"Official" Audyssey thread (FAQ in post #51779) - Page 2484 - AVS | Home Theater Discussions And Reviews
post #74491 of 74503 Old Yesterday, 03:12 PM
mogorf's Avatar
Quoted: 363 Post(s)
Liked: 155
Originally Posted by kbarnes701 View Post
It's easy to overthink this. We usually measure a room without an audience in it for example. Then we happily play back with two, three or more people sitting in the room - all significant, non-reflective masses.
How about those "two, three or more people sitting in the room" all dressed up in (reflective) leather gear?
Just couldn't resist!
Have a nice, overthinking-free weekend all!!
kbarnes701 likes this.
mogorf is online now
post #74492 of 74503 Old Yesterday, 03:23 PM
mthomas47's Avatar
Quoted: 86 Post(s)
Liked: 54
Originally Posted by NorthSky View Post
Ok, if you have a leather couch, yeah, you can put a blanket on top of it to take Audyssey measurements with the mic.
And if you have a glass coffee table between you and your screen, put a blanket on top of it too.
And if you have large reflective windows all around, close the curtains.
Brief, cover any highly reflective surface near by.
Originally Posted by Soulburner View Post
But then if after calibration you uncover them and go back to business as usual, you're going to have problems.
I agree with both of you, that in general you don't want to change anything between calibration and playback. But without wishing to be argumentative, I would cite the blanket over the couch back as an exception to that general rule. Getting the Audyssey mic too close to a hard surface such as a leather fabric "may" cause problems. No guarantee that it will, but it may. That is because the mic can pick-up short wavelength, high-frequency reflections from the hard surface only 3"-6" away, let's say, and attempt to over-correct for them. In my room, that created a rather harsh treble sound even with XT-32.
There are three ways that you can try to avoid that comb filtering effect from having your mic too close to a hard surface during calibration. The first is to move the mic forward another 12" or so. The second is to raise the mic 6" or so above the surface of the couch. The first two were often recommended by Audyssey when someone asked about proximity between the mic and a leather chair back. The third method is to temporarily cover the hard surface with something absorbent, like a soft towel or a blanket.
But all three measures are temporary, and just apply to the calibration. If you move the mic forward away from your chair, it is not recommended that you hunch forward where the mic was during movie or music playback. Similarly, if you raise the mic, you don't have to put your chair on risers, or sit on pillows to get up to where the mic was. And you don't have to leave the towel or blanket in place either.
I think we tend to obsess about this stuff a lot, as Jerry said in response to the jokes a few posts back. It may not be necessary to worry about doing any of the precautions I mentioned to get a good calibration. But if you are concerned, or are hearing something amiss in the higher frequencies, then finding a way to avoid comb filtering during calibration is worth trying, and the temporary blanket method is a good one.
mthomas47 is offline
post #74493 of 74503 Old Yesterday, 03:25 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 72
I would agree with the exception of covering the reflective backs of chairs. Leaving them uncovered during the calibration is likely to cause more problems than removing them for listening would. If you have measuring capability, it's an easy test. With my leather chairs 'bare' there was a significant difference - and not a good one - between that cal and one with the chairs covered for the cal.
But I was talking about post-calibration. If you go to those lengths for measurement, then un-do it all you end up with issues because you increase the reflectivity of the room. Correct?
Soulburner is online now
post #74494 of 74503 Old Yesterday, 03:49 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 3470 Post(s)
Liked: 1195
There is a balance. ...Like in all things life.
I agree with the couch thing, because of the Audyssey mic nearby. ...The rest is different, in direct relation to the mic measurements.
And, really, who wants to watch John Wick in a very highly reflective room? ...C'mon now, John Wick deserves much better than that.
______
If your room is less than perfect, and you took Audyssey measurements with a bunch of reflective surfaces, and you listen too with a bunch of reflective surfaces; just turn Audyssey Off and see what happens.
Or two, change your environment for the best (acoustic sound wise) .....Before and after Audyssey Room Calibration and EQ measurements and final results.
NorthSky is offline
post #74495 of 74503 Old Yesterday, 04:19 PM
pbarach's Avatar
Quoted: 148 Post(s)
Liked: 120
♦ If you get those two mic adapters, you can put your boom anywhere and install the Audyssey mic in any position you like (normally upright).
The first pic on top is the standard mic 5/8" to 3/8" male screw adapter (perfect for the 1/4" hole of a camera and the Audyssey mic).
The second pic (with two lengths) is for total flexibility; the one you attach first, then that small adapter from the top pic to it.
Thanks, but I decided to try buying a shorter mic stand and use the camera adapter recommended in the FAQ, which allows the mic to be tilted upwards when the boom is pointed up to reach a low seating position, but which is useless for a low seating with taller the On Stage boom mic stand. The stand I bought is the same price as the Rode adapter you pictured"
http://www.amazon.com/Samson-MB1-Min...=cm_cr_pr_pb_t
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #74496 of 74503 Old Yesterday, 04:28 PM
NorthSky's Avatar
Liked: 1195
That is perfect too, for most people.
* That Audyssey pyramid shaped mic; I wish they change the design for a real mic, a la Anthem for example.
Then we wouldn't have so many issues with that mickey mouse Audyssey mic.
Audyssey should keep improving, everything. But helas. It is going the way of the dodo. ...And life is following its course onto better horizons.
Even Keith has abandoned XT32 in favor of Dirac Live. ...Jerry too. ...And I'm next, along with Feri.
NorthSky is offline
post #74497 of 74503 Old Yesterday, 04:31 PM
AustinJerry's Avatar
Quoted: 1949 Post(s)
Liked: 1108
We can sit here and express opinions until the cows come home. But ultimately, you need to determine the approach that works best for you. That means take one calibration leaving the blanket off the back of the chair. Then conduct a listening test or, better yet, take some REW measurements. Then use the network save capability and preserve the calibration results. Run a new calibration with a blanket to eliminate the reflections. Repeat the listening and/or measurement tests, and pick the result you find most pleasing.
I have a lot of respect for people who experiment with various approaches and report results back here. I have less respect for people who take a stand without providing supporting facts.
AustinJerry is online now
post #74498 of 74503 Old Yesterday, 08:45 PM
dunan's Avatar
Quoted: 39 Post(s)
I confess I did the blanket treatment as i have leather furniture and it did fix the muffled highs issue I was having. If I dont use the blanket, I wind up with virtually no treble after calibration. As in earlier posts, I'm looking into some sort of room treatments as I have a lot of reflective bare wall space. Not sure the direction I'm going with it yet but I'd like to try something.
pbarach and mthomas47 like this.
dunan is offline
post #74499 of 74503 Old Yesterday, 08:57 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 72
Yeah, I was more responding to the post about covering a glass table, closing blinds, etc. I simply mentioned that if you calibrate that way, you should also do that for actual movie watching because that is how the system is calibrated.
Jerry's guide for REW contains some pointers on how to find reflection points and treat them, however it has been said by (I believe it was Floyd Toole) that people tend to prefer the sound of untreated side walls for music because it creates a larger soundstage. I plan on making my own with custom printed fabric, so whenver I get around to that I'll experiment with placement and see if I can replicate those findings. In the end it's up to us to decide what sounds best.
*Under Construction*
To: AVR-X4000, Chane A3rx-c, Rythmik L12 (2)
Samsung PN64H5000 Recommended Settings
post #74500 of 74503 Old Today, 03:56 AM
kbarnes701's Avatar
Quoted: 3388 Post(s)
Liked: 2698
As I said, and as mthomas just above has said with great eloquence, reflections from the seat backs do more harm than covering the seat backs during calibration. I have even verified it with REW. You don't have to follow this advice - if you prefer to measure with your mic close to a reflective surface, by all means do so.
kbarnes701 is online now
post #74501 of 74503 Old Today, 05:46 AM
Skylinestar's Avatar
Quoted: 289 Post(s)
Liked: 81
Regarding sub distance tweak after audyssey, can I adjust the distance for my center speaker instead of adjusting the distance of sub?
The problem is that the current sub distance xo nicely with my main left and right, but not with my center. Any attempt to tweak the sub distance will make the xo with mains worse.
Skylinestar is offline
post #74502 of 74503 Old Today, 07:44 AM
Liked: 1108
In my experience using the sub distance tweak, the sub distance yielding the best results is often slightly different for the center as it is with the left and right speakers. Since the splice between the center channel and the subs is the most important for smooth bass, my recommendation is to accept the sub distance that is best for the center channel. I believe this is also the recommendation in the written procedure. If the difference is significant, you might experiment with an average of the two distances.
I would never adjust the center channel difference--this will throw it out of whack with the rest of the speakers, and could affect dialog intelligibility, which would be far less desirable than a slight compromise in bass smoothness, IMO.
post #74503 of 74503 Old Today, 09:30 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 72
Where did I say I wanted to do that? I'm advocating covering surfaces.
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
