"Official" Audyssey thread (FAQ in post #51779) - Page 1735 - AVS Forum | Home Theater Discussions And Reviews
 3468Likes
post #52021 of 79637 Old 03-20-2012, 12:37 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Originally Posted by kbarnes701 View Post
OK thanks - for clarification, Denon AVRs don't have DSP modes then such as THX Cinema?
Whether they are THX certified or not, of course, they will still use Audyssey with the prime objective of Audyssey which is to set a system up so that at 0dB on the MV it is playing at THX Reference level. I can’t see how that is AVR-specific (assuming the AVR has Audyssey MultEQ).
Keith, amazing work so far.
Most of the Denon receivers will not Have THX re-EQ or other THX based DSP.
AFAIK, all the Denons denote the 2 Audyssey curves as "audyssey" and "Audyssey Flat."
IDK who invented reference, but reference is certainly the same thing on the non-THX Denons as on Onkyos. Denon, of course, does not refer to THX reference . . . nor, IIRC does Audyssey itself. THey just call it "reference level."
FWIW, I think it's potentially confusing to call 85 dB "average." 85 dB is how loud each speaker should be when playing back bandwidth limited pink noise at -20DbFS. I've never seen FilmMixer or anybody else in the business suggest that reference levels tell them anything about how loud "average" ought to be. They do of course place an upper limit on SPL per speaker. A person could pop in V for Vendetta (dialog averages below 80 dB at reference) and think they're improperly calibrated if they're looking fo the SPL meter to show 85 dB at some particular point in the movie.
It might (or might not) be worth mentioning that ARs made before the advent of DynamicEQ (at least, as I understand it, in the Denon line) attempt to make zero on the MV equal to reference, because reference level was not important to any of the pre-DEQ Audyssey technologies. Might say something like "Note: the Audyssey calibration process on older receivers without DynamicEQ may not result in setting the speaker outputs to equal reference levels at master vloume setting = 0."
JHAz is online now
post #52022 of 79637 Old 03-20-2012, 12:42 PM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
Here's another interesting thread on: "Why most of Denon's are not THX certified"
Tip: look for post by batpig and Goatse!!
mogorf is offline
post #52023 of 79637 Old 03-20-2012, 12:52 PM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5069
Thanks JHAz - appreciate your remarks.
So I now realise. Just checked the Denon site too.
OK - that is the same as Audyssey's Movie and Music then so I can easily explain what they do in the FAQ.
I've decided to just call it 'Reference Level' to avoid any possible confusion.
Yes, thanks. It needs to be clear that is is with bandwidth-limited pink noise that is being referenced there. Or Audyssey's -30dBFS when using their 75dB chirps. I'll sort it out when I get round to writing the FAQ and answer.
Yes, good point, which hadn't occurred to me. Thanks for the input.
kbarnes701 is offline
post #52024 of 79637 Old 03-20-2012, 12:54 PM
kbarnes701's Avatar
Liked: 5069
Thanks, Feri. I think I will try to give unit-specific issues a wide berth - the last thing I want to have to do is learn all about Denons! Will have a look at the link though.
post #52025 of 79637 Old 03-20-2012, 12:56 PM
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
OK thanks - for clarification, Denon AVRs don't have DSP modes then such as THX Cinema? EDIT: I just checked - a couple do but I am surprised to discover that most don't, including my 'favourite', the 4311.
the only THX certified Denons with Audyssey are the flagship products as JD noted above. All that stuff we talk about with THX RE-EQ are really Onkyo specific issues and how they implemented it.
I spotted something called 'Cinema EQ' in the specs which I take to be Denon's own version of RE-Eq or something like it.
basically, yeah, it's a legacy tech which they have had for a loooong time to deal with "harsh" soundtracks translated into the home environment. Really an outdated anachronism at this point. Denon is sometimes slow to remove these types of vestigial options, leading to ever more user confusion....
Do Denons have user-selectable Audyssey Reference or Flat curves, like the latest Onkyo's Audyssey Movie/Music curves?
Yes, Denons w/ MultEQ have always implemented the Audyssey / Audyssey Flat / Audyssey Bypass L/R selections.
If they have a user-selectable Reference curve then that already has the HF rollof, so without any THX modes, I can't quite see the purpose of Cinema EQ.
Join the club It's just there because... it is.... I suppose there are people who don't use Audyssey who want some method of high-freq roll-off. But anyway, Cinema EQ on Denons really doesn't have anything to do with Audyssey MultEQ.
Maybe it's best to delete the reference to THX and call it just 'Reference Level' - that way nobody with a Denon can be confused into thinking it doesn't apply to them.
yes, that's how I would do it.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #52026 of 79637 Old 03-20-2012, 01:00 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6497 Post(s)
Liked: 3607
Hi AJ - I am being slow today - which topics are Onkyo-specific?
Removed--already discussed in sufficient detail.
AustinJerry is online now
post #52027 of 79637 Old 03-20-2012, 01:14 PM
Gooddoc's Avatar
Quoted: 2672 Post(s)
Liked: 1844
Originally Posted by notnyt View Post
Denon released a hardware/firmware upgrade for the 5308. That is all that changed. in my setup, so XT to XT32 here.
As I said earlier, there have been numerous firmware issues during initial rollouts. Given the general experience that XT32 is typically superior to XT leads me to suspect a firmware issue could be at fault here. After all, you have XT and XT32 graphs to compare and its not looking too good for XT32. I'm fairly confident Audyssey technical support would love to see those graphs.
Gooddoc is offline
post #52028 of 79637 Old 03-20-2012, 01:33 PM
hclarkx's Avatar
Except it kind of sucks with XT32 from what I'm seeing.
The first graph here is raw response of a sealed system compared to Audyssey XT32, the second graph is the same system after being EQ'd MiniDSP, then running XT32. I had better results with standard XT, displayed in the third graph. Fortunately, I have a MiniDSP which I used to EQ my subs flat before running audyssey which presented me with some better results, shown in the second graph. Audyssey really had to stretch for this one
Yellow is after Audyssey XT32, green is raw response without Audyssey.
Blue is MiniDSP only, red is MiniDSP then Audyssey XT32
This is an older graph from before I upgraded my receiver with Denon to support XT32. Yellow is raw, green is after running Audyssey XT
I think your results are not difficult to explain. In the first graph you do not see Audyssey raising the sub level at the low end because Audyssey does not EQ to flat below the -3 db point. Your -3 db point is fairly obvious in this graph. Keep in mind that Audyssey is used by thousands of users and has to be safe from a liability standpoint. Forcing higher output below the - 3db point could destroy a subwoofer driver that does not have the Xmax to achieve flat below that.
In the second graph there was not much for XT32 to do, so it didn't do much.
In the third graph, the results are as expected. It seems no -3 db point was found. The rise at the low end remains because I think XT's does not correct that low.
Though the -3 db point is fairly obvious in your first graph, the reference for the -3db point is determined through a fairly complex look at the sub output over its operating range. Hence in most cases it is very difficult to eyeball the - 3db point as identified by Audyssey.
I've found that shifting the mic locations within the listening bubble can significantly affect where the - 3db point is identified. I've had my system (two 15" drivers per side) left with a -3 db point of 28 Hz and then be flat to 20 Hz by just moving the mics a bit or doing less locations (with XT32).
Another consideration is that Audyssey is trying to provide the best listening experience across the listening bubble. Hence the result at any one position is not a good indication of what Audyssey is doing. Additionally, if you mic, say, 10 locations in the listening bubble you must test exactly those same ten locations and integrate the results to assess exactly what Audyssey is doing. This alone explains most complaints about Audyssey not achieving flat response. A truly flat response at multiple listening (or mic'd) locations is not physically possible in a credible theater, home or otherwise.
Tell us, how big is your listening bubble relative to the room size, how many mic locations did you use for the Audyssey setup, and how was your own testing done (number of positions, location relative to Audyssey mic locations, etc.)?
And, of course, your results are far from problematic with or without Audyssey. Your subs are equidistant and it appears you have an excellent room and probably some good room treatments. You haven't left much for Audyssey to help with. Any help Audyssey provides is icing on the cake and is probably limited to spreading any remaining ill effects across the listening bubble so there is no bad seat (though no perfect seat either).
Harrison
hclarkx is offline
post #52029 of 79637 Old 03-20-2012, 01:36 PM
mogorf's Avatar
Liked: 613
+1. Especially with regards to differences in resolution between the two flavors of Audyssey. XT (for sub) = 128x, XT32 (sub+sats) = 512x. While I'm sure you are aware of the fact that XT32 EQs multiple subs in a different way than XT (read=better).
I would surely contact Audyssey support or maybe Chris Kyriakakis on Facebook Audyssey Tech Talk . With such an aweseome HT room you really deserve a product that works excellently to the brim.
Chime back please, I think we all can learn something new from your case. maybe a good lesson for the Audyssey FAQ currently under construction here.
Take care!
mogorf is offline
post #52030 of 79637 Old 03-20-2012, 01:38 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Makes me very curious, being that the update is fairly recent, and intended for one of the most expensive non-boutique avr's, I wonder if Audyssey might have slightly redesigned XT32 for it, to specifically limit the normalization so it doesn't occur below the measured F3?
This is something that's been brought to Chris's attention and he's mentioned that it's an idea they've contemplated implementing. The normalization after EQ can potentially lead to subs being overdriven as pre-out graphs have shown up to a 9db boost below F3.
Looking at notnyt's graph, it appears that is where the measured F3 for his subs are.
Hmmm...
Max
P.S. I see Harrison had similar observations and touched on this too while I was typing my reply
djbluemax1 is offline
post #52031 of 79637 Old 03-20-2012, 01:47 PM
notnyt's Avatar
Quoted: 2152 Post(s)
Liked: 1981
In the second graph there was not much for XT to do, so it didn't do much.
Another consideration is that Audyssey is trying to provide the best listening experience across the listening bubble. Hence the result at any one position is not a good indication of what Audyssey is doing. Additionally, if you mic, say, 10 locations in the listening bubble you must test exactly those same ten locations and integrate the results to assess exactly what Audyssey is doing. This along explains most complaints about Audyssey not achieving flat response. A truly flat response at multiple listening (or mic'd) locations is not physically possible in a credible theater, home or otherwise.
Harrison
The first and third graphs start with identical response, so that pretty much shoots a hole in that theory. Nothing changed between those graphs except XT -> XT32. I tested it with XT32 using one location and multiples. Many runs of each. I've run Audyssey many many times so I'm familiar with the quirks. My -3db point is actually 7.5hz, and what I was expecting to see was more bass cut above 35hz to deal with the rising response typical of sealed enclosures, which it did not do. I'll check for any new firmware updates as well, but I don't think there are any. I'm pretty happy with things as they are. MiniDSP to the rescue.
Anyway, you can see where the subs actually roll off, due to an electronic HPF.
notnyt is offline
post #52032 of 79637 Old 03-20-2012, 01:58 PM
mogorf's Avatar
Liked: 613
Hi notnyt, I have to confess this is the first time for me to hear about MiniDSP, and sorry for the unsolicited question, but are you really sure you need that device in the food chain when you have Audyssey XT or even XT32 on board?
mogorf is offline
post #52033 of 79637 Old 03-20-2012, 02:02 PM
kbarnes701's Avatar
Liked: 5069
Thanks batpig. I've done a little research since the earlier posts and am with it now I think. I’ll exercise caution with the FAQ post on this one
Yep - I see now.
OK thanks - I can cover the differences and purposes of the curves then so long as I mention the alternate names they may go by.
Agreed.
Yep - avoids any possible confusion. Thanks for the reply. I am so ingrained into the Onkyo way of doing things that it's easy to forget that not all AVRs are the same. I will bear it in mind though of course.
post #52034 of 79637 Old 03-20-2012, 02:04 PM
notnyt's Avatar
Liked: 1981
Yes, it is in line with my subs. Audyssey XT32 alone failed miserably at EQing my subs flat. XT worked much better.
Again, this is before and after XT32
This is before and after XT
notnyt is offline
post #52035 of 79637 Old 03-20-2012, 02:19 PM
mogorf's Avatar
Liked: 613
Yes, I've seen these graphs. Arrgh! Nonetheless, while trying to catch up with you, do you mean your system is hooked up like this:
AVR sub line out --> MiniDSP line out --> sub power amp power out --> sub
If I saw correctly on your pictures your subs are not powered subs but you have separate amps with line in level from the AVR and that's where in between you insert the MiniDSP. Do you have 1 MiniDSP for each sub amp?
mogorf is offline
post #52036 of 79637 Old 03-20-2012, 02:29 PM
Toknowshita's Avatar
Quoted: 37 Post(s)
Liked: 49
Does the Denon version of XT32 have you set the sub gain so it measures 75dB prior to running the speaker pings? IOW have you changed the gain setting on your sub between XT vs XT32?
Toknowshita is offline
post #52037 of 79637 Old 03-20-2012, 02:44 PM
pbarach's Avatar
Quoted: 318 Post(s)
Liked: 193
It sure would. But I don't think I know enough about it to do it myself. Could you (or anyone) give me the gist of it? Thanks.
I don't really understand it, but I googled and found a massive thread about dialogue normalization:
http://forum.blu-ray.com/showthread.php?t=121087
This is a Dolby metadata instruction to the processor that can't be turned off or modified--I did find that out. It seems to be a way of adjusting the overall master volume level for a particular BluRay disc to bring the dialog to a standard listening level, but it's not a dynamic adjustment that changes as the disc plays. It's a one-time setting as the disc starts. It shows up on the dial of some Denon receivers when the player is bitstreaming the audio to the receiver.
It would appear that this generally introduces an offset to reference level so that "reference level" at 0 dB for home listening will be different than 0 dB in the theater. If this is true, then nobody is actually listening at the same reference level in the home with which movies are mastered...
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #52038 of 79637 Old 03-20-2012, 02:55 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Then there is something wrong.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
post #52039 of 79637 Old 03-20-2012, 02:57 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
you got the signal chain these are certainly not plate amps built into the sub cabinets
There are several different types of MiniDSP that you can choose from. I believe Not' has the 2x8 where it can take 2 rca's in, and individually control the 8 rca's out after you EQ the signal.
beastaudio is offline
post #52040 of 79637 Old 03-20-2012, 03:00 PM
kbarnes701's Avatar
Liked: 5069
I think we need Roger D to chime in and explain it in simple terms - he's explained dialnorm before and I think I understand what it is and roughly how it works, but not sure what the implications are for DEQ and reference level, if any. I'll take a look at that thread later - the fact you say it's massive tends to make me think it's going to be complicated Thanks for the link.
post #52041 of 79637 Old 03-20-2012, 03:05 PM
pbarach's Avatar
Quoted: 318 Post(s)
Liked: 193
"Massive" it's not, when compared to THIS thread. 17 pages.
pbarach is offline
post #52042 of 79637 Old 03-20-2012, 03:08 PM
kbarnes701's Avatar
Liked: 5069
I just had a look. That 'Big Daddy' dude over there usually has very good contributions. bluray.com is one of my most-used sites.
post #52043 of 79637 Old 03-20-2012, 03:12 PM
mogorf's Avatar
Liked: 613
Bluray.com also has their dudes like our batpig's and jd's, eh?
mogorf is offline
post #52044 of 79637 Old 03-20-2012, 03:22 PM
mogorf's Avatar
Liked: 613
Interesting! If Not' has the 2x8 MiniDSP kit I suppose he has a signal flow like this:
AVR (Audyssey) on a digital platform --> AVR D/A converter for analog sub out --> MiniDSP RCA IN followed by A/D --> MiniDSP processing on a digital platform --> D/A converter in MiniDSP --> analog line out to each sub power amp...
I wouldn't volunteer to predict what such multiple D/A and A/D convertions with dual DSP'ing can cause, but as Not's results show it seems while XT has no conflict, XT 32 does suffer from such hook-up.
Fingers crossed for Not!
mogorf is offline
post #52045 of 79637 Old 03-20-2012, 03:28 PM
notnyt's Avatar
Liked: 1981
It has nothing to do with the MiniDSP. Even with the device out of the loop the issue is still present. It is most likely just Denon's implementation.
notnyt is offline
post #52046 of 79637 Old 03-20-2012, 03:32 PM
notnyt's Avatar
Liked: 1981
Yes, I had to lower the gain on my amps to get it to the 75db level. I didn't try running Audyssey with it 10db hotter as it was previously. Previous runs calibrated my subs to -11.5 or so, now it calibrated it to -1.5.
As an aside, after I finished my final EQing, I dropped my sub levels by 10db in the receiver and raised them by 10db on the amp. Everything measured the same, but now I have +24db of gain available from the receiver instead of just 12 when raising my sub levels =]
notnyt is offline
post #52047 of 79637 Old 03-20-2012, 04:19 PM
batpig's Avatar
Liked: 3415
I find this article pretty good in explaining the concept:
http://www.hometheaterhifi.com/volum...on-6-2000.html
here's a whitepaper from Dolby: http://tech.ebu.ch/docs/techreview/trev_293-spath.pdf
Setup Guide and FAQ
batpig is offline
post #52048 of 79637 Old 03-20-2012, 04:29 PM
kbarnes701's Avatar
Liked: 5069
post #52049 of 79637 Old 03-20-2012, 04:48 PM
mogorf's Avatar
Liked: 613
Just curious notnyt, what are you planning to do with that available +24 dB reserve in the bass department? Blow the neighbourhood? Your 5.8 system with 8 sub-drivers CAN DO!
I get it, you like your bass a teeny-weeny hot, huh? Just kidding!
Kidding apart, how is your Denon 5308 set up for sub? Here are the options from the Manual:
mogorf is offline
post #52050 of 79637 Old 03-20-2012, 04:55 PM
ReneV's Avatar
Dialog normalization is different from MultEQ's normalization problem. The latter is triggered by room modes and similar narrow frequency-range response humps in the first measurement position. A hump contributes to the SPL that Audyssey sets the channel offsets according to. In the case of a hump, the targeted SPL is above that produced naturally at most frequencies, including at all frequencies below the -3dB point, and Audyssey boosts the signal accordingly. This boost is independent from equalization proper and can go all the way to 0Hz. This can suck up enormous amounts of amplification and excursion for little audible benefit.
ReneV is offline
Closed Thread Receivers, Amps, and Processors
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
