"Official" Audyssey thread (FAQ in post #51779) - Page 1006 - AVS Forum | Home Theater Discussions And Reviews
 3468Likes
post #30151 of 79637 Old 08-27-2010, 07:20 PM
Roger Dressler's Avatar
Quoted: 1522 Post(s)
Liked: 710
Originally Posted by audyssey View Post
Yes it does! That's because Tom Holman insisted that they add these based on the USC work on 10.2.
Cool. And whose idea was it to make the HD-DVD and Blu-ray formats support all those channels so we could enjoy them at home? That would be me. [/horn toot]
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #30152 of 79637 Old 08-27-2010, 09:40 PM
audyssey's Avatar
Nice! Now all we need is someone to make an 10 or 11 channel movie... Do you have Spielberg's phone number handy?
Chris
Join me for Audyssey Tech Talk on Facebook here.
Follow me @ChrisAudyssey on Twitter here.
audyssey is offline
post #30153 of 79637 Old 08-27-2010, 09:44 PM
audyssey's Avatar
Originally Posted by TheLion View Post
Does DSX also provide an alternative to Dolby PL2x for back surrounds -> therefor expanding 5.1 content to 7.1/9.1/11.1 (depending on having wide and/or height speakers as well)?
If the algorithms are so much more advanced than PL2x than certainly DSX would have benefits for generating back surrounds as well.
Nope. DSX creates content for the Wides and Heights starting with 5.1 content. Back Surrounds are already created by today's upmixing algorithms. However, if you do decide to use the Back Surrounds then DSX will apply Surround Envelopment Processing to blend them better with the main surrounds and the fronts.
Chris
audyssey is offline
post #30154 of 79637 Old 08-27-2010, 10:14 PM
Liked: 710
Sorry, I'm just the plumber. For that you gotta call the city water department.
post #30155 of 79637 Old 08-28-2010, 02:07 AM
TheLion's Avatar
Exactly. But you keep stating that DSX processing is much more advanced than "simple" matrix upmixing like PL2x.
So why not use it for backk channels as well?
TheLion is offline
post #30156 of 79637 Old 08-28-2010, 03:56 AM
markus767's Avatar
Quoted: 3625 Post(s)
Liked: 1293
http://www.avsforum.com/avs-vb/showt...3#post19110913
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #30157 of 79637 Old 08-28-2010, 05:37 AM
gamelover360's Avatar
BGC is a good idea, but I think it's not needed when you are actually measuring the sub in your room. It's a fixed solution to a problem that varies depending on the exact distance of the sub from the walls and floor. So, I guess it doesn't really matter if you have it on or off. MultEQ will measure through it either way and make the needed adjustments.
I don't know what the THX Subwoofer setting Yes or No actually does. I think it simply enables the BGC control that is only available if you have a THX sub.
I think you are right. I actually turned off Audyssey EQ, and listened to some subwoofer sweeps from 15 hz to about 100hz....with THX subwoofer on and off. I heard no difference in extension or output.
gamelover360 is offline
post #30158 of 79637 Old 08-28-2010, 05:38 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
Originally Posted by LarryChanin View Post
Hi Roger,
True, and likewise in the home listening arena the problem is never in showing their value to the obsessives that frequent this forum. However, I should add that there are normal consumer folks who may place a totally different benefits to cost ratio when considering the necessity of upgrading to new multichannel AVRs/PrePros, adding speakers, power amplifiers, etc.
Larry
Yes, after 7.1, lossless and Room EQ what is left for the industry to promote if not more channels? I find myself more interested in the continuing improvements in EQ than more channels.
Gary J is offline
post #30159 of 79637 Old 08-28-2010, 09:54 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
I would think that James Cameron would be more likely to experiment with this.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #30160 of 79637 Old 08-28-2010, 10:47 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Chris, when will MultEQ XT 32 be added as a search option on your "find products with Audyssey" web page? Also, pre/pros are mis-classified as AV receivers making searching a matter of knowing in advance what model numbers are pre/pros or reading all of the fine print.
pepar is offline
post #30161 of 79637 Old 08-28-2010, 12:31 PM
audyssey's Avatar
The web team will be adding the new models soon.
Chris
audyssey is offline
post #30162 of 79637 Old 08-28-2010, 08:29 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
Maybe he has that planned for when he does his 3rd or 4th re-release of the ongoing Avatar money grab....
Johnla is offline
post #30163 of 79637 Old 08-28-2010, 09:39 PM
jedrgy's Avatar
Agreed!
jedrgy is offline
post #30164 of 79637 Old 08-29-2010, 02:02 AM
I can report that Pro graphs look no different with THX subwoofer set to yes or no. I have also listened to some frequency sweeps and could here no difference. So if there is any difference (which I doubt seriously) it is too small to be measured or heard by me.
post #30165 of 79637 Old 08-29-2010, 03:01 AM
pulse's Avatar
Does anyone know if i change from 4ohm mode to 6ohm mode in the speaker setup menu in my Onkyo 876 if i'll need to re-run an Audyssey calibration again ?
pulse is offline
post #30166 of 79637 Old 08-29-2010, 03:30 AM
Hugo S's Avatar
Quoted: 252 Post(s)
Liked: 148
Hi,
Yes... as it is indicated in the user manual.
Hugo
Hugo S is offline
post #30167 of 79637 Old 08-29-2010, 04:08 AM
pulse's Avatar
Originally Posted by Hugo S View Post
Hi,
Hugo
Ok many thanks for confirmation Hugo, I thought i had read that somewhere before that i would need to re-calibrate but could'nt remember where
pulse is offline
post #30168 of 79637 Old 08-29-2010, 05:41 AM
markus767's Avatar
Liked: 1293
The curves you posted are just a measurement of the static Dynamic EQ response. What's missing is the most important part: the Dynamic part! The adjustment being applied depends on two factors: (1) the volume control setting (those are the curves in the picture) and (2) a real time estimation of the content loudness in each channel. That last part is the tricky one to get right. Think of it this way: content comes along and it varies between soft and louder parts as its playing. Then you turn the volume down. The softer parts will need different adjustment than the louder parts. The trick is to do this with the right time constants so you don't have the listener go crazy. The other trick is to make sure you are not messing the spatial balance of the mix (in surround). And finally, you have to come up with the right way to measure loudness in real time.
Hi Chris,
I think this is not what we want to do. We don't want the loudness compensation EQ to change within a single track. This track was mixed at a certain fixed reference level, so the compensating equal-loudness contour EQ must not change as long as the overall listening level is not changed.
Another observation: the compensation curves of Volume EQ look different from the curves in ISO226:2003. What is the reason for this rather huge difference?
Best, Markus
Markus
post #30169 of 79637 Old 08-29-2010, 05:44 AM
Mactavish's Avatar
Liked: 29
Thanks for doing the test and reporting back!
Mactavish is offline
post #30170 of 79637 Old 08-29-2010, 07:09 AM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
Originally Posted by markus767 View Post
Hi Chris,
Best, Markus
Markus, I want Dynamic EQ to work as it was designed by Audyssey experts, i.e. to compensate in real-time whenever the MV is set to anything else than 0 dB. That's the whole idea of Dynamic EQing and to me it makes perfect sense. Think it over again, please.......and you'll surely get to the same conclusion.
mogorf is offline
post #30171 of 79637 Old 08-29-2010, 07:15 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
Originally Posted by mogorf View Post
Markus, I want Dynamic EQ to work as it was designed by Audyssey experts, i.e. to compensate in real-time whenever the MV is set to anything else than 0 dB. That's the whole idea of Dymanic EQing and to me it makes perfect sense. Think it over again, please.......and you'll surely get to the same conclusion.
Are you saying you are going with 10 years of research at Audyssey Labs over an internet poster?
Gary J is offline
post #30172 of 79637 Old 08-29-2010, 07:58 AM
markus767's Avatar
Liked: 1293
What is MV? Master Volume? If yes, then we're on the same page but Audyssey is not. You might want to reread Chris' post. Maybe I'm just misinterpreting what he's saying.
Markus
post #30173 of 79637 Old 08-29-2010, 08:09 AM
mogorf's Avatar
Liked: 613
MV = Master Volume
Chris in his referred post explains how Dynamic EQ works exactly for louder and softer parts within a given MV setting. 10 years of research has yielded such a fine, yet sophisticated product. Any reason to deny Audyssey Labs expertise? Better way would be to study it a bit more, eh?
mogorf is offline
post #30174 of 79637 Old 08-29-2010, 08:11 AM
larryis1's Avatar
The default setting on my Onkyo TR-SX608 for LPF of LFE is 120 Hz (this is also the setting I get after I run Audyssey). What is the criteria for changing this setting to say for example 80Hz? I read the Onkyo AVR manual and it discusses filtering out unwanted hum as an element (I do not appear to get hum at either 120 or 80 Hz).
I am using the Energy Take Classic 5.1 speaker system (including the provided Subwoofer (see following URL for speaker specifications).
Also, the Audyssey set-up provided a distance of 14 ft. from the main seating position to the SW, the distance is more like 12 ft. Is there any harm of mannually changing this setting in the Onkyo?
Another question, my center channel shows 70 Hz, whereas the side fronts shows 80 Hz. THX. Is there any harm or benefit to change the center to 80 Hz. THX or just leave it at the 70 Hz. setting?
If I manually change setting (Hz) or LPF for LFE, or distance from the SW to the main listening position... do I need to re-run Audyssey?
Any feedback on my questions would greatly be appreciated?
Best Regards
larryis1 is offline
post #30175 of 79637 Old 08-29-2010, 08:20 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Like it or not, Audyssey is using their research to go beyond even a dynamic adjustment of a static loudness compensation curve, i.e. here's the curve for this delta from reference, here's the curve for for that one, etc. And personally, I like it. With the roster at that company and their depth of experience in the film industry (and music industry based on the interviews and endorsements), how could someone with an interest in taking their theater to higher levels not like it?
We are getting Tomlinson Holman In A Box. Yea, I'm a fanboy.
edit: So I don't sound like a complete idiot (an incomplete idiot?), I want to qualify that.
I was a skeptic first. MultEQ XT "came along for the ride" when I bought my OP 885. When it equalized my LCR behind an AT screen to where the front soundstage sounded infinitely better than I had ever been able to make it sound, I sold my Rane 1/3-oct equalizers. When it cleaned up my bass far better than I had ever been able to do, I sold my Rane PE17. There was revelation upon revelation as I added an AS-EQ1 and Pro.
That's why I am a fanboy.
pepar is offline
post #30176 of 79637 Old 08-29-2010, 08:22 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
There is no criteria for changing the LPF on LFE; it should always be 120Hz. Better yet, there shouldn't even be a "setting" for it.
pepar is offline
post #30177 of 79637 Old 08-29-2010, 09:16 AM
audyssey's Avatar
Hi Chris,
Actually it is exactly what's needed. When the track was mixed at the "fixed" level they were listening to the softer and louder parts of that track and making decisions about the mix. Now, when you turn down the level the softer part of the track turns down more (in the bass region) because the loudness curves are not parallel! They start to diverge as you go lower in level. Therefore the soft part of the track now needs different adjustment than the loud part that falls on a different curve.
Our internal research results and listening panels.
Chris
audyssey is offline
post #30178 of 79637 Old 08-29-2010, 09:39 AM
markus767's Avatar
Liked: 1293
Got it, thanks. I misread your reply to Larry's post. Those graphs do show Audyssey's compensation curves at certain loudness levels but they are dynamically applied based on the actual program loudness relative to the reference level.
Markus
post #30179 of 79637 Old 08-29-2010, 09:47 AM
LarryChanin's Avatar
Has anybody ever measured the compensation contours of Dynamic EQ? I once did this for Dolby Volume but they looked wrong when compared to the equal-loudness contours defined in ISO 226:2003
That's because the equal loudness contours are not appropriate for listening to audio programs. They measured sensitivity to sine waves.
Best, Markus
Hi Chris,
In Roger's quote above in responding to a similar question, he states that using sine waves as test signals for determining perceptual equal loudness curves is not appropriate when listening to more complex audio content.
Can you please provide your insights on this issue?
Larry
LarryChanin is offline
post #30180 of 79637 Old 08-29-2010, 09:50 AM
Jeremy Anderson's Avatar
Quoted: 345 Post(s)
Liked: 658
Best Regards
LPF of LFE should always be left at 120Hz, since the LFE channel itself extends to 120Hz. It only exists on the Onkyos to maintain compatibility with subwoofers designed around THX specs that don't allow for 80-120Hz reproduction from the sub. Good to see that Onkyo is defaulting to 120Hz instead of 80Hz now.
Audyssey's subwoofer distance measurement takes into account delay caused by the amp in your sub as well as room acoustics. This will not always line up with actual physical distance, but should be the proper setting to put your subwoofer in phase with your other speakers, so I wouldn't change it.
There's no harm in bumping up your center to 80Hz from 70Hz. You just never want to go DOWN (i.e. from 80 to 70) because the detected point is where Audyssey stops EQ'ing.
Changing any of these settings won't require you to re-run Audyssey.
"Never believe any quote you read on the internet." - Abraham Lincoln
Jeremy Anderson is online now
Closed Thread Receivers, Amps, and Processors
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
