"Official" Audyssey thread (FAQ in post #51779) - Page 2410 - AVS Forum
post #72271 of 72290 Old Yesterday, 02:22 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 750 Post(s)
Liked: 271
Originally Posted by mogorf View Post
I know of no Audyssey enabled receiver that selects the x-overs based on woofer size. I may be wrong here.
Manually, in some Onkyo receiver models. I forgot to make that "manual" precision (I adjusted my prior post). ...Sorry about that Feri.
* http://www.whathifi.com/forum/home-c...er-frequency-2
mogorf likes this.
NorthSky is offline
post #72272 of 72290 Old Yesterday, 02:27 PM
NorthSky's Avatar
Quoted: 750 Post(s)
Liked: 271
Lightbulb ♦ Audyssey Bonus Link
♦ Audyssey ♦
NorthSky is offline
post #72273 of 72290 Old Yesterday, 02:33 PM
mogorf's Avatar
Quoted: 178 Post(s)
Liked: 113
Not at all and thanks Bob.
mogorf is online now
post #72274 of 72290 Old Yesterday, 02:34 PM
baloo_btru's Avatar
Quoted: 48 Post(s)
Liked: 102
So has anyone had a chance to use the cardboard "rocket" to use as a stand for the audyssey mic? I'm guessing it's better than nothing, but not as good as a true mic stand.
- Klipsch RF-82 ii, RC-62 ii, RS-52 ii
- Klipsch RW-12D
- Sony HW50es
- Firehawk G3
- Denon 2113
baloo_btru is online now
post #72275 of 72290 Old Yesterday, 03:28 PM
caloyzki's Avatar
Quoted: 64 Post(s)
Liked: 42
Originally Posted by kbarnes701 View Post
Originally Posted by AustinJerry View Post
To add to what Keith has said, a new section has been added to the REW Guide (linked in both Keith's signature and mine) which deals with how to accurately set/measure speaker output levels using REW. Based on my experiences when developing this new section, the speaker levels set by Audyssey, and as measured with a calibrated mic and REW, are usually spot-on. I have never seen variances much more than .5dB, which IMO is "close enough". Especially for the low frequencies, where the RS SPL can be somewhat inaccurate, the calibrated mic shows that the level set by Audyssey is quite accurate.
Can you share the distances Audyssey detected for your left and right surrounds?
Originally Posted by batpig View Post
Just trust audyssey. That's what they are telling you.
On paper it looks like this:
Left surround: + 0.05 dB/3.6 ft.
Right surround: - 1.50 dB/ 4 ft.
Something wrong here. Take a look at the numbers please. Since the left surround is closer to MLP it should have the negative trim, but in your case it's the other way around. Care to cross-check again?
On a second note, can you go up close to the left surround and listen closely? The tweeter may be broken so Audyssey had to boost the trim. Just a blind guess to be ruled out.
The external test tones will be more accurate because you can use them with Audyssey enabled. As the FAQ answer shows, it can make a big difference. There's nothing unusual in the trims being fairly different between speakers. The room will influence how loud the speakers sound - if some are in corners for example, and some are not, they will need to be trimmed down. As Jerry says, and as my own experience confirms, level setting is something Audyssey does almost to perfection.
Trust Audyssey to have this right. And when you say that one speaker sounds louder than the other, even though the difference is only 2dB, I start to worry you are overthinking it and maybe hearing things that are not really there - we all do this sometimes. Is your head when listening, for example, in the exact same spot as the mic was in when you measured the first position? If it is 6 inches out, then it will sound different maybe.
At the end of the day, it is your system and your ears. If you are not happy with the balance of the sound between the two speakers, then adjust the trim on one of them until you are. You won’t affect the actual calibration in any way.
It is extremely unlikely you have a blown tweeter BTW.
I still fear some discrepancy here caloyzki. Take a look at your numbers again. The left speaker which if farther away from MLP was trimmed down more that the right speaker which is closer.
You may verify the case by swapping the two speakers and running Audyssey again to see whether the trims follow the speakers or not while keeping the physical distance of each, of course. Up to you.
Hi sorry I didnt pay attention with the distance. So it means the problem is my speakers? Pls let me know what is the problem is thanks
here is the final result of the audysey
PHOTO UPDATED
Energy RC 70 fronts
Energy RC LCR center
Energy RC LCR surrounds
Rythmik LV12R and Mirage Omni 12 subwoofers
Denon 2112CI
caloyzki is offline
post #72276 of 72290 Old Yesterday, 03:33 PM
mogorf's Avatar
Quoted: 178 Post(s)
Liked: 113
Care to rotate the pix 90 deg cw? Thanks a million.
post #72277 of 72290 Old Yesterday, 03:45 PM
Gary J's Avatar
Quoted: 41 Post(s)
Liked: 88
Originally Posted by IgorZep View Post
It is undisclosed parameter (as Audyssey tells it is not to confuse people - ridiculous excuse
Maybe it is just your opinion that it is a "ridiculous excuse". And maybe not confusing people is a good idea.
mogorf likes this.
Gary J is online now
post #72278 of 72290 Old Yesterday, 03:58 PM
mogorf's Avatar
Quoted: 178 Post(s)
Liked: 113
Originally Posted by Gary J View Post
"It is undisclosed parameter (as Audyssey tells it is not to confuse people - ridiculous excuse"
Chris Kyriakakis: Audyssey MultEQ uses Finite Impulse Response (FIR) filters. Audyssey uses a proprietary method in calculating the filter coefficients, and so we do not disclose the resolution as it would lead to confusing comparisons with traditional methods.
http://www.audioholics.com/room-acou...m-eq-interview
With all the reverse-engineers on the Net trying to combat that little "x" I think it was a wise decision of Audyssey, indeed.
post #72279 of 72290 Old Yesterday, 03:59 PM
IgorZep's Avatar
Quoted: 97 Post(s)
Liked: 90
It is not an opinion. It is a fact. And if you feel yourself confused may be you shouldn't design/build your HT and pass it to someone else who is less confused about acoustics and related subjects...
IgorZep is offline
post #72280 of 72290 Old Yesterday, 04:01 PM
caloyzki's Avatar
Quoted: 64 Post(s)
Liked: 42
please see photos. thanks also is my fronts left and right has a discrepancy too?
Energy RC 70 fronts
Denon 2112CI
caloyzki is offline
post #72281 of 72290 Old Yesterday, 04:06 PM
Gary J's Avatar
Quoted: 41 Post(s)
Liked: 88
No discussion needed. Mogorf proved you wrong.
post #72282 of 72290 Old Yesterday, 04:09 PM
NorthSky's Avatar
Quoted: 750 Post(s)
Liked: 271
Looks all perfectly fine to me; enjoy the ride, crank it up.
caloyzki likes this.
NorthSky is offline
post #72283 of 72290 Old Yesterday, 04:14 PM
IgorZep's Avatar
Quoted: 97 Post(s)
Liked: 90
What is so complicated about 1/1500 sec or 0.67 msec? Dirac, for example, have no problem with disclosing their Dirac Live FIR filter resolution - it is limited to 10 msec of time-domain correction and contrary to Audyssey they really do non min-phase correction with this filter... What is really confusing are the Audyssey claims about time domain correction while their FIR filters only approximate min-phase behavior (the same as any PEQ).
kbarnes701 likes this.
IgorZep is offline
post #72284 of 72290 Old Yesterday, 04:16 PM
IgorZep's Avatar
Quoted: 97 Post(s)
Liked: 90
The fact that someone is incapable to understand something proves nothing except the fact that someone is incapable to understand something.
IgorZep is offline
post #72285 of 72290 Old Yesterday, 04:17 PM
NorthSky's Avatar
Quoted: 750 Post(s)
Liked: 271
Is Chris still active here @ AVS?
NorthSky is offline
post #72286 of 72290 Old Yesterday, 04:19 PM
Super Moderator
markrubin's Avatar
Quoted: 75 Post(s)
Liked: 334
move on please...
markrubin is online now
post #72287 of 72290 Old Yesterday, 04:30 PM
mogorf's Avatar
Quoted: 178 Post(s)
Liked: 113
Nope, but here's where he is hiding on the Innernet: https://www.facebook.com/groups/audysseytechtalk/
Feel free to join in Bob.
post #72288 of 72290 Old Yesterday, 04:58 PM
NorthSky's Avatar
Quoted: 750 Post(s)
Liked: 271
I like Chris, a lot.
And I do have a Facebook account; but I've never used it. ...Thx for the link though.
NorthSky is offline
post #72289 of 72290 Old Today, 04:43 AM
kbarnes701's Avatar
Quoted: 1133 Post(s)
Liked: 1546
kbarnes701 is online now
post #72290 of 72290 Old Today, 07:44 AM
Skylinestar's Avatar
Quoted: 78 Post(s)
Liked: 60
Agreed totally, Jerry. I have measured the post-calibration levels with REW too, and they are always spot on here ±0.5dB as you say. An impressive Audyssey performance and it shows that there should be no need to futz with trim levels except in exceptional circumstances, or to add some extra bass oomph, if desired.
Talking about setting speaker trim level, I think AVRs are only good for those speakers with mid/low sensitivity (95dB or lower) in a typical sized room, which is common for HiFi speakers. In the HT scene, more and more people are using the pro audio speakers (example JTR/Danley/JBLpro) with sensitivity of ~100dB. Audyssey chirps will definitely set the trim to the max -12dB. In this case, we need an SPL to further adjust the trim...and 0dB will be louder than reference.
Skylinestar is offline
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
