"Official" Audyssey thread (FAQ in post #51779) - Page 2386 - AVS Forum | Home Theater Discussions And Reviews
 3496Likes
post #71551 of 79637 Old 06-21-2014, 11:13 PM
jlpowell84's Avatar
Quoted: 1941 Post(s)
Liked: 915
smal DB differences in my bass department when fluctuating my house curve via mini DSP in live time on the fly are very noticeable. This thread is just plain crazy though. Haven't been here in awhile and I guess I picked the wrong time to come back :/
JLPowell84's Room
FTW21 Ported Build
Spoiler!
jlpowell84 is offline
post #71552 of 79637 Old 06-22-2014, 01:18 AM
kbarnes701 is offline
post #71553 of 79637 Old 06-22-2014, 02:53 AM
Super Moderator
markrubin's Avatar
Quoted: 1299 Post(s)
Liked: 2790
time to move on please
thanks
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
post #71554 of 79637 Old 06-22-2014, 05:18 AM
IgorZep's Avatar
Quoted: 395 Post(s)
Liked: 190
Originally Posted by mogorf View Post
Some members do not introduce unnecessary phase differences to their systems
Don't you? Do you listen exclusively full range speakers, no crossovers, no ported designs, etc.? I doubt it! The phase knob on the sub does no more harm than those things do.
IgorZep is offline
post #71555 of 79637 Old 06-22-2014, 05:27 AM
IgorZep's Avatar
Quoted: 395 Post(s)
Liked: 190
Today I asked my son (22 old) to sit at the MLP and close his eyes while I play music and used the remote to adjust Master Volume up and down by 2 dB. Guess what, he asked me: are you doing anything with that remote?
Why not do your own test and report back, please.
Incorrect experiment. Give him A/B control and ask what is what - he will be able to find it out!
My own test: connected two speakers to amps with different (unknown) gain. Level align by ear on music content within 0.5dB precision. Measure. Perfect match! I don't pretend my hearing is anything above average.
IgorZep is offline
post #71556 of 79637 Old 06-22-2014, 07:55 AM
mogorf's Avatar
Quoted: 1127 Post(s)
Liked: 723
I don't see anything incorrect in that experiment. But if you do care to share it?
mogorf is online now
post #71557 of 79637 Old 06-22-2014, 08:08 AM
IgorZep's Avatar
Quoted: 395 Post(s)
Liked: 190
It doesn't tell if the difference is audible or not. Even if he can spot the difference he cannot tell is it because of you changing the volume, the recording, or the musicians playing. Too many variables. Fix everything else, leave only one variable. Or elsewhere I don't know what are you are trying to measure / prove... It is definitely not the audibility between different loudness levels.
IgorZep is offline
post #71558 of 79637 Old 06-22-2014, 08:19 AM
mogorf's Avatar
Liked: 723
You would be absolutely right if all those variables kick-in at the same time, but I was playing music with low dynamic range (no Beethoven ) so the only variable was me with remote in hand. No need to complicate a simple everyday test. Wouldn't even call it an experiment.
post #71559 of 79637 Old 06-22-2014, 08:36 AM
IgorZep's Avatar
Quoted: 395 Post(s)
Liked: 190
They are!
Q.E.D.
IgorZep is offline
post #71560 of 79637 Old 06-22-2014, 02:29 PM
jjazdk's Avatar
Quoted: 34 Post(s)
Liked: 88
Prove it please. Prepare 4 audio files that we can download.
1. "As is" with a flat response.
2. The other 3 with filters set as per your graphs.
3. MP3 is ok.
4. Use file names that don't correspond to which is which!
Lookin' forward to the test.
Here you go..
http://www.jjaz.dk/privat/AVS/test.zip
One of the filters may not be that easy to identify on this particular piece of music, but it is easy to hear that something changed. At least I can easily spot them on my PC speakers.
primetimeguy and kbarnes701 like this.
Source: HTPC with JRiver
Pre: Focusrite Scarlett18i20 + 2 channel DAC
PA: April Music Stello S200 (GD1 >130Hz), 2x ICEpower 1000ASP (GD1 <130Hz), 2x ICEpower ASP1000 (Subs), Marantz MM8077 (Rear+Center+Back)
Spkr: GD1 (Front), GDA125 (2xRear+1xBack), GDA Center (Center)
Subs: 4 towers, a total of 28 x 10" 25W ScanSpeak
jjazdk is offline
post #71561 of 79637 Old 06-22-2014, 02:44 PM
jlpowell84's Avatar
Liked: 915
Originally Posted by jjazdk View Post
Here you go..
http://http://www.jjaz.dk/privat/AVS/test.zip
I want to try but link is not working for me
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #71562 of 79637 Old 06-22-2014, 02:50 PM
mogorf's Avatar
Liked: 723
Delete the double http and start from www.
Now it works for me.
post #71563 of 79637 Old 06-22-2014, 03:07 PM
mogorf's Avatar
Liked: 723
Here you go..
Thanks jj for taking your time to prepare the files. Appreciate it. I'll come back to you tomorrow, coz its already too late here to crank up the volume on the HT.
Thanks again.
post #71564 of 79637 Old 06-22-2014, 03:53 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 406 Post(s)
Liked: 307
Here you go..
Thanks for doing this, if only for sanity's sake. Predictably, they sound very different. Is the extra file flat or ??? There were only three curves in your OP #71505.
RUR is offline
post #71565 of 79637 Old 06-22-2014, 05:15 PM
jlpowell84's Avatar
Liked: 915
Here you go..
Ok, definitely a noticeable difference. I tried PLIIX Music with LCR JTR Triple 8's and dual Seaton Submersives on sub duty.
If you are going to try this test. You should try this test!!! Do not go down to my results. Rather download very quickly and run through with a pen to take a couple notes on your guesses. Then come back and compare.
Track labeled "ORG" I am guessing is the original un modified track.
Track Labled "27" I am guessing had low bass and mid bass cut.
Track Labled "43" I am guessing had the low bass and mid bass boosted.
Track Labled "79" I am guessing had the upper treble range boosted.
Other takers would be very interesting.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #71566 of 79637 Old 06-22-2014, 05:17 PM
jlpowell84's Avatar
Liked: 915
Did you listen? I can very easily hear the differences. And feel too at high volumes with dual Submersives
kbarnes701 likes this.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #71567 of 79637 Old 06-23-2014, 05:51 AM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
No doubt about this one, easy !
I like this very much, very smooth across sound stage on a pc 2.1 system
Did not move me, sounds out of phase to me, if I was to label it anything.
I haven't played these on my HT, just my 2.1 pc deck top system!
Yes there is no doubt these sound files have mods from one another.
Will do later,to early now..
joehonest is offline
post #71568 of 79637 Old 06-23-2014, 08:41 AM
mogorf's Avatar
Liked: 723
Just did my listening tests as follows:
MV: -10 dB (RLO: 0 dB)
MultEQ (Audyssey flat)+ DEQ on, DynVol off.
Dolby PLII Music mode
Among the 4 files I can only hear a tad bit of difference with "43". That one seems to be the one with the LF boost. The other 3 files sound pretty much the same for me even after repeated listenings. Please don't forget these ears are already 57 years old!
Will be looking forward to other members' listening tests. It's interesting.
Thanks jj again.
post #71569 of 79637 Old 06-23-2014, 10:07 AM
sdrucker's Avatar
Quoted: 888 Post(s)
Liked: 600
The test is now biased with your comments , but I just listened to the four sound clips during a break at a conference I'm at, using my Dell laptop's built-in JBL speakers. The conference room was empty, and the doors closed, so little if any background noise.
I heard a slight, possibly placebo difference in the bass between the original and tracks 27 (had less bass) and 79 (had more mid and upper frequency), more of one between 43 (most bass) and the original. 43 and 27 were clearly different cuts as well IMO.
But at least three of the tracks sounded different from one another, in a LT five second between clips A/B using Windows Media Player, and the same volume setting on the laptop. I would not conclude these four clips were identical, and I played two different ones where I randomly picked one of the three non-original clips with my eyes closed, and correctly guessed it was one with less bass.
Not 100% scientific (in a perfect world, I'd have someone play the clips rather than me, picking them randomly), but my ears must be OK. Oh, and I'm 51 .
Maybe this is why I want to play with the Trinnov target curve capability .
sdrucker is online now
post #71570 of 79637 Old 06-23-2014, 10:17 AM
kbarnes701's Avatar
Quoted: 6824 Post(s)
Liked: 5262
Originally Posted by sdrucker View Post
Not 100% scientific (in a perfect world, I'd have someone play the clips rather than me, picking the randomly), but my ears must be OK. Oh, and I'm 51 .
I can confirm that my ears are OK too (listening on the 2.1 system hooked up to my Mac). And I am even older than you!
Given that JND is 1dB or even less, this comes as no great surprise to me.
post #71571 of 79637 Old 06-23-2014, 11:09 AM
beastaudio's Avatar
Quoted: 4158 Post(s)
Liked: 3515
And then there are the ones who massively "google" any subject they pick up on threads looking for a lot of evidence, yet never bother to do their own simple homemade tests. Forum life, indeed. Gotta live with it.
Google is a pretty fantastic place to find industry white papers, proven research by audio engineers that don't compare phase changes in their speakers to a microwave oven's.
beastaudio is offline
post #71572 of 79637 Old 06-23-2014, 11:29 AM
mogorf's Avatar
Liked: 723
Right. And then its vise versa. Microwave oven design engineers don't compare phase changes in their ovens to speakers. But they both studied the basics when they entered college or university. Volts, amperes, resistance, capacitance, inductance, amplitude, frequency, phase, etc., and when done they move on with their studies to their specialized fields. Some become engineers in electro-acoustics, others in video techniques, even others in house-hold appliances, telephony, computers, just to name a few. All these fields share the same basics, but used specifically in each of the above fields.
Hope this helps.
post #71573 of 79637 Old 06-23-2014, 11:49 AM
kbarnes701's Avatar
Liked: 5262
LOL. I tried listening to my microwave oven and I definitely can’t hear any phase-related issues with it. It is inside a fixed cabinet though so I couldn't even begin to optimise it using placement. Mind you, it doesn't have Audyssey so it could be a load of old junk. I wonder if dual ovens would sound better? I understand they are harder to set up though, but I'm sure there are plenty of people on the Internet who could advise me.
ambesolman and beastaudio like this.
post #71574 of 79637 Old 06-23-2014, 01:05 PM
jlpowell84's Avatar
Liked: 915
You know what, I will have my wife play them at random and I will do repeated tests! Like play at least each one 5 times. On my HT speakers, JTR Triple 8's, I could easily hear the differences. But the blind will prove even better!
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #71575 of 79637 Old 06-23-2014, 01:10 PM
mogorf's Avatar
Liked: 723
The moment you tell her there are differences among the 4 files she will be biased. So, pssst!
post #71576 of 79637 Old 06-23-2014, 01:43 PM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
I haven't listened to the test tones yet, but wanted to comment on using our laptops for listening. They just don't play bass. when I go here http://www.seventhstring.com/tuningfork/tuningfork.html and push the waveform slider all the way to the left (a pure sine wave) the C below middle C, at about 130 Hz is so close to inaudible as to be effectively inaudible. If I put a little sawtooth wave in, I can hear all the way down to the next octave, at about 65 Hz, easily. but I am hearing zero 65 Hz tone, my brain is interpolating the fundamental from the harmonics present in the sawtooth wave. Certainly I am rolling off in the lows from middle C at about 260 Hz down to the inaudible, or nearly so, C one octave down. Whatever I perceive as different between samples on my laptop HAS to be happening above 130 Hz . . . likely well above . . . I'd wager that no laptop really reproduces anything significantly below 100 Hz, so you miss the bottom two plus octaves entirely.
JHAz is offline
post #71577 of 79637 Old 06-23-2014, 02:38 PM
sdrucker's Avatar
Quoted: 888 Post(s)
Liked: 600
You're more sensitive to specific Hz than I am. A good skill to have to really tune your system, based on specific common notes .
Having said that, there are IMO detectable "bass" differences on the clips. At least with the JBL laptop speakers, it was muddy bass; but we never said that the bass was "good bass"...
Audio Gear: Trinnov Altitude 32 (24 channel), NAD M27 amps (3)
Video: JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4444 (coming soon)
Misc.: Oppo 103, Oppo 203 UHD player, JRiver
Speakers: PSB Imagine T3 LCR, Imagine T Wides and Side Surround 1, T2 Side Surrounds, Imagine XB rears, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 11.4.6
post #71578 of 79637 Old 06-23-2014, 02:52 PM
kbarnes701's Avatar
Liked: 5262
FAQ ADDENDUM UPDATE!
The FAQ Addendum has now been updated to comply with the requirements of vBulletin software and is fully operational once again, with all links and graphics intact.
Thanks to Mike Lang, the AVS/vBulletin Dev Team and VerticalScope for being so responsive to our requirements.
The Addendum can be seen here:
post #71579 of 79637 Old 06-23-2014, 05:13 PM
primetimeguy's Avatar
Quoted: 623 Post(s)
Liked: 376
Post
Here you go..
I gave it a quick couple minutes on just my PC speakers. Didn't bother with main system since differences are pretty obvious between at least a couple tracks.
43 = boosted bass, rolled off highs
79 = reduced bass, boosted highs
org = original (assumption)
27 = the other one :-)
But yes, some bias in the test since I knew going in there was differences. Track 27 I'm not sure I would have said was different. I think I here it is there but would need to test on main system rather than PC to verify. But as mentioned, test is already biased. :-)
primetimeguy is online now
post #71580 of 79637 Old 06-23-2014, 06:05 PM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
Only use sine waves for speakers !!! Why would anyone use a sawtooth wave, it maybe very harmful .
Closed Thread Receivers, Amps, and Processors
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
