"Official" Audyssey thread (FAQ in post #51779) - Page 2543 - AVS Forum | Home Theater Discussions And Reviews
post #76261 of 76279 Old 06-23-2015, 08:14 AM
kbarnes701's Avatar
Quoted: 4520 Post(s)
Liked: 3359
Originally Posted by Moosebox View Post
Yes, I literally only read d)3. for some reason, even though I read the table of contents. I admit my mistake! Please have mercy, I ask for forgiveness from the Audyssey Gods!
LOL. No need to beg for mercy ... just wanted to be sure you were good to go.
kbarnes701 is offline
post #76262 of 76279 Old 06-24-2015, 10:53 AM
Dionyz's Avatar
Quoted: 12 Post(s)
I am seriously considering getting the "audyssey installer pro kit" for my soon arriving Marantz AV8802
However, I do not seem to be able to locate any place to get one (no luck searching this tread).
If anyone knows where to get this kit or has a used one they are considering selling, please p.m. me
Dionyz is offline
post #76263 of 76279 Old 06-24-2015, 10:53 AM
Dionyz's Avatar
Quoted: 12 Post(s)
Dionyz is offline
post #76264 of 76279 Old 06-24-2015, 11:37 AM
ambesolman's Avatar
Quoted: 692 Post(s)
Liked: 606
I know @kbarnes701 used to have it and switched to Dirac. Might see if he wants to let it go.
Sent using Tapatalk since the mobile version is still [emoji107]
ambesolman is online now
post #76265 of 76279 Old 06-24-2015, 11:53 AM
kbarnes701's Avatar
Liked: 3359
I do still have mine but the carriage to the US would be quite costly I'd think, making it more or less as much as new kit.
If @Dionyz sends an email to scott@techht.com (or his AVS user name is getgray if a PM is easier), Scott will sort it out for him as he is a distributor of the Pro Kit. Tell him Keith sent you and he will give you a good deal
post #76266 of 76279 Old 06-24-2015, 12:20 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East, dts:x Films: Under the Skin, 3D, Birdman, X_Machina, The Zero Theorem, Interstellar
Quoted: 4893 Post(s)
Liked: 2011
...Or he can go in the Classifieds section of the forums.
NorthSky is offline
post #76267 of 76279 Old 06-24-2015, 04:57 PM
Johnla's Avatar
Quoted: 37 Post(s)
Liked: 29
Info on where to buy, is in the Audyssey Pro Installer kit thread FAQ.
The Audyssey Pro Installer Kit Thread (FAQ in post #1)
Or you can purchase from AVS member "GetGray", through TechHt. Contact at scott@techht
Johnla is offline
post #76268 of 76279 Old 06-24-2015, 05:14 PM
Dionyz's Avatar
Quoted: 12 Post(s)
Thanks kbarnes701 & Johnia
NorthSky - really ??? That is the first place I looked, however, there were no sellers in the last 5 months.
Dionyz is offline
post #76269 of 76279 Old 06-24-2015, 07:06 PM
NorthSky's Avatar
Liked: 2011
Did you also check eBay? ;-)
NorthSky is offline
post #76270 of 76279 Old 06-25-2015, 03:00 PM
Seachongo's Avatar
Subwoofer settings for Audyssey set up
Hi, I have an old Energy EPS-12 sub with 3 dials:
#1 . Low frequency Equalization
#2 . subwoofer level
#3 . subwoofer roll off frequency
I understand that the level should be set midway at 12 o'clock and possibly the roll off frequency at 150? Not absolutely positive on that one.
Can anyone tell me what the #1 and # 3 dials should be set at to run Audyssey setup? I couldn't find any reference to a low frequency equalization setting in any posts.
Thanks so much
Seachongo is offline
post #76271 of 76279 Old 06-25-2015, 05:26 PM
batpig's Avatar
Quoted: 1817 Post(s)
Liked: 2004
Thanks so much
Turn the "roll-off frequency" knob all the way up to get it out of the way
The level, I would actually start at around 1/3 instead of 1/2, but that's something you have to play with (just make sure you don't get maxed out at -12dB after Audyssey)
The "equalization" knob (as the little picture next to the knob indicates) is a mid-bass boost, basically sacrificing flat response and low frequency extension for more "slam" with a bump in the mid bass. However, Audyssey attempts to EQ your subwoofer FLAT, so if you add a bump in the mid-bass, Audyssey MultEQ will waste resources trying to flatten the bump out. In other words, set that knob to the minimum (0) setting so the response is as flat as possible. Then, AFTER calibration, you can play with that knob if you want to get a little more oomph with explosions in movies and stuff.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #76272 of 76279 Old 06-25-2015, 05:47 PM
Seachongo's Avatar
Fantastic, thank you so much! I just saw this post as I got off of batpigworld :-). That is an incredible site, a huge help and an entertaining read! Thanks again.
post #76273 of 76279 Old Yesterday, 05:56 PM
Vader424242's Avatar
Quoted: 46 Post(s)
Liked: 56
Hi all,
I have a quick question concerning initial sub levels prior to Audyssey calibration. I thought I had a handle on it, but now I'm not so sure. My understanding is that, regardless of the initial sub SPL level, Audyssey would reset it to where it wanted anyway, so what is the importance of the 75dB recommendation? Would the final AVR setting vary based on the initial sub level? What about the sats (which should be balanced relative to the sub)?
In my case, I completely bypassed the sub level check prior to the first Audyssey sweep, and simply fiddled until I maximized the sub gain where it didn't completely bury the AVR needle at -12, and went from there. The final AVR setting was -10.5, which I found was way too low. I had to bump it to -6 just to get flat with the sats, and then a further 3dB to add some "spice." Now I am wondering if the results would be different if I had first set the subs to 75dB at the MLP.
What am I completely missing here? Thanks!
Peace... Vader
"Ya see, we plan ahead. That way we don't do anything right now. Earl explained it to me." - Valentine McKee
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
Vader424242 is online now
post #76274 of 76279 Old Yesterday, 06:01 PM
Skylinestar's Avatar
Quoted: 475 Post(s)
Liked: 90
The final setting of -10.5 should be flat with the sats. That's the purpose of Audyssey setup.
Skylinestar is offline
post #76275 of 76279 Old Yesterday, 06:05 PM
Quoted: 46 Post(s)
Liked: 56
Using both a Rat Shack and Galaxy 140 SPL meter, I had to bump it nearly 5dB to get it flat (using Disney WOW, and the fact that all tones are recorded at -20dbSF). In other words, running 3dB hot right now equates to a 75dB/85dB SPL reading (allowing for a 3dB discrepancy in the Rat Shack meter).
Peace... Vader
post #76276 of 76279 Old Yesterday, 06:23 PM
garygarrison's Avatar
Quoted: 148 Post(s)
Liked: 94
Audyssey can be pretty good at producing flat response -- not ruler flat, but smooth enough with speakers & rooms that don't have big problems.
But, it seems that a fair number of people don't like flat sound. Many people reporting here, myself included, turn up their subs several dB after running Audyssey. Also, didn't the Harmon research indicate that flat didn't sound subjectively "flat" to their test listeners? In any case, the preferred curve seems to be one that is somewhat elevated in the bass, getting lower smoothly until it gets to the top. I don't remember how much higher this curve would be at the bottom than at the top. Wasn't it something like 7 or 8 dB, or more?
Another factor is that many recordings (especially CDs, as opposed to SACDs, Blu-ray, vinyl, etc.) are strident at the top. J. Gordon Holt wrote an old article in Stereophile addressing this. It was titled "Down with Flat!"
The Rat Shack meter isn't very accurate. It's O.K. for overall SPL, but not for frequency response. There have been many compensation schemes published over the years to correct for inaccurate Rat Shack Meter readings, but these charts don't agree with one another. One possible explanation is that, as far as frequency response is concerned, the meters vary a gread deal (i.e., they are low in reliability or precision, as well as the aforementioned inaccuracy). I really don't know the reason(s), but I do know I have two of these meters, and neither one produces a curve that resembles a MLP curve taken with REW. The latter is smoother than the Rat Shack result, both before and after running Audyssey.
Alan P likes this.
garygarrison is offline
post #76277 of 76279 Old Today, 09:48 AM
01svtL's Avatar
OK, total Audyssey newbie here. I currently have a Marantz SR6004 with the AudysseyEQ. It has been giving me several problems lately, so I want to pick up a refurb from A4L, and have been looking at the Marantz 5008, Yamaha RX-A1000 and the Denon AVR-X3000. I know the 5008 and X3000 have the slightly newer version, the XT and the Yamaha uses their own version. My question is, how big of a difference will this make if I'm only using a 3.1 setup? One thing to consider is that I have Klipsch RF5's up front. The left one is perpendicular to the end of a couch, which sits about 18" in front of the speaker (tweeter and top woofer clearly seen from seating position, bottom woofer concealed behind the couch) and the right speaker is perpendicular to a large leather chair that is about a meter away (Tweeter and top woofer visible, but barely). Tweeters of both speakers are at perfect ear level. So basically the furniture is in a U shape with the speakers at the top points of the U, main seating position at the middle/bottom of the U. The sub sits just inside the top left point, clear view of it from the main seating position. Will the Audyssey XT be better at correction in this kind of situation than the original EQ? What about Yamaha's YPAO? Does the Odyssey even matter since I'm only using a 3.1, or will it definitely matter because of the furniture placement?
01svtL is online now
post #76278 of 76279 Old Today, 09:54 AM
batpig's Avatar
Liked: 2004
Last question first -- it doesn't matter how many speakers you have, they still interact with the room acoustics, so room EQ is going to help. And with a funky setup, I would think room EQ is MORE important to correct for the compromised layout. The more "ideal" your speaker layout and room acoustics get, the less work room EQ has to do to fix problems.
The difference between MultEQ and XT is there but it's subtle. There is no improvement in subwoofer correction, but there is a significant increase in satellite filter resolution so there is more ability to correct the other speakers' response. You should experience a subtle increase in "blend" between the speakers and more coherence / smoother integration, but it's probably not going to blow you away relative to basic MultEQ. The biggest jump would be if you could go all the way to XT32, but that's a few hundred more on the refurb market (Denon X4000, 4520CI, or Marantz 7008).
Setup Guide and FAQ
post #76279 of 76279 Unread Today, 10:18 AM
01svtL's Avatar
That's kinda what I was thinking. Thanks for the response! Yea really $400 is the top end for me right now, and the only reason I am considering the 5008 or 6006 at $429 is they both come with a 3 year warranty right now on A4L - which after all the problems I've had with my 6004 is a huge selling point to me.
So I care more about audio than I do the extras like networking etc. I like the sound of the Marantz paired to the RF's. I hear the newer Yamaha Aventage AVR's are more musical and less bright than the older RX-V Yamahas. It's pretty rare we sit and listen to music, but it happens. We are more likely to play music while cooking, working in the house or entertaining guests etc. At that point, I would think Audyssey would be less important and actual audio quality would be more (like Onkyo's are probably not a good match with the RF's horn tweeters, as weren't the older RX-V Yamaha's). Still, while watching movies, I guess it would help to have the room correction for all the imperfections between the speakers and seating position.
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
