"Official" Audyssey thread (FAQ in post #51779) - Page 2441 - AVS Forum
post #73201 of 73203 Unread Today, 10:36 AM
kbarnes701's Avatar
Quoted: 2589 Post(s)
Liked: 2278
Originally Posted by Brahmzy View Post
Yes, I've read those FAQs extensively - great help.
Unfortunately, My new home / great room is somewhat of a reflecto-chamber. All hardwoods, leather couches, 9ft flat ceilings etc. I've got a massive area rug in the main listening area completely covering up the wood, but that doesn't help the rest. The closest wall behind the main listening position is 25-30ft away.
Not much treatment I can do, or rather, that the wife would allow me to do that wouldn't look horrendous.
That could explain the problems you are having with dialog intelligibility. Unfortunately, short of adding treatments or using a different room there isn't a lot you can do. Room correction EQ alone won't help in a room that is so lively. Good quality headphones might be an option. If you use good headphones and add a bass shaker under your couch, you can get a really good experience, with the bass feeling like it is coming from the headphones, even though it is the couch getting a good thump. Crowson and Buttkicker make good tactile transducers.
kbarnes701 is online now
post #73202 of 73203 Unread Today, 02:46 PM
Quoted: 46 Post(s)
Liked: 3
Is it ok to just turn on dynamic volume without dyn EQ r vice versa or should both always be on together.
Federo5 is online now
post #73203 of 73203 Unread Today, 03:00 PM
Selden Ball's Avatar
Quoted: 814 Post(s)
Liked: 528
That's entirely up to you.
Selden
Marantz SR7009/7.1.4/FH+TM/DefTech PM1000/LCR+TM amped
Selden Ball is online now
post #73204 of 73203 Unread Today, 04:00 PM
batpig's Avatar
Quoted: 1204 Post(s)
Liked: 1612
Audyssey would say it's not OK -- the tonal adjustments of DEQ are necessary to keep the balance consistent as DV is lowering the volume. However, some folks find the bass boost in DEQ sort of counterproductive if they are trying to lower the late night bass using DV. Personally, I find the sound to be too thin and anemic if I'm using DV without DEQ, but there is a segment of folks out there who just hate DEQ. I use it all the time, although I always use the Ref Level Offset to tone it down a bit (rather err on the side of less compensation than too much).
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
