"Official" Audyssey thread (FAQ in post #51779) - Page 2420 - AVS Forum
post #72571 of 72590 Old 10-26-2014, 02:30 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 1708 Post(s)
Liked: 522
Originally Posted by JimP View Post
Where are you finding the lowest prices on an Audyssey pro kit that's suited for a Marantz 8801?
eBay?
NorthSky is offline
post #72572 of 72590 Old 10-26-2014, 02:47 PM
mogorf's Avatar
Quoted: 203 Post(s)
Liked: 117
Originally Posted by NorthSky View Post
eBay?
Bob: this is what eBay brings up for "Audyssey Pro Kit"
JimP: probably best to ask over at the "The Audyssey Pro Installer Kit Thread".
mogorf is online now
post #72573 of 72590 Old 10-26-2014, 05:16 PM
AustinJerry's Avatar
Quoted: 803 Post(s)
Liked: 813
Some people are just trying to inflate their post counts, Feri, without any real regard for the quality of their advice. Best to move on...
kbarnes701 and ambesolman like this.
AustinJerry is online now
post #72574 of 72590 Old 10-26-2014, 05:35 PM
mogorf's Avatar
Quoted: 203 Post(s)
Liked: 117
Just tryin' to be patient with some while helpful to some. Otherwise fully agree with Ya Jerry.
P.s.:New-Odyssey Nail System Complete Pro Do Yourself Salon Artificial Gel Nail Kit at a bargain price is available on eBay, ...um,...while supplies last, eh?
post #72575 of 72590 Old 10-26-2014, 05:49 PM
TurboTropic's Avatar
Quoted: 13 Post(s)
Originally Posted by primetimeguy View Post
Yes, you will want to store them first. If you hit cancel it will negate the calibration. Do as you said and go into Manual Setup and make changes as you see fit.
Thanks very much. Thought so but I appreciate the confirmation.
Optomo HD131xe on 106" Accuscreens 16:9 pull-down screen
Denon 1713 AVR
Sony PS3 Fat / Sony BDP-5200 / NAD T-514 DVD player (used as CD player)
Polk Monitor 30 Series ii LR fronts / Polk CS1 centre / Monoprice in-wall 5-1/4 Inch rear surrounds / SVS SB12-NSD sub
TurboTropic is offline
post #72576 of 72590 Old 10-26-2014, 11:25 PM
NorthSky's Avatar
Liked: 522
Lol ...The spelling is wrong too (eBay own spelling).
* Keith has his for sale. Check him out.
And if you carefully search by using the right wording, you're going to find all kind of good stuff, even on eBay. Professional microphones with stands for Room Calibration and EQ, and for only few dollars; some are excellent brands too, from Germany/
The Audyssey Pro kit itself, is $550 @ most places, then you need to pay for a key licence (extra).
NorthSky is offline
post #72577 of 72590 Old 10-28-2014, 02:20 PM
Strike Ace's Avatar
I have a question regarding the crossover used in Audyssey XT32.
My Receiver is a Onkyo TX-NR818 and I use MiniDSP 2x4 for manual tweaking.
What type of crossover is used electronical in Audyssey between mains and subwoofer?
I am not asking for the sum or measured spl from speakers depending on their roll-off.
If we take crossover @80Hz as an example:
Some say that a High-pass Linkwitz-Riley 2nd order filter is applied @80Hz together with two stacked Low-pass Butterworth 2th order @80Hz.
Others say that High-pass Butterworth 2th order is applied @80Hz and a Low-pass Butterworth 2th order @80Hz.
I have searched the web and forums quite a bit, but I have not found a clear answer.
Can someone clearify what crossover type and values that are used?
Strike Ace is offline
post #72578 of 72590 Old 10-28-2014, 02:48 PM
JHAz's Avatar
Quoted: 111 Post(s)
Liked: 158
It is not Audyssey choosing crossover slopes, its Denon and Onkyo and Marantz. Search your receiver and you are more likely to find the answer. Fwiw aiui, the manufacturers use the unbalanced thx crossover scheme ~ higher order on sub and lower order on mains. But it's been a long time since I worried about this. The room effects net response more than crossover slopes by a factor of maybe ten.
JHAz is online now
post #72579 of 72590 Old 10-28-2014, 02:55 PM
mogorf's Avatar
Quoted: 203 Post(s)
Liked: 117
Honestly this is a hard row to hoe. First off, Audyssey (any flavor) does not set crossover in any AVR/AVP known to man today (including your Onk 818). MultEQ reports the - 3dB roll-off frequency of each speaker (better said speaker pair except the center and the sub/s) and the AVR/AVP sets the c/o accordingly. Whatever slope each filter has is burried deep down the chain, not even mentioned on the spec sheets. Nonetheless, it is not a user tweakable setting, so I would not really worry about it too much, yet I understand your curiosity from the technical point of view.
post #72580 of 72590 Old 10-29-2014, 03:36 AM
Strike Ace's Avatar
Thanks for quick answer, I will search some more.
post #72581 of 72590 Old 10-29-2014, 03:46 AM
Super Moderator
DrDon's Avatar
Quoted: 103 Post(s)
Liked: 284
Remember to keep posts about the topic and not each other. If you have something to say to just one poster, use PM, not open forum.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #72582 of 72590 Old 10-29-2014, 06:24 AM
kbarnes701 is online now
post #72583 of 72590 Old Yesterday, 02:50 PM
Cheesebach's Avatar
Liked: 0
I'm not sure if this is the best place to ask this question, since it is a bit on the theoretical side, but here it goes - It's my understanding that after running Audyssey, the master volume on the AVR will have been calibrated so that the system will be playing at reference level for a movie when the master volume is set to 0dB.
My question is this: If any part of the system being calibrated (speakers or sub) is incapable of reaching reference level in the room it being used, what would the result be? Would you still be able to set the master volume to 0dB or above after calibrating? Or would all the individual speaker trim levels be maxed out? Taking it a step further, is there any way to interpret the Audyssey results to get an idea of how much headroom your system has to be sure it is not at risk of distorting at reference level volumes or above?
I'm not having any issues at the moment, just someone who like to understand what is going on behind the scenes for some things
Cheesebach is online now
post #72584 of 72590 Old Yesterday, 03:23 PM
batpig's Avatar
Quoted: 970 Post(s)
Liked: 1469
The answer is pretty simple -- Audyssey has no clue what the "maximum performance" or "headroom" of your system is. You can infer nothing about your system headroom from the Audyssey results. The test pings are at such a low level (30dB below full scale, or ~75dB) that they are nowhere near the point where any decent speaker or sub will be hitting their limits.
Whether your system can actually hit "reference level" is a function of the speakers, room size, amplification, etc. Audyssey really doesn't have much to do with it (although applying EQ in general could impact total headroom, especially with the subs, if there are significant boosts needed to EQ to flat). It is worth noting however that few people actually WANT to get to full reference in a typical home environment -- in these smaller spaces, especially if not acoustically treated, literal reference level is too loud. And "perceptual" reference level may be 5-10dB below literal reference level.
If you aim for a goal of -10dB it makes the whole system much easier to put together, since, due to the logarithmic nature of power demands, it takes 10x the power to raise the SPL by 10dB. So getting to -10dB is only requires 1/10th the performance of full 0dB reference. That's a goal that most people can achieve even on a relatively modest budget.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #72585 of 72590 Old Yesterday, 08:32 PM
Gooddoc's Avatar
Quoted: 463 Post(s)
Liked: 348
^^^^^I wish someone had explained that to me years ago. You know, before I fell in the rabbit hole .
Gooddoc is online now
post #72586 of 72590 Old Today, 01:15 PM
Cheesebach's Avatar
Liked: 0
Thanks for the quick response and explanation, batpig. It does make sense to me now why Audyssey wouldn't "know" what the actual headroom/capabilities of my AVR are since the test tones are well below reference level peaks. I'm still a bit confused on what the AVR does after an audyssey calibration with regards to the master volume settings though, so I'm wondering if I'm still thinking about this in the wrong way.
Hopefully I can explain my thought process and someone can help point out where I might be wrong in some of my assumptions. As I understand it, most AVRs will have the option to display the master volume setting either on a absolute scale (e.g. 0-98) or relative scale (e.g. -80dB to +18db). Before one runs an audyssey calibration, the relative scale option is at some pre-determined default where 0dB more than likely does not actually produce reference level on the user's system (it could be above or below true reference level).
Then, a user will run the audyssey calibration and through playing the test tones at a known power, audyssey will measure a volume from each speaker at the listening position and thereby get a measurement of the overall system's efficiency at converting the electrical power from the amp into sound at the LP. Using this data, the AVR will then re-calibrate its master volume "relative scale" so that "0dB" will now produce the true reference level on the user's system.
Does this then mean that the calibrated relative master volume scale range would then be changed as well? Would someone with a system not capable of reaching reference level see that their master volume setting only goes from -80dB to -5dB or something like that? If that is not the case and master volume still ranged from -80dB to +18dB, what would happen if the user of this theoretical system tried to set his volume to 0dB or above even though his setup was not capable of reaching reference level? Wouldn't this effectively be like "turning it up to 11" (going above 98 on the absolute scale for his AVR)?
I'm guessing that some part of my understanding of what is happening must be incorrect, so I'm hoping that someone can help steer me in the right direction.
post #72587 of 72590 Old Today, 02:11 PM
Alan P's Avatar
Quoted: 594 Post(s)
Liked: 296
Where you're getting confused is the "recalibration of the master volume". Audyssey (nor the AVR) does not re-calibrate the MV...Audyssey (along with your AVR) set the trim levels on your speakers so that they all play at the same level (75db with -30db test tones).
After that, it's all up to your speakers as to whether of not you can play at "0" MV ("reference level") without distortion.
Audyssey will sometimes reduce the maximum volume you can turn the MV up to though. It does this based on how many filters it applies and the max boost in those filters....but 0MV is still 0MV.
Alan P is online now
post #72588 of 72590 Old Today, 02:23 PM
kbarnes701's Avatar
Quoted: 1969 Post(s)
Liked: 2019
LOL. It's nice to have the headroom to be able to hit Reference now and then, if you really feel the urge though And, as batpig says, if you ever treat your room to a lot of acoustic panels, they do absorb quite a lot of the energy, so you will need to wind up the MV a fair bit. I 'lost' at least 3dB when I added all my treatments.
post #72589 of 72590 Old Today, 02:33 PM
bsoko2's Avatar
Quoted: 39 Post(s)
Liked: 66
My audio for most of my movies including Atmos TF4 plays at -5 but then I have a fully treated room.
bsoko2 is online now
post #72590 of 72590 Old Today, 02:38 PM
kbarnes701's Avatar
Liked: 2019
Same here, also fully treated. I listen to most movies at about -5dB. I call it 'home reference'.
post #72591 of 72590 Old Today, 02:42 PM
Cheesebach's Avatar
Liked: 0
Thanks for the reply - I think I'm starting to get it Is it correct to say then, that for a system that struggles to reach reference levels, Audyssey would set the speaker trim levels to positive values so that the AVR is applying a boost to all speakers at all volumes? And that the AVR might then cap or limit the maximum master volume setting by an amount equivalent to the maximum boost that it is applying to any one speaker? For example, if the volume on the AVR goes from -80dB to +18dB and the Audyssey speaker trim settings are +3dB, +2dB, +5dB, +1dB, +3dB, the AVR might limit/cap the master volume to +13dB (18dB - 5dB max trim). This is probably an over-generalization since the trim values for each speaker are averaged across all frequencies, but I hope that is the basic idea.
As a follow-up, is there any general trend among AVRs as to where in their master volume range that distortion starts to become an issue? Or would the whole range be relatively safe and useable? Thanks again for all the help!
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
