"Official" Audyssey thread (FAQ in post #51779) - Page 2387 - AVS Forum | Home Theater Discussions And Reviews
 3468Likes
post #71581 of 79637 Old 06-23-2014, 07:08 PM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
Originally Posted by joehonest View Post
Only use sine waves for speakers !!! Why would anyone use a sawtooth wave, it maybe very harmful .
Won't be harmful, unless you try to saw with it!
mogorf is offline
post #71582 of 79637 Old 06-24-2014, 01:25 PM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5069
FAQ UPDATE!
I have finished editing the last bunch of links to other parts of the AVS site and have now tested every FAQ link and all are working properly. This now completes the work on updating the Audyssey FAQ following the changeover to vBulletin forum software.
This means that the FAQ, the '101' and the Technical Addendum are now all fully functional again. The work on the Audyssey Pro Kit FAQ will be completed asap.
rickardl likes this.
kbarnes701 is offline
post #71583 of 79637 Old 06-24-2014, 06:09 PM
RapalloAV's Avatar
Quoted: 1299 Post(s)
Liked: 292
Does anyone know if DEQ affects the dialog when playing 5 db less than ref?
I find with DEQ engaged the speech seems deeper with my THX Klipsch horn tweeters, I prefer the speech with it on.
When I turn off DEQ the speech does seem a lot brighter, I didn't think DEQ affected that range of audio...
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is online now
post #71584 of 79637 Old 06-24-2014, 08:36 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Horse crap. Don't play cellos or anything with a moog synth. Seriously. Get a grip
Gary J likes this.
JHAz is offline
post #71585 of 79637 Old 06-24-2014, 10:03 PM
woody777's Avatar
Quoted: 17 Post(s)
What could possibly cause a -4.0 subwoofer level one day and a -8.0 the next? I preformed the Audyssey setup procedure the same each time and didn't change anything with my equipment. Any ideas?
woody777 is offline
post #71586 of 79637 Old 06-25-2014, 07:58 AM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
Have you moved anything in the room? Have a door or something open that was previously closed during calibration? Anything like fridges, clothes washers or dryers, etc running in the background? Live near a highway or airport? All things that could contribute differences. Heck, even the garbage truck lumbering by could cause an anomaly.
beastaudio is offline
post #71587 of 79637 Old 06-25-2014, 08:04 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
Slightly different mic positions. Ambient noise is only a problem if you get an error message to that effect.
Gary J is offline
post #71588 of 79637 Old 06-25-2014, 08:09 AM
mogorf's Avatar
Liked: 613
Another tip can be a slight mis-adjustment of the gain knob on the sub, even by accident like during cleanup or dusting (by non-qualified personnel, LOL). Some put a piece of Scotch tape on the gain knob to prevent such mis-haps.
mogorf is offline
post #71589 of 79637 Old 06-25-2014, 10:33 AM
Alan P's Avatar
Quoted: 4695 Post(s)
Liked: 3321
Yes, DEQ is doing it's thing unless you are at 0db MV (with "0" RLO). However, DEQ only boosts the subs and surrounds when you are below reference.
What you are hearing is the dialogue content in your subwoofer channel. You are either running a pretty high crossover, your subs are running fairly hot or the dialogue you are listening to has some pretty low content. If so, this is completely normal.
Alan P is online now
post #71590 of 79637 Old 06-25-2014, 10:43 AM
primetimeguy's Avatar
Quoted: 556 Post(s)
Liked: 359
Dyn EQ boosts ALL bass, not just in the subs, but all channels. If you look at charts it can start as high as 300hz. Granted it is minimal at that point and depends on volume level. But you probably can hear the difference with male voices for sure.
Alan P likes this.
primetimeguy is offline
post #71591 of 79637 Old 06-25-2014, 10:56 AM
Alan P's Avatar
Liked: 3321
Thanks for that primetimeguy, I stand corrected!
post #71592 of 79637 Old 06-25-2014, 12:12 PM
woody777's Avatar
Quoted: 17 Post(s)
I didn't move anything in the room and it's an open living room, so no doors. And the sub's control panel is not accessible.
I tried to put the mics as close as possible each time. Every other level was identical except the subwoofer.
Thanks guys... Any other ideas?
woody777 is offline
post #71593 of 79637 Old 06-25-2014, 12:28 PM
mogorf's Avatar
Liked: 613
No pets? No toddlers? No Lego inside the sub?
mogorf is offline
post #71594 of 79637 Old 06-25-2014, 12:46 PM
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Are you sure you mean brighter with DEQ off? It will boost higher frequenices with DEQ enabled, see graph,
so I find it strange it should be brighter when disabled at -5.
Or do you mean that it is brighter with both DEQ+MultEQ off vs DEQ On?
Also, the bass boost can start as high as 600hz.
rickardl is offline
post #71595 of 79637 Old 06-25-2014, 12:50 PM
Quoted: 556 Post(s)
Liked: 359
Thanks for tracking down that chart, I was lazy. :-)
The lack of bass will bring out the high freq an it will sound less full so my guess is that is what he means with brighter with DEQ off. Often times it can be hard to tell if one end of the spectrum is boosted or the other reduced.
post #71596 of 79637 Old 06-25-2014, 01:04 PM
chadwick537's Avatar
Has anybody done measurement sweeps of the various DEQ levels on surrounds? Just curious to see what sort of boost they receive..
My laptop only supports 2 channels on REW, so I can't test it.
chadwick537 is offline
post #71597 of 79637 Old 06-25-2014, 01:30 PM
woody777's Avatar
Quoted: 17 Post(s)
Haha pets were in the garage both times and the kids weren't home! Didn't check for Legos though.
woody777 is offline
post #71598 of 79637 Old 06-25-2014, 01:49 PM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
Was there a recent change with Audyssey to allow the use of Dynamic Volume without engaging Dynamic EQ, or was this specific to Denon (and maybe Marantz)?
I recently bought a Denon X2000 and noticed I can turn on Dynamic Volume independetly of Dynamic EQ (which is good, because I don't like Dynamic EQ)...
I was not able to do this on any other receivers I've owned that had Audyssey: Denon 991, Denon 1910, Marantz 6005, Marantz 1402. For those, if Dynamic EQ was turned off, Dynamic Volume was automatically off as well.
Anyone know at what point this change happened, and whether it's an Audyssey change or a change with the implementation in Denon (and Marantz?) receivers?
alphaiii is offline
post #71599 of 79637 Old 06-25-2014, 02:06 PM
Napoleon D's Avatar
If Audyssey detects on any of these it will try to create correction filters for them and this will clearly adversely affect your results. Remember, just because you can't hear the noise doesn't mean that Audyssey can't. If Audyssey detects the noise level is too high, it will raise the level of the chirps and try again. It will do this three times before giving up and displaying the error message. So long as the error message is not displayed, Audyssey will cope with the ambient noise level and deliver a good calibration.
If you get the error message and you have ensured that everything is turned off, you might want to try the calibration later at night when external noise is usually much lower. If you still get the error message despite that, then there is a chance that you have a fault. Often the mic may be faulty or have become damaged. Mics can be damaged by static electricity for example. If this is the case, you will need to obtain the correct replacement for your mic and then try again. If your unit has a factory reset procedure, it may be worth trying that before you blame the mic.
It is worth noting that you do not need to be paranoid about background noise levels. Chris Kyriakakis has stated (Ask Audyssey 14 July 2012) "If you are not getting a noise error then the data collected is perfectly fine." In other words, the calibration is not somehow 'improved' by having a very quiet background noise level. Just keep the noise levels as low as you can when calibrating."
My question is, will you get the same calibration results if there are a few sudden noises (car horn etc) as you would with absolute silence?
To me, parts of these paragraphs contradict themselves as written. It says, "if you are not getting a noise error message then the data is perfectly fine." Then in the first paragraph it states, "If Audyssey detects on any of these it will try to create correction filters for them and this will clearly adversely affect your results."
Why would it create correction filters if the system is designed to re-chirp faulty sessions or show an error message if there is ambient noise present - thus, repeating the process until it goes through.
"The reason we take 10 chirps per speaker is to overcome the effects of transient noise. They will be averaged out if they only happened during one of the chirps."
If the chirps are averaged out, does this mean that 7 clean chirps are averaged out against 3 poor chirp-readings?
"the calibration is not somehow 'improved' by having a very quiet background noise level."
If the 10 chirps are averaged out, then wouldn't it be better to have 10 chirps in silence?
I am just trying to get a consistency about this, as getting a quiet environment is the biggest challenge of Audyssey.
Thanks guys!
Napoleon D is offline
post #71600 of 79637 Old 06-25-2014, 02:11 PM
RapalloAV's Avatar
Liked: 292
Ok then obviously DEQ doesn't affect the front 3 channels at all if its only tied to the subs and surrounds. All my crossovers are set to 80Hz and my subs are not run hot, they are left at the same 75db I first set them to.
It must then be my imagination the fronts sound warmer with DEQ engaged. I run 5db less than ref.
Murray Thompson
X Owner RapalloAV
post #71601 of 79637 Old 06-25-2014, 02:18 PM
RapalloAV's Avatar
Liked: 292
Yes precisely that's what I mean. When I don't have DEQ engaged the speech seems much brighter, I don't like it with my Klipsch fronts.
Murray Thompson
X Owner RapalloAV
post #71602 of 79637 Old 06-25-2014, 02:35 PM
Quoted: 556 Post(s)
Liked: 359
That's not correct. I responded to Allan P's post and he acknowledged the correction.
post #71603 of 79637 Old 06-25-2014, 04:07 PM
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
It's not an audyssey change, it's a D&M change. I think it happened a couple of years ago but not sure exactly when (it was never announced or documented), and AFAICT it's only possible using the web interface.
Different manufacturers implement things differently. Like Onkyo I think now allowing DEQ without MultEQ engaged! Or scrapping the polarity check during calibration, or doing SubEQ wrong (measuring the subs independently instead of summed) on the first iteration.
Audyssey is not happy about as using each of their techs without "layering" as intended isn't how they are designed.
batpig is online now
post #71604 of 79637 Old 06-25-2014, 04:57 PM
RapalloAV's Avatar
Liked: 292
What AVR brand uses Audyssey correctly as it was intended?
Do any set up the subs spliced properly with the mains?
Murray Thompson
X Owner RapalloAV
post #71605 of 79637 Old 06-25-2014, 06:19 PM
batpig's Avatar
Liked: 3415
Well, any brand using Audyssey can be set up as "intended" whether or not the manufacturer allows some things that Audyssey would prefer they hadn't. Run MultEQ using all positions, afterwards set all speakers to "small", choose the Audyssey Reference target curve, and turn on Dynamic EQ. That is Audyssey "as intended".
These days, since Onkyo has abandoned Audyssey, it's pretty safe to say that D&M has the closest relationship and is most dedicated to Audyssey technologies.
AFAIK, there is no receiver that measures the speakers+subwoofer splice as part of Audyssey, although the Pro Kit has some additional filtering calculated depending on the crossover that is loaded.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
post #71606 of 79637 Old 06-25-2014, 06:42 PM
RapalloAV's Avatar
Liked: 292
Exclamation
Maybe I should have rephrased that....
I meant to say does any brand use Audyssey as intended by Audyssey, without manual intervention to make it right?
Since we only have D&M using it now, maybe its time for Audyssey to bring out a super new version to replace XT32. Maybe then they would have something brilliant to entice the others on-board.
Murray Thompson
X Owner RapalloAV
post #71607 of 79637 Old 06-25-2014, 06:51 PM
batpig's Avatar
Liked: 3415
Was anything I described (other than potentially having to adjust bass management) involve "manual intervention to make it right"? No receiver has given bass management over to Audyssey (only the Pro Kit suggests crossovers and loads them to the AVR as part of calibration) so that's sort of a moot point. The rest of it is basically out of box functionality. If I go and buy a Denon receiver, take it home, and run Audyssey, after I'm done I will get what I described -- MultEQ active on the Audyssey Reference target curve, with Dynamic EQ enabled.
Setup Guide and FAQ
post #71608 of 79637 Old 06-25-2014, 07:04 PM
RapalloAV's Avatar
Liked: 292
there is no receiver that measures the speakers+subwoofer splice as part of Audyssey,.
Did Audyssey ever intend this to be or not?
Murray Thompson
X Owner RapalloAV
post #71609 of 79637 Old 06-25-2014, 07:45 PM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
No web interface needed... at least with the X1000 and X2000.
alphaiii is offline
post #71610 of 79637 Old 06-25-2014, 07:52 PM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
I get that Audyssey intended for Dynamic EQ to be used... but I have never liked it... I've always thought the bass sounded exaggerated, especially at lower volumes where more EQ is being applied (and yes I've tried the various reference level offsets)... and I didn't find this was limited to the sub, but also effected the upper bass in the mains and center, most notably adding too much body (and sometimes boom) to voices.
I certainly happy D&M have made it possible to turn it off completely and still use Dynamic Volume for late night viewing.
alphaiii is offline
Closed Thread Receivers, Amps, and Processors
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
