"Official" Audyssey thread (FAQ in post #51779) - Page 2529 - AVS | Home Theater Discussions And Reviews
post #75841 of 75842 Old Today, 08:38 PM
AustinJerry's Avatar
Quoted: 2606 Post(s)
Liked: 1288
Originally Posted by Soulburner View Post
I have an Audyssey / room correction question. Why doesn't the system measure the room again after the filters are created to check its results? We all know that it doesn't always get it right for various reasons and rooms can be unpredictable. Accuracy could be improved if the system could compare the results to its targets, and make further fine adjustments if necessary.
Pretty simple answer, if you think about it. It would be impossible to place the microphone back in exactly the same spots that the measurements were taken. Since results can vary significantly, depending on where the mic is placed, they would not be valid.
AustinJerry is online now
post #75842 of 75842 Old Today, 09:40 PM
Morning5's Avatar
Quoted: 314 Post(s)
Liked: 104
"...the Level Calibration for your subwoofer will be within a range from about -3.0dB to +3.0dB..."
Should I aim for 0db? Is 0 db the perfect value?
Also, I havemy speakers very closeto the rerar wall and tv. Should I separate the speakes from the wall and tv at least 10 cm? Last time I ran audissey it seleced 40hz crossover, while my speakers are rated for 60hz - 80hz effective-.
Morning5 is online now
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
