TV audio to receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-14-2007, 06:58 AM - Thread Starter
jpapin1's Avatar
I just bought the Pioneer VSX-1016. I would like to conect the audio from the TV to the receiver to give me stereo sound. I know this must be elementary, but I can not find any instructions on this in the manual. Any help is appreciated. Thank You.
jpapin1 is offline
post #2 of 8 Old 01-14-2007, 07:35 AM
ak3883's Avatar
Unless I'm missing something, all you do is just hook up an RCA audio cable(white/red plugs) from the "audio out" jacks on the back of the TV, and plug those into one of the inputs on the reciever. It probably has a set labeled "TV" anyway. If it's a new HDTV, then it probably has an optical output, so hook that up into an optical audio input of the reciever. Or if you use a cable box, hook the audio outputs of the cable box right into the reciever.
ak3883 is offline
post #3 of 8 Old 01-14-2007, 08:40 AM
gimpy's Avatar
Quoted: 23 Post(s)
Are you using cable/sat. connections to your tv? If so, I would by-pass the sound only to the tv. Connect the sound directly from the sat. box directly to the receiver.
I have Direct TV (sat.) and my sound does not go through the tv at all. It goes directly from the sat. box receiver to my AV receiver. This way, I do have to turn on my receiver if I want to listen to the tv. I can also watch tv this way and play cd's/radio if I want to (no tv sound) at the same time.
(not sure about cable setup, though)
Frank
Frank, "Still the one"
gimpy is offline
post #4 of 8 Old 01-14-2007, 08:46 AM
JOHNnDENVER's Avatar
Yes, you only want to do this where the displays internal tuner is in use. Otherwise make an audio connection from each device.
JOHNnDENVER is offline
post #5 of 8 Old 01-14-2007, 08:49 AM - Thread Starter
jpapin1's Avatar
No cable/satelite box. I only have cable from wall to TV. On my paricular receiver, there is not an obvious TV audio hook up. It must be called something else. I can not find anything on it in the instructions. I know this sounds basic. This is the first time I have used a receiver.
jpapin1 is offline
post #6 of 8 Old 01-14-2007, 12:19 PM
pittdog1's Avatar
You can run red&white rca's from the set's audio out's to any rca in's on the receiver(except phono-if you have one), you can use vcr, cd, dvd, etc...., doesn't matter. If you don't have audio out on your set, then you'll have to use a VCR. Run the cable from the wall into the vcr then from the vcr to the set. Then, red&white out from vcr to in on the receiver. Select pro logic or pro-logic II for surround sound from stereo signal depending on what your receiver has.
If it only takes one match to start a forestfire, then why does it take the whole#$%@!&* box to start a camp fire for the kids?!?!? PITTDOG1
pittdog1 is offline
post #7 of 8 Old 01-14-2007, 01:24 PM - Thread Starter
jpapin1's Avatar
Thank you Pittdog1. That answers the question.
jpapin1 is offline
post #8 of 8 Old 01-14-2007, 04:54 PM
pittdog1's Avatar
You're very welcome.
pittdog1 is offline
