"Official" Audyssey thread (FAQ in post #51779) - Page 2527 - AVS | Home Theater Discussions And Reviews
post #75781 of 75789 Old Yesterday, 05:25 PM
aaranddeeman's Avatar
Quoted: 547 Post(s)
Liked: 153
Originally Posted by AustinJerry View Post
The measurement technique is correct now. I don't see a significant difference in the default distance and the tweaked distance, at least not enough that would cause an audible difference. I would leave it at the default.
Okay. Thanks.
Just want to make sure that I was looking at the right thing.
The default distance has roll off at crossover point (90Hz).
My tweaking was such that it becomes as flat as possible at 90Hz without significant drop in the 20-90Hz range. Is this the correct way to tweak?
aaranddeeman is online now
post #75782 of 75789 Old Today, 07:15 AM
Alan P's Avatar
Quoted: 1958 Post(s)
Liked: 1001
I concur.
I would however crank that sub trim up a bit. Probably sounds a little anemic right now.
AVR: Denon 4520ci, FL/R: Klipschorn, CC: Klipsch RC-64ii, SUR: Polk LS/FX x4, FH: Klipsch RB-51ii x2, SUB: PSA T-18 x2, DISP: Mitsubishi WD-73740, BluRay: PS3 & BDP-S5100, Remote: URC MX-700
Getting Started with REW
Audyssey 101
Audyssey FAQ
Alan P is offline
post #75783 of 75789 Old Today, 07:20 AM
Alan P's Avatar
Liked: 1001
Originally Posted by aaranddeeman View Post
Okay. Thanks.
Yes, you are correct. However, you don't really have a problem at the crossover (lucky man!) to begin with so that's why the tweak didn't seem to do much.
Here's a more dramatic example of how the distance tweak can help a big dip over the crossover:
Audyssey 101
Audyssey FAQ
Alan P is offline
post #75784 of 75789 Old Today, 08:06 AM
johnnymacIII's Avatar
Quoted: 113 Post(s)
Liked: 25
Originally Posted by mthomas47 View Post
I was sort of hoping that you wouldn't ask, as the answer is a little complicated. On the other hand, this question comes up from time to time, so it's probably worthwhile to try to provide a comprehensive explanation. So, here's my take on it.
There are sound waves bouncing around your head (and off it) from the leather sofa back, from the ceiling, from the floor, etc. all the time. You simply don't pay much attention to those sound waves for several reasons. First, if they are very high frequency waves, and many of them are, they are short in wavelength (less than an inch) and transient in duration. Unless there are a lot of them grouped together, our hearing just isn't sensitive enough to notice them. Second, there are psycho-acoustic phenomena in play. We tend to pay the most attention to the first arriving sound (the Precedence Effect: see Haas), so the sound we really notice is coming from the general direction of the speaker(s) playing it. And our brains are actually quite adept at filtering out extraneous noise, as we do when we talk on the telephone, or work, or talk to someone in a crowded restaurant. So, those spurious sound waves bouncing off your sofa and into your ears are largely unnoticed by your hearing, and ignored by your brain.
Ideally, Audyssey, and particularly XT-32, should ignore them as well. What you don't want Audyssey to do is to try to be fussy in the upper frequencies. There are graphs in the Addendum to the FAQ which show the difference between XT trying to over-correct the upper frequencies, and XT-32, doing less up top. The philosophy between the two versions is different. XT-32 attempts to disregard minor deviations in the upper frequencies, and only deal with variations that span across let's say 50-100hz. It's very different at the low end, though, where Audyssey will try to detect and correct issues involving only a few hertz. But, when Audyssey attempts to make so many minor adjustments up high, the result can be a garbled, or harsh sound. So, we want to avoid creating a situation where Audyssey will try to over-adjust in the high frequency range.
The Audyssey microphone doesn't hear the way our ears do; it is far more sensitive. And it doesn't have a psycho-acoustic mechanism like our brain, which will allow it to disregard what it hears in quite the way we can. So, if the mic. gets too close to a hard surface during calibration, the short waves bouncing off the surface into the mic. will "spoof" Audyssey into trying to "fix" a problem that doesn't really exist. Due to the close proximity, the sound waves will seem more prominent, and problematical, than they really are. And in trying to correct for that non-existent problem, Audyssey will create a lot of unnecessary filters (hair) in the upper frequencies. That is called comb filtering due to it's shape, and it is a form of distortion which Audyssey can inadvertently introduce. That's why users are advised to keep the Audyssey microphone about 18" away from hard surfaces. But, trying to stay so far away may not present an ideal calibration, so people came up with the idea of temporarily using a blanket.
When you use a blanket, or towel, during calibration, you can position the mic. close to hard surfaces without worrying about spurious reflections "spoofing" Audyssey into over-correcting. And when you remove the blanket after calibration, you will go back to your normal situation in which the relatively lesser acuteness of your hearing, and the psycho-acoustic phenomena discussed earlier, will protect you from hearing (or noticing) the spurious reflections bouncing around you. A lot of us have tried it and found that to be the case. To summarize, this procedure of using a blanket during calibration has been endorsed by Chris K,. the inventor of Audyssey, and well established empirically by numerous members of the thread. It makes sense acoustically, and it works. Win, Win, as they say.
Mike
Awesome write-up Mike. How close can you get with the blanket? I think I read 3 inches somewhere, does that sound correct? Thanks.
johnnymacIII is online now
post #75785 of 75789 Old Today, 10:07 AM
mthomas47's Avatar
Quoted: 202 Post(s)
Liked: 143
Thank you! I don't know that I have ever heard of a specific distance limitation. I generally keep the microphone about 4"-6" away from the blanket, but I think you would probably have to experiment to find out what works best for you. Depending on how much you lean back when you watch/listen, your ear canals are going to be about 4" or so from the back of the chair or couch, anyway. I have never felt that having the mic. 6" away from the back of my chair made any difference to the sound. Now, getting 18" away on the other hand, does make a difference for me.
mthomas47 is online now
post #75786 of 75789 Old Today, 10:31 AM
Quoted: 547 Post(s)
Liked: 153
Ah. looks like I am in much better shape (may be due to my sub is nearfield).
post #75787 of 75789 Unread Today, 04:54 PM
CRT Guy's Avatar
Hi all,
I just installed a Denon 2100w and some vintage Boston Acoustics VR 30. I am NOT running a subwoofer. They've only been hooked up for a few days now. On the first day, I did not use Audessey, and I thought the speakers sounded incredible as is. On the second or third day I tried Audessey, but honestly, did not put much effort into it. I received a refurbished Denon, which came with everything (seemingly) except the microphone stand, so I set the Audessey mic up on a cardboard box at ear level. I also only ran the test with one position. Honestly the results were quite good, in fact, I seem to like it more each day. It definitely enlarged the soundstage and raised it up.
Anyways, I have one complaint. Bass. I'm streaming TIDAL, so I'm getting CD quality sound, but I still find myself wanting to turn on "restorer" to low, because it really increases the bottom end and adds a lot of power to the sound. I don't know how else to explain it. I know that sometimes people are just used to music with heavy bass, but I don't really think that's the case here. Seeing that I don't have a sub, I can't run one "hot." I'd like to keep the current Audessey setting but some how add bass to it. I can do this perfectly by turning on "restorer" to low, but that also increases the highs and at that point they become just a little bit over done.
I know I need to run Audessey again with the proper stand, but based on my experience so far, and having had what I think was Audessey used in my car nearly six years ago, I can almost bet that I'm going to think it will be lacking in the bottom end. Is there anything I can do under these circumstances, besides to get a sub? It's not something that's in the cards right now.
I should add that I have read through most of the FAQ and guide in this thread and am planning to read it again now.
CRT Guy is online now
post #75788 of 75789 Unread Today, 05:20 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 169
Have you tried Dynamic EQ? I much prefer it ON because music lacks bass without it, especially at lower volumes. Otherwise, many people increase their sub level after Audyssey.
Soulburner is online now
post #75789 of 75789 Unread Today, 05:25 PM
garygarrison's Avatar
Quoted: 128 Post(s)
Liked: 81
Originally Posted by CRT Guy View Post
Hi all,
What is "restorer?" Is it just bass boost? If so. how many dB? Or does it synthesize extra bass? Some devices create bass underpinning one octave lower than whatever the fundamental of a given bass note is.
If you play your system significantly below Reference Level, the measured bass boost given by Audyssey's DEQ may help. I don't like it, but many do.
If you have a true bass control (not the one octave sliders which are incompatible with Audyssey), you can boost it a little. In my system I use Audyssey FLAT or Audyssey Reference with up to 6 dB bass boost. The advantage of this boost is that it does punch up some bass in the Left and Right main speakers between 80 to 200 Hz. People who just turn up their sub after Audyssey calibration are mainly changing response at about the crossover point and below (usually from 80 Hz on down). That helps, but does little to the areas of upper bass above 80 Hz, where some bass drum & timpani impact zones are (the latter instruments also have plenty of response below 80, but not generally the "smack" of the impact). In addition to using a little boost with the bass control, I also turn my sub a bit. I know you can't do that -- yet.
garygarrison is online now
post #75790 of 75789 Unread Today, 05:54 PM
CRT Guy's Avatar
What do you mean if I have "true bass control." You can hit options, go to "tone" and adjust bass and treble, but not in Audessey mode IIRC.
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
