"Official" Audyssey thread (FAQ in post #51779) - Page 2460 - AVS | Home Theater Discussions And Reviews
post #73771 of 73799 Old 01-30-2015, 04:31 PM
Alan P's Avatar
Quoted: 1261 Post(s)
Liked: 629
Some AVRs will let you adjust tone controls and still keep Audyssey active, some won't. I'm sure BatPig knows which ones are which.
49Merc likes this.
AVR: Denon 4520ci, FL/R: Klipschorn, CC: Klipsch RC64ii, SUR: Polk LS F/X x 4, SUB: PSA T-18 x 2, DISP: Mitsubishi WD-73740, BluRay: PS3 & BDP-S5100, Remote: URC MX-700
Getting Started with REW
Audyssey 101
Audyssey FAQ
Alan P is online now
post #73772 of 73799 Old 01-30-2015, 04:34 PM
mogorf's Avatar
Quoted: 317 Post(s)
Liked: 147
Originally Posted by 49Merc View Post
I'm not having any audio setting problems thanks to many of you yet after reading comments regarding tone control I'm now a bit curious. In my Denon AVR 1912's Audio Adjust, Tone is gray thus not adjustable. Audyessy is in use.
That's the way it should be.
49Merc likes this.
mogorf is online now
post #73773 of 73799 Old 01-30-2015, 07:29 PM
garygarrison's Avatar
Quoted: 52 Post(s)
Liked: 58
Originally Posted by Federo5 View Post
But it doesn't override or negate the audeseey settings right? It's just enhances them?
On my Marantz AV7005 (it's a preamp processor, very similar to the "front end" of Marantz AVRs, and some other AVRs) using the on-screen graphic EQ sliders (8 bands in bass, midrange and treble) DOES TURN AUDYSSEY OFF, while using the TONE controls for bass and treble under "Audio Adjust" DOES NOT. If in doubt, check to see if your Audyssey light is on, if you have one. The TONE controls (on mine) only have +/- 6 dB of range. I sometimes use them for music or movies that need them. The bad news is that if you use Dynamic EQ, the tone controls will not be available to you. I find I can get the best balance with Audyssey near Reference level, DEQ off, and occasional use of the true bass control (under "Audio Adjust"). Audyssey itself is not designed for optimizing program material, just the room and speakers. Many people find it a little bass shy.
Also beware any base (not bass) copy function. It doesn't copy the more than one hundred Audyssey corrections, but only crudely copies the curve at 8, or so, broad points. Chris K., the head of Audyssey, says it is best to not use it at all.
For bass comp, some people just turn up the sub, but that only helps below the crossover point (say, 80 Hz). If you need more bass impact at about 100 Hz or above, you would have to use the true TONE controls (not virtual sliders), or play considerably below Reference, and use DEQ.
I'm surprised you need treble boost, if Audyssey is set up right and your speakers have good high frequency response and are aimed right.
Good luck!
garygarrison is online now
post #73774 of 73799 Old 01-30-2015, 11:46 PM
milehighou's Avatar
After a lot of playing around, I've found that I prefer dynamic EQ off for 2-channel music. I did a lot of listening, and it just boosts the bass too much (even with reference offset on 15 dB). Audyssey and DynEQ seem fine for movies, but it's just not my thing for music. Anyone else agree?
For 2-channel, I'm using:
Bypass L/R
DynEQ off
Audyssey set my sub to -5.5dB, but for music, I raise it by 4 dB to -1.5dB. If if measure levels with these settings using a dB meter, I get a pretty balanced mix.
I do like how it EQs the sub. The bass seems cleaner and tighter with it on, but I don't like it messing with my mains,
milehighou is online now
post #73775 of 73799 Old 01-30-2015, 11:58 PM
remedy1978's Avatar
Quoted: 12 Post(s)
I ran Audyssey tonight with my Denon X3000. It set my mains to 100hz, center to 150hz, and surrounds to 80hz. I have RBH MC-6Cs for mains and surrounds and the MC-414C for my center.
Should I set the surrounds to 100hz same as my mains, or set everything to 150hz like the center?
remedy1978 is offline
post #73776 of 73799 Old Yesterday, 07:09 AM
Selden Ball's Avatar
Quoted: 1033 Post(s)
Liked: 599
Tone controls in D+M equipment are an alternative to Dynamic EQ. When you disable DynEQ, the tone controls will be available.
One way of looking at it is that the tone controls can be used to optimize the bass and treble response at a single sound level, while DynEQ attempts to optimize the frequency response if you listen at a variety of sound levels. Many people like to listen at just one non-deafening sound level, so tone controls aren't all that bad a choice
49Merc likes this.
Selden
Marantz SR7009/7.1.4/FH+TM/DefTech PM1000/LCR+TM amped
Selden Ball is offline
post #73777 of 73799 Old Yesterday, 07:56 AM
mogorf's Avatar
Quoted: 317 Post(s)
Liked: 147
On a second note Selden, DEQ does a second-tier adjustment even at one Master Volume setting, namely it adjusts for the proper loudness curves on-the-fly, i.e. in real-time as the passage gets softer or louder. Conventional bass/treble tone controls don't have this feature. How important this unique aspect of DEQ is to someone is another question.
post #73778 of 73799 Old Yesterday, 08:23 AM
mbroadus's Avatar
Quoted: 265 Post(s)
Liked: 97
Forgive my ignorance, Audyssey set my sub level to -6.5dB, what happens when I move the level toward 0dB? I have Dynamic EQ On with Ref Level Offset at 5dB. Trying to increase mid base of my SVS PC-2000 that seems a little boomy on the low end.
mbroadus is online now
post #73779 of 73799 Old Yesterday, 08:35 AM
kbarnes701's Avatar
Quoted: 3105 Post(s)
Liked: 2561
Originally Posted by batpig View Post
As I noted above -- the dialogue level IS the center channel level. Exact same thing, just the setting in the Audio menu gives you a "shortcut" to the channel level without having to go into the speaker setup menus and run the test tones.
So it doesn't just boost the dialogue, it boosts EVERYTHING that the center channel reproduces.
It's a shame they didn't apply a little more intelligence to the dialogue level adjust. If it worked just on human speech frequencies, it would kinda make more sense, although it would unbalance the overall sound from the center channel. But raising the center channel level unbalances the sound of the overall system anyway so maybe people wouldn’t care. I still maintain that dialog clarity is the norm in all modern movies and if someone is having problems hearing dialog clearly then they need to find the underlying cause and fix it.
kbarnes701 is online now
post #73780 of 73799 Old Yesterday, 08:37 AM
kbarnes701's Avatar
Liked: 2561
Attachment 514441
The sub gets louder.
If you are exciting room modes that have a tendency to cause boominess, then raising the level of the sub will exaggerate that boominess.
post #73781 of 73799 Old Yesterday, 08:45 AM
mbroadus's Avatar
Quoted: 265 Post(s)
Liked: 97
Thanks...are you saying the Dynamic EQ could be causing some of the boominess?
post #73782 of 73799 Old Yesterday, 09:12 AM
Liked: 599
To the extent that it increases the relative level of the lower frequencies as you turn down the volume control, yes.
You might increasing the Reference Level Offset to see if you like having DynamicEQ referenced to a different volume level. (Increasing the RLO decreases the master volume setting at which DynEQ does nothing.) See g)3. What is Reference Level Offset in Dynamic EQ?
Check your subwoofer trim to make sure it isn't pegged at -12dB. If it is, turn down the gain control on your subwoofer and run the Audyssey calibration again. See e)6. What do I do if my trim levels are at the limits of their adjustment ('maxed out')? and f)3. How do I set the controls on my subwoofer before running MultEQ?
Boomy bass also is influenced by subwoofer location. Have you done a "sub crawl"?
Another cause of boominess is to use the setting "LFE+MAIN". See f)7. What is ‘LFE + Main’ or ‘Double Bass’ and should I use it?
If you haven't recently, please take the time to review the Audyssey 101/FAQ
kbarnes701 likes this.
Selden
post #73783 of 73799 Old Yesterday, 09:20 AM
mbroadus's Avatar
Quoted: 265 Post(s)
Liked: 97
@Selden Ball - Thanks!. No sub crawl...sub is to large. Thanks for the links.
post #73784 of 73799 Old Yesterday, 09:21 AM
batpig's Avatar
Quoted: 1358 Post(s)
Liked: 1716
"You can't use tone controls with Audyssey" is a commonly mistated issue.
It is only Dynamic EQ that conflicts with tone controls, because DEQ is an automated tone control.
EVERY receiver with Audyssey lets you adjust tone controls with MultEQ active.
Remember "Audyssey" is not a monolith. It's multiple different technologies that do different things.
batpig is online now
post #73785 of 73799 Old Yesterday, 10:04 AM
kbarnes701's Avatar
Liked: 2561
It depends. As you probably know, at lower frequencies, the room is basically what you are hearing. The room and the subwoofer interact together. This causes peaks and troughs in the frequency response. Peaks and troughs of as much as 20-30dB are not uncommon in acoustically untreated rooms.
Audyssey tries its best through electronic means (the creation of inverse filters) to fix these issues, but it has limitations to how effectively it can work. One such limitation is the extent of the initial problem. If your problem was so great that Audyssey is unable to fix it, then raising the subwoofer level will also raise the level of the problem. The result is you will more clearly hear the problem than you did when the bass was at a lower level. Taking it to the absurd, if you switch off the sub altogether, you will now hear no bass problems at all. But of course, neither will you hear the bass.
Dynamic EQ can make the problem appear to be worse because it boosts the bass as the volume is lowered on the Master Volume control. Switching DEQ off can therefore make the sound appear to be 'better'.
The best solution is to treat the room and to optimize the sub's position in it. If treating the room is not possible (WAF) then it is important to optmize the sub's location before you run Audyssey. If you have independent measuring capability such as with Room EQ Wizard and a calibrated mic, then that is the best way to optimize the sub location. It is outside the scope of this thread to go into detail into that but there is a dedicated REW thread on AVS which will help you. An alternative that can bring good results (but inferior to measuring) is to do the 'sub crawl'. If you don't know how to this just google it and you will find numerous helpful sites.
post #73786 of 73799 Old Yesterday, 10:14 AM
mbroadus's Avatar
Quoted: 265 Post(s)
Liked: 97
Thanks...I'm seriously considering using the Room EQ Wizard. I don't believe the placement is bad cause I mostly notice the boominess at a lower volume level. Like you said, Dynamic EQ boosts the bass at lower volume. The higher volume level sounds fantastic with movies like oblivion and war of the worlds but concerned about disturbing the neighbors since I live in a townhouse. My wife likes to listen to movies at a lower level than I.
post #73787 of 73799 Old Yesterday, 10:18 AM
kbarnes701's Avatar
Liked: 2561
In that case, try using RLO as Selden suggested. It may help. The FAQ has all the info.
WRT to REW, if you do, please download Jerry's Guide linked in my sig. It will save you hours of frustration.
post #73788 of 73799 Old Yesterday, 10:22 AM
mbroadus's Avatar
Quoted: 265 Post(s)
Liked: 97
Will do, thanks. RLO is currently at 10dB.
post #73789 of 73799 Old Yesterday, 01:05 PM
mthomas47's Avatar
Quoted: 53 Post(s)
Liked: 41
If your receiver offers this function, you might also consider experimenting with low frequency containment, particularly for those times when you don't want to disturb your neighbors.
mthomas47 is online now
post #73790 of 73799 Old Yesterday, 03:10 PM
mbroadus's Avatar
Quoted: 265 Post(s)
Liked: 97
Night mode? I don't believe my receiver offers this, it's a Marantz NR-1504.
Just ran the sub through its paces using war of the worlds to show the wife what the sub could do since yesterday's calibration. Sounded fantastic at mid and high volume. No boominess or bloating.
post #73791 of 73799 Old Yesterday, 10:10 PM
OfficialPG's Avatar
Night mode is the dynamic volume setting on your receiver if I'm not mistaken.
OfficialPG is online now
post #73792 of 73799 Old Yesterday, 10:16 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 3014 Post(s)
Liked: 1005
Night Mode Dynamic Range; yes, the Marantz NR1504 receiver has that listening mode feature in it.
NorthSky is online now
post #73793 of 73799 Unread Today, 01:35 AM
tommaazz's Avatar
Quoted: 88 Post(s)
Liked: 51
Hi guys i have a question about dual sub...i have received my 2nd sb13ultra and i have xt32 (with subEQHT). I want to ask you what are my target settings for subs...should i put the same gain on the amp (might be a different AVR trim) or should i go for the same AVR trim...i will put my subs around 5db hot so i am targeting around -7 or -8 avr trim. Thanks
Marantz sr7008, monitor audio bx6,bx center,bx fx,bx1,sub SVS sb13ultra (2x), panasonic 60asw654
tommaazz is offline
post #73794 of 73799 Unread Today, 06:59 AM
mbroadus's Avatar
Quoted: 265 Post(s)
Liked: 97
Hmm...unfortunately, no night mode on the Marantz NR-1504.
post #73795 of 73799 Unread Today, 07:33 AM
Liked: 599
Marantz calls it "Dynamic Volume".
See page 97 in the owner's manual.
Selden
post #73796 of 73799 Unread Today, 07:52 AM
mbroadus's Avatar
Quoted: 265 Post(s)
Liked: 97
Found it thanks...I was searching the manual for night mode.
post #73797 of 73799 Unread Today, 11:06 AM
ambesolman's Avatar
Quoted: 519 Post(s)
Liked: 505
Bypass L/R
DynEQ off
I'm the opposite. I'll use it on music but not movies. The last time I ran audyssey, I used a lower and a higher position with the mic for positions 7 and 8. Since then I've had to raise my subs+8-10 hot to get the same impact I had before. I also raised the crossover from 80-90 and it added more thump and blends better. DEQ off or -10. Don't like it for movies.
Sent using Tapatalk since the mobile version is still [emoji107]
ambesolman is offline
post #73798 of 73799 Unread Today, 11:53 AM
mthomas47's Avatar
Quoted: 53 Post(s)
Liked: 41
Selden,
I know you know the difference, but I was originally talking about Low Frequency Containment, rather than Dynamic Volume. The NR-1504 does have Dynamic Volume, but may not have LFC.
post #73799 of 73799 Unread Today, 04:10 PM
Quoted: 52 Post(s)
Liked: 58
Although Dynamic Volume is useful if you have a sleeping baby, or a sound-sensitive insomniac in the house, or an intolerant neighbor, it almost always subverts the intentions of the composer, at least with orchestral music or jazz, and also subverts the intentions of filmmakers. Of such is life.
I used to live in a neighborhood (Berkeley, CA) in which there was almost always music in the air, and the sound of distant drummers past midnight. It was great! Later, in Oakland, the sound of distant gunfire was less relaxing.
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
