"Official" Audyssey thread (FAQ in post #51779) - Page 2503 - AVS | Home Theater Discussions And Reviews
post #75061 of 75065 Unread Today, 07:44 AM
SherazNJ's Avatar
Quoted: 299 Post(s)
Liked: 33
Wanted to share some results after performing Sub Distance Tweak provided by Keith.
I performed this tweak yesterday. I already had subs placed in best place possible before so didn't have to move subs. But I moved my center to give me better response. I garra say, my center channel response is as good as it gets when it comes to channel with sub integration .
Just the fact that we take separate reading of each channel from sub is a great advice. All along, I have had a dip around 60Hz for Left and Right and I thought I was because of subs. After I took reading of speakers (without sub), it turned out that its my speaker . Left Has a dip around 60 hz and right around 70Hz. Left is no issue because that dip get overlapped with sub but I couldn't get rid of 70 Hz. After running Audyssey, it was still there but its like only 2Hz wide ( I think barely noticeable).
I also realized that I should have crossed my subs at 60 instead 80. At 80, it was 3 db below actual speaker response.
After final calibration, the system sounds amazing. Bass has never sounded so well. Its like so tied now. Almost no booming. I'd say almost because I only watched one movie for 20 minutes. I don't know what did the trick. May the cross over from 80-60.
But what ever it is, I thank Keith very much for sharing his knowledge with us.
SherazNJ is online now
post #75062 of 75065 Unread Today, 08:12 AM
Liked: 0
Send a message via Yahoo to halicea
I hope you guys can help me better understand why I am getting the results I am getting when I run the Audyssey calibration.
I have an Integra DHC 80.3 Pre going into an Integra DTA 70.1 power amp. My speakers are Polk Audio LSiM 705s for fronts, 706c for center, 703s for front wide (I prefer this setup for music over surround backs), LSiFx surrounds and a PSW1000 sub. My room is 13’ x 18’ x 7.5’ ceiling.
When I run the Audyssey MultEQ XT32 calibration it sets all of my speakers at 40Hz.
Would someone please help me understand?
halicea is online now
post #75063 of 75065 Unread Today, 08:12 AM
Liked: 0
Sorry... didn't mean to post twice but I did not see the first post go through.
post #75064 of 75065 Unread Today, 08:32 AM
kbarnes701's Avatar
Quoted: 3795 Post(s)
Liked: 2923
Thanks for the hat tip but most of the Sub Distance Tweak Guide is the work of other people, as acknowledge in the guide. What I did was bring it together all into one place. Glad you found it useful!
kbarnes701 is online now
post #75065 of 75065 Unread Today, 08:34 AM
kbarnes701's Avatar
Liked: 2923
That is the response that Audyssey sees from your speakers, taking into account their interaction with the room. I'd suggest raising them somewhat to take the strain off them and put it on to the sub which is likely more able to handle low bass. Try 80Hz to start with and then 60Hz and see which you prefer, if any.
Also see these FAQ answers for more info:
c)4. Is it OK to change the Crossovers from Audyssey's recommendation?
c)7. Audyssey is setting my crossovers way differently to what I expected. Why?
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
