"Official" Audyssey thread (FAQ in post #51779) - Page 2459 - AVS | Home Theater Discussions And Reviews
post #73741 of 73755 Old Yesterday, 11:13 AM
Quoted: 62 Post(s)
Liked: 5
Originally Posted by JimP View Post
You didn't say which Klipsch center so I just went with the first one I came across. I think the rubber half moons are intended to be used to fill the holes if you don't use the tilt rod, otherwise you use the threaded holes for the tilt rod. Check page 3 paragraph center channel speakers that refers to figure 4 in the pdf. Here's the pdf. http://images.klipsch.com/Reference2...6138280000.pdf
If your didn't come with anything other than the speaker and the rubber half moons, then somebody shorted you the tilt assembly.
It's the klipsch 62.2. There are no holes though except for two just off center staggered either side of center with grooves
Federo5 is offline
post #73742 of 73755 Old Yesterday, 11:14 AM
Quoted: 62 Post(s)
Liked: 5
I'm trying to figure out what it might look like to see if the gf put it somewhere around here. I can't find it on Google. Maybe I'll just have her lay down and use her as the tilt rod
Federo5 is offline
post #73743 of 73755 Old Yesterday, 01:11 PM
ambesolman's Avatar
Quoted: 516 Post(s)
Liked: 504
Originally Posted by Federo5 View Post
I'm trying to figure out what it might look like to see if the gf put it somewhere around here. I can't find it on Google. Maybe I'll just have her lay down and use her as the tit rod
Fixed it for you[emoji6]
Sent using Tapatalk since the mobile version is still [emoji107]
ambesolman is online now
post #73744 of 73755 Old Yesterday, 01:25 PM
mogorf's Avatar
Quoted: 317 Post(s)
Liked: 146
Originally Posted by josey88 View Post
I am glad that I am not the only one that have used a protractor (and strings, in my case) to measure the location and placement of the surround speakers , lol...
So, how does it sound?
mogorf is offline
post #73745 of 73755 Old Yesterday, 01:32 PM
josey88's Avatar
Quoted: 78 Post(s)
Originally Posted by kbarnes701 View Post
And do you have a vise to clamp your head in while watching a movie?
Of course not , but in order to take maximum advantage of my limited options on the ceiling space (because , as you know, my surrounds and back surrounds are too placed on the ceiling) I needed to find the best max distance between heights and surrounds so I would be able to differentiate the output of each set of speakers against the other ... at least, that was the intention .
I also had to include the position of the Wides with relation to the overhead heights placement on the ceiling , even thou they are at 3.5 feet from the floor .
I spend a few days on thinking and on doing measurements , so it wasn`t easy and besides all of that , I wanted it to look right too for the wife approval angle , so, it wasn`t easy at all .
But it worked .
Now , on music , which in contrast to movies where the surround sound is more sporadic , I can enjoy the distinct difference in between dolby surround and DTSNeo :X music formats .
On DSU format , the surround sound is more centered at front and from the top of my seating position to the back and down because the top middle speakers are working ... separately from the sound of the surrounds behind me .
With the DTS Neo :X music format instead , the surround sound is extensively spread out at front to the sides because of the Wides . The front heights overhead are also clearly distinct (the top middles are silenced) so the surround sound is extended to the sides of the room at front and from the top front down with the surrounds and back surrounds filling up the back . It is just a matter of taste and types of music to go with one or the other format , but both formats are absolutely fantastic .
As an example , Patricia Barber sounds better on DTSNeo:X Music , in my humble opinion .
I am pleased with the system I put in place . I have obtained what I wanted . Even thou Atmos is perhaps not technically correct on the speakers location because of the above surrounds placement , the sound of the atmos movie was incredible .
The other movies that I have tried (since the last two weeks when the 7200 arrived) were DTS HD master Audio and on the A-DSX format the sound is also incredible ... I am completely satisfied with the performance of my 7200W and well worth its cost .
If I were to compare the surround performance between my old 5803 and the 7200 , in reality , there is no comparison at all . It is like comparing a domestic Siamese cat to a Bengala Tiger . The surround formats on the 7200W are so advanced that there is no comparison , so every time I power it up I am thrilled .
Do I need to clamp my head ? the answer is , happy to say it , no .
Last movie I rented yesterday was FURY ... what can I say ... I am still thinking about the sound on that movie ... the tank battle was unbelievably real
josey88 is online now
post #73746 of 73755 Old Yesterday, 01:51 PM
josey88's Avatar
Quoted: 78 Post(s)
Well, to tell the truth , the 7200W has surpassed my expectations . I had no idea that regular PCM could sound like that . I am a hardcore stereo guy , but the surround on this receiver is really amazing . Fabulous equipment and not a single issue with it .
I have tweaked Audyssey a little bit on crossovers , but just very little .
On movies ... well , it has jumped me to present performance standards so I made a correct decision on buying this thing .
Now , to wait for DTS;X upgrade (hopefully) and HDCP2.2 later on ... all is well .
post #73747 of 73755 Old Yesterday, 02:36 PM
kbarnes701's Avatar
Quoted: 3050 Post(s)
Liked: 2535
But it worked .
I was only joking with you. But thanks for the long response. I am glad that you are enjoying it all so much - makes all the expense and time and effort well worthwhile, I agree.
kbarnes701 is offline
post #73748 of 73755 Old Yesterday, 03:01 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 2964 Post(s)
Liked: 991
That, is a very good overall consideration.
...From it we can almost deduct the utmost importance of Audyssey's graphs with the help of REW when mic measurement is taken @ the critical MLP.
But that's why Audyssey MultEQ Pro can take up to 32 microphone measurements @ them respective locations.
That is a lot of graphs to show.
mogorf likes this.
NorthSky is offline
post #73749 of 73755 Old Yesterday, 03:05 PM
NorthSky's Avatar
Liked: 991
But it worked .
Loved, immensely, reading your two above posts.
NorthSky is offline
post #73750 of 73755 Old Today, 06:00 AM
buckley44's Avatar
Quoted: 31 Post(s)
Liked: 26
I have a question, I have a Paradigm signature sub with a Bass contour nob that if it's turned up gives a 6db while watching movies, it should be left at 0 for music. If I Turn this nob do I have to re-run Audyssey, which I don't think I do. Or am I mistaken???
From my sub manual -Adjusts the contour of the bass frequency response, from flat (0.0 dB),
which provides the most accurate bass for music, up to a +6.0 dB boost
at 60 Hz for more bass impact with movies in a home theater system.
This control can be used to tailor bass to best suit your personal
listening preferences
buckley44 is online now
post #73751 of 73755 Old Today, 06:01 AM
buckley44's Avatar
Quoted: 31 Post(s)
Liked: 26
post #73752 of 73755 Old Today, 08:26 AM
batpig's Avatar
Quoted: 1348 Post(s)
Liked: 1715
No need to re-run Audyssey, as you are basically adding a "preference bump" on top of the "flat" calibration. If you were to recalibrate Audyssey with the boost in place, Audyssey would expend resouces trying to knock down the bump and restore a "flat" bass profile.
So calibrating with the sub in the "flat" mode is correct, and then you can layer on additional boost for movie impact if you prefer it.
Alan P and 49Merc like this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #73753 of 73755 Old Today, 08:28 AM
buckley44's Avatar
Quoted: 31 Post(s)
Liked: 26
Thank you for your Help!
post #73754 of 73755 Old Today, 08:45 PM
buckley44's Avatar
Quoted: 31 Post(s)
Liked: 26
If I accidentally move my phase nob from 180 degrees to 0 and I move it right back to 180 realizing my mistake, I won't have to re run Audessey again will I ??
post #73755 of 73755 Unread Today, 09:15 PM
ambesolman's Avatar
Quoted: 516 Post(s)
Liked: 504
No
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
