"Official" Audyssey thread (FAQ in post #51779) - Page 2510 - AVS | Home Theater Discussions And Reviews
post #75271 of 75272 Unread Today, 07:22 PM
aaranddeeman's Avatar
Quoted: 410 Post(s)
Liked: 122
Originally Posted by gadgtfreek View Post
I shoot for around -6 to -8 with the sub gain knob, so I can then bump the trim level up hot in the menu and the actual final trim level would be around 0.0. Trying to stay between +3 and -3, and run the sub hotter than Audyssey sets it.
So when you change the trim to make it hot, do you change it in the setup->speakers->levels or use the input specific "channel level" that is done on the fly using remote?
I believe they both have same effect, the on the fly setting seem to have an advantage that you still maintain the original Audyssesy settings intact (and don't have to write them some where)
aaranddeeman is online now
post #75272 of 75272 Unread Today, 07:33 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 101
Depending on your AVR, you can check the Audyssey settings from right after your last run.
Soulburner is online now
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
