or think you can't, you're probably right." Mark Twain
drbonbi is offline
Old 12-31-2006, 08:24 AM
purduealum91's Avatar
Who has this receiver in stock? Will it still pass 7.1 LPCM over hdmi from the PS# if the receiver is connected to a monitor with a HDMI-DVI cable?
My new Sony $1k 5200 ES will NOT! and I am pissed. Its prolly going back. I want my PS3 games and blu ray movies in 7.1 LPCM!
purduealum91 is offline
Old 12-31-2006, 08:51 AM
drbonbi's Avatar
Vanns.com, an authorized Panny dealer, has it in stock at a sale price here http://www.vanns.com/shop/servlet/it...ails/538999768 That's where I bought mine - not on sale.
Yes, the XR700 will accept 7.1 LPCM over HDMI with a video out connection HDMI>DVI to the display. I know because I have had it set up that way. (It isn't well known but the DVI cable actually has more pins/wires in it than does the HDMI cable so an HDMI>DVI connection is pin to pin compatible. HDMI just doesn't use all the DVI pins.)
Just to clarify, however. I am using the Panny BD10 Blue-ray player and not the PS3 so YMMV.
Dana
drbonbi is offline
Old 12-31-2006, 06:22 PM
addam122k's Avatar
Ok, I've spent a good week researching this and I would like to ask some advice on a 7.1 receiver. I have narrowed it down to the XR57, XR 700(for extra HDMI and full 1080p), and Onkyo txsr604(hdmi 1.1...not sure how big of a deal that is?)
The Onkyo being the only non-digital amp. This is for a smaller game room (12X14?) with a 42" Panny th42ph9uk and a PS3. I know the 57 is sub-$300 now but I keep hearing of issues with PS3 and it only has 1 hdmi connection. The onkyo is mid-$3's but I'm not that familiar with the model. I know onkyo's history but not sure on the current products and quality. this leaves me xr700 for around $600. I'm very new to digital amps but have been hearing great stuff on these postings.
I have a computer I use as a mmserver and am wondering if I will see a noticable difference using a dvi->hdmi connection vs. the d-sub monitor connection on the 42-9uk? Would it be worth pushing for the 2-hdmi unit? Second, is the hdmi v1.1 going to make a difference for general game play and movie watching?
So, can I keep the cost down and go the 57 or 604 route or does the 700 present that much of an upgrade that the extra $200-$300 would make the difference? Thank you in advance for any advice here.
addam122k is offline
Old 01-01-2007, 08:30 AM
darryl b's Avatar
is there anyway to use the xr700 as a pre/pro?
thanks
darryl b is offline
Old 01-01-2007, 09:30 AM
Earz's Avatar
The 604 does not do 7.1 lpcm (only 5.1) over hdmi....and it has loud clicks when switching inputs.
It also can't compete with my sa-xr 45 for minute detail and fast tight mid bass...so I am taking it back and getting the 700 as a stop gap for 1.3
If it turns out that DTS-MA can be converted to PCM via the 700.....I doubt I will even bother upgrading to a 1.3 receiver.
The better your speakers....the better these digital Pannys sound....assuming there not dipping below 4ohm.
My theater is only 22 x 14 driving 5 custom made all Scan Speak revelator speakers that dip only to 5ohm and a lower end 500.00 B&W rear center.
Earz is offline
Old 01-01-2007, 09:48 AM
SiriuslyCold's Avatar
darryl b
nope - its a digital amplifier and doesn't have analog line outputs
Boo!
SiriuslyCold is offline
Old 01-01-2007, 06:03 PM
WeApOn's Avatar
Quoted: 35 Post(s)
Any idea on when there will be a price drop on this product? I have been highly considering it to pair with my 1080p TV and PS3, but with HDMI 1.3 products coming this year, is a price drop due soon? I bought my TV JUST before a big price drop and lost out on a good save, and I'm trying to avoid doing that again.
WeApOn is offline
Old 01-01-2007, 06:31 PM
drbonbi's Avatar
See my post #99 and check out the link. We're not supposed to be talking prices on the AVS Forum.
Dana
drbonbi is offline
Old 01-03-2007, 07:49 AM
Why is this receiver so difficult to find at retail?
Old 01-03-2007, 11:53 AM
WaldorfSalad's Avatar
If you have an Ultimate Electronics in your area you can get the XR700 there.
WaldorfSalad is offline
Old 01-03-2007, 02:32 PM
Hey Gang,
Does the XR700 have the dreaded -10db LFE issue? If so, whats the workaround?
Old 01-03-2007, 11:16 PM
shamus's Avatar
Quoted: 23 Post(s)
Hey Gang,
As far as I can tell..... No.
shamus is offline
Old 01-12-2007, 06:47 PM
Koald's Avatar
[quote=drbonbi]Vanns, an authorized Panny dealer, has it in stock at a sale price. That's where I bought mine - not on sale.
DRBONBI,
Vanns appears to be taking pre-orders pending availability.
Another possible low price source is Zoommania. (also currently out of stock)
Thanks for the good information,
Koald
Koald is offline
Old 01-12-2007, 07:17 PM
drbonbi's Avatar
[quote=Koald]
DRBONBI,
Koald
Amazon has it at a sale price. In stock!
Dana
drbonbi is offline
Old 01-12-2007, 08:35 PM
[quote=drbonbi]
Dana
Amazon themselves don't appear to have it. Are you referring to $519 through a new Marketplace seller (DataVision) with only 1 feedback rating? Good price but possibly a risky seller.
Old 01-13-2007, 04:55 AM
drbonbi's Avatar
[quote=WaldorfSalad]
I'm not touting Amazon but if you buy through them, you have their full protection.
Dana
drbonbi is offline
Old 01-14-2007, 07:32 AM
cglauner's Avatar
i had bad experiences with these guys as their customer service is horrible. if you dont live in the NY area (where they have their store), i would not get it.
crutchfield has it and they are good...
I ordered mine from Vanns when they had the sale and it is expected to get here on Monday...
cglauner is offline
Old 01-16-2007, 10:08 PM
cglauner's Avatar
I finally got my xr700 and i have a two questions.
I have PS3 and A1 connected over HDMI.
1. the display when playing music never shows what codec/bitrate it is using. I only see the "digital input" bar illuminated. can I see what codec the receiver is processing and how?
2. I also notices that in comparison to my old receiver (Pioneer 1018), the volume level is different = lower. I used to have my PS3 connected through the optical cable and now when I play movies or games, I have to increase the volume significantly to get the same output. The same applies to the DVR I have now connected through the optical, it seems much lower in volume and when I increase it, other source when switching back are much louder. does someone know why?
thanks
cglauner is offline
Old 01-18-2007, 02:50 PM
mageeks's Avatar
The SA-XR700 is meant to go hand in hand with the Panasonic Blu-ray player. The Player has 7.1 analog outputs but I don't see the same 7.1 inputs on the back of my receiver,only 5.1. Am I missing something here ? Is there some other way to plug in the rear surrounds ? Thanks.
mageeks is offline
Old 01-18-2007, 08:12 PM
shamus's Avatar
Quoted: 23 Post(s)
Do you have both???? If so, use HDMI. Set all speakers to large(on player) and make sure it shows a 7.1 speaker config(again on player). Use the receiver to change any speakers sizes, crossovers etc.... Pop in The Descent or Crank and enjoy!
shamus is offline
Old 01-19-2007, 12:59 AM
mageeks's Avatar
Thanks Shamus. Yes I got both units this month,Happy Christmas/Birthday to me. My old receiver was a Yamaha HTR-5590 which was great but there seems to be more possibilities with the Pan 700. I just put Crank and Descent on top of my Netflix que. So with the speakers on large on the Panny Blu-ray should I then set them to small on the XR 700 ? I've read that a few times.
I can't seem to have both the Panny Blu-ray and the Tosh A1 set up at the same time through HDMI. I lose the picture on the Toshiba so I went with component picture and analog sound on the Toshiba.
mageeks is offline
Old 01-19-2007, 08:12 AM
shamus's Avatar
Quoted: 23 Post(s)
Happy Birthday. Unless you have expensive full range speakers, all speakers on player are set to large and receiver should be set to small(dont forget crossover and delays). If your a little unsure of these, use the set up mic... its not perfect but it does an ok job. One problem when using component and HDMI, I believe component will be downconverted to 480!!! Try setting resolution on the players to a fixed resolution(1080i, 720p etc).... that could solve sync issues.
I have the XR-700 and the Panny BD player via HDMI and here are my settings....
BD-10
-4:3 aspect (on)
-PCM down conversion (off)
-Dolby Digital (bitstream)
-Dolby Digital Plus (PCM)
-DTS (bitstream)
-BD function sound (off)
-HDMI video (on)
-HDMI resolution (set to your display resolution)
-HDMI audio (on)
-CTRL with HDMI (on)
-Speaker sizes (large)
-Delays (0)
-Channel db (0)
XR-700
-lr,c,s,sb (small)
-sb (2-spk)
-subw (yes)
-Distance (measure to seating position)
-Filter frq (set to the smallest speakers crossover)
-Bi amp (off)
-Dual amp (auto)
-Drcomp (off)
shamus is offline
Old 01-19-2007, 10:48 AM
drbonbi's Avatar
shamus,
Very nice. Helpful. Thanks.
Dana
drbonbi is offline
