"Official" Audyssey thread (FAQ in post #51779) - Page 2176 - AVS Forum | Home Theater Discussions And Reviews
 3469Likes
Old 09-29-2013, 08:19 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5070
Originally Posted by comfynumb View Post
Originally Posted by kbarnes701 View Post
Run another cal with the slightly different mic positions suggested in the last several posts and see if you can improve it. Remember that with both Denon and Onkyo units, you can store the last calibration, so you can easily go back to it if the new one disappoints:
a)6.   Is it possible to save and recall an Audyssey MultEQ calibration?
Thanks. I have to learn how to save these from my Marantz, it doesn't sound very hard. Although my 4 runs on Friday sounded very similar while varying mic positions from a tight pattern and broadening them by a foot or so. Audyssey came up with exactly the same distances and XO points each time. I'm going to look into saving my calibrations and REW this week. One thing I know is my room needs some treatments.
I think the Marantz procedure is the same as the Denon isn't it?  (If someone confirms that I will add the comment to the FAQ).
kbarnes701 is offline
comfynumb's Avatar
Liked: 410
I will admit REW looks a little over my skill level. This is why I resisted it, and the fact I fear my room is so screwed up I'll go nuts trying to get it "right"
This said I'm game to try it.
comfynumb is offline
Old 09-29-2013, 08:20 AM
kbarnes701's Avatar
Liked: 5070
Originally Posted by peterfram View Post
Originally Posted by AustinJerry View Post
That is pretty much the case with 80% of the content of the entire AVS forums.
OCD AVphiles find tips and tricks that help normal and laid back people setup quality audio and video? Absolutely every day. Three cheers for the OCD among us! :-)
Good point.
Old 09-29-2013, 08:22 AM
comfynumb's Avatar
Liked: 410
Joel said I can save it from Audyssey's home page I believe. How quickly can you swap your different calibrations to compare?
Old 09-29-2013, 08:23 AM
kbarnes701's Avatar
Liked: 5070
I am sure you have the skill level needed. Jerry's Guide is your first port of call. Whatever difficulties you encounter will be overcome with help in the thread. Your room may be better, or worse, than you think - learning to measure it with REW won't change that, but it will tell you how practical/easy/difficult/impossible it is to improve it. Often just relocating speakers and subs can make a significant difference. Go for it!
Old 09-29-2013, 08:25 AM
kbarnes701's Avatar
Liked: 5070
IDK for Denon/Marantz. I believe their web interface is quite slow to reload earlier cals - but it has the advantage, IIRC, that you can save more than one. With Onkyo, you can recall a stored set of settings at the push of a button, but the unit only stores one set, so it is of limited use. I wasn't so much suggesting you use the feature to compare cals, as to save a cal that you really like in case the next cal gets screwed up somehow and you hate the result. Can happen.
Old 09-29-2013, 08:52 AM
SoundofMind's Avatar
Liked: 166
It takes several minutes (5-10) to do each Network Save.  I label the file on the HD with date and identifying details.  A separate log is nice for the OCD crowd, especially if you will be A/Bing.  ;)
Network Load takes about the same time, may be a bit faster.  This is based on my experience with Denons.  I presume Marantz  would be very much the same.
Yes, I still like playing with Dalis.
SoundofMind is offline
Old 09-29-2013, 09:29 AM
peterfram's Avatar
Quoted: 135 Post(s)
Liked: 99
There was a recent post here on how to save the config on a Denon. Takes about 12 minutes. It is a quirky process that I couldn't get to work until the details were posted. You can save configs and rename them, but you need to rename each config to "config.dat" before you load it. Apparently config(1).dat does not work for example.
peterfram is offline
Old 09-29-2013, 09:40 AM
comfynumb's Avatar
Liked: 410
Originally Posted by SoundofMind View Post
It takes several minutes (5-10) to do each Network Save.  I label the file on the HD with date and identifying details.  A separate log is nice for the OCD crowd, especially if you will be A/Bing.  wink.gif
Not bad, but I think it should be an option right from the AVR or pre. Good thing I'm not designing gear or the features would drive the price way up wink.gif
Old 09-29-2013, 09:44 AM
comfynumb's Avatar
Liked: 410
Thanks for the boost of confidence Keith and I will look into Jerry's guide first.
kbarnes701 likes this.
Old 09-29-2013, 11:14 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6502 Post(s)
Liked: 3611
Changing the name back to "Config.dat" is not a requirement, Peter. For example, I name my saved configuration files "Config_MM-DD-YYYY.dat". I never have trouble re-loading the files without re-naming them.
However, I am not saying that some special characters might cause the restore to fail. In your example, you use parentheses, which I have not tried. I guess the right advice would be to try the restore and if it doesn't work, try re-naming the file.
AustinJerry is online now
Old 09-29-2013, 11:25 AM
Liked: 3611
What do you mean? The network save is initiated from the AVR's web page. How could it be easier than that?
Old 09-29-2013, 11:38 AM
comfynumb's Avatar
Liked: 410
Old 09-29-2013, 05:04 PM
ggsantafe's Avatar
Quoted: 196 Post(s)
Liked: 162
Comfy - I had the same sense of feeling that REW was way over my level of competency - but as Keith has noted - Jerry's guide is super helpful, and forum members are quick to jump in and assist if you run into problems. the benefits far outweigh the concerns. Even if you don't pursue all of the options that REW offers - at the very least you get a very clear view of the acoustical properties of your room. It's worth pursuing and the costs are minimal - certainly far less then cost of new speakers and/or subwoofers. Screw your courage to the sticking post.
ggsantafe is online now
Old 09-29-2013, 05:25 PM
comfynumb's Avatar
Liked: 410
I think I can handle it with some help, it is the graphs that I'll need help deciphering. But like you said there are some good guys willing to help out here so I know I'm in good hands. I need to read Jerry's guide and subscribe to the REW thread. I'm actually dying to know if my room is as bad as I think it is.
Old 09-29-2013, 06:03 PM
mo949's Avatar
Liked: 1114
Don't do it! Resist...
mo949 is offline
Old 09-29-2013, 07:05 PM
peterfram's Avatar
Quoted: 135 Post(s)
Liked: 99
You are probably right about the special characters. There was a blurb in the post I linked about naming it correctly. I didn't test it. I just save it as config.dat and then rename it. The process takes long enough to keep me from testing it!
Old 10-01-2013, 11:25 AM
D Bone's Avatar
Quoted: 294 Post(s)
Liked: 376
Hey, I have a question for all of you experienced, knowledgeable Audyssey types. Have any of you that have measuring equipment, or I guess even if you don't, ever experimented with comparing a single MLP calibration to an 8pt traditional calibration? I don't mean what Chris says, but have any of you actually compared the results for yourselves, and if so, what did you find?
Samsung UN60D6420 ~ DirecTV HR-44 ~ Sony S5100 BD ~ Roku 3 ~ Denon AVR-X3200W ~ SVS Prime Bookshelf L/R ~ SVS Prime Satellite Surrounds ~ MultEQ XT L/R Bypass ~ Power Sound Audio XV15
D Bone is online now
Old 10-01-2013, 11:37 AM
Liked: 3611
Do you mean a single measurement at the MLP?  Or perhaps eight measurements (or less) without moving the mic?
While I haven't tried and measured this, I have done what we call a "tight grouping", which is varying the mic by only 3" in each direction.  The result:  flatter frequency response at the MLP, but poorer response as you move away from the MLP.  You may or may not like the results, but I feel you should respect the many people who have gone before you and try a more conventional mic placement.
Old 10-01-2013, 11:40 AM
D Bone's Avatar
Quoted: 294 Post(s)
Liked: 376
1 measurement at the MLP and then calculate vs a traditional 8pt calibration of the room. Not 8 measurements from a single spot. smile.gif
Old 10-01-2013, 11:41 AM
kbarnes701's Avatar
Liked: 5070
You can't do that. Audyssey requires a minimum of three measurements.
Old 10-01-2013, 11:54 AM
Liked: 3611
Only Pro requires three measurements, Keith.
Old 10-01-2013, 11:57 AM
Liked: 3611
Guys, this is crazy. Take all eight measurements, provide Audyssey with enough data to generate good filters, and enjoy the results. It's not like it takes forever to run eight measurements.
kbarnes701 and beastaudio like this.
Old 10-01-2013, 12:00 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
Ive done it, and still do it sometimes when I need a quick fix after something has changed. Bottom line is the single point gets your distances and delays good, so it is better than nothing, but bad news is you have two ears and a single EQ spot at this point and the sweet spot is about the size of a No.2 pencil. Even the slightest shift in position and your staging and image could falter. At least a three point calibration would be my suggestion, and do the tight grouping as I and Jerry typically do if you want to cut down on time. Nothing still beats a full calibration, whether it is tight grouping or traditional is your choice.
beastaudio is offline
Old 10-01-2013, 12:01 PM
mo949's Avatar
Liked: 1114
i believe this is just another comparison of tight vs loose grouping - phrased slightly different.
For me and my setup, unequivocal and potentially (or potently) laced in placebo goodness: tight works best.
mo949 is offline
Old 10-01-2013, 12:13 PM
D Bone's Avatar
Quoted: 294 Post(s)
Liked: 376
The reason I was asking is because I got a new SVS sub and I did an MLP 1 spot quick measurement/calculate/store so I could get the gain on the sub correct. I was eager to hear my SVS so I ran like this for a couple of days until I had the house to myself again, and then I ran my 8pt calibration. After the 8pt, my bass was noticeably thinner in the 50-100hz range than it was with my 1 spot calibration.
Flatter? Correct? Reference? IDK, but it is thinner and everything else sounds exactly the same to my ears (no measuring gear), so I was just hoping someone could prove I'm not crazy.........Many a Dr. has tried, and failed. tongue.gif
Old 10-01-2013, 12:44 PM
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
I have a Marantz AV8801 on the way. I am looking at a pair of SubMersive HP+ subs. Using the Master / Slave combo will only use one of the sub outs. Both of my subs will be on the front wall. This is the only spot I have for them.
Is using the 1 sub out a disadvantage in Audyssey? Is there any advantage to not go with the master / slave combo and using 2 SubM HP's (non slave) on the 2 subs outs?
The Moving Pictures Theater Construction Thread:
http://www.avsforum.com/t/1462881/th...ruction-thread
Houston GTG - Summer 2014
http://www.avsforum.com/forum/61-are...l#post26079610
avtexan is offline
Old 10-01-2013, 12:51 PM
sdrucker's Avatar
Quoted: 677 Post(s)
Liked: 453
Agreed: the only reason to do LT 8 measurements is for diagnostic reasons - e.g. to calculate distance and trims for two subs if you're running Audyssey Pro and reloading a previously saved set of calibration measurements where the software doesn't save the correct information, to verify suspect results, or to get a quick snapshot of a change in placement. Then it might be worth the trouble to do a basic consumer Audyssey run (three measurements I think is the conventional wisdom), get the tentative results, and abort before saving and moving back to Pro or established calibration.
Audio Gear: Trinnov Altitude 16/24, NAD M27 and Wyred4Sound MMC-7 amps
Display: Panasonic VT50, Lumagen Radiance Mini. Misc.: Oppo 103, Samsung K8500 UHD player, JRiver
Speakers: PSB Imagine T2, Center, Imagine T Wides and Side Surrounds, Imagine S rear surrounds,
PSB Imagine XA Dolby AE Speakers (4), HSU ULS-15 subs (4) - 9.4.4
sdrucker is online now
Old 10-01-2013, 12:58 PM
D Bone's Avatar
Quoted: 294 Post(s)
Liked: 376
I don't have Pro, just XT. If I had the knowledge I would definitely do some comparisons between single, tight 8 and wide spaced 8 just to see what exactly the differences were , and then I could 'prove' them with cool, colorful graphs.
Old 10-01-2013, 12:59 PM
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
Only on Onkyo products AFAIK. Denon/Marantz doesn't have this restriction. I can do a quick single point calibration if I'm in a rush.
When I set up an Onkyo 3008 for a friend a couple of years ago I was surprised by this. Another difference I found (hopefully Onkyo has fixed this since!) is that when I hit "cancel" during the measurements, the Onk cancelled the ENTIRE calibration. With Denons, when you hit "cancel" during a measurement, it just cancels that single measurement point. So, for example, if you are on mic position #5 and a barking dog interrupts a measurement, you can just cancel position #5 and restart it after locking the dog in the bathroom, without having to redo the first 4 positions. I tried this on the Onk 3008 when something disturbed a measurement point and was P.O.d to find that it kicked me back to the beginning.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
