"Official" Audyssey thread (FAQ in post #51779) - Page 2443 - AVS Forum
post #73261 of 73265 Unread Today, 05:32 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 2426 Post(s)
Liked: 714
Originally Posted by garygarrison View Post
Except for the subwoofer, which will be allowed to produce 115 dB
...On peaks.
NorthSky is online now
post #73262 of 73265 Unread Today, 05:42 PM
mogorf's Avatar
Quoted: 268 Post(s)
Liked: 136
Originally Posted by NorthSky View Post
...On peaks.
And with dual subs on "Twin Peaks"...couldn't resist.
mogorf is offline
post #73263 of 73265 Unread Today, 06:07 PM
NorthSky's Avatar
Liked: 714
I luv it! ...The true real Holidays spirit. ...Luv you Feri, all of you.
post #73264 of 73265 Unread Today, 07:25 PM
Quoted: 58 Post(s)
Liked: 4
Originally Posted by ggsantafe View Post
Please - let's not continue to obfuscate an already well defined concept and make it more difficult for the OP to find a reasonable and simple solution, as proposed by Keith
remind me not to play scrabble with you mr obfuscate
Federo5 is offline
post #73265 of 73265 Unread Today, 11:39 PM
lego1's Avatar
Question for you guys. I recently bought a used denon 1911. It is equipped with audyssey multeq. I also have the anti mode 8033 sub eq I was using since my previous rotel AVR did not have room correction.
I ran audyssey with a mic stand and am happy with the sound but read that all prior forms of audyssey except XT32 heavily correct the upper frequencies over 500hz which can effect speaker performance and hardly correct the sub. I checked the eq corrections under the audyssey menu and saw that the upper frequencies over 500hz are in fact boosted 3-4 dB.
My question is, since I don't have XT32 in this receiver, am I better served with turning the eq off and using the anti mode for sub eq, using the audyssey eq, or using anti mode and copying the audyssey flat curve to the manual eq and changing all corrections for frequencies over 500hz to 0.
Regardless what I do, I am still using the levels and distances set by audyssey.
My speakers are the B&W 685 for front, B&W HTM61 center, PSB S5 for surround, and Tannoy Di5DC for front height. My sub is the HSU STF2. All speakers are crossed away 80hz except the Tannoy which are crossed at 90hz.
lego1 is online now
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
