"Official" Audyssey thread (FAQ in post #51779) - Page 2442 - AVS Forum
post #73231 of 73256 Old Today, 02:05 AM
Quoted: 57 Post(s)
Liked: 4
Originally Posted by josey88 View Post
Well... I have been reading all those posts about calibrations and settings ... I will be getting the 7200W receiver next month but I am truly beginning to worry about all of this . It seems that it will be a nightmare of dozens of different inputs and different calibrations and settings in order to obtain a decent sound out of these receivers if I am going to believe all these threads ... hope not , and that Denon will have some way to set everything in a more simple way .
I have my old trusty 5803 with a simple set up , not too complicated and I have had wonderful sound out of it all these years .
Unfortunately , it needs to be upgraded in order to get 4K HDMI connections , Dolby True-HD , Atmos, etc , so that is why the 7200W is coming to play .
Now, having said that , I think that perhaps I will be having some problems with the way I have my subs set up and this "Audyssey thing" on the incoming receiver ...
I have my speakers on "large" (all of them) and the two subs on LFE+Main and I do get plenty of very low bass on the subs . BTW, the subs are in "auto " and they turn on instantly .
All of my speakers ( Sonus Faber "Electa Amator II" front mains , Sonus Faber " Solo" center and Jamo D8 concert surrounds and Jamo E6 surround backs) are full range .
The calibration level that I use is a sound meter from RadioShack and I do it at 70 DB, "C" weighting and "Slow" response and not at 80 DB.
The two SF "Gravis" sub`s filter pass are set at 47thz , so , as they go down to 24hz , they take care of the real low bass over the speakers at that higher point very fluidly and with much better impact , of course , although I get bass from the mains too but these subwoofers are very musical and they modulate the lower bass notes incredibly .
I really don`t know how I am going to interact with setting the speakers to "small " and the subs to 80 which seems silly to me ... I think that I tend to mix my "audiophile" point of view with the correct calibration for movies .
I guess I am in for a lot of experimentation .
I use the front main speakers and the subs with my other stereo hi-end equipment too , so I alternate them (I have developed a system of 2 sets of cables for that) , but the Denon 7200W will be used just for movies and internet music , Pandora , etc . The trick will be to find the balance between the setting of the speakers /subs with the different movie sound types and Pandora`s music ... ah, well !!!
The best thing to do is make sure you turn off all your wifi, cable, cell phone, clocks, make sure it's totally silent, and make sure your mic is PERFECTLY centered and level and away from the cushion and should be fine.
Federo5 is offline
post #73232 of 73256 Old Today, 02:06 AM
Quoted: 57 Post(s)
Liked: 4
Originally Posted by NorthSky View Post
You asked for "any tips to take it to the next level (no 2nd sub)", for "any boosters or anything to purchase to compliment my Marantz 7008 and Klipsch speakers in the future to continue to improve detail" (all above in your first quote, highlighted in red).
Well, short of acoustical room treatments, or upgrading your Klipsch speakers to Magico loudspeaker ones (all around); that is one "tip" (solution to a higher listening surround sound experience). ...Closer to audio nirvana bliss. ...I think. ...And very affordable too.
I just bought these, lol.
42.5k for q3 speaker. Umm that's a little out of my price range ATM, lol
Federo5 is offline
post #73233 of 73256 Old Today, 04:33 AM
kbarnes701's Avatar
Quoted: 2623 Post(s)
Liked: 2312
If you are new to Audyssey I suggest you start by reading the '101' and FAQ, both linked in my sig. They should answer all setup questions for you.
If you have a specific question, post it here and you will receive a good number of suggestions I am sure.
kbarnes701 is offline
post #73234 of 73256 Old Today, 05:34 AM
pbarach's Avatar
Quoted: 109 Post(s)
Liked: 113
Audyssey may find your speakers to be full-range and will want them set to LARGE. You don't have to disagree with that, if your new receiver has enough power to run all of your speakers at your desired volume levels. Setting speakers to SMALL lets the subwoofers' amps do most of the heavy lifting, since bass frequencies use most of the power.
Audyssey will set 0 dB as reference-level (75 dB). This is not the same thing as the 70 dB figure you get on a sound pressure meter. "Reference level" means each speaker level must be adjusted so that –30 dBFS band-limited (500 Hz – 2000 Hz) pink noise produces 75 dB sound pressure level at the listening position. In other words, the maximum level you will get from a system set to reference level is 105 dB.
AT&T U-Verse Northeast Ohio
Denon x4000, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, etc.
pbarach is offline
post #73235 of 73256 Old Today, 06:42 AM
funhouse69's Avatar
Quoted: 176 Post(s)
Liked: 51
When I upgraded from my RB-81's to the RF-82's and re-ran Audyssey it detected my mains as Full Range. So you are saying I should set them to Large or even Small? Is that going to change any other settings or do I also have to change other settings as well (like Crossover)?
Denon AVR-X5200 - Klipsch RF-82 II Fronts, RC-62 II Center, RS-52 II Surrounds & R-112SW & CDT-5800-C II sitting waiting to be installed for an Atmos 5.1.4 Setup.
funhouse69 is offline
post #73236 of 73256 Old Today, 07:04 AM
Quoted: 57 Post(s)
Liked: 4
It's up to you, I have the 82 2's and after the test it also set them to large and 40 HZ, I switched them to small and 80hz since I have a good subwoofer. I am also bi-amped. If anyone here can look at my question in the marantz thread I would appreciate it
funhouse69 likes this.
Federo5 is offline
post #73237 of 73256 Old Today, 07:04 AM
funhouse69's Avatar
Quoted: 176 Post(s)
Liked: 51
I just went through the FAQ and decided to set my Front / Mains to Small and set all of the crossovers to 80hz to see how that goes when watching a move. The settings before were Large with "Full Range" for the fronts and the Crossover for all my other speakers were at 60hz.
post #73238 of 73256 Old Today, 07:07 AM
Quoted: 57 Post(s)
Liked: 4
I have the rc'62 2 and rf 82 2's so we almost have the same. I have two towers for backs/surround and a 7008 receiver. The fronts sound clearer when u set to 80hz and small because they focus mainly on the highs. I find when the sub was on and the speakers were set to large and 40HZ it was way to much bass all the time. Our fronts are very good at producing bass.When I make the adjustments it's much crisper all around
Federo5 is offline
post #73239 of 73256 Old Today, 07:59 AM
Selden Ball's Avatar
Quoted: 837 Post(s)
Liked: 537
Modern D+M AVRs and pre/pros have a very user-friendly "setup assistant". It'll lead you through connecting your speakers and input devices and running the Audyssey calibration procedure. For example, all of the speaker outputs are connected by individual electro-mechanical relays which the setup procedure makes use of when it tells you to connect a particular pair of speaker wires. This helps to isolate wiring problems.
(Unfortunately, there are some bugs related to overhead speaker calibration in the initial release, so you probably should run it again after it has helped you configure the network and download the current firmware update.)
Also, please take the time to read the Audyssey 101/FAQ (<-- this links to the FAQ). Their recommendations have been developed over a long period of time to help you get the best results. The instructions provided in AVR manuals are woefully inadequate.
"Plenty of very low bass" is not necessarily the same as "accurate bass". In particular, if you haven't been very careful when setting the low pass filters in your subs to match the natural low-frequency fall-off of your main speakers, you might have gotten used to the "bloated" bass caused by the interactions between their overlapping frequencies. Often people who've gotten used to inaccurate, boomy bass tend to feel that Audyssey's results are "anemic".
Audyssey's calibration is done at 75dB. It doesn't matter what level is used for a calibration, so long as it's consistent. 75dB is quiet enough that it doesn't bother most people, and its individual calibration pulses are brief.
There are several reasons for choosing a crossover frequency of 80 Hz, which you might want to consider. Some are related directly to sound quality, others more to electronic capabilities.
1. Room modes: Low frequencies interact with your room's dimensions, resulting in peaks and nulls in sound levels at various locations and frequencies, potentially up to about 200 Hz depending on the size of the room. This is quite unlike how higher frequencies interact with the room's surfaces. You have to place subwoofers so they produce the flattest response at your main listening position. The optimal locations for subwoofers usually are not the same as the optimal locations for your main speakers.
2. Speaker capability: Distortion increases as you push speakers to the limits of their frequency performance. By offloading the lowest frequencies from the mains and surrounds to subwoofers which are better designed to handle them, you're reducing that distortion.
3. Amplifier capability: Distortion increases as you increase an amplifier's output toward its maximum. Most of an amplifier's power is needed to drive woofers at low frequencies. By offloading the lowest frequencies from the amps used for the mains and surrounds to the amps in the subwoofers, you're reducing that distortion, too, as well as making more headroom available.
Yup! Some people consider this an enjoyable part of the audio hobby. Not all do. (I'm actually more toward the latter end of the spectrum.)
D+M AVRs and pre/pros support using separate connections for separate sets of A and B main speakers. Using that feature does reduce the options available for the main surround-sound configuration, though.
And, of course, if you decide that you don't like how Audyssey works in your room, you can easily disable it.
I hope these comments help a little.
kbarnes701 likes this.
Selden
Marantz SR7009/7.1.4/FH+TM/DefTech PM1000/LCR+TM amped
Selden Ball is online now
post #73240 of 73256 Old Today, 08:04 AM
Quoted: 57 Post(s)
Liked: 4
When you talk about over lapping bass, my speakers are 80hz and lpf is 120. Is this ok?
Federo5 is offline
post #73241 of 73256 Old Today, 08:31 AM
Quoted: 837 Post(s)
Liked: 537
Yes, it is OK.
The LFE LPF provided in modern AVRs is used only for the LFE channel (the channel designated as .1) as it comes off the disc. It does not affect the sounds sent to or coming from the other speaker channels. The on-disc LFE channel is allowed to contain frequencies up to 120Hz. However, a few people have found that they like the sound of the LFE channel better if they reduce its LPF to 80Hz. Remember that filters are not "brick walls". They have a "slope" and do allow some higher frequencies through. (Also, the LFE channels on a few Blu-rays have been reported to contain unintended noise at frequencies above 120Hz because the mixer forgot to engage the LFE filter in the mixing software. While lossy multichannel endoders cannot physically include frequencies above 120Hz in their LFE channel, the lossless encoders can provide full-frequency bandwidth in all channels, including LFE.)
Overlapping bass happens when you send full-range signals to the main speakers, but replicate their lowest frequencies in the subwoofer(s) (i.e. turn on LFE+MAIN). Before the advent of receivers which included bass management, that was the only option available. The low pass filter on the subwoofer itself had to be carefully adjusted so that the subwoofer's high frequency sounds would blend in with the low frequency sounds coming from the main speakers.
Selden
post #73242 of 73256 Old Today, 08:38 AM
Quoted: 57 Post(s)
Liked: 4
Ok thanks! Would you know about my bi-amping q. I also turned off the zone 2 even though i picked zone 2 5.1 bi amp. My receiver was staying hot and i only watch in one room
Federo5 is offline
post #73243 of 73256 Old Today, 09:01 AM
Quoted: 837 Post(s)
Liked: 537
Sorry, I can't help much with bi-amping. I've never used it.
However, by picking the amp assignment "zone 2 5.1 bi amp", you have explicitly enabled the separate zone 2 in addition to the bi-amping. The zone 2 amps and preamps (and a lot of the receiver's shared circuitry) are on until you turn them off as you did.
If you want to keep it simple for a bi-amped 5.1 speaker configuration (and are not using Atmos), you can select the amp assignment "7.1 channel (Bi-Amp)". Then when you run the calibration it will turn off the speakers that you don't have.
Otherwise, you need to select the 11.1 amp assignment and do the settings manually.
Selden
post #73244 of 73256 Old Today, 09:14 AM
Quoted: 57 Post(s)
Liked: 4
So its ok to choose 5.1 bi amp and zone 2 and just turn off zone 2?
Federo5 is offline
post #73245 of 73256 Old Today, 09:16 AM
Quoted: 837 Post(s)
Liked: 537
Yes.
Selden
post #73246 of 73256 Old Today, 10:53 AM
Quoted: 29 Post(s)
Liked: 2
Yup! Some people consider this an enjoyable part of the audio hobby. Not all do. (I'm actually more toward the latter end of the spectrum.) D+M AVRs and pre/pros support using separate connections for separate sets of A and B main speakers. Using that feature does reduce the options available for the main surround-sound configuration, though.
Selden , my main speaker`s fall off low frequency is 35hz and the subs are set at 42hz ( not 47hz , as I said previously . I didn`t seem right , so I visually checked to be sure and yes , the filter pass are set at 42Hz , my apologies) .
The subs interlap the mains low frequencies perfectly ... no bloated bass here , I can assure you .
I will read the Audyssey thread , for sure.
BTW , the subwoofer setting for the Denon`s 5803 is set at 40hz variable .
And yes, I think that 75 DB cut be acceptable .
josey88 is offline
post #73247 of 73256 Old Today, 11:30 AM
pbarach's Avatar
Quoted: 109 Post(s)
Liked: 113
Audyssey systems on two different Denon models (4310 and x4000) each wanted to set my center channel and surrounds as LARGE. These are not full-range speakers in any sense of the word. Maybe they can output some low bass, but it's going to be much more distorted than the low bass output of my two subwoofers. Similarly, my front mains (B&W 704) are good down to about 30 Hz and they make some sound below that point (using test tones on a CD to check this), but I get much more bass impact by setting them to SMALL. I use 80 Hz all around as a crossover. I tried 60 Hz for the front mains and didn't hear any real difference between that and 80 Hz.
pbarach is offline
post #73248 of 73256 Old Today, 11:34 AM
TorelliTom's Avatar
Hopefully someone can enlighten me on something. Just got a Marantz NR1504, which is my first AVR with Audyssey or anything like it. Ran the setup, did six positions, and everything seems to sound great except the sub. No matter where I set the output level on the sub (other than basically almost off, -6db or even lower (no markings that far down on dial)) audyssey sets it at -12db. Its an older M&K MX-125 Mark II, which by todays standards should be pretty tame, but am I being told by the program that its too much for my room? At this point its barely audible. Room is roughly 12x15 standard living room. Sub is in the corner but not too close to either wall.
Thanks in advance!
TorelliTom is online now
post #73249 of 73256 Old Today, 11:38 AM
kbarnes701's Avatar
Liked: 2312
I agree. No matter how low the main speakers go, they will always struggle to reproduce very low frequencies, very loudly, compared with a good purpose-designed sub. Very low, very loud sounds demand huge amounts of amplifier power, which may or may not be readily available via the AVR amps. This in turn can affect the higher frequencies which may be starved off power on loud bass peaks. And it is also a huge ask of a regular speaker too to make loud 20Hz sounds, again stressing the speaker unneccessarily. If you have a sub, use it. That's what it was bought for. And low bass, loud, is what it does best.
post #73250 of 73256 Old Today, 11:40 AM
kbarnes701's Avatar
Liked: 2312
Thanks in advance!
You need to set the sub's physical gain knob lower so that Audyssey sets the trim higher. At -12dB you have maxed out the trim.
See here:
f)3. How do I set the controls on my subwoofer before running MultEQ?
f)4. If I want to run my subs a little 'hot' where should I make the changes?
f)5. Since I ran Audyssey everything sounds great - but where has my bass gone?
post #73251 of 73256 Old Today, 12:29 PM
Quoted: 29 Post(s)
Liked: 2
Yes, 100% correct. That is why I set my two Gravis subs at 42hz . They overlap my front main speakers , that can go down to 35hz , but would need to be cranked real loud for that , while the subs can take over from 42hz down to 24hz effortlessly and at normal sound levels . The trick , as Selden pointed out previoulosly , is the overlapping frequencies . If you do it right , the result is incredible accurate bass .
Of course , I am referring to music .
josey88 is offline
post #73252 of 73256 Old Today, 12:43 PM
TorelliTom's Avatar
See here:
Thanks, and I will read through that stuff before running another test, its just that the sub is literally turned down all the way and i'm still getting the -12. Could the fact that its a 'push-pull' design have anything to do with it? I read it can cause issues with what audyssey determines as the distance.
post #73253 of 73256 Old Today, 01:39 PM
kbarnes701's Avatar
Liked: 2312
Each to his own. Personally I'd let the subs do what they are designed for and cross over at 80Hz, taking strain off the mains and letting them give their best.
How did you resolve the phase issues from the 'overlapping' subs/speakers?
post #73254 of 73256 Old Today, 01:44 PM
kbarnes701's Avatar
Liked: 2312
It isn’t turned down ALL the way or it would make no noise at all Do you mean that if you turn it any lower it actually stops making noise? The knob on the sub is a gain control not a volume control, so there's no downside to setting it low. It just means the sub will deliver its rated power from a smaller input voltage. If it is truly turned as low as it will go and you still max out the trims (which I have never heard of before) then we will need to consider the next step.
The delay on the sub (distance) isn't the issue. It's the SPL it is producing. So much that Audyssey is trying to turn it down lower than it will actually go (trim-wise).
Mic was upright and at MLP for the 1st measurement? What is the distance from MLP to the sub?
TorelliTom likes this.
post #73255 of 73256 Old Today, 04:27 PM
mogorf's Avatar
Quoted: 261 Post(s)
Liked: 135
Please, let's not spread wrong technical information coz it causes confusion. The "gain" of the subwoofer plate amplifier is fixed, its constant and its carefully calculated and designed by R&D engineers. Gain is the characteristics of the active components in the circuit (transistors) and it does not change.
What can be changed (by the knob) on the subwoofer plate amp is the level of the incoming signal. Basically the knob can only attenuate this signal being a passive component. But in that case in order to reach the desired power output the level of the subwoofer output on the AVR must be increased. This is because "gain" is constant, so an attenuation on the plate amp side requires an increase of the output trim on the AVR side.
Hope this clears up matters.
mogorf is online now
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
