"Official" Audyssey thread (FAQ in post #51779) - Page 2403 - AVS Forum | Home Theater Discussions And Reviews
 3496Likes
post #72061 of 79637 Old 08-13-2014, 03:47 PM
Niroe64's Avatar
Quoted: 18 Post(s)
Liked: 45
Hey guys, I have a quick and simple question. I re-ran Audyssey in a new room and due to in-room response Audyssey set my surround "crossover" at 90 hz (usually get them at 60hz in other rooms). I know its not recommended to lower them but if I were to lower them to 80hz does audyssey cancel its filters all together for the whole system, just for those satellites, or just the ten hz on each speaker I lowered (because it obviously wouldn't have filtered those frequencies anyways)? Thanks!
AVR Onkyo 818
Fronts Klipsch RF-62II's
Center Klipsch RC-62II
Sides Klipsch RB-51's
Sub SVS PB 2000
Blu-Ray Sony Ps3 Screen Samsung UN46D8000
Niroe64 is offline
post #72062 of 79637 Old 08-13-2014, 03:54 PM
mthomas47's Avatar
Quoted: 3399 Post(s)
Liked: 4999
Originally Posted by garygarrison View Post
Agreed.
BTW, I think IMAX's sound is overrated. While it is plenty loud, and would read that way on an SPL meter, it doesn't seem to have the frequency balanced impact of the old multichannel magnetic tracks (especially 70 mm, like Todd-AO). IMAX, so far, seems to be a bit bright, and lack mid-bass (perhaps). So, given that, I wouldn't want it any louder. So far, the best sounding IMAX may have been Fantasia 2000, but, oddly, the Beethoven lacked the proper impact. The Firebird sequence sounded just fine, though. I realize that the sound may vary quite a bit from IMAX theater to IMAX theater.
Your comment about Todd-AO dredged-up some old memories. We lived close enough to Denver when I was growing up to go to the Cooper Theater, one of the first and best Cinerama venues. Although I can only remember seeing one true Cinerama movie there (How The West Was Won), we saw a number of wonderful 70mm movies there including: Around The World In 80 Days, Fantasia, Ben Hur, El Cid, Lawrence Of Arabia. That was our first real exposure to first class 2.35 or 2.5 aspect ratio movies, and both the picture and sound quality were spectacular. I think I remember reading somewhere that they used the big Altec speakers in some of those theaters, but I may be mistaken.
With all the usual caveats about the unreliability of audio memory, particularly from so long ago, I would have to entirely agree with you. That theater had amazing sound at whatever volume levels, and some of those soundtracks got very loud. The several IMAX theaters I have been to are mainly very loud, although to be fair, I did think Skyfall had pretty good sound.
mthomas47 is offline
post #72063 of 79637 Old 08-13-2014, 04:02 PM
batpig's Avatar
Quoted: 3720 Post(s)
Liked: 3592
When Audyssey pings each speaker, it creates a filter for the full frequency response of the speaker. That EQ filter is then tapered off above/below the measured -3dB points so that the speaker is not boosted below (or above) its limits.
So if Audyssey detects that your speaker rolls off at 87Hz, that's where it tapers off the EQ filters. It doesn't matter if you set the crossover at 40Hz, 80Hz, or 250Hz, that's where the EQ filter tapers off. So if you lower the crossover from 90Hz to 80Hz, you will simply "expose" a small hole in the response that doesn't have EQ filters applied.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #72064 of 79637 Old 08-13-2014, 04:10 PM
Niroe64's Avatar
Quoted: 18 Post(s)
Liked: 45
Thanks! Exactly what I thought but just wanted to make sure. I had seen something online while looking for this information that simply said Audyssey would "cancel" its filters if you lower the crossovers and the vagueness of it threw me off.
AVR Onkyo 818
Sub SVS PB 2000
Niroe64 is offline
post #72065 of 79637 Old 08-13-2014, 05:44 PM
batpig's Avatar
Liked: 3592
That's not vague. It's just wrong
post #72066 of 79637 Old 08-13-2014, 06:04 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3557
Better upping your x-overs than downing them; that way you don't lose any sleep (EQ).
NorthSky is offline
post #72067 of 79637 Old 08-13-2014, 06:30 PM
garygarrison's Avatar
Quoted: 627 Post(s)
Liked: 751
I heard (was it here?) that IMAX theaters used a customized Audyssey or Audyssey-like room correction. The ones I have been in (just 2) sound too bright to me.
Most of the theaters that were built (by Magna?) for Todd-AO had sound farmed out to Ampex, who in turn contracted with JBL to build gigantic custom speakers that used a combination of horn loading and bass reflex. Each channel used 4 - 15 inch front horn loaded woofers, and a big cellular midrange/tweeter. So, the 5 channels behind the screen used 20 woofers total. The surround channel usually used 1 - 15" woofer each, in a smaller, rear loaded, horn, but some theaters had more modest surrounds. Cinerama often used Altec, again with 4 woofers on each channel, across 5 behind the screen channels, plus two channels for surround. Both Cinerama and Todd-AO had either braced plywood wings between the speakers, or great surface area across the front of the speaker enclosure, that loaded the bass. The IMAX theaters I know of don't have the plywood, so that may be why they lack mid & upper bass, if that isn't just my imagination.
garygarrison is offline
post #72068 of 79637 Old 08-14-2014, 07:43 AM
kbarnes701's Avatar
Quoted: 6824 Post(s)
Liked: 5262
c)4. Is it OK to change the Crossovers from Audyssey's recommendation?
kbarnes701 is offline
post #72069 of 79637 Old 08-14-2014, 07:46 AM
kbarnes701's Avatar
Liked: 5262
Same here. I love the huge screen but I hate the sound. I can’t ever remember seeing a movie in an IMAX theater and thinking "wow, the sound was great". And now we have an Atmos theater on my doorstep, I've pretty much given up on IMAX anyway.
post #72070 of 79637 Old 08-14-2014, 10:55 AM
mthomas47's Avatar
Liked: 4999
Keith,
I guess we are a little off-topic, but since there isn't much other action anyway, I would love to hear your impressions of Atmos. Like yourself, I really enjoy the big IMAX screen, but I haven't seen and heard an Atmos theater yet.
Mike
post #72071 of 79637 Old 08-14-2014, 11:12 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 406 Post(s)
Liked: 307
Transmogrified from another thread:
Originally Posted by mogorf View Post
....Filter calculation and graph smoothing are two different animals, aren't they?
What I was addressing in the Atmos thread was not the "graph smoothing" in the predicted response, but the amount of smoothing which Audyssey applies to the measurements before filter calculation. This can and does vary between XT32 and earlier versions as evidenced by the measured filters shown by Keith and others to demonstrate how Audyssey XT32 has stopped "over-correcting" the HF. It's actually user-adjustable in Pro Trinnov gear from 1/12 octave to something like 3 octaves.
RUR is offline
post #72072 of 79637 Old 08-14-2014, 11:33 AM
beastaudio's Avatar
Quoted: 4147 Post(s)
Liked: 3504
Originally Posted by NorthSky View Post
Feri, when you look @ my sig what do you see?
* I am experiencing a boost in clarity, but a clinical (hospital smell) type of clarity, and that clarity was not really what the doctor ordered, but just a simple prescription from the pharmacist over the counter. ...Like codeine for example. There is something disconnected, unemotional about clinical rendition, in music listening.
Yes the bass is tighter, good thing, almost disjointed from the rest of the band playing. ...It's just a perception I feel sometimes, an illusion, deeper in my soul.
A manual PEQ might do just as well.
I love this, and agree whole-heartedly.
beastaudio is offline
post #72073 of 79637 Old 08-14-2014, 12:36 PM
kbarnes701's Avatar
Liked: 5262
Keith,
Mike
Mike, I have written a thorough review of my experience at the demo I attended at Dolby's London HQ in July - it is here:
'Ears on' experience of Atmos in a home theater, using Atmos-enabled speakers.'
And yesterday I attended a second demo at Dolby - I am in the process of writing up that review and will post it in the Atmos thread as soon as it is finished. It is much more technical in nature than the first review and I was fortunate to have a 30 minute one-to-one with two of Dolby's senior guys, so a lot of our questions will be answered in the second report.
post #72074 of 79637 Old 08-14-2014, 12:37 PM
mogorf's Avatar
Quoted: 1127 Post(s)
Liked: 723
Hi RUR,
IMHO, this is all about the case whether to EQ the HF region or not. I'm not familiar with Trinnov implementations but as I understand it Trinnov allows the enduser to decide on HF region EQ'ing or not and offers a solution to do it gradually.
Smoothing during filter calculations in this respect can be understood as applying a low pass filter to the signal during calculation of the filters.
Chris has always been an advocate of EQ'ing the whole audible frequency range coz in his school if there is anything to be EQ'ed it should be EQ'ed. Trinnov seems to represent another school letting the enduser tweak.
mogorf is offline
post #72075 of 79637 Old 08-14-2014, 01:09 PM
mthomas47's Avatar
Liked: 4999
Thanks, Keith! I look forward to reading both reviews.
post #72076 of 79637 Old 08-14-2014, 02:21 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 406 Post(s)
Liked: 307
Hi RUR,
Feri, nothing I said in the Atmos thread pertained to HF cutoff of correction, but to how measurement smoothing before filter calculation could, in effect, "ignore" narrow variations, like the Atmos notch. All OBE as it turned out, as per Sanjay's observation and Dolby's reply.
FYI, Trinnov has many user adjustable parameters, but HF cutoff of correction isn't one of them - FIR filters are either "On" full-frequency, or they're "Off".
RUR is offline
post #72077 of 79637 Old 08-14-2014, 02:31 PM
mogorf's Avatar
Liked: 723
Thanks for your reply RUR.
What exactly do you mean by "measurement smoothing before filter calculation"?
mogorf is offline
post #72078 of 79637 Old 08-15-2014, 06:45 AM
kbarnes701's Avatar
Liked: 5262
post #72079 of 79637 Old 08-15-2014, 08:35 AM
porschedrifter's Avatar
Hey guys I have an interesting question. For me, I have 2eq and my main listening position is a couch with a high back, placed directly against the wall.
So when doing calibration, could the first mic position be exactly ear height close to wall back and the last two be 2ft above the couch back and 2ft away from the wall as per the guide?
My issue is if I do the measurements with all 3 mic spots 2ft high and 2ft forward, the distance measurements are all off.
Sent from my d801/20e kdz.
//Onkyo 608 - B&W LCR 60 S3 Center - B&W DM 602 S3 Fronts - TSC TSS & Phase Tech DST Surrounds - B&W ASW600 S3 Subwoofer//
120''+ Screen size club.
"At 20 bits, you are on the verge of dynamic range covering fly-farts-at-20-feet to intolerable pain. Really, what more could we need?"
AudioCheck -...
porschedrifter is offline
post #72080 of 79637 Old 08-15-2014, 09:17 AM
batpig's Avatar
Liked: 3592
The rule of thumb is to avoid reflective surfaces like couch backs and walls. Plus with the couch against the back wall you have the issue of "bass buildup" at the boundary.
However, there is no need to have the mic 2 ft above the couch back in this situation. The only reason to elevate the mic above the couch back is if the couch back blocks "line of sight" between the mic and your surround speakers. If the couch is against the back wall I can't imagine that is happening. So given that your only concern is avoiding those boundaries.
What I would do is make the first mic position as close to your main listening position as possible, while keeping the mic 10-12" away from a reflective surface. So figure out where your head is at the MLP, and then scoot the mic forward a few inches until you have that kind of clearance from the back couch cushion. Then I would make the other two measurements maybe 6 inches forward and a foot or two to the left/right of the first one. So you make a little triangle with the three measurements, all of them at approximately ear height and surrounding your MLP while staying well in front of the back wall.
porschedrifter likes this.
Setup Guide and FAQ
post #72081 of 79637 Old 08-15-2014, 01:29 PM
wse
wse's Avatar
Quoted: 2204 Post(s)
Liked: 809
You convinced me to buy the Marantz SR7009 vs Yamaha Adventage RX-A3040 just because Marantz has Audyssey XT32
wse is offline
post #72082 of 79637 Old 08-15-2014, 01:42 PM
kbarnes701's Avatar
Liked: 5262
post #72083 of 79637 Old 08-16-2014, 01:03 AM
Roger Dressler's Avatar
Quoted: 1872 Post(s)
Liked: 1002
Originally Posted by Selden Ball View Post
spurious duplicate post, even though I only clicked once. *grump*
Why not just delete it?
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #72084 of 79637 Old 08-16-2014, 03:06 PM
tezster's Avatar
Quoted: 517 Post(s)
Liked: 400
Question - I replaced my Energy 10.3 sub with an SVS SB-2000 and re-ran Audyssey (I have a Denon X2000). Although I have limited floor space to work with, I'm able to run both subs if I stack them on top of each other. Since this means that the subs are co-located, I should theoretically be getting a +6db gain. Without re-running Audyssey, would I be accurate in assuming I need to reduce the LFE level by 6db to ensure I'm getting the calibrated LFE output level? Note that both the Energy and SVS subs calibrated very close to each other in terms the LFE level set by Audyssey: -8.5db for the SVS, and -9db for the Energy, with the gain set at the 12 o'clock position for both.
tezster is offline
post #72085 of 79637 Old 08-16-2014, 07:58 PM
Alan P's Avatar
Quoted: 5135 Post(s)
Liked: 3833
Absolutely not, you need to re-run Audyssey.
Alan P is offline
post #72086 of 79637 Old 08-17-2014, 05:16 AM
Selden Ball's Avatar
Quoted: 3486 Post(s)
Liked: 1757
Because there's no "delete" button visible in my browser. I'm using Firefox with NoScript. It's currently blocking 12 of the 15 scripting sites that the forum uses. The delete button might be provided by one of those sites, I suppose.
*sigh* found it. I was expecting it to be in the main forum view, not in the editing view. I don't know how I've managed to overlook it for so long.
Selden
Selden Ball is offline
post #72087 of 79637 Old 08-17-2014, 05:22 AM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
If it is like AdBlock you can easily reload one time without blocking.
Gary J is offline
post #72088 of 79637 Old 08-18-2014, 10:22 AM
mthomas47's Avatar
Liked: 4999
The new report from my second day at Dolby Labs is now posted.
The official Dolby Atmos thread (home theater version)
Keith,
Great reviews of Dolby Atmos! Like a lot of other people, I particularly enjoyed your second, more in-depth review. I saw that you have already bought some new speakers. Have you also taken the plunge with an Atmos AVR yet? When you do, it will be interesting to read about your impressions of the Atmos/Audyssey interface.
Mike
post #72089 of 79637 Old 08-18-2014, 12:51 PM
kbarnes701's Avatar
Liked: 5262
Keith,
Mike
Hi Mike - thanks! I have pre-ordered a Denon X4100W - it will be here sometime in September I'm told. I will be installing the ceiling speakers the moment I have seen Dolby's custom installer setup guidelines, due to be released before CEDIA. I am also toying with Marantz as an alternative (my dealer is a friend so I have flexibility to change my mind )
post #72090 of 79637 Old 08-24-2014, 03:31 PM
Quoted: 627 Post(s)
Liked: 751
No posts in 6 days? That is so unlike us. Is something wrong with the forum software?
Closed Thread Receivers, Amps, and Processors
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
