"Official" Audyssey thread (FAQ in post #51779) - Page 2388 - AVS Forum | Home Theater Discussions And Reviews
 3470Likes
post #71611 of 79637 Old 06-25-2014, 08:02 PM
pbarach's Avatar
Quoted: 318 Post(s)
Liked: 193
Originally Posted by alphaiii View Post
No web interface needed... at least with the X1000 and X2000.
On the x4000, if Dyn EQ and Dyn Vol are off, turning on Dyn Vol will also turn on Dyn EQ. However, at that point you can turn off Dyn EQ and Dyn Vol will remain on. This is with the remote.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #71612 of 79637 Old 06-25-2014, 08:12 PM
LGTWHIT's Avatar
I agree Alpha. I recently moved my Yamaha to my newly finished basement and never had any unnecessary or "exaggerated" bass with the YPAO calibration. I love everything about Audyssey except for the bass. At lower normal viewing volumes there's always this overwhelming background bass that I feel shouldn't be there especially with a deeper voice or a background sound. My YPAO never had an issue with this. I've even turned the gain down to 35% and it's still noticeable. I guess its time to learn manual calibration, here we go...
LGTWHIT is offline
post #71613 of 79637 Old 06-25-2014, 08:17 PM
primetimeguy's Avatar
Quoted: 556 Post(s)
Liked: 359
Or simply turn off DynEQ
primetimeguy is online now
post #71614 of 79637 Old 06-25-2014, 08:33 PM
LGTWHIT's Avatar
Whoa, much better! Still learning
LGTWHIT is offline
post #71615 of 79637 Old 06-25-2014, 08:41 PM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
Yep, works the same on the X1000 and X2000... and it's not described in the manual that it can be done this way, I just did it by accident when I was setting up the X1000... definitely a pleasant surprise...
On every other Denon or Marantz receiver I've owned, turning off Dynamic EQ turned off Dynamic Volume as well....
I still wish these companies would add Dolby Volume... but I think that ship has sailed... I don't even think Harman and Onkyo are using it anymore. Shame, since the consensus was that it worked better than Dynamic EQ/Dynamic Volume... but I guess the licensing fees weren't minor.
alphaiii is offline
post #71616 of 79637 Old 06-25-2014, 11:43 PM
Napoleon D's Avatar
I have been using Dynamic EQ for 4+ years. When I first heard it, I thought the bass was over inflated, there is no way i can do this (in an apartment) without the fire department here in an hour. I subsequently got a subdude for my subwoofer, along with about a foot of padding underneath it. I calibrate these days and am religious about using Dynamic EQ and I can feel my bass literally just trying to grab the floor to hit that deep bass hitting that minimal level where it's reaching the point it should be in order to satisfy senses but not shake the room - as it would sound in a dead room. Know what I mean? I have used Dynamic EQ for a few years now without a single neighbor complaint, and i was getting them previously before i modified my subwoofer setup (even without Dynamic EQ engaged).
Bass is now more like a strong pinch instead of an explosion. I can feel the audio creating that tight "barriered" soundfield around me where it's loud as hell, but not a single rogue reflection or sound-wave sneaks through to fatigue my ears - if that makes any sense. My only problem in fact is that the sound gets so flat that it's a bit boring, and i think it's because the calibration is taming the heck out of the exciting yet reflective trebles. I can get up to -10dbs and it still does not sound "loud" to my ears (depending on the blu-ray). Anything above that though pushes it.
I'm trying to hit that happy medium where the sound is bright enough but still has that bubble big enough to save me from ear fatigue. Is that understood at all?
But if someone can still answer my questions about Audyssey and ambient noise. Things would be much more peaceful if i felt that i didn't have to control the universe of sound completely during a calibration.
Thanks all. After 10 years on here, I have gotten very far!
Napoleon D is offline
post #71617 of 79637 Old 06-26-2014, 02:54 AM
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Here are some further quotes by Chris about ambient noise and especially the last one about "short impulsive noises":
Originally Posted by Chris K
If there is too much ambient noise, Audyssey raises the chirp level to get a good signal to noise ratio.
If you don't get an ambient noise too high error then that means the measurements were above the required signal to noise ratio and the room correction filters are fine.
We have set a threshold for the noise below which it doesn't audibly affect the measurements (and therefore the filters). If you don't get the "ambient noise too high" error message then the noise is not high enough to affect the measurements.
Also, the repeated chirps for each speaker increase the signal to noise ratio and that helps with short impulsive noise.
If the noise affected the measurements you would know. MultEQ would raise the level of the chirps and then report an ambient noise error message for some types of noise. Or your distance measurements would not be accurate if there was noise corruption. If none of that happened then the data you got is good and you don't need to worry about it.
The test signal repeats louder if MultEQ found that there is a high level of room noise that is affecting the measurements. This happens if there is any device that makes noise nearby. For example a fridge, a heater fan, a computer fan, a projector, etc. Also, if there is electrical hum in your system (e.g. from the cable system) this could cause this problem.
If you make noise during the silence period then MultEQ will pick it up and repeat the chirps at a higher level. If it doesn't do that then you are fine.
Each channel plays 10 chirps at a given level. Repeating chirps at one level improves the signal to noise ratio for that measurement and guards against short impulsive noises that might corrupt one or two chirps.
If the background noise is steady and above the "approved" limits, then MultEQ repeats the 10 chirps at a higher level. It constantly checks to make sure that the signal to noise ratio of the data is above what it needs to be to get good readings.
So, yes, if your calculation has completed without a noise error message your measurements are fine.
That said, to be sure I get well above the noise floor, I raise the digital gain (with 10dB) on my sub to 85dB instead of 75dB pre-Audyssey. Afterwards, I raise the receivers trim from -10 to 0 and decrease the digital gain on the sub with 10dB. That is one of my personal "tweaks".
rickardl is offline
post #71618 of 79637 Old 06-26-2014, 03:55 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5071
My question is, will you get the same calibration results if there are a few sudden noises (car horn etc) as you would with absolute silence?
Thanks guys!
Yes. See this FAQ answer:
b)2. Why is Audyssey reporting 'Ambient Noise Too High'?
If you don't get a warning you are good to go.
kbarnes701 is offline
post #71619 of 79637 Old 06-26-2014, 03:58 AM
kbarnes701's Avatar
Liked: 5071
I
You don't. Read the FAQ answer - if you don't get an ambient noise warning then you are good to go.
post #71620 of 79637 Old 06-26-2014, 09:17 AM
Napoleon D's Avatar
Thanks all for the responses.
post #71621 of 79637 Old 06-26-2014, 09:20 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
Any one compare the multieqXT to the MCACC from pioneer? Im having a hard time trying to decide between the x2000 and a pioneer sc-71 recievers. They both offer the same features. pioneer has a slightly warmer cleaner sound but both sound good. The Denons less money, I just worry the room correction will suck on the Pioneer. My Yamahas Yapo did an ok job but I had to tweek it. From what I understand the denons is either on or off, there is no middle ground to modify the settings.
lemonslush is offline
post #71622 of 79637 Old 06-26-2014, 09:37 AM
kbarnes701's Avatar
Liked: 5071
This (Russian) site has a comprehensive test of XT32 vs MCACC vs YPAO, with graphs etc. XT32 comprehensively beats MCACC. Of course XT is not XT32 by any means so the comparison is unfair, and MCACC has recently been updated I believe. But the test will give you a good idea of what is involved. Use google translate - it makes a reasonable job of it, in pidgin English.
lemonslush likes this.
post #71623 of 79637 Old 06-26-2014, 09:55 AM
fitzcaraldo215's Avatar
Quoted: 38 Post(s)
Liked: 42
That might be true, and it generally might be good enough in the overall scheme of things. But, ambient noise cannot possibly make the calibration better. It is still a good idea to minimize any you can hear yourself, and that cannot possibly hurt. So, winter or summer, I always turn my HVAC off during the calibration, as well as trying to eliminate other noises. I do not want it cycling on or off during the calibration. Even if a sudden unexpected intermittent noise - dog bark, car horn, airplane, telephone, etc. - occurs during a tone sweep, I would rather repeat that one mike position sweep than risk an inferior calibration result.
Call me obsessive, but I have heard anecdotal reports of issues, one from noted equipment reviewer Tony Cordesman. I was once in the middle of an hour long Pro calibration and there was a sudden downpour outside. The room was right beneath the roof, so it could be heard as a steady noise. I continued anyway with no warnings from Audyssey. But, the resulting calibration was poor, and a complete redo in better weather provided a much better result. Perhaps it was something other than the noise of the rain, but my calibration habits now are to eliminate external noise - steady or intermittent - as much as possible. It does not take long and there is no way it can make things worse.
fitzcaraldo215 is offline
post #71624 of 79637 Old 06-26-2014, 10:07 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
Can you point out where that was said?
Gary J is offline
post #71625 of 79637 Old 06-26-2014, 10:21 AM
kbarnes701's Avatar
Liked: 5071
I agree. And the FAQ answer does say to turn things off where possible and to measure in a quiet room because, as you rightly say, it can do no harm. But Audyssey is adamant that the system will raise the level of the chirps three times to combat external noise and that unless you get a warning the calibration is good. Audyssey also is adamant that one-off loud noises such as a dog barking during a sweep isn’t a problem either because it will be recognised as anomalous. But yes, we agree - get the room as quiet as possible to start with.
post #71626 of 79637 Old 06-26-2014, 10:29 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
Does the EQ on the x2000 eq the sub? Or is that just the xt32?
post #71627 of 79637 Old 06-26-2014, 10:37 AM
kbarnes701's Avatar
Liked: 5071
XT EQs the sub too. See this FAQ answer for the differences between the different flavours of Audyssey:
h)2. What is the difference between the various versions of MultEQ?
post #71628 of 79637 Old 06-26-2014, 10:55 AM
Quoted: 38 Post(s)
Liked: 42
Well, I may have been the first one to have said it quite that way. As Keith points out in the FAQ, external noises should be eliminated as much as possible. Chris has said the same. But, I would hope there is no debate on the logic of what I said. Are you suggesting more ambient noise can make the calibration better? Do you need an expert opinion to prove what I said?
I admitted I might take ambient noise elimination to a more than necessary degree. But, what exactly is the necessary degree to eliminate the ambient noise? You can reactively wait to see if Audyssey tells you there is too much noise, assuming it knows with full accuracy where to draw the line. Or, you can proactively eliminate noise sources before the calibration. What could be the possible harm in eliminating even more noise than Audyssey needs to do its thing? Answer: no possible harm, not on this planet.
post #71629 of 79637 Old 06-26-2014, 11:00 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
Got it.
Gary J is offline
post #71630 of 79637 Old 06-26-2014, 02:31 PM
kbarnes701's Avatar
Liked: 5071
Nobody could reasonably disagree with your position in this, Fitz.
post #71631 of 79637 Old 06-26-2014, 03:39 PM
woody777's Avatar
Quoted: 17 Post(s)
Originally Posted by woody777 View Post
What could possibly cause a -4.0 subwoofer level one day and a -8.0 the next? I preformed the Audyssey setup procedure the same each time and didn't change anything with my equipment. Any ideas?
I solved my own problem... And you guys even already have it covered in the FAQs! Nicely done!
The difference is in the auto on/off feature of my subwoofer. When the sub is off and there is a slight delay in the initial chirps because it has to be woken up, the result is -4.0 in Audyssey. But when the sub is already on and there is no delay in the initial chirps, the result is -8.0 in Audyssey.
I can't really compare the two different results side by side, but I think I like the -4.0 results much better than the -8.0 results - even if I raise the subwoofer trim to -4.0 in my AVR. What else is Audyssey doing?
woody777 is offline
post #71632 of 79637 Old 06-26-2014, 04:10 PM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
Good to hear your news woody, congrats!
Meantime, please allow me some further thoughts:
1. I never use auto wake-up on my sub due to reasons you have already described (its set to "off"). Moreover, I don't want my sub to "wake-up" but I like it being "woken up" and "ready-to-go" all time.
2. -8 dB trim on the sub seems to me to be a good option. You may consider to leave it "as is" for movies as that has been set up by Audyssey for film "reference level", yet you have a massive "allowance" from -8 dB to +12 dB (a range of 20 dB) when it comes to listening to music with bass sometimes being nowhere but ready to be boosted to taste.
3. Audyssey is doing a lot else. DynEQ compensates for ear characteristics, DynVolume is good for late night movie watching and to tame loud commercials, Audyssey LFC is there to tease neighbors when it comes to bass traveling through adjacent walls, and Audyssey DSX is there for you to discover.
mogorf is offline
post #71633 of 79637 Old 06-26-2014, 11:54 PM
woody777's Avatar
Quoted: 17 Post(s)
Thanks! I appreciate the response!
woody777 is offline
post #71634 of 79637 Old 06-27-2014, 10:47 AM
woody777's Avatar
Quoted: 17 Post(s)
One last question...
I know a lot of people like to raise the center channel slightly (especially if they raise the subwoofer), but Audyssey is actually lowering my center channel by -2db. Audyssey set the center channel at +3db according to the parameter check menu, but in the channel level menu the center channel is set at +1db. The only settings I changed post Audyssey is large to small and all crossovers raised to 80. Any idea why this would happen?
woody777 is offline
post #71635 of 79637 Old 06-27-2014, 07:19 PM
William Moore's Avatar
I have had some similar problems since "re-running" Audyssey again to re-balance my left surround channel which was about 3-4 db low prior to recalibrating. (It's restored now) Here is what is confusing me: when I check the "Audyssey parameters" I find that my front L & R speakers are listed as "full band" and in the "configuration" menu they are set to Large, while in the "Manual" set-up menu, my front L &R speakers are set to small with an xover of 80hz, which is what I changed them to following my last calibration. Other than this, the center is small with a 90hz xover and the surrounds are small with 110 hz xovers in both manual set-up and Audyssey. So what is going on here? Which settings do I trust? Shouldn't they be the same? My Velodyne sub now shows a -3.5db setting, which I'm told is acceptable, but the bass seems to be a little boomy. I changed the "LPF fpr LFE" to 80 hz. Will this help? And, if not, just increase the negative db vol setting from -3.5 to maybe -4.0? Also, I have always felt that the surround levels as set by Audyssey are too high. What is the best way to deal with this? Just manually reduce the levels on the surrounds by a few db? And, will this adversely affect the overall calibration? BTW, my receiver is a Marantz SR7007. Thanks!
William Moore is offline
post #71636 of 79637 Old 06-27-2014, 07:23 PM
Oopps! I forgot one question. Should I turn off Dynamic EQ? My Dynamic Volume has always been off, since I don't need it. Thanks again!
post #71637 of 79637 Old 06-28-2014, 12:56 AM
tommaazz's Avatar
Quoted: 224 Post(s)
Liked: 127
Wink
Hi. Leave LPF/LFE at 120 hz and raise the sub trim to 0, and of course turn dynEQ OFF and try how it sounds . I have dynEQ disabled and a +6 db boost to my subs and it sound very good no boomines at all...if i listen at around -20 and lower (quieter) then i enable dynEQ but with -10db offset as i dont like the boosted surronds that dynEQ applies without offset. Try it with some scenes and report back. Good luck
I have a marantz sr7008 and if you chek under speakers (manual) menu this is are the right settings. Put all speakers as small and do not lower the crossover settings that audyssey sets (you can put it higer if you wish but do not put it lower). If you have checked the speakers under audyssey menu then this are the setting that audyssey set/found them (they are just for your reference if you change something and then you cant remember how audyssey sets it). Hope this helps.
tommaazz is offline
post #71638 of 79637 Old 06-28-2014, 07:27 AM
mthomas47's Avatar
Quoted: 2454 Post(s)
Liked: 3054
I also have a 7008, and the only thing that I would add to William Moore's answer is that the last time I ran Audyssey, I noticed that when I went into Manual, my crossovers had already defaulted to (or simply remained at) my previous settings for them. The current calibration settings are the ones to trust and then reset manually from there. If you change anything in the room, or even vary microphone positions a little between runs (which is highly likely), your recommended crossover points may also change. Nothing had changed in terms of recommended crossovers in my case, and I had assumed that was the reason that they defaulted to my previous settings. But your experience seems to indicate otherwise, so be sure to double-check and then rely on your latest calibration results for any manual resetting. This may just be an idiosyncrasy of Marantz receivers, but it is definitely something to be aware of.
mthomas47 is online now
post #71639 of 79637 Old 06-28-2014, 12:23 PM
If I raise the sub trim to "0", won't this make the sub even louder than it is now? And what is the "offset" you speak of? Also, if Audyssey sets my front L&R speakers to "Full Range" and I change them to "Small" in the manual set-up, what is the crossover point for these 2 speakers?
post #71640 of 79637 Old 06-28-2014, 02:01 PM
mthomas47's Avatar
Liked: 3054
Your -3.5db setting for the sub should be fine from a calibration standpoint, but you can adjust it either up or down to taste. And yes, adding more sub volume would probably exacerbate the problem you are perceiving. The "boomy" quality you mention combined with your feeling that the surrounds are too loud could perhaps be attributed to DynEQ. I think you said you had been leaving it on and that was when an offset was suggested. The offset feature is right under DynEQ in your menu. Try various offset settings, and if you like, try DynEQ "Off" to find out what works best in your room and for your preferences. Finally, if you want to set your speakers to "Small" go with the recommended crossover of 80 (I believe you said that hasn't changed). You can always experiment with raising them, but not lowering, if you want to. The FAQ has a lot of useful information about all of this (including the reference level offset) if you get a chance to do some reading.
Closed Thread Receivers, Amps, and Processors
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
