"Official" Audyssey thread (FAQ in post #51779) - Page 2413 - AVS Forum
post #72361 of 72388 Old 09-09-2014, 04:06 PM
zeus33's Avatar
Quoted: 176 Post(s)
Liked: 183
Originally Posted by Spottedfeather View Post
I DO need to adjust the levels of each speaker separately. I hear more out of my right side than my left side. So the left side speakers need to be louder.
Sorry, I didn't realize you meant your actual hearing for each ear. When you said sides, I thought speakers. Either way, you can, so you will be fine.
zeus33 is offline
post #72362 of 72388 Old 09-10-2014, 05:01 AM
kbarnes701's Avatar
Quoted: 1436 Post(s)
Liked: 1712
Ah. It had me a bit confused. Perhaps I should explain more. I hear slightly more out of my right side than my left side. What I was worried about was that the sound after running Audyssey would be off balance and appear to come more from the right side.
So long as you had the mic at the MLP for position 1, Audyssey should take care of that by adjusting the trims. Audyssey is pretty good at getting the trims levels and distances right. If you find that it is unbalanced after running Audyssey, we really ought to troubleshoot that, but it is fine to adjust the trim on one of the speakers a little if you wish - it won’t impact the calibration filters at all.
I'm wanting to get Audyssey so that I can smooth out the dynamic range of DTS audio tracks. I don't like the dynamic range. I need Audyssey for the dialogue normalization/dynamic volume. But the manual for the receiver that I'm interested in says that if you change settings after running Audyssey, you won't be able to use dynamic volume.
That is not correct. Denon manuals are notorious for being difficult to interpret. As in the example in your original post, what they say isn't always what they mean.
So, you're saying that if I run Audyssey and use dialogue normalization/dynamic volume, I will be able to adjust the volume of the individual speakers so that I can get balanced sound ?
Yes - you can adjust the trims to your hearts content and Audyssey will still run properly. HST, you shouldn’t really need to adjust the trims, but a couple of dB won't do any harm.
twain250 likes this.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
kbarnes701 is online now
post #72363 of 72388 Old 09-15-2014, 08:23 AM
Bigham16's Avatar
Quoted: 58 Post(s)
Liked: 43
I picked up my new Marantz 7009 last Thursday and got to hook it up over the weekend. Kbarnes and Mogorf you guys will find this very interesting, DEQ now sounds great!!! Every thing sounds even, the surrounds, 4 ceiling speakers , and subs sound great unlike with the 4520. The center channel is much more clear on all content and I didn't have to bump it up dB or two.
The other very strange thing is the 7009 said my subs were way to high. When level matching they are above in the red. The 4520 never said they were too high as I had them match at about 71 dB (through Audyessy) because of all the bass DEQ gave (I ran Audyessy a number of times on the 4520 all with the same results). But even before I had the 4520 I had level matched each sub to 75 dB with an SLP meter.
Not sure why the 7009 would have produced very different results but I am now a fan of DEQ.
To further test things, I moved the 4520 downstairs to see how Audyssey and DEQ would sound on my 3.1 setup in my living room. Living room is large, open concept with very high ceiling. Thought maybe the 4520 just didn't like my mediaroom but then thought why would the 7009 produce better results than the 4520? Anyway, after running Audyssey and applying DEQ the bass is still too powerfull just like the mediaroom.
Any ideas as to why the two different resutls between the 7009 and 4520? Could my mic for calibration been bad on the 4520? Thought it was interesting and wanted to pass along.
______________________
Bigham16 is offline
post #72364 of 72388 Old 09-15-2014, 08:30 AM
Gary J's Avatar
Quoted: 49 Post(s)
Liked: 89
Bad mic, different positions - any number of things. The point is when you get it right Audyssey Reference DEQ is always better than no DEQ.
Gary J
Gary J is offline
post #72365 of 72388 Old 09-15-2014, 08:35 AM
batpig's Avatar
Quoted: 615 Post(s)
Liked: 1248
The mic for those two units is interchangeable so have you tried switching mics?
batpig is online now
post #72366 of 72388 Old 09-15-2014, 08:37 AM
Bigham16's Avatar
Quoted: 58 Post(s)
Liked: 43
No, but I just thought about that while I was typing. Will give it go next time I get a chance. Thanks for the idea.
Bigham16 is offline
post #72367 of 72388 Old 09-15-2014, 08:46 AM
mogorf's Avatar
Quoted: 186 Post(s)
Liked: 115
Hi Bigham,
After swapping the mics as bp suggests, you may also do a factory reset on the 4520 and run Audyssey again.
P.S. Glad to hear you're a fan of DEQ, after all.
Cheers, Feri
mogorf is online now
post #72368 of 72388 Old 09-15-2014, 08:49 AM
Bigham16's Avatar
Quoted: 58 Post(s)
Liked: 43
Will do and thanks!!
Originally Posted by mogorf View Post
Hi Bigham,
Bigham16 is offline
post #72369 of 72388 Old 09-15-2014, 12:11 PM
AV_mike's Avatar
Quoted: 18 Post(s)
Liked: 39
I would also suggest swapping the microphones, as I had similar observations. I tried the 5-year old mic I got with my first AVR (Onkyo TX-SR876) instead of the 4520 mic and got 'better' results.
My sub level always came out approx. 3dB lower than the mains, when tested with a calibrated REW setup (4520 mic), but its level was spot on when using the 'old' mic.
I have since gone the whole hog and got the Audyssey Pro Kit - that gives even better results, and also confirms that the original 4520 mic was not to be trusted.
The sub level was just the most obvious fault - there were other smaller level discrepancies through the frequency range.
Regards, Mike.
Bigham16 likes this.
AV_mike is offline
post #72370 of 72388 Old 09-15-2014, 02:34 PM
RapalloAV's Avatar
Quoted: 87 Post(s)
Liked: 45
Is it ok to extend the cable on the mic when you have the AVR in another room?
Murray Thompson
RapalloAV is offline
post #72371 of 72388 Old 09-15-2014, 02:54 PM
Bigham16's Avatar
Quoted: 58 Post(s)
Liked: 43
I recall seeing an early post that said yes but no more than 20 feet (not sure that is correct). Here is the link that was on the post for the extned cable:
http://www.mcmelectronics.com/product/24-6265
Bigham16 is offline
post #72372 of 72388 Old 09-15-2014, 03:30 PM
AustinJerry's Avatar
Quoted: 611 Post(s)
Liked: 745
D.7 in the Audyssey FAQ.
AustinJerry is offline
post #72373 of 72388 Old 09-15-2014, 05:06 PM
RapalloAV's Avatar
Quoted: 87 Post(s)
Liked: 45
Thanks for that Jerry, never thought that would be in the FAQ page.
I have a stereo extension, what would happen if that was used?
Murray Thompson
post #72374 of 72388 Old 09-16-2014, 02:35 AM
kbarnes701's Avatar
Liked: 1712
Always check the FAQ....
d)7. Can I extend the Audyssey mic cable?
post #72375 of 72388 Old 09-16-2014, 12:51 PM
pwong888's Avatar
Can anyone recommend the length on the first mic poisition between the mic and the home theather recline seat.
pwong888 is offline
post #72376 of 72388 Old 09-16-2014, 01:23 PM
kbarnes701's Avatar
Liked: 1712
If you are having to ask that, then you won't have read the Audyssey 101, linked in my sig. I'd advise reading it and following each step to the letter if you are new to Audyssey. This will ensure that you get a great calibration right from the get-go.
post #72377 of 72388 Old 09-16-2014, 01:23 PM
kbarnes701's Avatar
Liked: 1712
It wouldn’t work
post #72378 of 72388 Old 09-17-2014, 04:14 PM
wse
wse's Avatar
Quoted: 369 Post(s)
Liked: 335
Is there a list of the new AVR with XT32?
My humble Cinema
wse is online now
post #72379 of 72388 Old 09-17-2014, 05:22 PM
batpig's Avatar
Quoted: 615 Post(s)
Liked: 1248
Considering that D&M is the only AVR vendor still fully aligned with Audyssey, it's a pretty easy list. Basically any of the higher end Denon (X4100 and up for the new models) and Marantz (SR7009 and up) AVR models. Both of the new Marantz pre/pros (the AV7702 and the upcoming 8802) have it too.
Onkyo has dropped Audyssey completely, and the other niche vendors (like NAD) who used Audyssey never licensed XT32, only XT.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
post #72380 of 72388 Old 09-17-2014, 05:30 PM
mcallister's Avatar
This may be somewhere in the thread. But I have an all active Danley 7.1 using active SH100s for side and back surrounds. For some reason every time in run audyssey it sets the back surrounds to 150 Hz and the sides to 80Hz. Since I can't lower the crossover point of the back speakers is my only option just trying to re-run audyssey and hope it sets a lower crossover point?
mcallister is offline
post #72381 of 72388 Old 09-17-2014, 09:26 PM
Selden Ball's Avatar
Quoted: 272 Post(s)
Liked: 390
I would suggest trying to determine why Audyssey is not hearing the low frequencies from the back surrounds. Are they being blocked by the back of the seating, for example? Or are the woofers or associated amps damaged in some way? Another possibility is that room acoustics is causing them to generate nulls in the vicinity of the microphone positions. At any rate, you'll probably need some kind of spectrum analyzer to discover what's happening, like REW.
kbarnes701 likes this.
Selden
Selden Ball is online now
post #72382 of 72388 Old 09-18-2014, 04:48 AM
kbarnes701's Avatar
Liked: 1712
Yes. Denon.
Denon/Marantz is the only mainstream manufacturer still using Audyssey XT32.
Edited to add Marantz.
post #72383 of 72388 Old 09-18-2014, 04:55 AM
kbarnes701's Avatar
Liked: 1712
Is the 150Hz crossover causing audible problems? For example, are you able to localise the bass that has been handed over to the subwoofer at ~150Hz? If not, then you can leave them as Audyssey set them, so long as your sub is happy to play at 150Hz, which I'd expect it probably can.
Otherwise, if there are audible issues from a XO so high, I'd lower the XO a bit - maybe to 120Hz. Yes, this will leave a small uncorrected 'hole' in the FR between 150 and 120Hz, but I doubt if this would be in any way audible for rear surround channels and may be a good compromise if leaving them where Audyssey wanted them is causing audible issues.
Why has Audyssey set one pair at 150Hz and the others at 80Hz? Position of the speakers in the room, the inability of the mic to 'see' the rear surrounds as well as it can the sides... there are various possible reasons.
If you care to try again with a new calibration, be sure that the mic position is such that the rear surrounds are easily 'seen' by the mic. If necessary, raise the mic a few inches for a few of the measurements, even if this puts the mic somewhat above the recommended ear level.
Sometimes Audyssey needs a little 'help' to get the best result
post #72384 of 72388 Old 09-18-2014, 05:19 AM
mogorf's Avatar
Quoted: 186 Post(s)
Liked: 115
Originally Posted by kbarnes701 View Post
Yes. Denon.
Denon is the only mainstream manufacturer still using Audyssey XT32.
...and Marantz. See the post of bp here.
Cheers, Feri
post #72385 of 72388 Old 09-18-2014, 05:39 AM
kbarnes701's Avatar
Liked: 1712
Denon and Marantz being the same, essentially, yes.
post #72386 of 72388 Old 09-18-2014, 06:03 AM
mcallister's Avatar
Thanks guys! I will see what I can find out and re-run audyssey.
post #72387 of 72388 Old 09-18-2014, 06:09 AM
kbarnes701's Avatar
Liked: 1712
Please report back if the suggestions work, or don't work, so we can add to the body of knowledge contained in the thread. Thanks.
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
