EMOTIVA Thread Q&A [TECHNICAL TALK ONLY] - Page 578 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #17311 of 17339 Old 02-05-2016, 11:18 AM
caesu's Avatar
I solved the humm/buzz issue, thanks for the thought though
Im using it to run my rear speakers, so I had the volume turned to the max from the get go and let my receiver calibrate the channel levels. It ended up making the surround back like -12db....
I also noticed that the humm/buzz was actually in both speakers, slightly more pronounced in one over the other.
I turned the volume down to 75% and it was pretty much quiet, and then to 50% volume and both speakers are now dead quiet. I ran the avr calibration again and it set the surround back speakers to +3.0db.
Makes a lot more sense as I was probably just pushing the amp to the max and had them generate some humm/buzz at max power (even then only audible like 1-2 inches away from the speaker).
All is good now, the amp is working as I intended. Thanks everyone who helped me along with this!! You guys are great
caesu is offline
post #17312 of 17339 Old 02-20-2016, 07:23 PM
Ediddy's Avatar
Quoted: 73 Post(s)
Liked: 71
When downstairs this evening to put in a movie and both my amps where off I have an XPR-2 and a XPA-5. The five cut on with no issues but the XPR-2 clicked on and then off. I tried to cut it on several times and the same thing happened. The XPR-2 run my two tower speakers and they where off as well. Once I unplugged my amp and plugged my speakers back in they powered on. I then unplugged the speakers took out all of the speaker wire and the xlr balanced outputs going to my amp. Once I cut the amp back on it started clicking really loudly. I have a separate 20 amp outlet that only runs the XPR-2. I haven't had any issues with this amp before and I'm not sure why it's tripping with nothing else hooked up to it. Really perplexed. There goes movie night
(2) GoldenEar Triton 1s, GoldenEar SuperCenter XXL, (4) GoldenEar HTR 7000, Dual Seaton Sumbersive HP (Master / Slave), Sony VPL 55es, Dalite 119 inch UTC, Darby Darblet, Oppo 103, Integra 80.3, Emotiva XPR 2, Emotiva XPA 5, Panamax 5102, Harmony Elite.
Ediddy is offline
post #17313 of 17339 Old 02-21-2016, 10:43 AM
Aquarian09's Avatar
Quoted: 67 Post(s)
Didnt read the entire thread, but I have a quick question, is it true about the Gen 3 XPA models ?
if its true, How much would they cost ?
Aquarian09 is offline
post #17314 of 17339 Old 03-07-2016, 11:10 AM
rustolemite's Avatar
Quoted: 137 Post(s)
Liked: 47
Quick dumb question I just replaced my XPA-5 Gen1 with a Gen2 model and I am hearing a little pop right the amp cuts on, its right after it all the blue lights come on, the Gen1 never did this.
Is this normal? I have this running on a marantz av7702mkii the Gen1 was going through a Yamaha CX-A5000.
VIDEO: Mitsubishi WD-92840 - Samsung BD-J7500 - Sony BDP-CX960 - HTPC -Xbox One
AUDIO: XTZ Cinema Series -M6 L/C/R - S5 Surrounds - S2 Atmosphere - HSU VTF-3 MK4 Sub - Marantz AV7702mkII - Emotiva XPA-5 Gen2 - Blue Jean Cable Canare 4S11 Speaker Cable
http://www.invelos.com/dvdcollection.aspx/Rustolamite
rustolemite is offline
post #17315 of 17339 Old 03-07-2016, 12:48 PM
ALtlOff's Avatar
Quoted: 1095 Post(s)
Liked: 542
I get the same thing, pop and click, from my gen-2 and my XPR's. It always seemed normal to me.
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
post #17316 of 17339 Old 03-07-2016, 01:00 PM
Quoted: 137 Post(s)
Liked: 47
Hey thanks for the response glad its not just mine and it doesn't seem to affect anything else and only does it when powering up.
post #17317 of 17339 Old 03-07-2016, 03:35 PM
azz7686's Avatar
Quoted: 169 Post(s)
Liked: 59
Good to know cause my new XPA-2 does this also was kind of worried.
Spoiler!
azz7686 is offline
post #17318 of 17339 Old 03-07-2016, 04:20 PM
ALtlOff's Avatar
Liked: 542
Honestly, the only reason it didn't worry me much was that my XPR's have even more pops and clicks including speaker pop, my gen-2 XPA-5 is no where near as bad as those...
Plus I have 4 triggering on at the same time, there's a bunch of little noises going on for a couple of seconds, but never any issues.
azz7686 likes this.
My Build Thread:
ALtlOff is offline
post #17319 of 17339 Old 08-20-2016, 09:40 AM
Jupiter7's Avatar
Quoted: 24 Post(s)
Liked: 2
I bought a refurbished XPA2 Gen2 amp from Emotiva Ebay two months back. Recently I am hearing a short hiss sound from the front left speaker about 10 secs after I turn off the amp. I have attached a recording of the sound. There is bit of background noise, but you can hear the sound at about 10s. It is not very loud, but loud enough to hear it clearly from my sitting position (8ft from the speaker). Has anyone experienced this?
Jupiter7 is online now
post #17320 of 17339 Old 08-21-2016, 07:09 AM
Nemesis.ie's Avatar
Quoted: 56 Post(s)
I get a similar sound for about 3 seconds when powering on one of my UPA-1 amps.
It#s been like that since new (several years ago) and does not seem to affect normal use so I have ignored it (as shipping the unit back from Ireland would be a pain and it does not seem to be a problem).
Probably something to do with some of the capacitors charging/discharging.
Nemesis.ie is offline
post #17321 of 17339 Old 08-21-2016, 07:15 AM
Jupiter7's Avatar
Quoted: 24 Post(s)
Liked: 2
Do you get it when powering off also? I'll call Emotiva and see what they say about this.
post #17322 of 17339 Old 08-21-2016, 08:29 AM
Nemesis.ie's Avatar
Quoted: 56 Post(s)
No, only at power on.
post #17323 of 17339 Old 08-21-2016, 12:19 PM
jruser's Avatar
Quoted: 59 Post(s)
I have an XPA-5 gen1 and wanted to hook up some Klipsch RP-140SA. These speakers have a max 50W continuous rating. Would the XPA-5 blow them out? The XPA-5 would also be powering some RB-81's and an RC-62, which can handle more power.
If it wouldn't blow them out, would there be a large volume difference between the channels, if driven with the same signal?
jruser is offline
post #17324 of 17339 Old 08-22-2016, 03:50 AM
Nemesis.ie's Avatar
Quoted: 56 Post(s)
It would only likely cause damage if you cranked up the volume to very high levels. If you keep the output below the rated 50w it would actually be safer for the speakers than e.g. using a 25w amp as the amp will not go into clipping before the speaker's max ability is reached.
I'm not sure what you are asking about the channel differences, the levels can be balanced using your sound processor (and if you have a built in room correction system it will do that for you automatically).
I have Emotiva ERM-6.3s (300W or so capable) and also some RSL ceiling speakers (they suggest 25 to 150W) running from an XPA-5 with no issue. YPAO on my processor has the ceilings at about 2db higher than the bookshelfs.
Unless you have a huge space or are over-zealous with the volume knob everything will be fine.
post #17325 of 17339 Old 09-04-2016, 03:56 PM
JohnnymoZ's Avatar
Quoted: 28 Post(s)
Liked: 74
What are you guys using for the RCA cables from your EMO to your AVR's? I saw these on Monoprice.... would these work?
image for pid 2680
6ft High-quality Coaxial Audio/Video RCA CL2 Rated Cable - RG6/U 75ohm (for S/PDIF, Digital Coax, Subwoofer & Composite Video)
Product# 2680
my stuff:
Harman Kardon AVR 3600
Emotiva XPA-3
OPPO BDP-103
Klipsch RF-82II Mains
Klipsch RC 62II Center
Klipsch SS.5 L&R Surrounds
Klipsch SS.5 L&R Rear Surrounds
HSU Research VTF2-MK4 Subwoofer
Samsung UN65F8000 LED Monitor
JohnnymoZ is offline
post #17326 of 17339 Old 09-05-2016, 09:10 AM
goros's Avatar
Liked: 34
image for pid 2680
6ft High-quality Coaxial Audio/Video RCA CL2 Rated Cable - RG6/U 75ohm (for S/PDIF, Digital Coax, Subwoofer &; Composite Video)
Product# 2680
I build my own using Belden 1694A, SnapNSeal SNS1 ends with gold plated monoprice F-male to RCA connectors.
goros is offline
post #17327 of 17339 Old 09-05-2016, 10:22 AM
DonH50's Avatar
Quoted: 1926 Post(s)
Liked: 1457
image for pid 2680
Product# 2680
Those will work just fine.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #17328 of 17339 Old 09-05-2016, 11:59 AM
JohnnymoZ's Avatar
Quoted: 28 Post(s)
Liked: 74
Ok, good thank you.... Ive been using a set of 20 year old Monster cables.. I had to tear 2 Siamese pairs apart to get 3 individuals. Id rather have the 3 separates.
my stuff:
Emotiva XPA-3
OPPO BDP-103
post #17329 of 17339 Old 04-28-2017, 06:07 PM
Roopster's Avatar
XPA-3 gen 2 - no sound output
Hi All,
Need some assitance with a XPA-3 Gen 2.
Have searched the thread and the forum, but not found any leads
Have the unit connected to a Marantz AV7702 and driving Golden Ear Triton 3 speakers.
I have the trigger cable also connected so the XPA 3 switches on when the Marantz does.
The XPA-3 comes on and the 3 blue lights come on one by one (with soft click)
Unfortunately, i am unable to get any sound out of the amp.
I have used different sources, the internal sound check from the Marantz, double checked all connections (interconnects and speaker), swapped interconnects to new ones but still no joy.
Am using RCA interconnects and have the input selector switch set to unbalanced.
The unit doe snot seem to be in fault mode or protection mode either.
Any pointers or suggestions is greatly appreciated.
Regards
Roopster is online now
post #17330 of 17339 Old 04-29-2017, 01:20 AM
Nemesis.ie's Avatar
Quoted: 56 Post(s)
Maybe try the input switches set to balanced in case they accidentally got wired backwards.
If it's new it sounds like it could be DOA.
post #17331 of 17339 Old 04-29-2017, 08:21 AM
Roopster's Avatar
Thanks Nemesis.
Unit is not new. Was working earlier - with the input switches in the unbalanced position.
Unit under warranty - but not keen to call Emotiva support based on prior experience.
Have read online about some fuses that may need replacing. Am just surprised that if there was an issue, it would go into fault or protection mode - but doesn't - at least does not look like it has.
post #17332 of 17339 Old 04-29-2017, 08:27 AM
Nemesis.ie's Avatar
Quoted: 56 Post(s)
In that case, maybe pop the top off and check that none of the wires to the controller board(s) have come loose/or fallen off as well as the fuses.
IME the fault protection only engages due to issues with the output.
post #17333 of 17339 Old 04-29-2017, 08:53 PM
Roopster's Avatar
Thanks Nemesis,
Will do that.
post #17334 of 17339 Old 04-30-2017, 05:02 AM
Nemesis.ie's Avatar
Quoted: 56 Post(s)
Good luck!
post #17335 of 17339 Old Yesterday, 08:27 PM
Roopster's Avatar
Good luck!
Spoke to Emotiva support today.
They suggested that the output fuses may have blown. They say that it is quite common.
And sent me a doc on how to check/replace the fuses.
The doc is for a Gen 1 product, but figured a Gen cant be that different.
Unfortunately - after removing the only three screws I could find holding on the top cover, I cannot even budge the top cover.
Lift up, slide off, tried all sorts of stuff but still no joy.
Don't want to pry using a screwdriver as that would definitely damage the sheet metal.
Any pointers from anyone who as removed the top cover of an XPA-3 gen 2?
is there a special technique to get the cover off?
Thanks in advance
post #17336 of 17339 Old Yesterday, 11:38 PM
Nemesis.ie's Avatar
Quoted: 56 Post(s)
Originally Posted by Roopster View Post
S
Thanks in advance
If I recall, the lid on my XPA 5 was quite easy, some screws along the back edge and maybe a couple on each side and it slid off towards the back.
It's buried in a corner at the moment so I can't get at it to look.
You may need to gently pry between the front edge (thick aluminium) and cover, you could use a plastic tool to avoid damage.
https://www.ifixit.com/Store/Tools/Spudger/IF145-002-2
https://www.ifixit.com/Store/Tools/H...er/IF145-013-1
post #17337 of 17339 Old Today, 07:17 AM
Roopster's Avatar
Thanks Nemesis,
I did try to slide it off towards the back (similar to PC tower cases. No joy. I also tried to pry using some plastic tools I had (used to remove trim in autos, but managed to snap one of those (and they are pretty tough) - thats why I am thinking there may be more to it than meets my eye. Only three screws i could identify
post #17338 of 17339 Old Today, 12:05 PM
DonH50's Avatar
Liked: 1457
Look for another screw? Email or call Emotiva?
post #17339 of 17339 Old Today, 04:03 PM
Roopster's Avatar
Thanks Nemesis,
Spoke to Emotiva again today
there are an additional 4 screws on each side of the XPA-3 gen 2 amp - DUH - face palm
I did see them, but they were so much lower did not think they could be holding on the top cover. Seems there are 4 lugs on each side of the top cover that reach down internally that these screws bolt into.
Emotiva , Emotiva Xpr 1 , Emotiva Xmc 1 , Emotiva Audio Corporation , Emotiva Xpa 3 Amplifier , Emotiva Usp 1 Stereo Preamplifier , Emotiva Upa 200 2 Channel Amplifier , Emotiva Xpa 2 Stereo Power Amplifier , Emotiva Xpa 1 Monoblock Power Amplifier , Emotiva Xpa 5 5 Channel Power Amplifier
