"Official" Audyssey thread (FAQ in post #51779) - Page 2567 - AVS Forum | Home Theater Discussions And Reviews
post #76981 of 77007 Old Yesterday, 03:42 PM
mthomas47's Avatar
Quoted: 326 Post(s)
Liked: 277
Originally Posted by pasender91 View Post
I love what audissey XT32 does for EQ of the room but boy do i hate the Audissey DSX wides , they add a lot of echo into the wide stage, i find it appaling.
I know its not wides, but i found the PL IIz and Dolby Surround upmixers so much more attracting
I have never tried wides, but I surely like PLIIx.
mthomas47 is offline
post #76982 of 77007 Old Yesterday, 03:49 PM
asere's Avatar
Quoted: 411 Post(s)
Liked: 54
Originally Posted by mthomas47 View Post
It's fine as it is. But you were saying that you wanted more bass. So, if you are thinking of adjusting it upwards, then I would re-calibrate to get it much deeper into the negative numbers. I have been calibrating at -11, so that I can go up as much as I want and still be in negative numbers. And I have experimented with adding as much as 9db from that initial setting.
There was a time when a lot of us thought that -3 to +3 constituted the ideal calibration zone, but that thinking has changed based on information from Mark Seaton and Ed Mullen, two of the World's leading subwoofer experts. Again, the FAQ, and the two experts, can explain it to you better than I can. But I am careful to follow their advice.
My sub DXD 12012 has a setting that's for reference bass for the sub volume and it's suppose to stay there. It's a green dot setting on the back.
It's not like other subs where you move the knob like to 9 o'clock and get to calibrating with audyssey.
On that reference setting audyssey always sets my sub to say -3/+3.
If I want sub to give more bass I basically need to move the knob past reference say 8 o'clock and then run audyssey?
If the results are say -10 then I do the calibration for the sub to my liking by changing audyssey results to say 0 on the avr?
Sent from my SM-G900P using Tapatalk
asere is offline
post #76983 of 77007 Old Yesterday, 03:50 PM
mogorf's Avatar
Quoted: 658 Post(s)
Liked: 225
Mike's got it!
Just for reference, in my case Audyssey set my sub channel trim to -6 dB. Its OK with me for majority of movies. But when listening to music on the same living room setup I do need to raise this trim a tad bit, sometimes maybe a bit more than a tad bit due to the fact that some music recordings lack the bass I need. Being in the negative trim range makes it easy to adjust bass without overdriving the subwoofer channel causing undesired clipping or distortion withing my listening comfort range.
mthomas47 likes this.
mogorf is offline
post #76984 of 77007 Old Yesterday, 03:54 PM
asere's Avatar
Quoted: 411 Post(s)
Liked: 54
Originally Posted by mogorf View Post
Mike's got it!
If audyssey set it to -6 and you wanted more bass you would then just bump it up on avr?
asere is offline
post #76985 of 77007 Old Yesterday, 03:59 PM
mogorf's Avatar
Quoted: 658 Post(s)
Liked: 225
Yes, yes, yes, ...bump it up on the AVR! That's the way to do it!
mogorf is offline
post #76986 of 77007 Old Yesterday, 04:02 PM
asere's Avatar
Quoted: 411 Post(s)
Liked: 54
But say you get +3 after audyssey but want more. Can you go up on avr or is it better to get say a - 8 and then bump from avr?
asere is offline
post #76987 of 77007 Old Yesterday, 04:06 PM
mogorf's Avatar
Quoted: 658 Post(s)
Liked: 225
asere, you are pulling my leg! You know the good answer by now, right?
mogorf is offline
post #76988 of 77007 Old Yesterday, 04:12 PM
asere's Avatar
Quoted: 411 Post(s)
Liked: 54
No I'm just confused now. Audyssey has always set my sub to around +3/-3. I however read from Ed Mullen like the other poster mentioned something about if you get a negative 10 for example it's best to bump up from avr. I guess what I'm wanting to know is if you get a +3 and are not happy is it better go to in avr then and bump up or is it better to get a -10 and bump up. Or is it the same?
asere is offline
post #76989 of 77007 Old Yesterday, 04:18 PM
ERuiz's Avatar
Quoted: 337 Post(s)
Liked: 120
If I recall correctly, if you end up at +3 sub trim in the AVR, then you only have +9 more to play with since +12 is the max. So the proper way is to set the gain on your sub so that you end up with a sub trim of circa -10ish. This would actually give you +22 to play with.
Efrain "AviatorBimmer" Ruiz
ERuiz's Samsung UN65JS8500 Calibration
ERuiz is offline
post #76990 of 77007 Old Yesterday, 04:24 PM
mthomas47's Avatar
Quoted: 326 Post(s)
Liked: 277
You are misunderstanding what Ed Mullen is saying. He is saying to try not to exceed a setting of about "0" in your AVR, regardless of how you get there. So, if Audyssey sets your sub to "0", let's say, and you plan to leave it there, then you are fine. Most of us, though, like to add something from where Audyssey sets it. But we still shouldn't exceed "0", so the recommendation is to increase the gain on your sub so that Audyssey will set your sub low (like -6 or -9, for instance). And then you can raise the level to whatever you like, but still not exceeding about "0". You are overthinking this and getting yourself confused. Just take it on faith for a while until it becomes clearer.
mogorf likes this.
post #76991 of 77007 Old Yesterday, 04:24 PM
mogorf's Avatar
Quoted: 658 Post(s)
Liked: 225
No its not the same, With a lower trim you always have more headroom to bump up your sub in the AVR. Hope this is clear!
mogorf is offline
post #76992 of 77007 Old Yesterday, 04:31 PM
mthomas47's Avatar
Quoted: 326 Post(s)
Liked: 277
Close, but not quite. The current wisdom is to try to stay in negative numbers to avoid over-driving the sub. I don't entirely understand the theory behind it, but since it comes from two of the leading sub makers, I am willing to take their word for it. So from -11, you would have about 11 or maybe 12db to play with. Just as a reminder, it takes a doubling in power to get a 3db volume increase. And a 10db increase is twice as loud as the previous sound level. So, 10db is a lot. A lot depends on your MV setting, though. If you are running movies at -20 on your MV, for instance, it's less of a concern. But I prefer to follow the advice just in case, irrespective of my MV setting.
mogorf likes this.
post #76993 of 77007 Old Yesterday, 04:32 PM
asere's Avatar
Quoted: 411 Post(s)
Liked: 54
Ok I'm understanding now. If I get say +3 then I shouldn't bump up. But if I get a -2 I can bump up to 0. If I get -6 I can bump up to +6, yes?
asere is offline
post #76994 of 77007 Old Yesterday, 04:33 PM
asere's Avatar
Quoted: 411 Post(s)
Liked: 54
All clear and excuse my handicap lol!
asere is offline
post #76995 of 77007 Old Yesterday, 04:35 PM
markhyams's Avatar
Stereo Subwoofers with Audyssey?
I have a Denon 4520 (running as a pre-amp), a separate power amp, and 2 subwoofers.
My goal: to have 2-channel music with STEREO subs, calibrated with XT32.
My idea: Hook up one sub to the main L pre-out from the Denon, and the other to the main R pre-out, use the subs’ internal high-pass crossover (80Hz) and connect the line out from the subs to the power amp.
When I run Audyssey, the subs and the main L/R speakers will receive the test signals at the same time. My question is, will this work? Will Audyssey be able to EQ each channel, even though above 80Hz will come out the speaker, and below 80Hz will come out the sub?
Thanks for your help!
Mark
markhyams is offline
post #76996 of 77007 Old Yesterday, 04:37 PM
mogorf's Avatar
Quoted: 658 Post(s)
Liked: 225
Glad we're on the same wavelenght! Enjoy!
mogorf is offline
post #76997 of 77007 Old Yesterday, 04:39 PM
mthomas47's Avatar
Quoted: 326 Post(s)
Liked: 277
You are close to understanding. If you are at +3, lower the sub gain to get a - number, or no higher than "0". If you are at -6, you have 6db of upward adjustability. The advice is: Don't go into the positive numbers on your AVR, period. I'm stating it a little strongly, but that is an easy way to understand and remember it.
mogorf likes this.
post #76998 of 77007 Old Yesterday, 04:45 PM
mogorf's Avatar
Quoted: 658 Post(s)
Liked: 225
Mark
Not recommended. Just try to use Audyssey "as intended", i.e. connect speakers to speaker terminals and subwoofers to subwoofer terminals. And call it a day.
BTW. There is no sucha thing as stereo subs, or stereo bass. Bass is non-directional to our human ears. For more details, please read the blog "Small vs. Large". Link in my sig.
mogorf is offline
post #76999 of 77007 Old Yesterday, 04:48 PM
mthomas47's Avatar
Quoted: 326 Post(s)
Liked: 277
Mark
Hi Mark,
I may be misunderstanding something, but why don't you just run your two subs into your Denon as Sub 1 and Sub 2. Then after Audyssey time and level aligns the subs, and your AVR sets crossovers for your mains, you can reset the crossovers on the mains to 80Hz, or whatever you like, as long as you don't go below the original crossover assigned by your Denon. Meanwhile, you want your subs' high pass filters set as high as they will go. If you haven't already done so, you might want to read through the Audyssey Set-up Guide, and those portions of the FAQ that deal with multiple subwoofers.
Mike
mogorf likes this.
post #77000 of 77007 Old Yesterday, 04:53 PM
asere's Avatar
Quoted: 411 Post(s)
Liked: 54
Gotcha thx!
mogorf likes this.
asere is offline
post #77001 of 77007 Old Yesterday, 04:57 PM
markhyams's Avatar
Hi Mark,
Because this just results in mono bass. The two subwoofer channels are identical, although they are EQed separately.
Mark
post #77002 of 77007 Old Yesterday, 05:02 PM
asere's Avatar
Quoted: 411 Post(s)
Liked: 54
Now I mentioned I understood and I do. But if you get -6 and you bump up to -9 is that considered hot? Or is hot considered over 0?
Sorry I'm just used to the +/-3.
asere is offline
post #77003 of 77007 Old Yesterday, 05:26 PM
mthomas47's Avatar
Quoted: 326 Post(s)
Liked: 277
Mark
Well, you certainly are free to pursue the notion of stereo bass, but I believe that Feri gave you the right scoop on that. If you have subwoofers, you already know that the low bass sounds they play (below about 80Hz) are non-directional. That is the whole reason that subs were developed, and the whole reason why they work. You can place your sub(s) wherever in the room it produces the strongest bass, and it will support the speakers in the room, wherever they are located. I'm sure that you have already observed that for yourself. So if I were you, and I wanted to set crossovers at 80Hz, I would try it as recommended, and just see what you think.
I don't know how good your main speakers are, but if I really needed to set high crossovers, say 100-120Hz, I might then try to locate my two subs at the front of the room and fairly close to the main speakers, because at that point, I probably would be able to localize (hear where the sound was coming from) the subs fairly easily. But that would be a kind of stereo bass out of necessity. And both subs would still be playing the same sounds. That would still be true if you had 8 subs; and some people do. If your mains are capable of playing down to 8oHz or so, and you are planning to set crossovers at 80, you should be good to go, more or less regardless of where your subs are physically located. I do recommend a sub crawl to optimize their placement, though.
If you believe that you can still localize some bass sounds at that 80Hz setting, then consider setting your crossovers at 60Hz, if your mains are capable enough. I would experiment with that if I were you before doing what you asked about. There is an awful lot of accumulated Audyssey and subwoofer knowledge on this thread, and you are getting the benefit of it.
post #77004 of 77007 Old Yesterday, 05:29 PM
mthomas47's Avatar
Quoted: 326 Post(s)
Liked: 277
Don't worry about what's hot right now. Bump it up however much you like. Just don't go over "0" when you do it. That's why you want to start with -9, or so.
asere likes this.
post #77005 of 77007 Old Yesterday, 08:14 PM
asere's Avatar
Quoted: 411 Post(s)
Liked: 54
Has anyone used Audyssey Dynamic Surround Expansion? If so how is it? It's part of Audyssey's Gold and Platinum package.
asere is offline
post #77006 of 77007 Old Yesterday, 10:38 PM
Skylinestar's Avatar
Quoted: 566 Post(s)
Liked: 104
Avoid it. If the dialogue is locked to the center speaker, it's ok. But many movies have dialogue that pans around the left and right speaker. In this case, DSX will make the dialogue echo-ey.
Skylinestar is online now
post #77007 of 77007 Old Yesterday, 11:03 PM
garygarrison's Avatar
Quoted: 185 Post(s)
Liked: 120
Mark
This would be a very unusual way to set-up. If I understand you, and if I understand the way home theater with Blu-ray works, you should NOT do this! In the past, before subwoofer outputs, some people would hook up their subs that way for music. It's my understanding that this is not appropriate for movies because the filmmakers put in sound effects that come out only through the pre/pro or AVR subwoofer output, and you will miss these effects if you wire things up as you propose. With some pre/pros and AVRs you could get around this by using the setting "no sub" and the special sound effects would be mixed with the main signal(s), but the very loud sound effects (sometimes much louder than music, with peaks of 115 dB if you play at reference level) above the in-subwoofer high pass filter of 80, on up to 120 Hz, about where these effects end, would be passed on to your main speakers where it could possibly damage them, especially with a few of the truly outrageous movies out there.
The usual subwoofer true crossover is 80 Hz, and the usual low pass filter for LFE is 120 Hz. With movies you need both.
I imagine that most purists would not want the signal for the main R & L to pass through the sub circuitry first.
garygarrison is online now
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
Gear in this thread - Kht1005 by PriceGrabber.com
