"Official" Audyssey thread (FAQ in post #51779) - Page 2485 - AVS | Home Theater Discussions And Reviews
post #74521 of 74525 Unread Today, 12:03 PM
Liked: 0
Originally Posted by kbarnes701 View Post
Before getting to Audyssey, if it were me I'd want to know why my sub was humming and to fix it. The sub shouldn't hum so something must be wrong. Is it a loud hum? Is it mains frequency? A ground loop? What?
Second, if you are setting up to use 75dB test tones (the first stage that Audyssey asks for) the sound coming from the sub when Audyssey pings it should be relatively quiet, not cat-terrifying loud. This also suggests a problem somewhere. I assume you did adjust the sub so the reading is ~75dB, as Audyssey requires?
Only when you have fixed any problems with the sub is it worthwhile to figure out the Audyssey calibration IMO.
Thanks for the reply. I don't know know how to quantify how loud the hum is. It's not loud but it's clearly audible I'd say.
I don't know what "mains frequency" is so I couldn't really answer that. Don't know if it's a ground loop either.
I didn't see anything anywhere suggesting setting the sub to 75 db. I was just following the onscreen prompts for audyssey.
I agree that I need to fix any problems before calibrating, I just don't know if there are problems or if I just have something set incorrectly. Should my sub amp be set at 180 Hz when running Audyssey? I called Denon and they didn't seem to be able to give me a definitive answer either...
I did read through the links in your signature but there is a whole lot of info there to digest and could very well have overlooked something or just done something wrong...
MNnative is online now
post #74522 of 74525 Unread Today, 12:30 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 78
Are you sure that's 180Hz, or is it 180 degrees (phase)? If it's the latter, leave it at 0 for now. If it's the former, and it's the crossover setting, you should set it as high as it can go.
Soulburner is online now
post #74523 of 74525 Unread Today, 12:47 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 3511 Post(s)
Liked: 1215
Originally Posted by Alan P View Post
I see this all the time when trying to post in this thread and have reported it without much help.
The only way I've found around it is to make sure I quote someone before replying...probably doesn't help when editing the FAQ though.
This thread is unique on that aspect (Database error).
There are three solutions that I know of:
1. Like you said; quote another post.
2. At the page's bottom, last post, @ left; click on 'Reply'.
3. Just post like normal by typing your post in the large white dedicated space, and when done, don't click on 'Submit Reply' but on 'Preview Post';
then you can submit your post.
Those three tricks work.
* But the main thing is this: You have to remember (I never do myself). ...And if you don't remember, and that you post normally, without quoting, and click on 'Submit Reply' (and not on 'Reply' first), you are going to end up with that 'Database error' and your post is gone for good.
So, if you make the mistake of not using one of them three solutions above, and that you worked real hard on a post with lots of good info and scientific measurements and theories for over an hour and up to four hours; too bad, your hard work is gone.
It gets me all the time, I can never remember to post differently here in this Audyssey thread.
And the reason is very easy to understand why; it's because we are used to post normally everywhere else, and we just do the same here.
For this reason this thread is the one I experienced the most frustration over time. ...And I tried to stay away if I can help it, but it's not always easy to remember and also when you like to reply to a post.
It was asked before if there should be an official Audyssey thread Part Two, because this one was so humongous.
Perhaps that was the right solution ....
P.S. When Keith wants to add to the FAQ, he probably click on 'Edit'. ...Then 'Save'.
He'll have to check another route if he ends up with a 'Database error'. ...Check if 'Preview Post' is an option when editing before saving.
* [I just checked, and it's not an option; but 'Edit' and 'Save' always works fine for me]. ...And there is also 'Go Advanced'; that might help...
NorthSky is online now
post #74524 of 74525 Unread Today, 12:50 PM
Liked: 0
Hz, for sure. I'm rerunning Audyssey now with the setting at 180 Hz and the volume on the sub at about 25%. No explosions of noise yet...
post #74525 of 74525 Unread Today, 02:04 PM
kbarnes701's Avatar
Quoted: 3435 Post(s)
Liked: 2728
Can you hear it from where you normally sit, or just when you put your ear near the driver?
Mains in the USA is 60Hz. This is what 60Hz sounds like:
It is one of the first on-screen prompts - you have to set the sub level to 75dB. Do you have an older AVR? What version of Audyssey do you have? If your version of Audyssey doesn't prompt you to set the sub at 60Hz, download a free SPL meter for your phone and use that to get it close to 75dB using the volume knob on the sub. Do this before running Audyssey.
What does the legend under that sub control say? You need to set the sub crossover to its highest setting, so that it doesn't fight with the crossover in the AVR. This is covered fully in the FAQ and 101. They are essential reading.
Follow the step by step guide in the 101. You need to do each step to ensure a good calibration.
kbarnes701 is online now
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
