Help!!!!! my integra receiver is sick - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-21-2007, 06:13 PM - Thread Starter
NYOKIE's Avatar
Ive got the integra dtr 5.4 reciever and my surr left is putting out low volume. Ive tried different speaker wire and tried the speaker itself on a different channel and neither is a prob. Using different speaker and wire the left surr is weak. I tried boosting the channel through level calibration and it shuts down the system on protect. Is the amp on this one channel blown? I think im beyond my 3 yr warranty Im pretty sure that model has a seperate amp for each channel as the brochure lists it as 85 X 6.
NYOKIE is offline
post #2 of 2 Old 01-21-2007, 07:11 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2310 Post(s)
Liked: 2886
Your receiver likely needs service, but it is barely possible that you've accidentally screwed up a setting somewhere.
If your receiver has a procedure for restoring Factory Default settings, write down your desired settings and do that now. Reenter your speaker configuration settings.
If your receiver has an "all speakers" audio mode -- i.e., every speaker sent the same signal -- switch to that mode and use that as another test of whether the output for that speaker is faulty.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
