"Official" Audyssey thread (FAQ in post #51779) - Page 2384 - AVS Forum | Home Theater Discussions And Reviews
 3496Likes
post #71491 of 79637 Old 06-19-2014, 08:24 AM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
The easiest way to start a dual sub system is to run a test tone, start at 30hz to each sub at the mlp useing a sound meter adjust the level of each sub so that its the same say 90db one sub at a time, with one sub at 90db turn on the second sub did the meter reading go higher or lower, adjust the phase for strongest output at the mlp. Can use distance as a phase setting to fine tune. Same goes for sub to mains/center/rears/etc. This is just the basics, but you get the idea.. You can do this before and after audyssey. Yes its work and takes a lot of your time. You may find things like the sub in phase with the mains @ 40,50 hz but out of phase @70,80 hz. the same could happen with the center, it can in phase with the sub/mains @80hz but out of phase with the mains @ 100hz but in phase @120 hz The combos are endless, things to listen for are male voices and of course tight clean bass, just to name a few, if it sounds muddy than phase is the first place to look...
joehonest is offline
post #71492 of 79637 Old 06-19-2014, 09:05 AM
mogorf's Avatar
Quoted: 1119 Post(s)
Liked: 714
Joe, this setup makes too much mess in the phase department, I, for one, wouldn't follow this way.
mogorf is online now
post #71493 of 79637 Old 06-19-2014, 09:32 AM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
You don't need to change anything if your happy, its just a test, honestly there really isn't much you can do about it anyway. Speaker polarity and Xover to get out of the bad phase zone, higher Xover will fix/ patch most phase issues. So if your center is good for full range/40hz as good as that might be, a phasing issue may out weigh that,, polarity wiring or/ and go with a higher Xover like 70/120hz may clear things, only if you feel the need to, blue or red pill. Using THX 80hz or higher setting is good cause it doesn't put more speakers in the most sensitive phase zone. One thing I've noticed that small satellite speakers that Xover at 100/150hz seem to sound very clear and clean but not full or loud , there always trade offs. 3 way speaker systems are most prone to crazy phase shifts, a cross over thing in poor 3 way speaker designs? Ported vs sealed speakers and subs have issues of there own. I guess Audyssey can't fix everything..
post #71494 of 79637 Old 06-19-2014, 11:44 AM
kbarnes701's Avatar
Quoted: 6824 Post(s)
Liked: 5260
AUDYSSEY 101 IS NOW FULLY OPERATIONAL FOLLOWING SYSTEM CHANGEOVER TO vBULLETIN!
This completes the work on
  • The Audyssey FAQ,
  • The Audyssey 101 and
  • The Audyssey FAQ Addendum
which was required as a result of the changeover from the Huddler platform to vBulletin.
All links have been checked and verified as working with the exception of a few links in the main FAQ which link to other AVS posts. These will be fixed in the next few days.
The Audyssey Pro FAQ is functional but in a bit of a mess. This will be fixed in the next 7 days.
Thanks for bearing with me during this major system update.
jevansoh likes this.
kbarnes701 is offline
post #71495 of 79637 Old 06-19-2014, 12:56 PM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
Never rule out a bad test mic, just because its working doesn't mean its good. if you feel your not getting good results, try another mic if possible. I've had 4 mics, 2 denon and 2 onkyo same spec units, yet I would swear each one produced very small but audible difference, each one did have its own personality..
post #71496 of 79637 Old 06-19-2014, 12:59 PM
mogorf's Avatar
Liked: 714
Well noted, thanks.
post #71497 of 79637 Old 06-19-2014, 01:12 PM
mogorf's Avatar
Liked: 714
Originally Posted by jkasanic View Post
EDIT: I'm also seeing every post as a hyperlink (since yesterday) for some reason?!
Me too.
BTW, I don't see the panel for editing a reply, you know the one that has Bold, Italics, Underline, etc. and the buttons to embed a link or an image... and all that jazz...
post #71498 of 79637 Old 06-19-2014, 01:58 PM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
the mics are tested to be within plus or minus 2 dB of the FR curve buit into the system, so it's not exactly a huge surprise that different mics yield subtly different results. That's different, at least technically, from "bad" and in the end one's preference for the results from a particular mic doesn't "prove" the mic is "correct" or "not bad." But those deviations are part of the price for not using $500 - $1000 measurement mics as part of the system. Which has a significant price effect . . . . FWIW.
kbarnes701 and twain250 like this.
JHAz is offline
post #71499 of 79637 Old 06-19-2014, 03:34 PM
mogorf's Avatar
Liked: 714
And then we realize that the +/- 2 dB of the FR curve is pretty much enough for our ears, yet saved us a sizable amount of hard earned money in the range of $500 - 1,000 we can spend elswhere.
post #71500 of 79637 Old 06-19-2014, 03:57 PM
pbarach's Avatar
Quoted: 367 Post(s)
Liked: 219
Originally Posted by Aberslam74 View Post
I have a Denon AVR-X4000, which has Audyssey XT32 and Sub EQ HT.
During the Audyssey setup process, it plays a single test tone to the subwoofer 1 and has you adjust the gain/level of the subwoofer until it is between 72 and 78 decibels. Then it does the same for subwoofer 2.
Does anyone know the frequency of the test tone that is used for setting the gain/level of the subwoofer/s ?
It's not a single frequency, it's a bunch of them, like white noise...
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #71501 of 79637 Old 06-20-2014, 05:48 AM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
Reran Audyssey XT before watching Man of steel last night (recommended, superman remake). It seems the results turned out better than I last remember. Maybe the speakers/subs have finally broken in or the house being at a higher temperature 78 vs 76. Or just having different expectations from the past runs and being a year older.. It could even be the new softer pillows!
post #71502 of 79637 Old 06-20-2014, 05:51 AM
mogorf's Avatar
Liked: 714
How'bout humidity Joe? Did you check humidity?
Enjoy!
post #71503 of 79637 Old 06-20-2014, 05:54 AM
kbarnes701's Avatar
Liked: 5260
Variations between Audyssey runs are usually caused by slightly different (or radically different if you were experimenting) mic positions during the measuring phase. If the mic is positioned differently between runs, then a difference in the calibration is inevitable, and sometimes it will be significant enough to be audible.
post #71504 of 79637 Old 06-20-2014, 04:39 PM
jjazdk's Avatar
Quoted: 34 Post(s)
Liked: 88
Please, Feri, not again.. Even though you have stated it countless times in this thread, it is NOT true that Average Joe cannot hear +/-2dB variations in the frequency response.
Please take a look at these three frequency responses, and tell me, do you honestly believe they will sound the same? They only represent a +/2dB variation, but the differences between them would be very audible.
kbarnes701 and joehonest like this.
Source: HTPC with JRiver
Pre: Focusrite Scarlett18i20 + 2 channel DAC
PA: April Music Stello S200 (GD1 >130Hz), 2x ICEpower 1000ASP (GD1 <130Hz), 2x ICEpower ASP1000 (Subs), Marantz MM8077 (Rear+Center+Back)
Spkr: GD1 (Front), GDA125 (2xRear+1xBack), GDA Center (Center)
Subs: 4 towers, a total of 28 x 10" 25W ScanSpeak
jjazdk is offline
post #71505 of 79637 Old 06-20-2014, 04:49 PM
jjazdk's Avatar
Quoted: 34 Post(s)
Liked: 88
I see some still haven't caught up with the subject, yet. It's not about "who set up how many subs", but about phase vs. frequency issues. Once the phenomenon is understood it will help to set up from 1 sub to an infinite number of subs.
Yes, let us talk about phase vs. frequency. First of, you need to understand that your subwoofer does NOT have a flat phase response in itself, nor is it free of group delay. Every loudspeaker has a natural phase shift that follows frequency, that is inevitable.
Thus even with your hated phase-knob at 0 degree, your subwoofer will NOT exhibit zero phase or zero group delay.
I have made two simulations on a well known driver, the LMS-Ultra 5400, to show it to you (and whomever else interested).
Note: The dotted black line in the frequency response graph is the phase of the acoustic output)
Ported enclosure (200 litre, f3 = 23Hz)
Sealed Enclosure (200 litre, f3 = 50Hz)
kbarnes701 likes this.
jjazdk is offline
post #71506 of 79637 Old 06-20-2014, 05:37 PM
mogorf's Avatar
Liked: 714
Dear jj, this only goes to show you have a misunderstanding of frequency vs. phase, all in all. Care to look at those graphs you posted again? Ground rule it that until the frequency response is flat the phase response is gonna be just as flat, as well. Once the frequency response starts to slope it will be followed in the same manner by the phase response.
And as frequency vs. phase is a general issue, not limited to HT, or speakers, it will do the same for a magnetron in your microwave oven. Capito?
post #71507 of 79637 Old 06-21-2014, 12:27 AM
jlpowell84's Avatar
Quoted: 1941 Post(s)
Liked: 915
Thumbs down
Keith is right. Mic positions are never the same exactly. I have had experience with many Audyssey calibrations and sometimes even if nothing has physically changed in the room the results can be more desirable. The biggest room improvements you will ever see are the first reflection points on the floor and ceiling. I did an experiment where I put a tough and thin type garage 4x8 rug right in front of my couch. It certainly had much more reflective properties than my plush carpet. After a week I removed it and the improvement was absolutely phenomenal! My ceiling treatment does a good job too
Haven't been here in awhile but I see the same old is still present
Also I am adding heights and wides tomm!
JLPowell84's Room
FTW21 Ported Build
Spoiler!
jlpowell84 is offline
post #71508 of 79637 Old 06-21-2014, 05:19 AM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
With this combo, Audyssey would calculate the speakers output to be a DULL and LIFELESS sounding HT.
If this mic is used in this auto setup
And the natural FR of your speakers in the room is something like this
I know I've been a victim of this scenario, to many times!
post #71509 of 79637 Old 06-21-2014, 01:40 PM
mogorf's Avatar
Liked: 714
Prove it please. Prepare 4 audio files that we can download.
1. "As is" with a flat response.
2. The other 3 with filters set as per your graphs.
3. MP3 is ok.
4. Use file names that don't correspond to which is which!
Lookin' forward to the test.
post #71510 of 79637 Old 06-21-2014, 01:55 PM
mogorf's Avatar
Liked: 714
Joe, I really don't know what you are talking about!
post #71511 of 79637 Old 06-21-2014, 02:20 PM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
3. MP3 is ok.
Honestly, its not his job to prove it, but its Audyssey job to fix it!! jjazdk is showing 3 scenarios that are possible going by the +/-2dB variations in the Audysseys mic frequency response.
Maybe the only thing that needs to be proven is the +/-2dB spec for Audyssey mic, I believe it could be much worse!
jjazdk theory sure does answer alot of questions to why does my HT sound like this after auto run, good thing there is the on/ off button..
I'm sure this is true having used 4 different mics with the same HT system.
post #71512 of 79637 Old 06-21-2014, 02:22 PM
mogorf's Avatar
Liked: 714
post #71513 of 79637 Old 06-21-2014, 02:23 PM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
No one said it would be easy, but it really is.
Basically if the mic reads the room as overly "bright" due to being overly sensitive at the high end.
Audyssey is going to calculate the speakers high end output to be lower in that range, by way to much!
In my case it would make music sound DULL and LIFELESS and Audyssey best left OFF.
I'm sure jjazdk knows what I'm saying / showing cause we're on the same page about this one.
Are there also specs for S/N and sensitivity (volts out) ?
post #71514 of 79637 Old 06-21-2014, 02:45 PM
garygarrison's Avatar
Quoted: 618 Post(s)
Liked: 731
... it is NOT true that Average Joe cannot hear +/-2dB variations in the frequency response.
I believe I read that with a simple midrange test tone, most people can hear 1 dB variations, and, with a complex signal (I think they used music, and perhaps square waves?) some people can hear smaller differences.
garygarrison is offline
post #71515 of 79637 Old 06-21-2014, 02:58 PM
mogorf's Avatar
Liked: 714
Who are those "most people", please? And who are "some people", please? Where did you "believe" you read all "that"? Do you just think or are you sure they used music? Who the heck listens to square waves? Who are those people who can hear smaller differences, please?
Today I asked my son (22 old) to sit at the MLP and close his eyes while I play music and used the remote to adjust Master Volume up and down by 2 dB. Guess what, he asked me: are you doing anything with that remote?
Why not do your own test and report back, please.
Gary J likes this.
post #71516 of 79637 Old 06-21-2014, 03:04 PM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
There you go, you have your answer, my exwife would of said "stop playing around" !!
post #71517 of 79637 Old 06-21-2014, 03:06 PM
kbarnes701's Avatar
Liked: 5260
Yes - it has been well documented in this thread. Some members have short memories. I posted a lot of evidence about it including tests carried out by audio scientists with PhDs. The Just Noticeable Difference (JND) is without any shadow of doubt 1dB. It's honestly not worth arguing all over again - the fantasists will never agree with it and simply ignore any objective evidence which is posted if it contradicts their fantasies.
jjazdk likes this.
post #71518 of 79637 Old 06-21-2014, 03:07 PM
mogorf's Avatar
Liked: 714
LOL.
English is not my first language, but is it:
1. "would of", or
2. "wood of", or
3. "would have"?
post #71519 of 79637 Old 06-21-2014, 03:13 PM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
LOL.
1. "would of", or
2. "wood of", or
3. "would have"?
I was JUST quoting my EX WIFE,
if it was me, I would have said
"would have" it is my ex wife who has poor english skills.
Now you see the long term damage of being with the wrong woman to long..
post #71520 of 79637 Old 06-21-2014, 03:16 PM
mogorf's Avatar
Liked: 714
And then there are the ones who massively "google" any subject they pick up on threads looking for a lot of evidence, yet never bother to do their own simple homemade tests. Forum life, indeed. Gotta live with it.
Closed Thread Receivers, Amps, and Processors
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
