"Official" Audyssey thread (FAQ in post #51779) - Page 2399 - AVS Forum | Home Theater Discussions And Reviews
 3470Likes
post #71941 of 79637 Old 08-10-2014, 03:20 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5071
Originally Posted by mgrotel View Post
Hi guys, couple quick questions for you.
I got new Klipsch tower Icons (KF-28s and KC-25 center) for my front stage (LCR) replacing the AJ pioneers, so much more efficient speakers. When I ran Audyssey Multi XT it set the front towers to large. I got the KF-28s so dual 8" woofers. I also have dual RW-12d subs so my first questions is:
1. Should I leave the front towers to large, or change to small and set to 80hz x-over?
2. If I set them to small and 80hz crossover, will that mess up how they integrate with the subs? since I am changing what Audyessy multi XT set?
3. Since the Klipsch are so much more efficient, Audyessy set them to about -6.0 dB all across the front. For music listening, can I just turn Audyessy off in the settings and then turn it back of for movie watching and all setting will remain? Or what is the best way to get that gain back on the front stage for music listening?
This is covered pretty fully in the FAQ:
c)3. I have big tower speakers at the front. Shouldn't I set these to Large'?
c)2. Why do I often see advice to raise the Crossovers to 80Hz?
You can turn Audyssey on and off at will without losing any settings.
kbarnes701 is offline
post #71942 of 79637 Old 08-10-2014, 03:44 AM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Awesome, thank you. I read those FAQs a while back but did not remember that. Thanks so much.
mgrotel is offline
post #71943 of 79637 Old 08-10-2014, 04:28 AM
kbarnes701's Avatar
Liked: 5071
You are very welcome! Enjoy!
post #71944 of 79637 Old 08-10-2014, 09:54 AM
mthomas47's Avatar
Quoted: 2486 Post(s)
Liked: 3089
Thanks so much.
I have one additional comment on recapturing gain and whether to turn Audyssey off for music. You should surely experiment, but in general, Audyssey will be very helpful for both movies and music. If I understand your gain question, the -6db settings across the front are fine. If you want more total volume, just use your master volume control. If you want more volume just from the front three, you have several options including increasing the individual levels post Audyssey (won't affect your calibration, but will affect the implementation of DEQ, so check the FAQ on that one); or better, experiment with something like the Dimension control in PLII. Most of the surround modes offer some method of concentrating sound more to the front or rear.
I am guessing that you were just thinking that the -6db is too low, which it isn't, but if there is something specific to the front that you hear and want to tweak, there are a number of ways to do it without interfering with your Audyssey calibration. Bottom line: if you have a good calibration, you shouldn't need to turn off Audyssey.
mthomas47 is online now
post #71945 of 79637 Old 08-10-2014, 04:44 PM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Thanks for the additional information. I previously had the Pioneer AJ series LCR, but when I wanted to blast the music sometimes, I listen loud, the amp would get so hot it turned itself off one time. I have a Denon 2112 with 90W per channel. I attributed this to the low sensitivity of the pioneers (87 or so) and the 6ohm rating. So now I have the Klipsch Icons, which are rated at 98 for sensitivity. When Audyssey lowers my front stage by 6 dBs, this sort of negates the higher volume I wanted to achieve with the more efficient speakers.
So, what I have found works is, for loud music listening, I can use "stereo" or "multi channel stereo" modes and it seems to give me back that 6dBs from the front stage. Then switch back to PL II when I put a bluray in. Your comment did prompt a couple questions from me though.
You said this: "increasing the individual levels post Audyssey (won't affect your calibration, but will affect the implementation of DEQ..."
What is DEQ and where can I set the levels without it affecting my calibration? After I run the calibration, the individual speaker levels I am changing are adjusting the levels on the calibration as far as I know.
And what is this? "Dimension control in PLII"
mgrotel is offline
post #71946 of 79637 Old 08-10-2014, 05:13 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3546
Dynamic EQ; to listen late @ night without disturbing the babies and the lady.
The channel levels can be individually/manually adjusted from your remote control, and the level of DEQ can be adjusted from the audio setup menu. ...Medium is generally the accepted level.
Dimension Control for PLII is simply the level of dimension you like in your room; simply experiment with it and set it where you're happy.
EDIT: I meant Dynamic Volume. Sorry, after all those years I still get confused sometimes.
NorthSky is offline
post #71947 of 79637 Old 08-10-2014, 05:26 PM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Thanks, where can I adjust this dimension PL II control?
mgrotel is offline
post #71948 of 79637 Old 08-10-2014, 05:37 PM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Originally Posted by NorthSky View Post
Dynamic EQ, to listen late @ night without disturbing the babies and the lady.
This sounds like Dynamic volume to me. Right?
mgrotel is offline
post #71949 of 79637 Old 08-10-2014, 05:42 PM
NorthSky's Avatar
Liked: 3546
In the Audio Adjust Submenu. ------ • PLIIx/Neo:6
* Dynamic Volume is different: It's for a steady volume level between the movie and the commercials when watching TV, and from all the various channels.
EDIT: DynV: For late night listening.
NorthSky is offline
post #71950 of 79637 Old 08-10-2014, 05:56 PM
mthomas47's Avatar
Liked: 3089
Dynamic EQ and Dynamic Volume are different. The FAQ has excellent descriptions of both and some helpful tips for how to use DEQ. It's fairly complicated to condense in a single post. If you haven't read the FAQ in a while it would be a worthwhile refresher.
PLII has controls in the music mode which control the center width, the dimension (front emphasis versus back emphasis) and panorama (a wrap around effect). If Denon implements PLII in the standard way, Dimension has a default setting of 3. If you reduce the setting to 2, or 1, it will transfer more information to the surrounds. If you increase the setting to 4-7, it will emphasize the front/center speakers. You can experiment to find the setting you like. As long as you enjoy PLII for movies as well, it is an easy way to maneuver back and forth, as your AVR will automatically default to your music settings when you go from TV/ movies to music, and vice versa. Your owners manual should have some info on this, but I think I hit the high spots.
ambesolman likes this.
post #71951 of 79637 Old 08-10-2014, 06:37 PM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
I understand they are different, but he was getting EQ and volume mixed up. Volume uses the day, evening, midnight settings, which is for watching a movie late at night when you don't want some parts being a lot louder than others. He mixed that up with DEQ.
mgrotel is offline
post #71952 of 79637 Old 08-10-2014, 06:44 PM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
I have no such option under audio adjust menu. Maybe my Denon 2112 is getting a tad dated.
And D. Volume is what you described, to keep loud parts quiet at night. Hence the day, evening, midnight settings.
DEQ is for adjusting gain on certain frequencies as volume is changed from reference levels. It has settings measures in dB levels from reference.
Just wanted to clear that up for others reading. As said, the FAQ does a great job of explaining.
I am still interested in these PLIIx options that I do not see on my menu.
mgrotel is offline
post #71953 of 79637 Old 08-10-2014, 09:09 PM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Ok, I found the Dimension, that helped a lot. Thanks. I had to be in a certain mode for the avr to allow me to adjust it or even look at it. For music, I wanted only the front stage playing, but if the surrounds play a little, that is fine too, and this accomplishes that. I can just leave it in PLIIx now, and only have to switch from music to movie.
I feel like I need to run the subs really hot for music, which I play though an aux cable from my phone. Then still hot, but not as hot, for movies. FYI I guess. Thanks all for the help.
mgrotel is offline
post #71954 of 79637 Old 08-10-2014, 09:14 PM
NorthSky's Avatar
Liked: 3546
Sorry, I didn't know that you have a high-end Denon receiver. ...I thought you had an Onkyo one.
NorthSky is offline
post #71955 of 79637 Old 08-11-2014, 02:03 AM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Oh no worries, I think I have it figured out. Thanks for your help.
I think Audyssey has my surrounds too hot for movie watching, so I am going to turn down the gain on them some. I just got done watching Divergent and at some points I felt like all I could hear were the surrounds, or maybe that was just a really good immersive sounding feeling. I just don't want the rears to overpower, shouldn't the majority of the sound seem like its coming from the front stage?
mgrotel is offline
post #71956 of 79637 Old 08-11-2014, 03:10 AM
kbarnes701's Avatar
Liked: 5071
Remember that when Audyssey sets the trims it is aiming to set your system to Reference Level. That is at 0dB on the MV, your system will play (if it is capable of it) 85dB average, 105dB peak and 115dB peak (LFE) (for movies). You are not 'losing' anything with a setting of -6dB on the speaker trim. If you want it to play louder, turn up the Master Volume!
mthomas is correct that altering the trims does not negate in any way the Audyssey calibration. But it can affect Dynamic EQ as he says.
Here are some FAQ answers that may be useful to you:
a)3. I keep reading about Reference Level'. What is it?
e)1. Is it OK to change the trim levels Audyssey sets?
g)2. What is Dynamic EQ?
post #71957 of 79637 Old 08-11-2014, 03:41 AM
kbarnes701's Avatar
Liked: 5071
Do you have Dynamic EQ switched on? It is a known failing of DEQ that it can overboost the surround channels and of the most common complains in this thread. Unfortunately, there is nothing you can do to fix this properly. Best advice is to set the system to the level you usually listen at and then turn down the trims of the surround channels by a couple of dB or so. That is a better solution, IMO, than disabling DEQ altogether.
post #71958 of 79637 Old 08-11-2014, 08:40 AM
mthomas47's Avatar
Liked: 3089
You are very welcome. I'm glad that worked for you. A lot of people like to run their subs a few decibels hot with Audyssey.
As Keith said, DEQ is designed to slightly emphasize the surrounds. Given the fact that you like a stronger front soundstage for music, and feel that DEQ is over-boosting your surrounds for movies, lowering the trim levels on the surrounds by a couple of decibels might be a really good workaround to achieve both objectives.
post #71959 of 79637 Old 08-11-2014, 09:37 AM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
Another general advice for first time Audyssey users is to calibrate and use it "as is" for a couple of days or even for a week without tweaking. Some were not used to hearing the surrounds in their previous systems and now the presence of sounds (effects) coming from the sides may be rather new. Also there are those who like to have the majority of the sounds coming from the front LCR stage while surrounds only adding a kinda ambience effect.
Worth to try to see how your ears adapt to the new setup and if not, then do the tweaking.
Preference vs. reference....
mogorf is online now
post #71960 of 79637 Old 08-11-2014, 09:55 AM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Thanks, but I am a little confused on how adjusting the trim levels does NOT affect the calibration. I honestly do not understand how it cannot affect it. For example, in an extreme case, if I set the front right speaker to run 10dBs hotter than the calibration set it, then when watching a movie, it would sound terrible. How is that not affecting the calibration?
thanks
mgrotel is offline
post #71961 of 79637 Old 08-11-2014, 09:57 AM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
I will try and cut back the surrounds about 2 dBs each, I have a feeling that will be better. Thanks all.
mgrotel is offline
post #71962 of 79637 Old 08-11-2014, 10:02 AM
mogorf's Avatar
Liked: 613
thanks
To be precise with the wording, adjusting the channel trims does not alter the filter frequency response set by MultEQ for a given channel. Altough it will affect the loundess curves set by DynamicEQ.
post #71963 of 79637 Old 08-11-2014, 10:08 AM
Bigham16's Avatar
Quoted: 196 Post(s)
Liked: 140
I am sure I will get some backlash...after running Audyssey, turn off Dynamic EQ and set all channels to 75dbs using an SPL meter if you have one (leave Audyssey on). This made a major difference in my room but then again I have a dedicated room. I do use DEQ for stereo listing as it sounds amazing but not for Movies/TV/Video Games.
If you don't like it then you can always reset your AV back to your original Audyssey setting with DEQ. No harm no foul.
Just another option to try...or preference
Bigham16 is offline
post #71964 of 79637 Old 08-11-2014, 10:09 AM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Ok, thanks.
mgrotel is offline
post #71965 of 79637 Old 08-11-2014, 10:17 AM
batpig's Avatar
Quoted: 3575 Post(s)
Liked: 3420
Yes, you got it right and he got it wrong. Dynamic Volume is for not disturbing babies and ladies.
Dynamic EQ is what keeps tonal balance and surround impression steady regardless of volume level. It certainly helps at lower volume levels by preventing the sound from becoming thin and weak with inaudible surrounds, but it doesn't prevent explosions from being loud.
Others have provided some good suggestions but I would also mention that you can adjust the Reference Level Offset for Dynamic EQ which tones down its boost. If you think your surrounds are a little "hot" with movies that's what I would try first, and then if you want a little more low end oomph you can bump the subs a few dB to compensate.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #71966 of 79637 Old 08-11-2014, 10:22 AM
Selden Ball's Avatar
Quoted: 3086 Post(s)
Liked: 1509
thanks
The way I read what you've written, you're conflating two different types of calibration: sound level calibration and Audyssey's room response (frequency) calibration. The first changes, but the second does not.
Changing the sound level (gain) of a particular speaker channel does not change Audyssey's room response calibration for it. In other words, the relative gains of that channel's different frequencies (the room response calibration) don't change when you adjust the over-all gain of that channel. The amplitudes of all of the frequencies change simultaneously by the same number of dB.
Selden
Selden Ball is offline
post #71967 of 79637 Old 08-11-2014, 10:25 AM
batpig's Avatar
Liked: 3420
Just to be clear and emphasize this again -- you are not "negating" ANYTHING by having the trim levels set lower. It doesn't rob you of power or anything of the sort. It's just the digital trim level needed to get your speakers to play at the specific reference volume. Remember (as others pointed out above) that Audyssey isn't calibrating your system to balance relatively, it's also trying to get your speakers to play at the same ABSOLUTE level. The more efficient Klipsch speakers need far less power to play at that volume so the receiver trims them down.
Just to make it clear with an example with easy math -- let's say your Pioneer speakers needed a +4dB trim and your Klipsch speakers need a -6dB trim. This means that the Klipsch are 10dB (4 minus -6) more sensitive than the Pios. The decibel scale is logarithmic -- a 10dB increase requires TEN TIMES more power. So that means to achieve a specific volume level with the Klipsch the receiver only has to use one-tenth the power it needed with the Pios. So setting the trim lower due to much more efficient speakers isn't robbing you of power, it's ADDING HEADROOM.
Setup Guide and FAQ
batpig is offline
post #71968 of 79637 Old 08-11-2014, 10:32 AM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Got it, thanks.
mgrotel is offline
post #71969 of 79637 Old 08-11-2014, 10:36 AM
Alan P's Avatar
Quoted: 4698 Post(s)
Liked: 3327
You knew it was coming.
If you are setting your speakers to 75db using the AVRs internal test tones, your levels are not correct (in relation to reference level) as the internal tones bypass Audyssey's filters.
The correct way to do it is with external tones (downloaded, from disc, REW, etc.), that way you are hearing the tones through Audyssey.
All that being said, it ain't gonna rip a hole in the space-time continuum or anything.
Bigham16 and garygarrison like this.
Alan P is offline
post #71970 of 79637 Old 08-11-2014, 10:39 AM
Bigham16's Avatar
Quoted: 196 Post(s)
Liked: 140
And if I hadn't posted then I would have not learned something new
Bigham16 is offline
Closed Thread Receivers, Amps, and Processors
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
