Rotel Owner's Thread - Page 54 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
post #1591 of 1610 Old 05-06-2016, 12:06 PM
Liked: 8
Rotel and my dealer were good enough to swap out my RSP1582 with a fresh one, seems to be working perfectly. These are great components.
I had some BJC HDMI and Interlinks made a while back, I think the BJC XLRs are not grounded (the popping noise thru the speakers) and the HDMI crapped out on me "mid-Spectre" (sorry, Mr Bond) so I got pissed and dropped some coin on some AQ fluff. Mackenzie XLRs, Carbon HDMIs, Rocket 44s (bi wire), new Power cables for both amps, the processor and the Oppo. Oh, and Cryo-treated Hubbell HBL5362 outlets from CableDyne.
I had a moment of impulse, hopefully I do not go further down the rabbit hole.
Patrick Butler likes this.
HoustonRider is offline
post #1592 of 1610 Old 05-17-2016, 06:10 AM
Liked: 8
So the last BJC XLR was replaced ( I only had 6, waited on the last to arrive) with new AQ Mackinzies, and the pop/noise is gone. What a difference for sure.
Finally getting it all buttoned up the way I want, now focus on tuning.
post #1593 of 1610 Old 05-22-2016, 05:54 AM
Quoted: 328 Post(s)
Liked: 49
Does the Rotel 1590 pre amp (DAC) go up to 24-bit/192kHz for optical ?
blackjack616 is offline
post #1594 of 1610 Old 05-23-2016, 06:09 AM
Patrick Butler's Avatar
Quoted: 283 Post(s)
Liked: 99
Hi blackjack616,
Per page 16 of the manual, yes.
Patrick Butler
B&W Group North America
blackjack616 likes this.
Patrick Butler is offline
post #1595 of 1610 Old 05-24-2016, 08:02 PM
x43x's Avatar
Quoted: 260 Post(s)
Liked: 385
Is anyone using the ARC function on their 1572? I'm using the proper output of the Rotel to the proper input of my TV. I've set the HDMI Control to ON on the Rotel per the manual and selected ARC audio on the TV, but what else am I missing? The manual is pretty vague on what source I need to have selected on the Rotel. There is no selection for "HDMI OUTPUT 1" in the audio selection for the input I'm using for the TV. Is there a special "input" I need to select for ARC to work properly?
LG OLED65E6P - Rotel 1572 - Rotel 1075 - Oppo 103 - Samsung K8500 - Roku 2 - B&W 704, HTM7, DS3 - ML Depthi - Vincent PHO-700 - VPI Traveler
x43x.com
x43x is online now
post #1596 of 1610 Old 08-30-2016, 07:40 AM
hatlesschimp's Avatar
Quoted: 282 Post(s)
Liked: 166
Will the Rotel 1585 run 3x Kef Ci5160rl-thx and 2x Ci3160Rl-thx. They are both 4 ohm speakers. Also will the Rotel 1555 be able to handle them too. Cheers
Sent from my SM-N930F using Tapatalk
hatlesschimp is online now
post #1597 of 1610 Old 09-19-2016, 09:09 AM
wackid's Avatar
Quoted: 144 Post(s)
Liked: 37
Did anyone switched off the blue led of a RB-1582?
Can i de solder it? Or is it just a connector?
I know about the sticker.
Really don't like it's on all the time even though the 12v switch isn't triggered.
If a device is off the powerleds has to be also i think.
Panasonic TX-P65VTW60 | Panasonic DMP-BDT500 | Asus Chromebox OpenELEC triple boot | Onkyo TX-NR709 | Monitor Audio Apex 10 | Canton Chrono SL 590 black | Klipsch R-115W | KEF HTB2 | Zalman HTPC | Harmony Ultimate
wackid is offline
post #1598 of 1610 Old 09-19-2016, 09:12 AM
Quoted: 283 Post(s)
Liked: 99
Not something that I would personally try (I'm a miserable solderer.)
You could also try this:
http://www.bwgroupusa.com/bwgroup-pa...mmer-ring.html
Patrick Butler
post #1599 of 1610 Old 09-19-2016, 10:15 AM
wackid's Avatar
Quoted: 144 Post(s)
Liked: 37
Patrick Butler
Funny... You are quoting me without the part that i am aware of the sticker which was in the bag.
If you have one who blinds it all i am satisfied
wackid is offline
post #1600 of 1610 Old 09-19-2016, 10:41 AM
tanman's Avatar
Quoted: 29 Post(s)
Liked: 27
^ Black Electric Tape is what I use. For dimmer version use painters masking tape.
wackid and hatlesschimp like this.
tanman is offline
post #1601 of 1610 Old 09-19-2016, 10:45 AM
Quoted: 282 Post(s)
Liked: 166
I use a post it note. lol
post #1602 of 1610 Old 09-19-2016, 10:53 AM
wackid's Avatar
Quoted: 144 Post(s)
Liked: 37
You cut it all out or something? Do you have a picture?
wackid is offline
post #1603 of 1610 Old 09-19-2016, 11:52 AM
tanman's Avatar
Quoted: 29 Post(s)
Liked: 27
Some ideas as suggested. Trim it to your liking. It's on my RMB 1095.
ID:	1669625   Click image for larger version
ID:	1669633   Click image for larger version
tanman is offline
post #1604 of 1610 Old 09-19-2016, 12:09 PM
wackid's Avatar
Quoted: 144 Post(s)
Liked: 37
LOL... This can't be true on a high end amplifier... I thought you cut it nice or something.
But if it works for you? I think i am open it so see how it's done.
wackid is offline
post #1605 of 1610 Old 09-19-2016, 12:11 PM
tanman's Avatar
Quoted: 29 Post(s)
Liked: 27
Gets the job done. As I said you can trim it nicer. Mine is not visible.
tanman is offline
post #1606 of 1610 Old 09-19-2016, 12:14 PM
Quoted: 282 Post(s)
Liked: 166
Maybe a Sharpie marker pen will do the job.
post #1607 of 1610 Old 09-19-2016, 12:28 PM
wackid's Avatar
Quoted: 144 Post(s)
Liked: 37
Problem solved... It's just a small 3 lead connector which you can pull out. As shown on the first picture... I am blue led free!! Yessss
Please note the speaker protection led at the last picture... The two leads bent down over the connector SHAME on you Rotel.
ChrisGTL likes this.
wackid is offline
post #1608 of 1610 Old 09-19-2016, 12:45 PM
tanman's Avatar
Quoted: 29 Post(s)
Liked: 27
^^^Exactly my point as to not to tinker with a "high-end-amplifier" when there is nothing wrong. A simple tape does the job!
tanman is offline
post #1609 of 1610 Old 09-19-2016, 12:55 PM
wackid's Avatar
Quoted: 144 Post(s)
Liked: 37
I know what i am doing, if you are not confident with it leave it with a tape.
But not in my equipment rack.
wackid is offline
post #1610 of 1610 Old 09-21-2016, 09:14 AM
Quoted: 17 Post(s)
Liked: 1
Can I get some insight on the RCD-1570 cd player, I need to upgrade from Audiolab cd8200, will the upgrade be sideways or really a upgrade?
melody50 is offline
Rotel , Rotel Rsx 1562 , Rotel Rsx 1550 Home Theater Receiver , Rotel Rsp 976 Surround Sound Preamplifier Processor
