"Official" Audyssey thread (FAQ in post #51779) - Page 2182 - AVS Forum | Home Theater Discussions And Reviews
 3490Likes
post #65431 of 79637 Old 10-07-2013, 01:03 PM
RapalloAV's Avatar
Quoted: 1571 Post(s)
Liked: 455
Originally Posted by beastaudio View Post
Seriously. You are happy and it sounds good and it all works! What more could you ask for, leave well enough alone!
Thanks for that, after your confirmation and Jerrys Im happy to leave well alone. smile.gif
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is online now
post #65432 of 79637 Old 10-07-2013, 01:35 PM
Selden Ball's Avatar
Quoted: 3356 Post(s)
Liked: 1637
So long as they're waking up OK, -11dB trim is fine.
A trim of -11dB means that the receiver has attenuated its output to compensate for the relatively high gain in the amps driving the subs.
Selden
Selden Ball is offline
post #65433 of 79637 Old 10-07-2013, 01:48 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Precisely.
If the trims in the avr are on the low end (eg. -11) as long as subs with an auto On feature turn on, you're fine.
The danger is if they're on the high side (eg. +11db). In this case, you want to check the gain structure in your setup (the V output range of the avr vs. the V input range of the sub's amp) to ensure the avr's line level signal won't potentially clip the sub amp's input. To do this, you'll need to determine the range of the avr's pre-outs for the sub channel AND the range of the sub amp's input to see if they're well matched.
Or, you could simply recalibrate the setup after increasing the sub volume so the avr trim setting is closer to zero, or in the -ve range, just to be on the safe side.
Max
kbarnes701 likes this.
djbluemax1 is offline
post #65434 of 79637 Old 10-07-2013, 01:52 PM
mogorf's Avatar
Quoted: 1115 Post(s)
Liked: 709
Hi Selden,
+1.
In the meantime, please allow me to amend your above sentence a tad bit as follows:
"A trim of -11dB means that the receiver has attenuated it's output to compensate for the relatively high gain in the amps driving the subs...in order to achive movie reference level when the Master Volume is set to 0 dB".
BTW, and IMHO this wake-up feature of a sub (any sub) is one of the most sillyest features Man has ever created. I can not come up with a situation where this is really needed. E.g., I like to play music with DEQ ON when friends are over and we're having a chat while music is playing in the background with deep and smooth bass even at a -50 dB MV setting. My Dali sub has that switch, but I always have it turned off.
Whaddaya think?
mogorf is online now
post #65435 of 79637 Old 10-07-2013, 01:58 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7412 Post(s)
Liked: 4120
What do we think? Pointless.
AustinJerry is online now
post #65436 of 79637 Old 10-07-2013, 02:02 PM
mogorf's Avatar
Liked: 709
Care to expand a bit on pointless, Jerry?
post #65437 of 79637 Old 10-07-2013, 02:47 PM
D Bone's Avatar
Quoted: 297 Post(s)
Liked: 377
Feri, just curious, do you leave your sub on 24/7, or turn it off and on manually. If 24/7 how long have you ran it like that?
Samsung UN60D6420 ~ DirecTV HR-44 ~ Sony S5100 BD ~ Roku 3 ~ Denon AVR-X3200W ~ SVS Prime Bookshelf L/R ~ SVS Prime Satellite Surrounds ~ MultEQ XT Flat / DEQ OFF~ Power Sound Audio XV15
D Bone is offline
post #65438 of 79637 Old 10-07-2013, 02:56 PM
mogorf's Avatar
Liked: 709
I always turn it off when I turn off my whole system. My sub is totally powered off. I use a mains socket remote control to do that. My sub is built into my front "stage", thus it would be inconvenient to remove it (read: pull it out) from it's location every time I'm finished.
Here's a pic for your ref.:
post #65439 of 79637 Old 10-07-2013, 02:59 PM
batpig's Avatar
Quoted: 3686 Post(s)
Liked: 3529
Whaddaya think?
I think you are 100% wrong. There's a reason almost every sub has this feature -- it's REALLY helpful. Most subs' power switches are tiny little things on the back, not easy to reach in many setups. The Auto-On feature means you never have to worry about turning your sub on and off. If you can't think of a situation where it's needed, you are sorely lacking in imagination for setups which may not be like your own.
It's equally useful to have auto-on circuits for external amps (e.g. a Zone 2 amp) because again you never have to worry about powering it on/off. It just operates seamlessly... system is on, subwoofer or external amp is on too.
This is your setup, yet you can't imagine a situation where an auto-on circuit would be needed? confused.gif This is PRECISELY the situation where it is REALLY NEEDED!
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #65440 of 79637 Old 10-07-2013, 03:08 PM
mogorf's Avatar
Liked: 709
This is of course your opinion bp. I have a solution that works best for me with a socket remote. What's the problem?
BTW, when listening at a very soft level the signal strength may not be enough to switch the sub out of standby mode, thus resulting in loss of smooth bass. This is the sutiation here I think you are 100% wrong. Think about it a bit, please. cool.gif
post #65441 of 79637 Old 10-07-2013, 03:14 PM
batpig's Avatar
Liked: 3529
There's no problem for YOUR solution. But you specifically asked what other people thought, and I told you.
It's worth noting that the fact that you had to devise another solution in essence proves the usefulness of the Auto-On feature. You said that you "can not come up with a situation where this is really needed", but the ONLY reason YOU don't need it is because you came up with an alternate solution. That by its nature proves that there is a problem that requires a solution; the Auto-On circuit is the solution that already comes for free with the subwoofer.
You are in essence arguing that "feature X is a silly feature because you can buy an additional piece of hardware that replaces the function of feature X." That implies that there are situations where the functionality of feature X is needed, thus rendering your claim that you can't think of a situation where it would be needed completely bizarre.
Setup Guide and FAQ
post #65442 of 79637 Old 10-07-2013, 03:16 PM
Liked: 4120
The problem, Feri, is that this is a pointless discussion in the Audyssey thread.
post #65443 of 79637 Old 10-07-2013, 03:20 PM
mogorf's Avatar
Liked: 709
What is wrong with you Guys here? Ever thought of a wake-up feature for your satellite speakers? Any difference to a sub?mad.gifeek.gifcool.gifrolleyes.gifwink.giftongue.gif
post #65444 of 79637 Old 10-07-2013, 03:25 PM
batpig's Avatar
Liked: 3529
There is a HUGE difference. The sub has an AMPLIFIER in it which requires power from an electrical socket. The satellite speakers are passive and do not need any additional "wake up" besides the receiver turning on.
Setup Guide and FAQ
post #65445 of 79637 Old 10-07-2013, 03:33 PM
mogorf's Avatar
Liked: 709
Come on bp, use your fantasy, please!!! Satellites are also run off amplifiers, aren't they? Technically anything can be solved. Practically of course, it's nonsense!
post #65446 of 79637 Old 10-07-2013, 03:37 PM
batpig's Avatar
Liked: 3529
I can agree that your comments on the issue are nonsense.
kbarnes701 and TKO1 like this.
Setup Guide and FAQ
post #65447 of 79637 Old 10-07-2013, 03:49 PM
mogorf's Avatar
Liked: 709
post #65448 of 79637 Old 10-07-2013, 04:00 PM
kbarnes701's Avatar
Quoted: 6818 Post(s)
Liked: 5247
I am away this week with Mrs Keith, fortunately. Joining in on a cellphone is a real PITA. But l still know pointless when I see it :)  All I have to add is the more you feed 'em the hungrier they get :l
kbarnes701 is offline
post #65449 of 79637 Old 10-07-2013, 04:24 PM
kbarnes701's Avatar
Liked: 5247
Originally Posally ted by SoundofMind View Post
Originally Posted by kbarnes701 View PostHe has - but he's wrong ;)
Or, to put it a better way, he's only thinking in terms of Audyssey, as he usually does. In those terms, he is right. Thinking more holistically, he's wrong.
Keith, you've lost me here.  Like the OP, I'm unclear as to what is wrong with my post or my citing Chris' advice in this instance, wholistically or otherwise.   What is it in that FAQ answer that indicates how my post (and my quoting Chris) is wrong in this instance?
More importantly, is there something you'd have the OP do differently irt his sub set up?
what beast said basically. High neg trim sub may not wake up. High pos trim may clip sub amp. Plus what is in referenced FAQ answer.  Sorry 4 short response. On cellphone.
post #65450 of 79637 Old 10-07-2013, 04:31 PM
mogorf's Avatar
Liked: 709
Hi neg sub wake up makes no sense! Why does a sub need to wake up? Don't use that setting! High pos trim will not cause clipping coz its set by Audyssey that way in order to play movie reference at 0 dB MV.
post #65451 of 79637 Old 10-07-2013, 04:35 PM
sdrucker's Avatar
Quoted: 795 Post(s)
Liked: 542
Something of interest to anyone looking for information on which flavor of Audyssey is included in which AVRs:
Chris K. answered a question on FB's Audyssey Tech Talk about whether an updated list of AVRs was going to be restored to the Audyssey website posted by one of our own (Feri).
In response, he (Chris) said there were no plans to do so in the near future, because "we don't really have a resource available to do that and keep the list current. I'll be happy to answer individual questions from this group". However, he did agree that a reader putting a list of AVRs or pre/pros with Audyssey together on an A/V enthusiast site of choice was a good idea.
WTF? They don't have anyone that can do a Google search or look up websites of the usual manufacturer suspects?
Sorry to out you from FB, Feri, but I thought it newsworthy....
Audio Gear: Trinnov Altitude 16/24, NAD M27 amps (3)
Video: JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4444 (coming soon)
Misc.: Oppo 103, Oppo 203 UHD player, JRiver
Speakers: PSB Imagine T3 LCR, Imagine T Wides and Side Surround 1, T2 Side Surrounds, Imagine XB rears, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 11.4.6
sdrucker is offline
post #65452 of 79637 Old 10-07-2013, 04:39 PM
kbarnes701's Avatar
Liked: 5247
 ote:
Please see the FAQ where it is all explained in detail.
post #65453 of 79637 Old 10-07-2013, 04:42 PM
kbarnes701's Avatar
Liked: 5247
Originally Poste
audysseyno longer GAF. Just interested in being new Bose.  This thread now principal Audyssey resource.
post #65454 of 79637 Old 10-07-2013, 04:43 PM
Liked: 4120
Responses like this and other subtle queues make me wonder whether Audyssey is having financial difficulties.
post #65455 of 79637 Old 10-07-2013, 04:45 PM
sdurani's Avatar
Quoted: 4921 Post(s)
Liked: 3353
Or, doesn't Audyssey have an internal list that shows which version of MultEQ they themselves licensed to specific receiver and pre-pro models?
Sanjay
sdurani is online now
post #65456 of 79637 Old 10-07-2013, 04:48 PM
mogorf's Avatar
Liked: 709
No problem for outing Stuart, I was just as well astonished as you are now. The previous seach engine on Audyssey homepage was really helpful for folks wanting to know different flavors, I know I used it a lot. C'est la vie! Google is our friend! smile.gif
post #65457 of 79637 Old 10-07-2013, 04:49 PM
sdrucker's Avatar
Quoted: 795 Post(s)
Liked: 542
As we've discussed ad nauseum here, they've moved well beyond the home audio market being their emphasis to being some sort of mobile software platform/IP licensor as their mission. We all know that they're not the same company they were when XT32 was released. But this is basic functionality to direct potential users to which of their licensing partners have a particular flavor of Audyssey XT in the first place. They might actually get a higher incremental stream of revenue if they noticed what we have about XT32 being a strong recommendation based on testing by our forum members. and at least mentioned which recent AVRs had XT32 included.
@ Feri: I don't like being the bomb thrower, but it was shocking enough to be mentioned here. And DK about you, but even though I had always intended to get XT32 when I went into Audyssey in the first place, it was still worth seeing which units had what version to know what others here on AVS had, or what the new units might have.
What's even worse is that someone looking to use, say, the Pro kit, even through a "custom installer", won't know which units are Pro ready from Audyssey's own website, meaning that the info on the manufacturer websites has to be accurate. Double eek.gif
All I know is they better keep generating updated licensee Pro keys on the Installer site....
sdrucker is offline
post #65458 of 79637 Old 10-07-2013, 05:00 PM
mogorf's Avatar
Liked: 709
You are right Stu,...and as I said I'm not happy either! But to cheer you up, at least you can know that XT32 will not become obsolete (for the time being)! How is that for a good feeling? eek.gifsmile.gif
post #65459 of 79637 Old 10-07-2013, 05:01 PM
Point Source
beastaudio's Avatar
Quoted: 4007 Post(s)
Liked: 3309
And so do all of my speakers, and they are all on an "Auto On/Off" feature. I don't understand why you choose to bypass these options if you amps have the ability. It doesnt require getting behind them and messing with any plugs.
It just said that one "user" found this post helpful, well, unfortunately it is not, as ANY amp requires a range of voltage to make it operate within its proper constraints, IT HAS NOTHING TO DO WITH AUDYSSEY and its trims. If a sub with integrated amp didn't see enough voltage from the line out it would not "Turn on" but in most cases, they are sensitive enough to catch it. I had a zone two amp that OTOH wouldn't turn on as the input voltage required was way too high for me to play my outdoor speakers at a reasonable volume. Once I cranked it up a bit to where it was uncomfortable if we were trying to talk by my table on the deck, it would work fine, but I didn't want that, so I switched it out for one that had a lower input sensitivity and all is good smile.gif
High positive trim WILL VERY MUCH CAUSE SUB AMP INPUT CLIPPING AT REFERENCE. Need I repeat it? Unless you have tested it out (which I have) and documented it (which I have) Feri, don't make erroneous comments to which you have no backing for. I simply stated earlier in this thread that I have pushed my system to where I began to see clipping at the input of my EQ that is in-line between my AVR and my sub amp, and at a positive subwoofer trim on the AVR, and even some of the negatives (namely down to -3 or so), I have seen it clip my EQ which is equipped with "Clip lights" so I can easily see during playback when it happens. I imagine you haven't tried to test the input voltages you are getting from your AVR to your sub when you are really running the system hard? It obviously depends on the AVR/Pre, and the imput sens. of the amp that the line out is going to, but if you don't have experience testing this aspect, then don't post about it.
To your defense you are right about one thing, the audyssey calibrated trims will make the sub play at the right level from an overall spl standpoint, but if you are really way up on the sub level trim in the AVR to get there, and the sub's volume knob is too far down, you really WILL clip the input of your sub amp and have a very bad day if it stays that way for too long. Not sure why I spent the time posting all this since the OP was questioning the opposite of all this, where the trims are too low. Let's move on now please...biggrin.gif
FS: BossoBass A-14K amplifier
beastaudio is online now
post #65460 of 79637 Old 10-07-2013, 05:09 PM
kbarnes701's Avatar
Liked: 5247
It just said that one "user" found this post helpful, well, unfortunately it is not, as ANY amp requires a range of voltage to make it operate within its proper constraints, IT HAS Technically  TO DO WITH AUDYSSEY and its trims. If a sub with integrated amp didn't see enough voltage from the line out it would not "Turn on" but in most cases, they are sensitive enough to catch it. I had a zone two amp that OTOH wouldn't turn on as the input voltage required was way too high for me to play my outdoor speakers at a reasonable volume. Once I cranked it up a bit to where it was uncomfortable if we were trying to talk by my table on the deck, it would work fine, but I didn't want that, so I switched it out for one that had a lower input sensitivity and all is good smile.gif
It was me who hit the thumbs up by mistake LOL. Big hands small phone keyboard. No way to remove tbumbs up. Definition of irony!  Agree with your post above.
porschedrifter likes this.
Closed Thread Receivers, Amps, and Processors
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
