"Official" Audyssey thread (FAQ in post #51779) - Page 2525 - AVS | Home Theater Discussions And Reviews
post #75721 of 75724 Old Yesterday, 06:56 AM
tbaucom's Avatar
Quoted: 57 Post(s)
Originally Posted by mthomas47 View Post
I agree with you that it depends on the situation. I have read that conversation with Chris before, but it has been awhile, so I went back to read it all again. While Chris acknowledges the potential power issues, he is pretty emphatic about leaving the crossovers wherever XT-32 sets them, as long as they aren't set to Large. He is still very adamant about always using Small settings.
Keith made a good point about optimizing speaker positioning, as well, but even that is just a general guideline and not an absolute. I think we all have to pick and choose what recommendations we are going to follow, and where we are going to experiment and then use our own judgment. And frankly, I think that includes not only the advice we can receive on this thread, but Chris' advice, as well. Among the variables which I personally think are important in deciding where to keep your crossovers are: how much you use your system for music, and whether you can hear differences in the sound of your satellite speakers and your sub(s); and what volumes you like to listen to. As Keith was pointing out, it takes a lot of power, and very efficient speakers, to approach Reference volumes in even a fair size room. So, the closer you want to get to Reference, the more important it probably is to have very capable subs to which you can offload bass below about 80hz. On the other hand, if most of your listening is done at -25 to -20, the easier it is to feel comfortable about using lower crossovers.
Almost anything we can say about most of this is a generalization. Keith has been at the forefront of establishing guidelines (the FAQ) which have helped innumerable Audyssey users, including myself, get started. But once we start to understand the basic principles involved, then if we want to go beyond the guidelines and experiment to discover what we really like, then there certainly is no harm in that.
Mike
I agree with every thing you said. I just find it ironic that the "official Audyssey thread and faq" does not even mention what the creators of the software actually recommend.
tbaucom is offline
post #75722 of 75724 Old Yesterday, 09:14 AM
mthomas47's Avatar
Quoted: 194 Post(s)
Liked: 135
I agree it is a little ironic that Chris' comments with respect to XT-32 never got incorporated into the FAQ. They could probably be treated similarly to the alternative approach to setting the LPF for LFE. The standard recommendation is 120hz, but there are some good reasons given for using 80hz.
To me, the whole issue of bass management is so idiosyncratic to the individual goals and audio system of the user, though, that it is difficult to come up with one-size-fits-all guidelines, anyway. The FAQ attempted to establish some simple principles which would apply to the great majority of cases. And I think it does that very successfully. I also think it is assumed that people like yourself who are interested in questioning those principles will post on the thread. At which point, you will start to hear different perspectives, and alternative approaches to some of the Standard Operating Procedure listed in the FAQ. If the FAQ were completely sufficient, in and of itself, we probably wouldn't have had another 24,000 posts since it was created.
With respect to this whole discussion of Chris' 2011 recommendations, though, and what is really the "proper" way to configure your crossovers, I see bass management as something closely associated with Audyssey, but distinct from it, as well. I believe that this is an important point. For instance, you will often hear that Audyssey, or room EQ in general, doesn't care if you are watching 5.1 movies or listening to music. It's purpose is to improve the room/speaker interaction by eliminating some (much) of the treatable distortion. I think that idea is correct: Audyssey doesn't care what your specific audio goals are. It will simply try to improve your overall audio quality by eliminating distortion in the room. But you care what your audio goals are, and in my opinion, that's where bass management starts to get complicated, and starts to diverge from Audyssey as a purely room correction system.
If you are a serious home theater enthusiast (HT is what Audyssey was originally designed for), then you may wish to try to approach Reference volumes with your system. And that goal will drive your satellite speaker choices, your subwoofer speaker choices, your amplifier choices, and your bass management choices. I have read that the average person listens to audio systems at a volume of about -25 to -20 on the Relative scale. I don't know for sure whether that's true, but from what I have seen on this thread, I would say it's in the ballpark. So, let's take the low end of the average and say that you want to watch a 5.1 movie at -24db. (We will just deal with this at average volume levels, for simplicity. Peak volumes would obviously be much higher.) Let's also assume that you have fairly efficient speakers in a not too large room. So, at -24db, let's say you are using only 15 watts per channel. You want to experiment and push your system toward Reference. No problem, you increase the MV by 3db to -21, and you are still using only 30 watts per channel. That's easy for any modern AVR. Increase to -18 and you have to double the power again, to 60 watts. Still no problem. But if you want to get to -15db, now you will need 120 watts per channel, and most AVR's will be clipping by that point. And some speakers may start to have trouble handling that power, as well. If you want to get to -12db (still pretty far from Reference), you will need 240 watts per channel. And so on, with a doubling in power for every 3db. Of course, we are listening at slightly more than double the total volume that we started with by the time we get to -12. A lot of people, including myself, simply don't like listening at very loud volumes, irrespective of distortion. That's probably why average listening volumes are in a much lower range, and why most AVR's don't go much over 120 watts per channel.
But, even making reasonably favorable assumptions regarding the initial power demands at -24db, we can see that the idea of trying to approach Reference volumes requires extremely efficient speakers that can handle lot's of power, really good subs, strong external amplifiers, and good bass management. For the great majority of systems, it would be very important to transfer the load from your satellites to your subs if you are trying to get up anywhere near the -15db range or higher. And you certainly may want to do it at even lower volumes, as well. If you are serious about approaching Reference volumes, though, it will drive many of your equipment choices. But what if you aren't trying to trying to approach Reference volumes? What if your goals are completely different? This is where I think the disconnect comes in with respect to bass management.
If you are content to listen at that presumed average range of -25 to -20db, or so, transferring the load to your sub(s) is a little less important, particularly if you have XT-32. And that is what I think Chris was addressing in Ask Audyssey: the typical user with XT-32 who listens at typical, relatively low volumes. In that case, depending on your own assessment of the sound, and of the capabilities of your satellites and sub(s), crossovers of 60, or even 40, may work perfectly well for you, if that's where your AVR set them.
Or, if your audio system is primarily a music system (as mine is), and HT is distinctly, or even somewhat secondary to that, then lower crossovers, or even running your speakers as Large, may be very viable options. And your goals here may have resulted in deliberately different equipment choices compared to the person who was trying to achieve a Reference HT system. Again, Audyssey doesn't really care about your specific audio goals. It simply tries to EQ the sound to improve room/speaker interactions.
In my opinion, this is often why it is so difficult for us to communicate when we discuss some of these issues. Our goals can be so different, and with them our perspectives, that we find ourselves assuming that others share our own goals, and craft our advice accordingly. This is also why I think the whole subject of bass management is so complicated. You not only have to understand the basic principles of bass management, you also have to clearly understand what your own goals are. And then once you know what you want to accomplish, you have to figure out how best to do that with your room, your system, and your set-up. It's a pretty individual and personal process. It's also pretty hard to get all of that into a set of general guidelines.
I hope people will forgive the length of this post, but I have been thinking the last couple of days that this issue needed a little more discussion, and this was cathartic if nothing else.
Mike
ambesolman and tbaucom like this.
mthomas47 is offline
post #75723 of 75724 Old Yesterday, 11:35 PM
REM Germany's Avatar
Quoted: 51 Post(s)
Sorry for cross posting this from the 8802 thread, but maybe I am getting some help here:
Alright,
I got my 8802 yesterday and had the whole Saturday morning to set everything up....Couple of questions further down if someone can be arsed to read through my wall of test.
In addition to the 8802 I got myself an Antimode Dual Core and the first thing I did was to have this little box of magic go crazy on my room modes and it is amazing how flat this thing manages to get the frequenzies below 80 hz. I had some pretty hefty modes around 50 hz which I never got under control with the onboard EQ of my Velodyne and the Antimode just flattened them. Pretty nice...
Second step was then to wire everything up and let Audyssey do its thing...
I havent got around to listen to a full movie, but I managed to play a couple of sequences of my favourite movies/scenes and the results so far sound pretty promising (reference setting with dynamic EQ enabled).
Now there is just one thing I am wondering about...when I first ran Audyssey I ran it as part of the initial setup and I noticed that it basically cranked the volume up on all channel. Pretty much +11 db and +12 db on everything but the Subwoofer, which got -0.5 db assigned, so I assume I nailed at least the Subwoofer Setup with the Antimode.
The volume on the 8802 was the "out of the box" 40 on the volume scale when I ran Audyssey...I thought it was a but strange that every channel was raised basically to the max, but when manually checking the level of the channels with a SPL they were indeed all at the same level (had to raise the volume to 70 on the Marantz to get to 72 db on the SPLwith the help of the testtones).
I then ran Audyssey a second time with the volume up to 48 which seems to be the volume setting I found ok when testing with the above mentioned movie scenes.
Somehow I would have expected that the mastervolume makes a difference, however once again all channels got raised by around 11-12 db.
Could this be related to the fact that I have active speaker? There is the possibility to increase/gain volume on each speaker. At the moment all sit at around 5 of a 0-9 scale.
As mentioned the speakers are all at the same level, but I am wondering if it could cause any harm to have each channel run at max gain from the Pre/Pro settings?
From a sound perspective everything sounds pretty much fine at the moment, only center channel seems to be a bit quiet for my taste so I might increase it a bit from the options menu. Had to do the same with my old processor and with the Nad M17 and the 7702 I had over for testing.
This is the first time I am using Audyssey on a processor, so I would appreciate any advice if the above is normal behaviour.
Thanks a lot!
REM Germany is online now
post #75724 of 75724 Old Today, 12:05 AM
ambesolman's Avatar
Quoted: 646 Post(s)
Liked: 578
Sounds like the settings on the speakers themselves are too high. I'd lower them to 2-3, then rerun audyssey to see if it's still maxing out your trims. If still maxed out, try 1. Other than that, I'm out of ideas and hopefully smarter folks will chime in.
Sent using Tapatalk since the mobile version is still [emoji107]
ambesolman is online now
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
