"Official" Audyssey thread (FAQ in post #51779) - Page 2438 - AVS Forum
post #73111 of 73134 Old 12-15-2014, 11:01 AM
Alan P's Avatar
Quoted: 903 Post(s)
Liked: 454
As I stated...no, you have to run the full Audyssey calibration after you add the sub. No way to load the old "speakers only" Audyssey cal and combine with the new "with sub" cal.
AVR: DENON 2113ci
FL/R: Klipschorn
CC: Klipsch RC64ii
SUR: Polk LS F/X x 4
SUB: PSA XS15 x 4 (Soon to be replaced with dual T-18s!)
DISP: Mitsubishi WD-73740
Alan P is online now
post #73112 of 73134 Old 12-15-2014, 11:07 AM
Quoted: 43 Post(s)
Liked: 3
Alright man, thanks. Got an SVS sub so looking forward to it!
Federo5 is online now
post #73113 of 73134 Old 12-15-2014, 03:47 PM
pbarach's Avatar
Quoted: 99 Post(s)
Liked: 104
Originally Posted by Alan P View Post
Nope, you have to do the whole thing over. There shouldn't be any difference in how Audyssey EQs your speakers....they are all measured individually.
I agree that the OP has to recalibrate, but there are often differences in a recalibration due to differences in microphone positioning. It's almost impossible to get EXACTLY the same mic placements in successive calibrations.
mogorf likes this.
AT&T U-Verse Northeast Ohio
Denon x4000, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, etc.
pbarach is offline
post #73114 of 73134 Old 12-15-2014, 04:06 PM
Alan P's Avatar
Quoted: 903 Post(s)
Liked: 454
While I agree, I've ran Audyssey dozens of times and have never noticed anything sounding differently unless I made an intentional change (in placement, gain, MLP, mic placement, etc.).
mogorf likes this.
AVR: DENON 2113ci
FL/R: Klipschorn
CC: Klipsch RC64ii
post #73115 of 73134 Old 12-15-2014, 04:08 PM
AustinJerry's Avatar
Quoted: 1140 Post(s)
Liked: 922
Originally Posted by Federo5 View Post
Hey guys. I just bought a sub! I spent 10 calibrations without a sub getting my sound to something I love. Now with a sub I am afraid I won't get this sound from my speakers again, I have the settings saved on my computer. Is it possible to somehow just run audyseey for my sub when I get it and than load the saved speaker settings or do I have to do the whole thing over again and hope the frequencies match up similar.
Now that you are adding a sub, you will clearly be changing the sound you get. For one thing, the sub will be handling the frequencies below the crossover point, not the main speakers. While I can understand you concern that you may not get back to the "sweet spot" you have been enjoying, you should actually hear an improvement in the overall sound with the sub taking on the low frequency duties. If at first it sounds different, make sure you give yourself time to become accustomed with it. I'll bet you will be happy in the long run.
Also note that with the sub, you can move it around to different spots in order to find the best bass response, something you were not able to do with the mains. I encourage you to experiment.
mogorf likes this.
AustinJerry is online now
post #73116 of 73134 Old 12-15-2014, 04:14 PM
mogorf's Avatar
Quoted: 257 Post(s)
Liked: 133
+1. Most important is the first mic position at the MLP, followed by utilizing the max. number of positions as recommended by Audyssey or the Audyssey set up guide.
mogorf is online now
post #73117 of 73134 Old 12-15-2014, 04:20 PM
mogorf's Avatar
Quoted: 257 Post(s)
Liked: 133
Another +1.
@ Federo: and when your done with the setup, set all your speakers to "Small" and select an initial crossover of 80Hz. Also make sure DEQ is ON and DynVol is OFF. And then give yourself time to become accustomed with the new calibration and setup.
post #73118 of 73134 Old 12-15-2014, 05:12 PM
Quoted: 43 Post(s)
Liked: 3
Each time I move the sub do I have to keep doing a new calibration or does it matter.
post #73119 of 73134 Old 12-15-2014, 05:14 PM
Quoted: 43 Post(s)
Liked: 3
Originally Posted by mogorf View Post
Another +1.
Thats what I use now unless I am listening late at night. Thanks for the info!
post #73120 of 73134 Old 12-15-2014, 05:14 PM
mogorf's Avatar
Quoted: 257 Post(s)
Liked: 133
Yes!
But, to save you some time please follow the Subwoofer Crawl video before running Audyssey calibration:
markrubin likes this.
post #73121 of 73134 Old 12-15-2014, 06:19 PM
antennahead's Avatar
Quoted: 67 Post(s)
Liked: 25
^ Is that some new hip hop dance........ the subwoofer crawl?
antennahead is online now
post #73122 of 73134 Old 12-15-2014, 06:32 PM
mogorf's Avatar
Quoted: 257 Post(s)
Liked: 133
Yeah, sort of,...its something that may easily lead you to finding the best place in-room for your sub(s) for achiving deep, smooth and even bass when its done properly. Part of a so-called "cold set up" prior to running your room EQ s/w. Should you have little kids they will enjoy what Papa is doing by riding on your back. What you tell your better half for doing stuff like that is up to you or your talent!!!
post #73123 of 73134 Old Yesterday, 01:58 AM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 2252 Post(s)
Liked: 667
NorthSky is online now
post #73124 of 73134 Old Yesterday, 08:40 PM
Quoted: 43 Post(s)
Liked: 3
So I ran 4 different calibrations with a subwoofer and each time although my sub is only 6.9 fee from my PML audyseey says it is over 9 feet all 4 times. Since I do not have carpet I lay blankets down everytime in order to get a proper frequency for the speakers as this works but is this the reason the sub measurement is way off. I have it in front of my tv, I tried twice on the left twice on the right. My set up is small from speakers, tv to PML but wide open on either side. Maybe move the sub to the side for next test. Although it says it is 9ft the sub seems quit on audysee although when I toggle , EQ is lots of bass, aud bypass lots, off is lots. This time though the center doesn't seem to pop out in Audyseey like it had previously. Anyway I am able to bring up my old settings and manually adjust the distance, also is it possible to simple pre put in a distance of a speaker or sub before the test.
post #73125 of 73134 Old Yesterday, 08:45 PM
Liked: 922
The sub distance determined by Audyssey is really a delay, not a physical distance. It is quite common for the AVR distance to be larger than the physical distance because of internal delays due to the sub's electronic circuitry. You should not be concerned at all.
Alan P likes this.
post #73126 of 73134 Old Yesterday, 08:57 PM
Quoted: 43 Post(s)
Liked: 3
ok sweet. Thank you
found that in the beginners guide, long read
"26. You may also notice that Audyssey has set your subwoofer distance from the Main Listening Position much greater than it actually is if you measured it with a tape measure. This is perfectly normal. Audyssey does not measure the actual distance, but the delay between the signal leaving the subwoofer and arriving at the mic. Because many subwoofers have internal circuitry and filters inside them, they can add a significant delay to the sound arriving at the mic. Audyssey takes this delay into account and sets the subwoofer distance accordingly. Do NOT change the subwoofer distance manually."
post #73127 of 73134 Old Yesterday, 09:14 PM
NorthSky's Avatar
Liked: 667
That's right:
1. The distance to the subwoofer starts @ its woofer driver's voice coil (that's roughly four to six inches additional).
2. The subwoofer's own crossover produces an electrical delay* that can vary from roughly one to four feet, depending of the sub itself and its positioning.
3. And that also includes the digital filters from its own DSP EQ. ...And Phase selection.
* One foot distance equals one millisecond delay. ...Your own sub's x-over is roughly adding 2ms delay. ...Which is generally better than the average.
And Audyssey compensated for it.
post #73128 of 73134 Old Yesterday, 09:19 PM
NorthSky's Avatar
Liked: 667
...It's all mechanical really.
post #73129 of 73134 Old Today, 04:41 AM
kbarnes701's Avatar
Quoted: 2518 Post(s)
Liked: 2241
It's for regular questions like this that I wrote the FAQ
f)1. Why has Audyssey set my sub distance much greater than it actually measures?
kbarnes701 is online now
post #73130 of 73134 Old Today, 11:04 AM
zeus33's Avatar
Quoted: 331 Post(s)
Liked: 256
Your listening environment should not be altered from the way it normally is. You will not get accurate results if you add blankets for the calibration that aren't normally there. Leave your room the way it normally is when you run your calibration. This is covered in the Audyssey FAQ.
zeus33 is online now
post #73131 of 73134 Old Today, 11:12 AM
mogorf's Avatar
Quoted: 257 Post(s)
Liked: 133
+1.
On a second note I would buy carpets, they serve multiple purposes. Just thinking out loud!
post #73132 of 73134 Old Today, 01:22 PM
Quoted: 43 Post(s)
Liked: 3
I read that again last night. Mostly for the sub info. I did read somewhere, not sure there or somewhere else that the sub gain should be between -+3 and my calibration set it at -4. Should I re-calibrate
post #73133 of 73134 Old Today, 01:52 PM
NorthSky's Avatar
Liked: 667
The Sub's Gain control is @ the rear of the sub itself (round black knob). * People usually set it @ between 9 and 11 o'clock.
The Sub channel level (trim control) from your receiver has been set by Audyssey @ -4.0dB ... That is perfect, leave everything there, your Audyssey calibration is done. ...Mission accomplished.
mogorf likes this.
post #73134 of 73134 Old Today, 02:03 PM
kbarnes701's Avatar
Liked: 2241
I think you are referring to the sub trim level in the AVR.
If so - that is fine. The ±3.5dB thing is just a rough guide. My sub trim comes in at -6dB for example and I am happy with it. The basic idea is to get enough sub trim to drive the sub amp input sufficiently, but not so much trim you run the sub amp input into clipping. Think of the trim setting as a control which varies the output voltage of the sub preout on your AVR. You want enough output voltage so that you don't feed the sub with a puny signal, forcing you to increase the gain excessively on the sub (and along with it, the noise floor) and OTOH you don't want to feed the sub amp input with so much voltage that it is more than the sub amp can handle and drive it into clipping. At -4db trim you are good to go.
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
