Denon AVR 4306 & HDMI 7.1 PCM(PS3)? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-16-2007, 07:57 PM - Thread Starter
jjam_20's Avatar
has anyone been able to get this to work. I can only get mine to see 5.1. I called and asked Denon and they siad it would but they were going to confirm it and call me back tomorrow. Any help or info would be appreciated.
jjam_20 is offline
post #2 of 3 Old 01-17-2007, 07:54 AM
mark.hannis's Avatar
Yes, it does work but you need to set the PS3 to decode the codec's and output just PCM. Pop in a movie like Descent which has 7.1 (well 6.1 actually but the reciever will still show 7.1) Also you need to be using the HDMI port to do this.
mark.hannis is offline
post #3 of 3 Old 01-17-2007, 08:37 AM
coeus's Avatar
I've been able to get this to work after setting PS3s BD output (optical) to bitstream. Give that a try and see if it helps.
coeus is offline
