"Official" Audyssey thread (FAQ in post #51779) - Page 2417 - AVS Forum
post #72481 of 72503 Old 10-18-2014, 10:13 AM
kbarnes701's Avatar
Quoted: 1891 Post(s)
Liked: 1980
Originally Posted by Tangled Cable View Post
Is there a way to save more than one Audyssey calibration? Does the previous calibration just get erased by the current one?
a)6. Is it possible to save and recall an Audyssey MultEQ calibration?
Follow the advice to check out the FAQ and 101. Audyssey should improve the sound not make it worse, and for almost everyone, it does. Chances are there is a setup anomaly. It is meant to be 'automated' but it is far from plug 'n' play, as is witnessed by the fact that this is the longest thread on AVS and that the FAQ runs into dozens of pages with about 80 questions covered.
With perseverance and help from the thread contributors, you will get it working well I am sure.
kbarnes701 is offline
post #72482 of 72503 Old 10-18-2014, 03:29 PM
coli's Avatar
Quoted: 83 Post(s)
Liked: 30
Does Audyssey resample everything to 48khz internally?
coli is offline
post #72483 of 72503 Old 10-18-2014, 03:48 PM
Kal Rubinson's Avatar
Quoted: 81 Post(s)
Liked: 138
No. Your AVR/prepro does that if it doesn't have enough DSP horsepower to run Audyssey at higher resolution. It is not Audyssey, per se, but is implementation specific.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #72484 of 72503 Old 10-18-2014, 05:10 PM
mathlete's Avatar
I've noticed an audio issue that I haven't been able to correct. First, I have a Marantz SR7008 with Audyssey XT32 (thanks to the recommendations I got here). Despite running calibration a couple times, I can't shake an annoying reverb effect on dialogue. What's interesting is that this is present on many, but NOT all blu-rays. For example, it was quite noticeable on Pacific Rim but not on The Wolverine.
I have acoustic panels at the first reflection point as well as directly behind the center seat. I put these up hoping it would tame the room, but I still notice this reverb that leads to muddy dialogue. Is there any manual adjustment I could make to help lessen this?
mathlete is offline
post #72485 of 72503 Old 10-18-2014, 05:47 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 1574 Post(s)
Liked: 497
Maybe, in the future, Denon/Marantz will add a fifth DSP chip (or less, but with much more processing power), and strike a deal with Audyssey, to go above and beyond; 96 and 192kHz. ...Maybe.
NorthSky is online now
post #72486 of 72503 Old 10-18-2014, 05:51 PM
NorthSky's Avatar
Liked: 497
Methinks that you simply hearing what's truly on the movie sound recording (ADR) from the center channel.
I wouldn't sweat about it; it's normal. ..With some films it's more obvious than others.
post #72487 of 72503 Old 10-18-2014, 06:39 PM
mathlete's Avatar
That was my friend's contention when he heard it. Maybe I really am just crazy here.
mathlete is offline
post #72488 of 72503 Old 10-18-2014, 08:44 PM
NorthSky's Avatar
Liked: 497
Not crazy, to the contrary; your system is highly resolute, your ears too. ...You can hear exactly what's on the movie soundtracks.
post #72489 of 72503 Old Yesterday, 12:34 AM
Quoted: 109 Post(s)
Liked: 30
No "deal" required, just the DSP to pull it off. They offer it now up to 92KHz and higher - as mentioned here. However, Audyssey would do nothing but pass information above 24KHz unaltered.
audio2xs is offline
post #72490 of 72503 Old Yesterday, 11:43 AM
NorthSky's Avatar
Liked: 497
Yes, you are right; just need more DSP processing power in the receiver, or SSP, that's all.
And then Audyssey can be implemented to provide 96 and 192kHz, higher resolution audio.
It'll come...when DSP chips get more powerful, and more affordable. ...Just like in our Androids.
...And hopefully Onkyo/Integra will see the light. ...Like Denon/Marantz do.
And Dirac Live will be with us more and more. ...Implemented in receivers and SSPs @ very affordable prices. ...Less $ than Audyssey. ...And with better overall sound performance.
post #72491 of 72503 Old Yesterday, 06:23 PM
teddyc23's Avatar
SVS PC12-NSD Calibration Questions
I just purchased an SVS PC12-NSDsubwoofer. This is replacing a Polk PSW505. I noticed a few thingsAudyssey related I was wondering if anybody had any advice.
  1. After running Audyssey I noticed the SVS sub distance was set at 19ft. My old sub calibrated at 7ft (I would say around 7ft is the actual distance.) Is this an issue or is it related to some additional processing the SVS is doing?
  2. In the past I have liked the sub a little hotter than the default Audyssey calibration. I have always had Dynamic EQ on, but I use a RLO of 15 to avoid any surround or sub channel over boosting. My old Polk worked well at +6db above calibration by using the setting in my Denon receiver. I have found I like the SVS around +9db above the calibration. I was wondering if anyone else likes running there SVS sub this hot? I do not listen at reference level, but I do like it somewhat loud on occasion. Should I worry about running the sub this hot? I am wondering if my preference to run the SVS louder than the Polk comes from the SVS flatter response.
Thanks for your help.
Teddy
teddyc23 is online now
post #72492 of 72503 Old Yesterday, 07:36 PM
NorthSky's Avatar
Liked: 497
1. Where is your sub in your room; exact position? ...Same position as before with your Polk? ...Near a front corner?
2. Which Audyssey flavor do you have; XT, XT32?
3. Your SVS sub; does it have a DSP EQ in it?
4. On your sub; where is the Gain and Phase set @? ...X-over is bypassed right?
5. After Audyssey calibration; what is your sub level set @? ...From your receiver or pre/pro.
* I would leave the sub distance alone; the internal electrical x-over accounts for what Audyssey gave you (each sub varies).
** I wouldn't add more than say 6dB myself, after calibration, and only if the margin level accommodates it.
*** Usually, people set their sub Gain (before Audyssey) from roughly 1/4 to 1/3 of its rotary volume knob.
<<>> Did you consider to add your Polk sub as well to your entire setup (two subs)?
post #72493 of 72503 Old Yesterday, 09:23 PM
batpig's Avatar
Quoted: 897 Post(s)
Liked: 1424
1. Extra distance is due to digital filters in the subwoofer. Did you enable the "direct" or crossover bypass mode on the SVS? If not that would definitely explain the extra distance.
2. I think it's less about flatter response and more about quality -- especially distortion, power and headroom / dynamic capability. The SVS is just insanely more capable than the Polk. At levels at which the Polk is struggling and distorting heavily it is breezing along with minimal distortion. When you lower distortion, you can play louder and it doesn't "feel" louder because the sound is cleaner. Many people who upgrade to really good subs are surprised that a high quality sub does not "boom" like their older cheap sub did. It takes a while to acclimate to increased refinement and precision of the superior sub.
Also of course with Dynamic EQ heavily offset its not surprising that you need to boost the sub a bit more than most people. Especially if you listen well below reference, which means you are basically replacing the bass boost that you cut off to spite the surround boost with some manual boost of your own.
ambesolman likes this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #72494 of 72503 Old Today, 03:46 AM
kbarnes701's Avatar
Liked: 1980
Teddy
Check out the FAQ and 101 before attempting an Audyssey calibration:
f)1. Why has Audyssey set my sub distance much greater than it actually measures?
f)4. If I want to run my subs a little 'hot' where should I make the changes?
post #72495 of 72503 Old Today, 09:54 AM
teddyc23's Avatar
Originally Posted by kbarnes701 View Post
Thanks for the link to the FAQS.
Teddy
post #72496 of 72503 Old Today, 09:57 AM
teddyc23's Avatar
It seems that my SVS sub does not have a direct mode. No big deal as long as Audyssey is able to cope.
Thanks for the information.
Teddy
post #72497 of 72503 Old Today, 10:03 AM
kbarnes701's Avatar
Liked: 1980
Teddy
You are welcome. If you are new to Audyssey, I suggest a read of the 101, linked in my sig. It can save much frustration.
post #72498 of 72503 Old Today, 10:05 AM
teddyc23's Avatar
1. The Polk was in a rear corner. The SVS is in the same spot.
2. I have a Denon 1610 with just plain MultiEQ
3. No EQ that I can adjust. It does have a limiter.
4. The sub manual mentions to defeat the x-over turn it to the highest setting. I have it at the highest setting. The phase is at 0.
5. My sub is at the 12:00 position. My AVR shows -9.0DB calibrated at this setting. I figured this wasn't a big deal because I knew I was going to boost it. I was using +9DB but I may back it off to +6DB. For my AVR sub channel level what should I be shooting for? Is 0.0 after boosting the best setting for the AVR sub channel?
I thought about running the polk but I am out of places to put it :-)
Teddy
post #72499 of 72503 Old Today, 04:47 PM
NorthSky's Avatar
Liked: 497
1. Did you ever try one of the front corners? ...Me, I would put the SVS in the front L corner, and the Polk in the R front corner. {If possible of course.}
2. MultEQ I see. ...Do all your six mic positions. ...All of them.
3. Ok, no EQ in your SVS.
4. Perfect.
5. Twelve o'clock on the sub (Gain), fine. ...And -9.0dB in your Denon for the Sub level: that's why I would use both subs, and try them in both front corners. ....I find it low; still within the limits though.
* If you keep everything the way it is now [me I would put the two subs where I indicated, and redo Audyssey doing all the six mic measurements, within four feet of each other (even within three feet), and your results should be better, IMHO]; don't go over -3.0dB on your Denon's subwoofer channel level.
______
post #72500 of 72503 Old Today, 06:10 PM
aaranddeeman's Avatar
Quoted: 64 Post(s)
I have noticed that Audyssey sets the trims about 4db lower thn what you get using SPL meter @ 75db.
Is this a known issue or is SPL meter to be blamed?
aaranddeeman is online now
post #72501 of 72503 Old Today, 06:26 PM
AustinJerry's Avatar
Quoted: 740 Post(s)
Liked: 789
After I finish a calibration, I always perform a level-checking exercise. I set Audyssey on, DEQ off, and play the speaker level-setting tones from Spears & Munsil ver 2 test Blu-Ray. I measure the output levels using a calibrated microphone and REW software. I almost always find the speaker levels set by Audyssey to be extremely accurate, including the subwoofer channel. Remember, if you are checking levels using the internal test tones, these test tones do not have Audyssey engaged, so that may account for level differences. Also, there may be an accuracy issue with your SPL, especially in the lower frequencies.
I would focus more on whether the speaker-to-speaker level is consistent, rather on the overall output level. After all, if you feel that the sound level is low, simply raise the master volume.
AustinJerry is online now
post #72502 of 72503 Old Today, 06:29 PM
Quoted: 64 Post(s)
Ah. Okay. I was using internal test tones from the receiver.
Good idea to check the level across speakers..
And the mater volume..
post #72503 of 72503 Old Today, 08:03 PM
NorthSky's Avatar
Liked: 497
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
