"Official" Audyssey thread (FAQ in post #51779) - Page 490 - AVS Forum | Home Theater Discussions And Reviews
 3491Likes
post #14671 of 79637 Old 05-19-2009, 05:07 PM
bluesky636's Avatar
Originally Posted by batpig View Post
This is the description in the AVR 1910 manual:
Reference Level Offset: Audyssey Dynamic EQ takes the standard film mixing level of 85 dB SPL during -20 dB FS input as its reference level. However, since standardization is lacking outside the film industry, the reference level of media contents may not be appropriate. In order to view such contents, Reference Level Offset of Dynamic EQ has available offsets of 5 dB, 10 dB and 15 dB.
- 0dB: Suitable for viewing movies.
- 5dB: Suitable for listening to classical music and other content mixed at a high level.
- 10dB: Suitable for listening to jazz and other audio sources with a wide dynamic range. Also suitable for viewing TV.
- 15dB: Suitable for listening to pop, rock music and other content with an extremely wide dynamic range.
(Chris, looks like you let Denon translate this to Japanese and then back again to "Denon-ese" ... only Denon could come up with a linguistic gem like "in order to view such contents" when discussing an audio feature )
Looks to me like Denon got things backwards, though.
Classical music typically has an "extremely wide dynamic range" whereas your typical rock recording is "mixed at a high level" with a very narrow dynamic range.
Or did things "get lost in translation?"
bluesky636 is offline
post #14672 of 79637 Old 05-19-2009, 07:28 PM
blownaway's Avatar
Originally Posted by Mike_WI View Post
I believe "transducer" = Buttkicker (etc) type of chair transducer.
(correct me if I'm wrong)
Mike
Ohh, that makes more sense. Thanks!
blownaway is offline
post #14673 of 79637 Old 05-19-2009, 09:56 PM
allredp's Avatar
Re-ran Audyssey a few weeks ago and loved the results after following scrupulously all the instructions for mic-placement, etc. here. I had added some bass traps and broadband absorption across my front wall, so I thought I'd re-run Audyssey.
Wow, the result was wonderful across the board until I hit scenes with ultra-low hz material. Those scenes are way too hot now for my Ultra.
For example, in Transformers where the choppers fly in at the start--now I'm getting room-rattling extension and power like I never have before. Also, Spiderman 3 with the spinning sand pit machine is just unbelievable. However, in both those movies where other scenes have lower hz stuff, the Ultra makes bad noises--it is clearly being over worked and it make those frightening (in a bad way) mechanical noises.
Honestly I like the overall effect on everything else except the sub 20hz scenes. BTW, I'm running my Ultra in 15hz mode, no room-compensation, in a 2,700 sq ft room (15' x 27' x 7.8'). My processor is the Onkyo 875 being used as a pre/pro.
The only thing I can figure is that there is some over-cooked boosting going on down in those lowest frequencies.
Earlier today another Ultra owner (with duals) reported having the same experience in another thread! I'm kind of relieved because I was worried I just needed to get another Ultra to compensate for the infrasonics.
I actually posted some weeks ago about the "hotness" of Transporter 3, but it turns out that everything I play which has very low hz material just overwhelms the sub.
Ideas? Solutions?
creative>energy
allredp is offline
post #14674 of 79637 Old 05-19-2009, 11:06 PM
ATWindsor's Avatar
Yeah the same thing occured to me, todays pop and rock unfortantly has anything but a "extremly wide dynamic range".
AtW
ATWindsor is offline
post #14675 of 79637 Old 05-20-2009, 01:48 AM
MACCA350's Avatar
Liked: 26
Ideas? Solutions?
Idea
Current Solutions
cheers
MACCA350 is offline
post #14676 of 79637 Old 05-20-2009, 05:18 AM
Mike_WI's Avatar
Quoted: 203 Post(s)
Liked: 141
+1
I was thinking the same thing.
Mike
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & output x1 cards} - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520 FW v30.1]
HT Details: link
Mike_WI is offline
post #14677 of 79637 Old 05-20-2009, 05:54 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 36
Originally Posted by Gary J View Post
Well then, we'll look for proper accreditation in the literature.
"We would like to thank members of the AVSForum Official Audyssey Thread. Specifically, Gary J, Pepar, Kal, and the guy with all those subs."
Disclaimer: The above statement was only meant as a joke. I do not know who really raised the issue in question.
Mark
giomania is offline
post #14678 of 79637 Old 05-20-2009, 05:57 AM
allredp's Avatar
Originally Posted by MACCA350 View Post
The only two options currently at hand that I can see are:
1) Use your subs built in subsonic filter and increase the slope(or implement one if it doesn't have one)
2) Don't use Audyssey
cheers
I appreciate your response--though I am not happy with the answer, eh.
At least I'm not the only one having this issue; you start to think the subwoofer gods have it in for you after a while!
Enjoy the day...
creative>energy
allredp is offline
post #14679 of 79637 Old 05-20-2009, 06:06 AM
Jim Hef's Avatar
...in a 2,700 sq ft room (15' x 27' x 7.8')....
That's 3,150 cubic feet!
Jim Hef is offline
post #14680 of 79637 Old 05-20-2009, 06:46 AM
andyev's Avatar
I have searched but I can't find the answer. I am looking at getting a new receiver and the audyssey feature is the huge selling point. It looks like it comes with a 12' cable. The problem is my receiver is 50' from the room and I need to run it through the house. Is it possible to buy a longer cable and audyssey still work? If so, what kind of cable would I need?
andyev is offline
post #14681 of 79637 Old 05-20-2009, 07:09 AM
Wireless member
pepar's Avatar
Quoted: 1044 Post(s)
Liked: 544
Mark
Not me. I didn't complain provide input on this issue.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #14682 of 79637 Old 05-20-2009, 07:11 AM
Wireless member
pepar's Avatar
Liked: 544
A very good, well-shielded one. Alternatively, you could temporarily relocate your AVR to the room being measured.
pepar is offline
post #14683 of 79637 Old 05-20-2009, 07:20 AM
andyev's Avatar
A very good well shielded what? What kind of cable? I could relocate the receiver but then I'd have to buy new speaker wire to run to the speakers as well as run a source to the receiver which would be a PITA. All my equipment is in an equipment closet on the other end of the house.
andyev is offline
post #14684 of 79637 Old 05-20-2009, 07:29 AM
Wireless member
pepar's Avatar
Liked: 544
I'm sorry. The mic included with my Onkyo Pro 885 cable has a 1/8" phone plug and the 885 the corresponding female. This connector is also known as a mini-phone plug/jack. Radio shack sells them, as do any number of online companies. You will need to check the specs of your specific AVR for the connector type; I don't know that they are - or are not - all the same.
Temporarily relocate for the measurement. Obviously your speakers are in the room being measured. Set up the AVR there for setting up Audyssey. There is some practical limit to the distance one can extend the single-ended mic cable. I don't know exactly what that is, but I imagine that performance deteriorates before it simply doesn't work at all. Perhaps someone else can address the cable length limit.
pepar is offline
post #14685 of 79637 Old 05-20-2009, 07:43 AM
audyssey's Avatar
This is not what we provided for their manual. It's all mixed up. Thanks for pointing it out--we have notified them...The settings shown are correct, but not the explanations.
Chris
Join me for Audyssey Tech Talk on Facebook here.
Follow me @ChrisAudyssey on Twitter here.
audyssey is offline
post #14686 of 79637 Old 05-20-2009, 07:49 AM
audyssey's Avatar
50' is too long for the consumer mic cable. Even the best ones will have high frequency loss because of the resistance increase. The mic level signal is too low for such long lengths. Up to 25' is OK, but beyond that is not recommended. The Pro kit can be extended hundreds of feet because it has a separate preamp that can be near the mic.
Chris
audyssey is offline
post #14687 of 79637 Old 05-20-2009, 08:27 AM
StimpsonJCat's Avatar
Enjoy the day...
I've found that my current workaround is to not use Dynamic EQ and Dynamic Volume. I've been able to get acceptable bass management with MultEQ still on. If I turn on Dynamic EQ/volume I get the boost in the lower frequencies freaking out my sub. I could leave it on and lower the sub level as well as the LFE, but I lose too much bass this way.
I only have to do this with Blu-ray or HDDVD. I don't have the same issues with TV or DVDs.
I still believe there is an issue. I don't know why it would boost the lower frequencies so much. Because it can't be reproduced with the same equipment at Audyssey I think the room enviornment plays a large role in this issue. But in my mind Audyssey should not be boosting those frequencies anyways.
But in the end I like the HD Audio better without the Dynamic EQ / volume and I'm glad I can still use it for TV. I still need a bigger sub!
StimpsonJCat is offline
post #14688 of 79637 Old 05-20-2009, 09:03 AM
MACCA350's Avatar
Liked: 26
As I mentioned, the graphs I posted are without using Dynamic EQ/Vol. The increase in the sub 15Hz range has nothing to do with Dynamic EQ.
If you are interested in seeing a static graph of what Dynamic EQ does see here
If you are using Dynamic EQ and normally listen at lower than reference you will be compounding the low Hz increase relative to the midrange, but it's not the root cause and Dynamic EQ does not increase frequencies above reference.
The issue is that Audyssey MultEQ is increasing low Hz(below the -3db filter adjustment cut off).
cheers
MACCA350 is offline
post #14689 of 79637 Old 05-20-2009, 09:21 AM
cheers
I agree. But for my setup/environment I was able to achieve an acceptable level of bass management by just turning off Dynamic EQ. I guess the extra boost from Dynamic EQ was just enough to push my sub too far. I think the problem still exists and I have no real headroom (If I decide to crank it up I will still have an issue). But, for the level I listen to movies at turning off Dynamic EQ stops the sub issues and still gives me the bass I want. This is just a workaround that works in my setup for now...not a solution to the real problem.
post #14690 of 79637 Old 05-20-2009, 09:21 AM
MACCA350's Avatar
Liked: 26
Chris,
Will the "Dynamic EQ Reference Level Offset" feature be available as an update for previous models(ie Denon 3808 etc)?
cheers
MACCA350 is offline
post #14691 of 79637 Old 05-20-2009, 09:24 AM
MACCA350's Avatar
Liked: 26
Understood, just remember that you will have the same problem if you increase your master volume to/near 0db reference
cheers
MACCA350 is offline
post #14692 of 79637 Old 05-20-2009, 09:27 AM
batpig's Avatar
Quoted: 3693 Post(s)
Liked: 3544
Like I said, you shouldn't have let them translate it to Japanese and then to Denon-ese
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #14693 of 79637 Old 05-20-2009, 09:32 AM
counsil's Avatar
cheers
Agreed.
Dynamic EQ has nothing to do with it. At reference, Dynamic EQ on and off yield the same results. All that Dynamic EQ does is make my subs unhappy at a lower master volume.
I can reproduce the boosting in the teen Hz area over and over again. I have even tried moving my subs to 3 other acceptable locations in my room with the same boosting result. I used to think that room setup was the main culprit. Now I am more inclined to believe that sub design (as it interacts with Audyssey calibration) and/or Audyssey implementation is more to blame. But to be honest, I don't have a clue. All I know is that I can, and have, reproduced this issue several dozen times in 4 totally different sub locations in my basement.
Comments/suggestions?
Never argue with an idiot; they drag you down to their level and beat you with experience.
Counsil Basement HT
counsil is offline
post #14694 of 79637 Old 05-20-2009, 09:42 AM
BGLeduc's Avatar
Quoted: 1698 Post(s)
Liked: 1555
Dude, if Denon starts getting things right in their manuals, you will be out of a job!
Having said that, it is amazing that they appear to have taken something that (I assume), is already IN proper, clear, correct English, and still butchered it. How these huge companies can not afford to have a native English speaker on staff as a tech writer remains one of the minor mysteries of life.
Brian
#JB17
BGLeduc is offline
post #14695 of 79637 Old 05-20-2009, 09:47 AM
batpig's Avatar
Liked: 3544
my entire "de facto Denon guru" salary of zero dollars will then disappear!
I'll take that gig Chris, put in a good word for me
Setup Guide and FAQ
batpig is offline
post #14696 of 79637 Old 05-20-2009, 09:50 AM
HDTVChallenged's Avatar
Liked: 215
Originally Posted by counsil View Post
Agreed.
How about a question? Just to be clear - I've tried to follow the discussion, but I'm still a bit confused.
Are you seeing/hearing/measuring the boost audibly (with a mic or REW) or are you seeing an actual electrical boost at the receiver's sub-woofer output?
HDTVChallenged is offline
post #14697 of 79637 Old 05-20-2009, 09:58 AM
counsil's Avatar
I use REW. I have posted a couple of examples. Search back a bit to find them.
Counsil Basement HT
counsil is offline
post #14698 of 79637 Old 05-20-2009, 10:04 AM
counsil's Avatar
Here is one example of Audyssey really boosting the teen Hz area...
http://www.avsforum.com/avs-vb/showt...7#post16450277
And here is another...
http://www.avsforum.com/avs-vb/showt...1#post16473881
Counsil Basement HT
counsil is offline
post #14699 of 79637 Old 05-20-2009, 10:30 AM
counsil's Avatar
More and more folks in the SVS PB13 Ultra thread are mentioning that they too are having problems with their subs bottoming out very early with Audyssey engaged. Maybe this is an SVS Ultra issue? But why can't Chris reproduce this in his lab with his SVS Ultra? I am perplexed.
Counsil Basement HT
counsil is offline
post #14700 of 79637 Old 05-20-2009, 10:58 AM
BRADH's Avatar
Quoted: 37 Post(s)
I have used my dual Ultra 13's for a little over an year now. First with a Int 9.8 and now a Denon AVP with out any problems (room 22x15x8) subs in 15Hz mode. Maybe its with the 3808. I hope you guys get it figured out.
Brad
BRADH is online now
Closed Thread Receivers, Amps, and Processors
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
