"Official" Audyssey thread (FAQ in post #51779) - Page 2481 - AVS | Home Theater Discussions And Reviews
post #74401 of 74430 Old Yesterday, 11:46 AM
kbarnes701's Avatar
Quoted: 3353 Post(s)
Liked: 2677
Originally Posted by audioguy View Post
I have run Audyssey Pro many times without incidence but got this message today and have no clue what it means (new speakers -Triad Plat for LCR and in room silver monitors for 4 surrounds).
This was the 2nd run so turned off the center channel and subs to speed up the process.
I have no idea what this means.
Setup screen:
Error Message:
It means that Pro thinks you have specified a set of speakers that are not in the right place. For example, if you had a 5.1 system and you told Pro that you had Left, Right, Center, Surround Left and Surround Right set up but in reality you had connected the SL and SR to the Rear SL and Rear SR. Are you sure your config in Pro and your actual speaker layout are the same?
BTW - very nice speaker choice!
kbarnes701 is offline
post #74402 of 74430 Old Yesterday, 11:58 AM
audioguy's Avatar
Quoted: 633 Post(s)
Liked: 394
Thanks for the speaker choice complement. Other than 2 channel I have yet to hear them until I got Audyssey run. Hence I would like to get this problem solved.
I have a 7702. (my solved "hum" problem has returned with a vengence). Ran the trim/volume test and each speaker played when it was supposed to. So it is physically set up correctly and I told Audyssey how it was set up.
As you can see from my speaker configuration screen, I have told Audyssey that I have Surrounds and Rears. I originally told it I had 3 front channels and two subs as well but when I got the error message the first time, I told Audyssey I did not have subs or a center channel to speed up the incrediblly slow Pro process.
I will try regular Audyssey and see what happens!!
New Theater
Don't count the years. Make the years count. Lou Holtz
audioguy is online now
post #74403 of 74430 Old Yesterday, 12:35 PM
mthomas47's Avatar
Quoted: 83 Post(s)
Liked: 50
Originally Posted by Holiday121 View Post
Ok I will just have to find out how to disable the center in the settings since I already have it ran.
I am doing this because I just am not happy wih the way any center sounds unless it's thr EXACT same speaker as my left and right.
I don't have room for a acoustic transparent screen so I am going to give the phantom a try.
I knock out my center when I play music, but like the way the center anchors dialogue for movies and TV. Depending on what kind of surround processing you are using, you might try experimenting with less center and more fronts, rather than entirely excluding the center. For instance in PLIIx Music Mode, you can spread the center sound incrementally to the fronts. Other technologies can give you similar options. That's just something you could consider to improve the blend if you aren't content with the phantom center.
mthomas47 is offline
post #74404 of 74430 Old Yesterday, 12:53 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 59
I still don't understand the need for this. When you play music, the center channel is not used unless it's a 5.1 track.
Soulburner is online now
post #74405 of 74430 Old Yesterday, 12:56 PM
AustinJerry's Avatar
Quoted: 1903 Post(s)
Liked: 1103
What? If you use Dolby PLII Music, the center channel gets a lot of action, even for 2.0 sources.
AustinJerry is online now
post #74406 of 74430 Old Yesterday, 01:00 PM
kbarnes701's Avatar
Liked: 2677
It's very odd then. Let us know what regular Audyssey finds.
post #74407 of 74430 Old Yesterday, 01:16 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 59
But why would you use PLII if you don't like your center channel and want it off for music?
Unless he has a 4.1 setup where his rears are the same. Unless I missed it, he hasn't explained this.
*Under Construction*
To: AVR-X4000, Chane A3rx-c, Rythmik L12 (2)
Samsung PN64H5000 Recommended Settings
post #74408 of 74430 Old Yesterday, 01:46 PM
Liked: 1103
In the event that that is what the OP wants to do, he would simply go into the speaker configuration page of the GUI and change center channel from "1" to "None". Still unsure what he (or anyone) would want to do this, unless the center channel is a real POS.
Edit: Since, IMO, the center channel is so important for the overall sound of an audio system, the best answer is to either replace the speaker itself, or figure out why it sounds bad.
post #74409 of 74430 Old Yesterday, 02:14 PM
mthomas47's Avatar
Quoted: 83 Post(s)
Liked: 50
The OP has what I would consider a very good center of the same make as his fronts, but a different model. He said that he wasn't satisfied unless all three were an exact acoustic match. Creating a phantom center would be one solution, and I suggested redistributing some of the center to the fronts as an alternative to eliminating the center entirely. I would tend to agree with you that the center is so important for movies and TV that replacing the center, or finding some kind of workable compromise through PLIIx, or some other surround mode, would be the best solution. But I know people who happily operate with nothing but a phantom center, so I guess preferences vary.
In my own case, I spent more than a decade acquiring and customizing six vintage speakers for my music system. It is not possible to match them musically with a center, but I don't mind the center for movies and TV. That's why I use PLIIx in the way I mentioned. (It seemed impolite not to explain my reasons for doing it this way since the question came up.)
post #74410 of 74430 Old Yesterday, 03:09 PM
batpig's Avatar
Quoted: 1451 Post(s)
Liked: 1768
Note that you can actually mute the center channel in PLII Music mode by setting the Center Width parameter to the max value (everything to the FR/FL, nothing to the CC).
Not completely relevant to the OP's question but since it was brought up, wanted to point it out.
Soulburner likes this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #74411 of 74430 Old Yesterday, 03:37 PM
Holiday121's Avatar
Quoted: 112 Post(s)
Liked: 40
So PLII music mode will distribute more to my front left and right speakers without making any other changes.
Maybe I was just to afraid to let go the format it was filmed with like dolby hd or master.
Holiday121 is online now
post #74412 of 74430 Old Yesterday, 06:44 PM
audioguy's Avatar
Quoted: 633 Post(s)
Liked: 394
It worked perfect. Sounds more than good enough for now. I will investigate the Pro issue when I have more time.
As Harry Pearson once said to me: "If it works right the first time, it's not High End".
So there you have it.
New Theater
post #74413 of 74430 Old Yesterday, 06:57 PM
pbarach's Avatar
Quoted: 142 Post(s)
Liked: 120
Originally Posted by garygarrison View Post
Everything in your room should be exactly the same when you calibrate as it is when you listen to music or run a movie, especially something like a large expanse of glass.
I agree in principal, but it can never be exactly the same for calibration because there will be no people sitting on the furniture. I would imagine that something as large as a human would have some effects on the way sound travels around the room... I don't think anyone has reported on an attempt to measure that effect.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #74414 of 74430 Old Today, 12:27 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 59
That's why we had a discussion on sitting in the listening position during measurement recently.
Decades/centuries from now, our descendants might talk about the lost audiophile art of holding your breath while balancing the mic on your nose to obtain the perfect zen measurements.
post #74415 of 74430 Old Today, 05:32 AM
kbarnes701's Avatar
Liked: 2677
LOL. Glad you are back up and running. Hope the Pro thing resolves itself when you next try it.
post #74416 of 74430 Old Today, 09:20 AM
mthomas47's Avatar
Quoted: 83 Post(s)
Liked: 50
You probably already know this, but Pro Logic (PL-II) is a Dolby technology. The various versions of PL-II will simply pass through a 5.1 signal to a 5.1 system. You can then choose to change the way the sound is distributed to the various speakers via your AVR controls. The real advantage comes in with a stereo recording, which will be redistributed to a 5.1 system, or with a 5.1 recording, which will be redistributed to a 7.1 or larger system. Give it a try and see whether you like the way it sounds.
post #74417 of 74430 Old Today, 02:03 PM
mogorf's Avatar
Quoted: 357 Post(s)
Liked: 154
Originally Posted by IgorZep View Post
On a well designed FIR (at least for audio processing) you won't be able to find where it ends just by barely looking at the measured impulse response. The higher the frequency - the less time from the impulse peak you can do something useful to correct, it there are still some visible oscillations at a distance significantly more than wavelength of particular frequency/range - it is not a correction anymore, it is an added distortion, that could become audible at some point. Also the end of the filter should be properly fade-out to avoid echo. If you see a 'cut' in the impulse response - there is an echo in the sound.
Igor, thanks and sorry for a late reply. Yet, IMHO your wording seems a bit far from "everyday use", it seems like a conversation between two qualified FIR filter designers, meantime a bit hard to consume/understand/digest by most of mortals. Care to draft an explanation a tad bit closer to Layman's?
Me thinks the above description referenced in the FAQ wouldn't really look good.
Keith?
mogorf is offline
post #74418 of 74430 Old Today, 02:37 PM
kbarnes701's Avatar
Liked: 2677
Keith?
The description referenced is very technical I agree - perhaps even too technical for a "technical addendum" to the FAQ. I am more or less ready to draft the text for the additional copy but I will hold back a while to see if Igor can explain the FIR issue in more "everyday" terms I don't think we need incredible detail anyway - the main takeaway is the view that MultEQ might be a better choice than XT (in some circumstances) because it has the potential to "do less harm" in the upper frequencies than XT. The graphs already provided show that quite well I think.
post #74419 of 74430 Old Today, 02:38 PM
garygarrison's Avatar
Quoted: 72 Post(s)
Liked: 64
I agree that a room will sound different with no people sitting in the furniture. I guess I was just cautioning against calibrating with drapes covering the glass, then, perhaps, listening with the glass exposed.
Decades ago, I read about recordists putting burlap sacks of something (grain? rags?) in the empty seats near the orchestra to simulate people, in order to make a good recording in an empty concert hall.
I love the idea of putting small microphones in front of either ear, One could hire 5 or 6 unemployed people to sit there with microphones strapped on during Audyssey calibration. Yes, Soulburner, they should definitely hold their collective breath and restrict any flatulence. I wouldn't rely on them balancing microphones on their noses, though, unless Audyssey comes up with some fuzzy logic algorithm to account for the microphones swaying back and forth.
garygarrison is offline
post #74420 of 74430 Old Today, 02:50 PM
kbarnes701's Avatar
Liked: 2677
One could hire 5 or 6 unemployed people to sit there with microphones strapped on during Audyssey calibration. Yes, Soulburner, they should definitely hold their collective breath and restrict any flatulence. I wouldn't rely on them balancing microphones on their noses, though, unless Audyssey comes up with some fuzzy logic algorhythm to account for the microphones swaying back and forth.
Cadavers. That's what's needed. The automobile industry uses them for testing the effects of collision impact on the human body. We can get the cadavers first, use them for calibration, and then pass them on to Ford.
http://articles.latimes.com/1993-11-...1_safety-tests
http://jalopnik.com/5622667/how-a-ca...your-car-safer
post #74421 of 74430 Old Today, 03:03 PM
ggsantafe's Avatar
Quoted: 58 Post(s)
Liked: 90
B stock cadavers
ggsantafe is online now
post #74422 of 74430 Old Today, 03:13 PM
Liked: 1103
Sorry, isn't this getting a bit ridiculous? In my many, many Audyssey calibrations, I have found no evidence that the presence of a large mass occupying the MLP chair produces a measurable difference in calibration results. I certainly agree that one should not remove furniture, etc. to "game" the calibration, but other than those general guidelines, anything more obsessive is just that--obsessive.
post #74423 of 74430 Old Today, 04:51 PM
Quoted: 72 Post(s)
Liked: 64
Of course. Most of my later post was an attempt at humor, as was Keith's, I hope. I do believe the walls, windows and furniture should not be changed after calibration.
"I have found no evidence that the presence of a large mass occupying the MLP chair produces a measurable difference in calibration results." So, apparently you, or someone, tried that.
post #74424 of 74430 Old Today, 05:06 PM
mogorf's Avatar
Quoted: 357 Post(s)
Liked: 154
Truth be told, if not for the consumer version, but for the Pro Kit it would be really nice if Audyssey bundled some "dummies" like the ones used in automobile crash tests, ...placed around seat No.2, No.3, etc. Of course all Audyssey branded!!
In the end we will get to the conclusion that Hi-Fi systems always sound the best when there is nobody in the room!
mogorf is offline
post #74425 of 74430 Old Today, 05:26 PM
IgorZep's Avatar
Quoted: 226 Post(s)
Liked: 133
I've already tried to explain it as simple as possible. The fade-out part should be understandable to anyone who mastered some audio... And frequency dependent windowing is quite tricky to explain expressively... Anyway, not everything is needed to be included into the FAQ. We have some comparison to display, so, whoever understands could look at it and make conclusions for himself, the resolution is also pretty easy to understand when it is translated to frequency domain (like 375 Hz between 'control points' for XT) and this is also a useful information in terms of how low in frequency it can correct at all (something we should see on the spec sheet instead of abstract incomparable 16x, 128x, 512x etc.).
IgorZep is offline
post #74426 of 74430 Old Today, 05:47 PM
mogorf's Avatar
Quoted: 357 Post(s)
Liked: 154
Igor, you are a "hard row to hoe" when it comes to simplicity, eh? How many here do you think has had experience in "mastering some audio"?
Saying: "whoever understands could look at it and make conclusions for himself" is not what a FAQ needs.
Saying: "pretty easy to understand" is beyond doubt true for those who pretty easily understand,..but what about the rest trying hard to read and understand the FAQ?
Saying: "useful information" is not going to be useful information for those who can not make use of this information. Hope you get it!
What is really needed here is a "tech to everyday" translation...
mogorf is offline
post #74427 of 74430 Old Today, 07:45 PM
Liked: 1103
Let me see if I understand you correctly, are you asking whether I am a large mass?
post #74428 of 74430 Unread Today, 08:17 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 59
If a "large mass", ahem, won't alter the measurements, then neither will a small tripod that everyone says "don't use!".
post #74429 of 74430 Unread Today, 08:26 PM
Liked: 1103
No one has said don't use a small tripod. We have tried to say that a mic stand with a boom attachment makes it considerably easier to place the mic properly. Since such a stand can usually be purchased for less than $30, we continue to be amazed why, for such a small investment, people continue to do things the hard way. You can lead a horse to the water...
post #74430 of 74430 Unread Today, 08:42 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 59
I use a boom stand which works well with the UMIK-1 and its holder. But it doesn't work well with the Audyssey mic because I can't keep it at a strict 90 degree angle. It's tilted because my seating position is lower than the boom arm.
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
