Problem with Onkyo TX-SR674 using HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 106 Old 11-06-2006, 07:30 PM - Thread Starter
Gillest's Avatar
Here is my setup:
1) Samsung HL-S7178 (1080P) TV connected to Onkyo TX-SR674 receiver using HDMI cable.
2) Samsung DVD-HD960 connected to Onkyo using HDMI.
3) Also have Bell 9200 HD-PVR connected to Onkyo with HDMI.
Problem:
When playing DVD getting small video/audio cuts (few miliseconds but enough to notice) about every 5 minutes. DVD player is setup to run at 1080P and problem happens selecting DTS or DD5.1.
Bell HD-pvr running at 1080I not giving any issues. Running the dvd player at 1080I still gives cuts but less frequently.
It seems the Onkyo is having problem processing the audio at the same time as doing passthru of 1080P to TV.
Anyone experienced this?
Tested connecting the dvd directly to the Samsung tv (It has 2 HDMI ports and supports 1080P) and the problem does not happen.
Gillest is offline
post #2 of 106 Old 11-07-2006, 04:25 AM - Thread Starter
Gillest's Avatar
Has anybody been able to do 1080P hdmi passthru with this receiver?
Gillest is offline
post #3 of 106 Old 11-07-2006, 07:56 AM
leibniz's Avatar
sorry, i don't have a 1080 display, but i've never seen these issues. i use an upconverting DVD player at 720p (until my A2 arrives!) and also a Pro brand ATSC tuner at 1080i. neither seems to have a problem.
it strikes me as odd that your Bell PVR at 1080i doesn't exhibit the problem, but that your DVD player at 1080i does (though less often than at 1080p). when you tested the connection directly to the television, did you use the same cable?
leibniz is offline
post #4 of 106 Old 11-07-2006, 10:36 AM
Nathan_R's Avatar
I have the same problem with my Sammy Blu-ray player at 1080p through the 674. I thought I was alone.
PSN: KyFriedNate
Nathan_R is offline
post #5 of 106 Old 11-07-2006, 10:47 AM - Thread Starter
Gillest's Avatar
Nathan,
If you have not done so please report it to the ONKYO support line (800-229-1687).
I am awaiting a call back from them after spending over 1 hour explaining the problem and after they told me they did a test that did not show the problem. After a while they admitted their test was at 1080I....
Hopefully they can come out with a fix otherwise I am returning the unit (bought it 2 weeks ago).
Cheers,
Gillest is offline
post #6 of 106 Old 11-07-2006, 10:51 AM - Thread Starter
Gillest's Avatar
Leibniz,
I used the same cable when doing test directly to tv and also swapped cables many times doing my tests. What I believe is the reason it is not hapenning using the Bell HD-pvr is that because the Bell pvr only sends video thru the hdmi (I have a toslink for sound) and this particular problem is related to decoding audio while doing passthru of the video when connected in hdmi.
Gillest is offline
post #7 of 106 Old 11-07-2006, 03:15 PM
leibniz's Avatar
Gillest, that's disheartening! Please keep us informed as to what happens with Onkyo support.
I'll do some testing with my HDtuner set at 1080i and see if I can produce the same problem with mine.
leibniz is offline
post #8 of 106 Old 11-07-2006, 03:51 PM
Nathan_R's Avatar
For what it's worth, I haven't had any problems with 720p or 1080i with the Onkyo-- just 1080p.
PSN: KyFriedNate
Nathan_R is offline
post #9 of 106 Old 11-07-2006, 04:19 PM - Thread Starter
Gillest's Avatar
Well that is the issue with this receiver (1080P).
Onkyo claims that their receiver is able to passthru 1080P. So far it seems that this feature does not work properly. I bought it because of that feature and I personnaly want it to work.
Nathan, Did you report the problem with Onkyo? We need people to start complaining if we want them to understand that this is not an isolate issue but for everyone using 1080P.
More and more people will be using it in the future with Blueray or HD-dvd. I cannot believe they released a product without doing the basic tests at 1080P.
Gillest is offline
post #10 of 106 Old 11-08-2006, 04:16 AM - Thread Starter
Gillest's Avatar
Just an update to let you know that I have not still received a call back from Onkyo. I will try them agin later today if I do not hear back from them.
Gillest is offline
post #11 of 106 Old 11-09-2006, 04:24 AM - Thread Starter
Gillest's Avatar
Nathan,
I know you also reported the problem to ONKYO. Did you get a reply from them?. I am still waiting for them to respond. I have sent another email and also have left a vm with the Onkyo distributor for Canada.
Hopefully they will be responsive to our problem.
Gillest is offline
post #12 of 106 Old 11-09-2006, 09:05 AM
Nathan_R's Avatar
No, they haven't responded to either my email or voicemail.
PSN: KyFriedNate
Nathan_R is offline
post #13 of 106 Old 11-10-2006, 04:31 AM - Thread Starter
Gillest's Avatar
Well, I have sent numerous emails to Onkyo support and left a voice mail with the Canadian distributor for ONKYO but nobody has replied yet. I have asked my dealer to help by contacting ONKYO thru his channel and so far he has not been successful.
I am very close to trow in the towel and to ask my dealer for a refund and I would then probably be considering the PIO Elite 81 or 82TX. More money but hopefully these will work as advertised.....
Will give it until next Monday....
Gillest is offline
post #14 of 106 Old 11-10-2006, 02:01 PM - Thread Starter
Gillest's Avatar
Well, just got off the phone with my reseller and he told me that ONKYO is getting a fix (small transistor + software from what I gathered ??) and that should arrive sometime next week.
This is good news because it shows that they acknowledged that there is a problem and they have an action plan!. Hopefully this will solve the problem for me and any others buying this receiver.
Will keep you all informed.
Cheers,
Gillest is offline
post #15 of 106 Old 11-11-2006, 09:44 AM
leibniz's Avatar
thanks for staying on top of this gillest! let us know when you hear more regarding the fix.
leibniz is offline
post #16 of 106 Old 11-13-2006, 04:06 PM - Thread Starter
Gillest's Avatar
Well, I have been contacted by my reseller who gave me the name and address of an authorized Onkyo service center that is supposed to have the latest fix for my 674. I am to go there an request that my 674 be upgraded for 1080P. Apparently they are aware of the small transistor that needs to be changed and the new software that needs to be loaded.
Going there tomorrow and hopefully I wont have to leave the receiver there for a few days and they will be able to upgrade it on the spot.
Will let you know tomorrow night.
Gillest is offline
post #17 of 106 Old 11-14-2006, 02:00 PM - Thread Starter
Gillest's Avatar
Had to leave my receiver with the Onkyo authorized service centre unfortunately. They said it could take a few days up to a week because they needed to order the part (transistor?).
The person at the service centre showed me an email sent to them by ONKYO advising them of this issue (1080P) and the work needing to be done on the TX-SR674.
Will just have to wait and see if it really fixes my problem.
Gillest is offline
post #18 of 106 Old 11-14-2006, 10:40 PM
mhem67's Avatar
My heart just sank after reading this thread. Now I feel ripped off by Onkyo. Please post your results after the supposed fix. Thanks
mhem67 is offline
post #19 of 106 Old 11-15-2006, 06:36 AM - Thread Starter
Gillest's Avatar
mhem67,
Why? Please expand on your experience.
thanks,
Gillest is offline
post #20 of 106 Old 11-15-2006, 09:03 AM
guste's Avatar
Gillest,
I'm curious, did you get your unit locally, or did you pick it up from an online retailer? I'm just looking at my options (Marantz SR 4001, HK AVR645, JVC RX-D702B, Denon AVR-887, Onkyo TX-SR674) and availability seems to be coming into play for my decision.
Also, good luck with getting the unit fixed... I've been following the thread for awhile to see how you make out.
guste is offline
post #21 of 106 Old 11-15-2006, 12:55 PM
Dan_R_M's Avatar
If the fix works, I wonder if they will make production line changes so that the newer ones in the stores will be fixed.
Dan_R_M is offline
post #22 of 106 Old 11-15-2006, 01:03 PM - Thread Starter
Gillest's Avatar
Originally Posted by guste View Post
Gillest,
I bought the unit from a local A/V store in Montreal. They have been great at pursuing Onkyo to help me (maybe because i told them I wanted a refund if Onkyo could not fix it ).
As I mentioned previously, I will let everyone know once I get my 674 back as far as if the fix corrected my 1080P problem.
Gillest is offline
post #23 of 106 Old 11-16-2006, 02:48 AM
mhem67's Avatar
Originally Posted by Gillest View Post
mhem67,
thanks,
Well, I bought this receiver to complement my 1080p lcd. When I get a 1080p disk player I fully expect 1080p passthrough with no glitches. From what you have posted it seems there is a problem with that. I do not expect to have to take a brand new unit to get an upgrade so soon.
Also, after reading other posts here about the 674 not being capable of 7.1 LPCM via HDMI, I think I should have waited before making my purchase. Honestly, since I am a newbie at this so I could be wrong, it appears that I will not be able to use HDMI for a 7.1 speaker set. If this is incorrect, someone please enlighten me.
I did get a good price for the 674 and it works great for now. It is the future hookups that I intended to make that worry me now.
mhem67 is offline
post #24 of 106 Old 11-16-2006, 05:34 AM - Thread Starter
Gillest's Avatar
nhem67,
Unfortunately, I believe you are right about HDMI not being able to carry 7.1 Lpcm on the 674.
As far as 1080P, hopefully ONKYO will have solved this issue with the upgrade.
Will post here when i get my unit back.
Cheers,
Gillest is offline
post #25 of 106 Old 11-16-2006, 11:32 AM
Jakeman02's Avatar
Aparantly not yet. I emailed them with the same question as I'm currently looking at the 604 and 674. They see it as an isolated issute. Maybe if more have the problem they will think differntly.
Thank You for contacting Onkyo USA Product Support.
James,
The issue you are asking about was an isolated issue we are aware and are currently researching it in our CS Lab.
Bob Elder
Again, thank you for contacting Onkyo USA Product Support,
if you need further Assistance feel free to call us at 800-229-1687.
Jakeman02 is offline
post #26 of 106 Old 11-23-2006, 02:50 PM - Thread Starter
Gillest's Avatar
Got my Onkyo 674 back today from repair.
They changed a resistance and upgraded the software. Guess what? It did not fix the problem! I just called my dealer to let him know.
As far as I am concerned I just want a refund at this stage.
Gillest is offline
post #27 of 106 Old 11-23-2006, 05:06 PM
DaveFi's Avatar
Quoted: 71 Post(s)
Liked: 33
Do the 674/604 have bass management over HDMI? I don't have a sub because I live in an apartment.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #28 of 106 Old 11-23-2006, 05:26 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2250 Post(s)
Liked: 2818
The fact that your problem is happening only once every few minutes implies to me that it is happening when the player tries to reconfirm the HDCP (copy protection) compliance of the HDMI signal path.
Running a 1080p signal uses a lot of bandwidth in the cable. If the cable is not quite up to it, the additional effort of re-doing the HDCP handshake may cause a glitch. It sounds like you are right on the borderline of this working.
A 1080i signal uses less bandwidth and thus is working for you.
If this is really what's going on, then you may only need to replace your current HDMI cables (all of them that need to be in the 1080p signal path) with high end cables that have slightly less signal degradation. Get the shortest cables that will work for you as length is also an issue in such cases.
Such cables are ridiculously expensive, so get them from a place where you can return them just in case they don't solve your problem.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #29 of 106 Old 11-23-2006, 06:52 PM - Thread Starter
Gillest's Avatar
Bob,
That is very interesting.
I am using the 3' hdmi cable that came with the Samsung DVD-HD960 player connected to the onkyo 674. I am using a 6' 24 gauge HDMI cable (from monoprice) from the Onkyo to the Samsung TV.
I will see if I can get some high end cables and try your suggestion.
Gillest is offline
post #30 of 106 Old 11-23-2006, 06:55 PM
Read the FAQ!
Liked: 2818
And remember it's not just the guage. A thicker cable is not necessarily better. Partly it is the internal connections and the quality of the contacts on the connectors. But largely it is just that the more expensive cables are cherry picked by quality control and only the best get the big price tag.
--Bob
