"Official" Audyssey thread (FAQ in post #51779) - Page 2409 - AVS Forum
Old 08-30-2014, 12:37 PM
zeus33's Avatar
Quoted: 137 Post(s)
Liked: 176
Originally Posted by scubasteve2365 View Post
I understand that XT has better resolution filters, I get that it's better. What I'd like to know is how much better? How can I value it? Can anyone testify to how much better XT is over the vanilla? I tried searching for some actual comments on the percieved improvements but didn't have any luck. I'm sure it's buried in this thread somewhere, but it's hard to search for.
Very minimal. You probably wouldn't even notice. However, XT32 is a MASSIVE improvement over both. That is the version that you want.
http://www.audyssey.com/technologies/multeq/flavors
zeus33 is offline
Old 08-30-2014, 02:40 PM
scubasteve2365's Avatar
Quoted: 84 Post(s)
Liked: 244
I guess, I'd feel better knowing exactly what they mean by "filter resolution" at 2x. What is this saying in more technical terms?
"The Scuba Tank" thread here
PSN/XBL : ScubaSteve2365
scubasteve2365 is online now
Old 08-30-2014, 02:57 PM
IgorZep's Avatar
Quoted: 95 Post(s)
Liked: 89
It is undisclosed parameter (as Audyssey tells it is not to confuse people - ridiculous excuse, telling this to HT builder is like disguising stiffness of concrete from building architects... not to confuse them).
But you can assume x=1/1500Hz (in terms of FIR filter resolution) as a reverse-engineered value based on available data and measurements.
IgorZep is online now
Old 08-30-2014, 02:59 PM
Selden Ball's Avatar
Quoted: 167 Post(s)
Liked: 370
Presumably the values are the relative numbers of coefficients in the FIR filter algorithms.
Unfortunately, the details are a closely held trade secret.
However, if you are willing to take the time to measure the results using a spectrum analyzer like REW, one can evaluate the improvement in any particular listening environment and often determine what other procedures could be used to improve the room's acoustics. See the REW thread for details.
Selden
Selden Ball is online now
Old 08-30-2014, 03:02 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 736 Post(s)
Liked: 260
I just purchased an Denon AVRS900W. I initially believed the AVR had MultiEQ XT based on the comparison from Denon's website (see attached image). I guess I'm wrong in that it only includes MultiEQ (non-XT), as it certainly only uses the 6 measuring points during setup.
Hi, according to several experts Audyssey MultEQ XT32 is the true beneficial Auto Room EQ.
Anything else below (inferior flavors, including XT, MultEQ, and 2EQ) are missing some essence.
When Audyssey was first introduced to the mass population in our AV receivers back in 2006, it was revolutionary.
With years passing by, XT32 was the most impressive improvement, and we discovered how much more, compared to the other Audyssey flavors below. ...Also, a receiver that is Audyssey MultEQ Pro Capable is another higher notch if you are going to buy a licence with the Pro kit (about $600 extra).
Audyssey MultEQ has a very fair amount of filters in the bass (subwoofer), very good, as a fact as much as Audyssey MultEQ XT (I believe).
The thing with less than XT32 is the less than perfect EQuing all around; mids, highs, and bass too, plus only one sub.
Nowadays, we have YPAO, MCACC, AccuEQ, ARC, and Audyssey. ...Plus MiniDSP and Dirac Live.
There are several others too but those are the mainstream ones.
Audyssey MultEQ XT32 is the way to go. I think. ...Less in the family is ok, but less nonetheless.
NorthSky is offline
Old 08-30-2014, 03:09 PM
NorthSky's Avatar
Quoted: 736 Post(s)
Liked: 260
That! ^
NorthSky is offline
Old 08-30-2014, 03:14 PM
NorthSky's Avatar
Quoted: 736 Post(s)
Liked: 260
Here the numbers don't mean much @ all. ...It is the measurements before and after that count. ...Graphs.
And what you hear, from those representative graphs, in your room. ...Happiness.
NorthSky is offline
Old 08-30-2014, 04:11 PM
Quoted: 84 Post(s)
Liked: 244
Thanks for the responses guys. I don't feel that bad about it now, seeing something like "2x" and not knowing what it means gave pause.
On my previous receiver, a yammy, I did setup more manually with REW. It appears I cannot tweak any frequency response (EQ) and keep Audyssey active, but can I tweak distance and work in the time domain? I'd like to take the sub delay down to 0 (I have a minidsp) and verify/massage the other delays as needed if I discover things in REW while Audyssey is active (I like the dynamic and other functions)
Old 08-30-2014, 05:23 PM
NorthSky's Avatar
Quoted: 736 Post(s)
Liked: 260
Steve, if I was you, I would return the Denon receiver, or sell it, and search for (get):
♦ Onkyo TX-NR818 AV receiver or
♦ Onkyo TX-NR929 AVR or
♦ Denon AVR-4311CI or
♦ Denon AVR-4520CI or
♦ Denon AVR-X4100W (with D Atmos & DS) or
♦ Denon AVR-X5200W AV receiver (Dolby Atmos, and Dolby Surround "upmixer").
* You want Audyssey MultEQ XT32, and you don't want to pay too much to obtain it, and you might also want Dolby Atmos and Dolby Surround. ...If I was you.
...And of course unless someone has a better idea or two.
NorthSky is offline
Old 08-30-2014, 06:06 PM
Skylinestar's Avatar
Quoted: 78 Post(s)
Liked: 60
But XT32 still doesn't give a perfect crossover between subs and mains. We still need to manually adjust the subwoofer distance for proper integration. Audyssey should do something about this. I hope XT32 will get a successor.
Skylinestar is online now
Old Today, 06:33 AM
caloyzki's Avatar
Quoted: 58 Post(s)
Liked: 42
Hi guys I have a question. I noticed that after I completed my 8 mic positions audyssey xt, that my speakers are not in 75db when I check it with my spl radio shack. Is it okay to adjust the level trims to get all of them to 75db after audyssey? Thanks
caloyzki is offline
Old Today, 06:39 AM
kbarnes701's Avatar
Quoted: 1104 Post(s)
Liked: 1538
Read this FAQ answer before you do anything.
e)3. Why is it a bad idea to use your AVR test tones and a SPL meter to check trim levels?
kbarnes701 is online now
Old Today, 06:41 AM
kbarnes701's Avatar
Liked: 1538
Audyssey doesn’t measure the combined response of the sub(s) and the mains at any stage, so it can only 'calculate' the best XO at the splice. If you use independent methods, such as REW, to optimise the XO at the splice you will almost always improve on what Audyssey has set, based on numerous reports on AVS and in this thread. I compiled a guide to tweaking the sub distance settings and it can be downloaded via my sig link.
Old Today, 07:14 AM
Quoted: 78 Post(s)
Liked: 60
Yes, I did follow the guide and got great results in manually tweaking the sub distance and checking with REW.
I wonder if Trinnov/Dirac/Datasat has perfect crossover...
Old Today, 07:33 AM
AustinJerry's Avatar
Quoted: 471 Post(s)
Liked: 695
To add to what Keith has said, a new section has been added to the REW Guide (linked in both Keith's signature and mine) which deals with how to accurately set/measure speaker output levels using REW. Based on my experiences when developing this new section, the speaker levels set by Audyssey, and as measured with a calibrated mic and REW, are usually spot-on. I have never seen variances much more than .5dB, which IMO is "close enough". Especially for the low frequencies, where the RS SPL can be somewhat inaccurate, the calibrated mic shows that the level set by Audyssey is quite accurate.
AustinJerry is online now
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
