Need expert advice: Onkyo Tx-sr803 (Zone 2 & 5.1 setup??) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-07-2007, 04:11 PM - Thread Starter
Perfectmax's Avatar
I am looking to be able to use my zone 2 (FM or CD) and have 5.1 surround (THX, etc..) running at the same time.
I have the Onkyo TX-DS803
Is this possible. From what I am reading in the manual it isn't however is isn't 100% clear.
My questions (please understand the difference between SURROUND BACK L&R and SURROUND L&R before reading).
1.) it seems that the only way I can run 5.1 surround is when I plug my rear speakers into SURROUND BACK L&R. With zone two activated (ACT) my rear speakers don't work.
When I switch the SURROUND BACK L&R to SURROUND L&R and have zone two playing CD or FM I can get surround sound (playing movie) working at the same time. However, is this surround sound true 5.1 THX???? I don't think so... That is the money question!
3.) In order to get true 5.1 THX I need to have my rears pluged into SURROUND BACK L&R?
4.) 5.1 THX will not work when I plug my rear speakers into SURROUND L&R?
2.) My conclusion is that I can not play a movie in 5.1 THX and have stereo playing in ZONE 2. Is this correct?
I am looking for the facts... PLEASE HELP!
THANKS GUYS!
Perfectmax is offline
post #2 of 5 Old 01-08-2007, 07:45 PM - Thread Starter
Perfectmax's Avatar
Anyone???
post #3 of 5 Old 01-09-2007, 03:56 AM
highdefsw's Avatar
I have the 804.
Zone 2 pulls it power from the back surrounds as you have said.
Surround back L/R are just matrixed as a fill in sound field, the "Surround L/R" connections are the real deal, utilizing the discrete 5.1 signal.
The best sound field will be using the surround L/R connections and any DSP modes including THX can be applied to these speakers.
Hope this helps.
highdefsw is offline
post #4 of 5 Old 01-09-2007, 04:50 AM - Thread Starter
Perfectmax's Avatar
Originally Posted by highdefsw View Post
I have the 804.
Hope this helps.
Are you 100% positive that the surround L/R speakers will work as 5.1 THX?
post #5 of 5 Old 10-01-2012, 07:03 AM
pete-615's Avatar
i just got an sr803 iam trying to hook up two speakers a cdplayer and want to listen to fm no video can any one help it wont play when i turn it on as i play with the buttons it comes on and works great when i shut it off it starts all over again any help would be appricated thanks
pete-615 is offline
