"Official" Audyssey thread (FAQ in post #51779) - Page 1140 - AVS Forum | Home Theater Discussions And Reviews
 3496Likes
post #34171 of 79637 Old 12-31-2010, 02:26 PM
audyssey's Avatar
Originally Posted by ghstudio View Post
First thing i noticed was that pro tuning on the 4311 did zero tuning of my sub!!!
Forgot to mention this. Thrang just sent me his Pro graphs on the 4311 and the sub is calibrated as expected.
Chris
Join me for Audyssey Tech Talk on Facebook here.
Follow me @ChrisAudyssey on Twitter here.
audyssey is offline
post #34172 of 79637 Old 12-31-2010, 02:59 PM
noah katz's Avatar
Quoted: 1107 Post(s)
Liked: 387
Presumably one polarity of subwoofer connection gives a better blend at XO than the other.
Is there a way to divine this with Pro?
It just shows separate sub and satellite responses, so how is one to know?
Or does the polarity error message work for subs?
Noah
noah katz is offline
post #34173 of 79637 Old 12-31-2010, 03:13 PM
audyssey's Avatar
Not really...
Yes, it does check for sub polarity. But, the polarity is not really useful for blending. What's really needed is varying the phase as a function of frequency (also known as group delay). Pro performs this calculation internally and checks the flatness of the resulting blend based on the measurements it took from the subs and sats. Then it reports a list of choices for the xover frequency starting from the best one.
Chris
audyssey is offline
post #34174 of 79637 Old 12-31-2010, 03:20 PM
jmschnur's Avatar
Does this happen with XT32 implementations without Pro?
jmschnur is offline
post #34175 of 79637 Old 12-31-2010, 03:25 PM
ghstudio's Avatar
Quoted: 16 Post(s)
I might be able to test using the amps in the 4311 (if my speaker cables will reach)....but I don't hear the harshness when I use the sound equalizer thru the same amp, so I'm not quite sure what that will prove. Doesn't mean i won't do it....it's just unlikely to be the problem (NHT Power 5).
Let me step thru this calmly on Monday. Something is wrong..probably me but I'm pretty experienced isolating problems.
One thing I am going to do is get the sound equalizer out of the path. We now know that both the sound equalizer and 4311 see the same before curves in the pro software (I have them saved) and that was important to see.
I have not run the 4311 with the pro equalization because of the sub curve which likely means I did something wrong so listening would probably have no value.
If my other measurements are correct (forgetting for a moment about the sub), then it's really looking like something is happening as Denon applies the Audyssey corrections.
I'll go thru it methodically on Monday.....and send whatever I can capture.
One other thought is that the NHT 2.9's are known for their directionality. I may be setting the microphone too wide from the sweet spot, because I sit almost directly in front of the left front....so I use that as postion 2. I'll try setting the 4311 taking all readings within the sweet spot and see if that changes things. However, I am using the exact same measurement points for all my testing so far...and I don't hear the harshness when use the sound equalizer...only when I use the 4311's XT32 so this is an unlikely path.
Have a happy new year's eve and don't drive tonight....
I haven't really tried audyssey dynamic eq at all yet.
ghstudio is offline
post #34176 of 79637 Old 12-31-2010, 03:35 PM
audyssey's Avatar
Sadly no..It requires significant computing horsepower to do that calculation so it has to be done on the PC.
Chris
audyssey is offline
post #34177 of 79637 Old 12-31-2010, 04:04 PM
noah katz's Avatar
Liked: 387
So Pro has full control over relative phase of subs and sats - great!
Just to make sure I understand, the sub polarity would matter then, right?
Except for the rare case where they were 90 deg out of phase at XO, in which case a +/-180 change wouldn't matter.
Noah
post #34178 of 79637 Old 12-31-2010, 05:42 PM
jmschnur's Avatar
So what does the sub EQ that is part of the standard XT32 with my 80.2 do with respect to phasing for the two sub woofers in my system?
jmschnur is offline
post #34179 of 79637 Old 12-31-2010, 07:43 PM
PHUELIPH's Avatar
i apologise in advance if this question has already been asked.
I have been a fan of Audyssey, since the the denon 4306. I currently own the denon 4308 and am anxiously awaiting delivery of the new denon avr-a100 with audyssey multeq xt 32. My question is after audyssey does it's thing can i still go back and manually change crossovers and speaker size like i did in the 4308, and is there anything else i need to know regarding audyssey.
thank you very much for your help.
PHUELIPH is offline
post #34180 of 79637 Old 12-31-2010, 07:48 PM
PHUELIPH's Avatar
oops almost forgot.
HAPPY NEW YEAR. Mr. Audyssey and evryone on this forum.
PHUELIPH is offline
post #34181 of 79637 Old 12-31-2010, 09:52 PM
jevansoh's Avatar
Quoted: 51 Post(s)
Liked: 102
Yes you can. It will act the same as your previous Denon in that regard.
There is a TON of stuff you can always learn about Audyssey by reading this thread and the great FAQ/Setup Guide on the first page of this thread.
Make sure you only "raise" your crossovers if you choose to do so, however, and do not lower them as Audyssey does not correct below the measured/recommended crossover setting in your AVR.
Happy New Year to you and everyone else, too!!
--J
jevansoh is offline
post #34182 of 79637 Old 12-31-2010, 10:55 PM
Gooddoc's Avatar
Quoted: 3108 Post(s)
Liked: 2413
This has been my contention all along. MultEQ is working correctly on the data it's given. If the incoming data has a high frequency roll off then it will adjust accordingly to meet the target. The question we should be focusing on is why it sees a roll off. So far we have seen blown tweeters as one cause. Another cause is measuring too far off axis.
We do have the equipment and we have checked the production unit we were sent (as we do with all products prior to certifying them). There were no issues found.
It does make sense and, yes, that is part of the test.
I hate to bring this up, but can you try without an external amp connected? What if there's something wrong in the amp? Would not be the first time we have seen this...
Dolby Volume and MultEQ XT32 are not comparable. One limits the dynamic range for late night listening and the other performs acoustical correction. Not even apples and oranges as they are both fruit. More like apples and cows.
I intend to do some REW sweeps again, but in my case I know for sure I am flat until at least 10 KHz in my room. So I can't understand why any boost would be necessary in that FR range. I would think negative trims instead.
I'm hoping this is user error on my part. I can't say I'm an expert with REW either, so that is a wild card too . I think I have a handle on it, but who knows? I will post graphs if I can find the time and figure out how to do it again.
Gooddoc is offline
post #34183 of 79637 Old 01-01-2011, 02:12 AM
markus767's Avatar
Quoted: 4212 Post(s)
Liked: 1623
Originally Posted by moodyman View Post
The only remedy for room nulls, that I know of, is to change subwoofer placement, use multiple subs, or you might be able to play with the phase adjustment on the subs. The goal here is to move the room null somewhere else other than the listening position.
You could also change the listening location and/or use acoustic treatments but those would be bulky.
By the way, a "room null" can't be moved. A room's modal pattern distibution is fixed because it is a property of the room, not the source.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #34184 of 79637 Old 01-01-2011, 08:02 AM
steve1959's Avatar
I posted this on the Onkyo thread but it was suggested that I might get a better response here.
OK, everythings out of the box, network is fine, firmware is updated with no problem. I've tried to run Audyssey several times and it hangs during the calculating phase. All the speakers check out. I've even let it run overnight and it still hangs. I've tried 3 and 6 positions for calibration - same problem. I've tried re-setting the unit and starting over - same problem. My speaker configuration is set for 5.1 although I have front-high's on order. The progress bar is stuck right in the middle during the calculating phase and doesn't move. Faulty unit or am I missing something???? Could it be problems with the Audyssey Mic?? When it says set your sub to 75db, the Mic measures that with no problem. Help!
steve1959 is offline
post #34185 of 79637 Old 01-01-2011, 08:09 AM
audyssey's Avatar
Sounds like a faulty unit. The mic can't cause the hangup. If it was a mic problem then you would be getting an error during the measurements.
Chris
audyssey is offline
post #34186 of 79637 Old 01-01-2011, 08:41 AM
perritterd's Avatar
Hello. I've been reading everyone talk about mic height...I've read that the position of the mic is highly important to the results you get back from Audyssey. My question is what part of the mic should be ear level-the top tip of the mic, the base of the mic, or is the mic sensitive enough to even matter? If I need to place the mic on a stand above my head due to a couch, where should I measure from my ears to what part of the mic for best results? Bob.
Bob
perritterd is offline
post #34187 of 79637 Old 01-01-2011, 09:03 AM
OldSlow's Avatar
Hey all, I been reading for hours and I'm still confused.
First off, crossovers settings. In the guide it says it's ok to raise them but not lower them.
Where are these crossovers exactly? In the receiver settings? Aren't the crossovers the same thing as when Audyssey sets the speakers to full band and then everyone says it should be lowered to 60 or 80?
Am I just that dumb or what?
Also can I or should I readjust the Audyssey levels to be the same at all speakers with spl meter? i.e 75db
Should I run Audyssey with or without THX audio mode?
OldSlow is offline
post #34188 of 79637 Old 01-01-2011, 09:18 AM
audyssey's Avatar
Sub EQ HT is independent of MultEQ. It can work with any version of MultEQ including XT32. It is a method for properly blending two subwoofers. Each sub is measured individually and the differences in level and delay between the two subs are corrected. Then the subs are treated as "one" and MultEQ pings them together to create a single filter. We found that this gives better results than creating a filter for each sub separately.
Chris
audyssey is offline
post #34189 of 79637 Old 01-01-2011, 09:22 AM
audyssey's Avatar
Yes, they are in the Speaker Settings menu in your AVR
Audyssey doesn't set speakers to Full Range, the AVR does based on the measurements. Each has their own rules, but most now use 40 Hz as the decision point to set speakers to Full Range. Audyssey strongly recommends against setting any speaker to Full Range if you have a subwoofer in your system. Unfortunately we are not allowed to be in charge of this setting. You have to change speakers to Small by manually setting a crossover after the calibration is finished and stored.
You can make manual adjustments if you want, but Audyssey is already setting the levels for reference.
When you run the Audyssey calibration all internal AVR settings are ignored.
Chris
audyssey is offline
post #34190 of 79637 Old 01-01-2011, 09:58 AM
ReneV's Avatar
There may be an issue with inverted terminology here. Think of 'large' as 0Hz crossover and 'lowering' as decreasing the numerical value of the crossover point. Going from 'large'/0Hz or 40Hz to 60Hz is raising the crossover and is OK. The other way is not OK.
ReneV is offline
post #34191 of 79637 Old 01-01-2011, 10:11 AM
jmschnur's Avatar
Does the tuning the delay mean they are "phased" with thesystem?
jmschnur is offline
post #34192 of 79637 Old 01-01-2011, 10:22 AM
audyssey's Avatar
The delays for all speakers and subs are set so that sound from each arrives at the same time. In the case of two subs, they are individually time delayed to match each other. Then the summed combo is delayed to match the other speakers.
Chris
audyssey is offline
post #34193 of 79637 Old 01-01-2011, 11:10 AM
OldSlow's Avatar
Now I get it!
Thnx all...
OldSlow is offline
post #34194 of 79637 Old 01-01-2011, 11:12 AM
OldSlow's Avatar
This Chris guy must have the patience of Job!
OldSlow is offline
post #34195 of 79637 Old 01-01-2011, 11:25 AM
Wireless member
pepar's Avatar
Quoted: 1070 Post(s)
Liked: 551
jmschur, you probably know this, but the delays for all speakers and subs are set so that sound from each arrives at the same time ... at the first measurement position.
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
post #34196 of 79637 Old 01-01-2011, 11:28 AM
LarryChanin's Avatar
Hi Chris,
I'm still a bit unclear about the issue of phase.
In an effort to resolve that uncertainty I'd like to make a number of statements which reflect my current understanding (or confusion ) and if you wouldn't mind could you please confirm, correct or amplify each statement?
  • All devices that have MultEQ XT32 happen to also have Sub EQ HT.
  • If you have a Sub EQ HT device and two subwoofers the issue of manually adjusting the phase between the subwoofers is irrelevant because Audyssey sets the timing individually and by correctly adjusting the timing by definition it sets the subwoofers in phase.
  • If you do not have a Sub EQ HT and have two or more identical subwoofers you can get them in phase at the primary listening location by locating them the same distance from the first measurement location.
  • If you do not have Sub EQ HT and have two or more subwoofers that can't be located the same distance from the first measurement location, then it may be beneficial to either manually change the Audyssey established distance or adjust the phase controls on the subwoofers. However, these approaches would require using measurement software to provide visibility of the effects of altering the distance or phase and through trial and error to find values that yield the flattest pre-Audyssey calibration frequency response. Then run the version of MultEQ that you have to further adjust the combined response.
  • If you have MultEQ Pro it will adjust the phase relationship between the subwoofer and the satellites to yield the smoothest response near the recommended crossover frequency.
Larry
LarryChanin is offline
post #34197 of 79637 Old 01-01-2011, 01:38 PM
markus767's Avatar
Liked: 1623
I'd like to add a question to Larry's: why is there a need to "phase-align" subwoofers? It has been shown that adding delays (subwoofer to mains and/or subwoofer to subwoofer in a multiple subwoofer setup) can considerably improve the in-room frequency response at the listening position(s).
Markus
post #34198 of 79637 Old 01-01-2011, 02:37 PM
SpotcheckBilly's Avatar
Does an AVR that's equipped with MultEQ XT, like an Integra DTR-80.1 for example, also have the Sub EQ HT feature?
SpotcheckBilly is offline
post #34199 of 79637 Old 01-01-2011, 02:42 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7708 Post(s)
Liked: 4313
http://www.audyssey.com/products/?cat_filter=38
AustinJerry is online now
post #34200 of 79637 Old 01-01-2011, 02:57 PM
moodyman's Avatar
yes.."moving a room null" was a poor choice of words on my part....
moodyman is offline
Closed Thread Receivers, Amps, and Processors
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
