"Official" Audyssey thread (FAQ in post #51779) - Page 2566 - AVS Forum | Home Theater Discussions And Reviews
post #76951 of 76964 Old 08-26-2015, 02:18 PM
antennahead's Avatar
Quoted: 183 Post(s)
Liked: 121
Originally Posted by Badas View Post
When you say DEQ are you referring to Dynamic EQ? If so that might explain the muddy sound. As it will be pumping up the bass in those low frequencies.
Air in treble is a funny thing isn't it? Once I played with a tubes I understood air. I had never liked treble until I heard a tube render it so sweetly with ambiance. After hearing what tubes could do I look for it in all my equipment now. Dangerous game tubes tho. I have $5K worth of spare NOS* tubes.
*New old stock.
Any 12ax7s you wannna spare ........................... my guitar amp could use some good NOS magic
antennahead is online now
post #76952 of 76964 Old 08-26-2015, 02:54 PM
Badas's Avatar
Quoted: 47 Post(s)
Liked: 29
I would if I had them.
Badas is offline
post #76953 of 76964 Old 08-26-2015, 03:07 PM
Quoted: 183 Post(s)
Liked: 121
I was teasing you. I do however know all about tubes. In the guitar world it's called "chasing tone"
post #76954 of 76964 Old 08-26-2015, 05:07 PM
Badas's Avatar
Quoted: 47 Post(s)
Liked: 29
I knew you were. However I'm the type of guy that would have passed you some. I often do at headphone meets.
Chasing a sound is fun. I bought loads and loads of tubes before having the desired arrangement (power, rectifier and drive tubes). Once I found my desired sound I purchased 14 sets of everything. 70 years worth. My lifetime.
Badas is offline
post #76955 of 76964 Old 08-26-2015, 10:05 PM
Quoted: 183 Post(s)
Liked: 121
You're a kind soul I totally get the "desired combination" thing...... it's very similar in guitar amps. I wish I had stockpiled a bunch of NOS tubes years ago. Guitar players seek a different thing tube amp wise than audiophiles....... we want some break up at the right point in our power tubes......... that singing sustained harmonically rich guitar sound that permeates classic rock ........ tube distortion Sorry if I've temporarily derailed the thread
Badas likes this.
post #76956 of 76964 Old 08-27-2015, 12:51 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 674
Brain fart here. I had been using my display for a few days, and just setup some new gear. I ran XT32 setup with the tv cranked up pretty good, but I am assuming the test tones go to the pre outs and speaker terminals only and would have nothing to do with anything passing thru the displays speakers and mucking with auto eq? I usually leave the displays speakers disabled.
Panasonic VT50 / Sony S7200
Denon AVR-4520CI
Klipsch RF-7II and RC-64II
Dual Rythmik FV15HP's
gadgtfreek is offline
post #76957 of 76964 Old 08-27-2015, 01:05 PM
mogorf's Avatar
Quoted: 650 Post(s)
Liked: 223
What exactly did you do? Apart from brain f@rt?
mogorf is online now
post #76958 of 76964 Old 08-27-2015, 01:09 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 674
Just second guessing myself. Wanted to make sure audyssey sweeps werent passed on to the tv speakers thru HDMI and messed with the auto eq for my speakers connected to the AVR.
Denon AVR-4520CI
post #76959 of 76964 Old 08-27-2015, 01:15 PM
mogorf's Avatar
Quoted: 650 Post(s)
Liked: 223
Hope all's OK by now! Enjoy!
post #76960 of 76964 Old 08-27-2015, 07:40 PM
mthomas47's Avatar
Quoted: 318 Post(s)
Liked: 270
If I understand your question correctly, Audyssey test tones are played only through the speakers hooked up to your AVR and enabled in your Speaker Configuration Menu. You can track the sweeps as they play through the speakers, and see the virtual speaker display on your screen. If your TV has built-in speakers, those are disabled anyway once you turn on your AVR. So, you're good.
gadgtfreek likes this.
mthomas47 is offline
post #76961 of 76964 Old Yesterday, 09:54 AM
ciukacz's Avatar
I am trying to improve tonal balance for music listening.
My whole music library has ReplayGain tags calculated for 89dB reference.
However Audyssey's DynamicEQ works with 75dB reference.
Do I need to somehow account for the 14dB difference?
ciukacz is online now
post #76962 of 76964 Old Yesterday, 11:04 AM
mogorf's Avatar
Quoted: 650 Post(s)
Liked: 223
Hi ciukacz,
This, IMHO is one of the hardest questions I've ever read here on this thread.
Nonetheless, as another advocate of using ReplayGain for music libraries, here's what I do. I set RG so that music is played back with a peak level not exceeding 0 dB. That gives my ears a pleasing tonal balance at any volume setting.
Although you might also want to experiment with -5 dB or even -10 dB peaks. Turn DynamicEQ on and do a lot of listening tests till you can settle RG to your liking. And then keep it that way, especially for playlists where your music playback levels may vary a lot. Once you set individual RG you won't have to touch your remote for volume between songs anymore.
My experience is that as we go back by decades the playback level is getting lower and lower, typically by some 5 dBs, i.e. the older the recording the lower the initial playback will be.
You may read on the subject with a keyword search. "Loudness war".
I use Foobar 2000 with a plug-in called "Peakmeter Spectrum" to check playback levels and it works for me like a charm.
Hope this helps.
post #76963 of 76964 Old Today, 01:32 AM
ciukacz's Avatar
If we agree that ReplayGain algorithm can actually calculate at what SPL the mix was performed (because that's what it's trying to do, right?)
then why should I experiment with different settings as you suggest?
There should be only one correct value to compensate for the difference between these two reference levels.
I am just asking what is the correct "offset" I should use and where do I put it.
The tools at my disposal are source level offset on the AVR side and preamp setting in XBMC software.
post #76964 of 76964 Old Today, 01:54 AM
mogorf's Avatar
Quoted: 650 Post(s)
Liked: 223
Well, not exactly. With ReplayGain you put a tag into each of your music files where the dB value will surely be different album by album/band by band and by date of recording.
See above.
Nope. The whole point of RG is to bring your whole library to the same playback level, album by album.
Again, there is no single correct offset with RG.
Neither of these will let you achive your goal, you need to "touch" every song, or every album at least.
Hope this helps.
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
