"Official" Audyssey thread (FAQ in post #51779) - Page 52 - AVS Forum | Home Theater Discussions And Reviews
Old 02-22-2008, 07:09 AM
Wireless member
pepar's Avatar
Quoted: 336 Post(s)
Liked: 202
Does Audyssey "expect" that the measuring points match the recommendation to start at main LP, 2' to the left and right and then 2' in front of each of those three positions, and deviation from that protocol will produce sub-optimal results? I will be setting up my 885 this weekend and have picked up a lot from this thread that, I think, will push me around the learning curved quickly. However, my seats are 28" apart and my two rows are 60" apart, and I'd like some guidance on whether to stick to the 2-foot thingy or have the six measuring positions be my six listening positions?
Does that make sense?
pepar is offline
Old 02-22-2008, 07:14 AM
audyssey's Avatar
No, there is no expectation on the spacing of the mic. I would suggest starting with your 6 seats and then taking two more measurements between the two rows.
Chris
Chris
Join me for Audyssey Tech Talk on Facebook here.
Follow me @ChrisAudyssey on Twitter here.
audyssey is offline
Old 02-22-2008, 09:07 AM
Kal Rubinson's Avatar
Quoted: 257 Post(s)
Liked: 249
Chris
Really? I was under the impression that the first measurement must be at the listening position in order to calculate levels/distances and that the other positions were used only for EQ purposes. Can you clarify?
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
Old 02-22-2008, 09:15 AM
Trekari's Avatar
Quoted: 98 Post(s)
Liked: 41
The first position is used to determine levels and timing, yes. What Chris was saying is there is no expectation on the "spacing" of the measurements. i.e. Audyssey is not programmed to expect that the user place the microphone exactly 3' away from the previous measurement, then the next measurement 3' away from that, etc.
Trekari is offline
Old 02-22-2008, 09:25 AM
Quoted: 257 Post(s)
Liked: 249
OK. I read the question to include asking about the first position at the LP.
Kal Rubinson
Old 02-22-2008, 09:45 AM
MysteryMan1's Avatar
I've just run the Audyssey auto-setup on my Onkyo 805 & Orb speaker system.
I was surprised that all the speaker levels have been set at negative values (sub at -13, rest at -2 to -8).
Is this normal behaviour and is it OK? I would have expected that at least one of the settings would be 0!
MysteryMan1 is offline
Old 02-22-2008, 10:03 AM
hifisponge's Avatar
The speaker levels are all set relative to a predetermined reference level. If your AVR is THX certified, then that reference level is 105dB peaks when the master volume is set to "0". You must have fairly sensitve / efficient speakers, or sit very close to them.
hifisponge is offline
Old 02-22-2008, 10:20 AM
fyzziks's Avatar
You might want to run Audyssey again with your sub amp turned down a bit, so you get a bit more equal level values between the sub and the other channels.
fyzziks is offline
Old 02-22-2008, 10:25 AM
Wireless member
pepar's Avatar
Quoted: 336 Post(s)
Liked: 202
Chris
Thanks, I'm looking forward to doing the setup. I have a new (woven) AT screen and have not inserted my 1/3 oct EQs on LCR hoping that I don't have to.
Jeff
pepar is offline
Old 02-22-2008, 11:29 AM
Yes, good idea! I need to do it again, anyway, when I add the 2 rears speakers.
Old 02-22-2008, 11:30 AM
The are Orb Mod1's and Mod2's - is sensitive good?
We sit about 11' from most of speakers.
Old 02-22-2008, 11:39 AM
noah katz's Avatar
Quoted: 558 Post(s)
Liked: 217
Chris,
"Assuming that you don't want to remeasure when the futon is in place,..."
You got that right
"... I would suggest shifting the pattern I suggested in an earlier post so that is goes behind the front couch. I would take three measurements on each couch and two more between them and closer to the center."
Each row seats four (6 1/2' wide), so would it be better to put the mike 3' to the side of center than 2/?
Also, a brick fireplace juts out to about 2' from the right side of the couch.
Should I cover it with sound absorbing material during setup?
Noah
noah katz is offline
Old 02-22-2008, 12:14 PM
audyssey's Avatar
Chris,
You got that right
Noah,
Start with the mic in the middle of the front row and then move out to the left and right so that you don't go outside the front speakers.
I would leave the fireplace as it so that its effects are part of the measurement.
Chris
Chris
audyssey is offline
Old 02-22-2008, 01:36 PM
DBaker's Avatar
Does the MultEQ test tone play from the center speaker? The sequence should be L, C, R, RS, Rback, LBack, LS, Sub.
Chris
Yes I was getting a tone from the center speaker but it didnt sound the same as the tone from the mains. Took the bridge off the center speaker and hooked the output up to the high frequency and got no tone at all. Opened the speaker and the negative wire to the tweeter had come off its spade lug. Guess it happened in shipping. Reattached it and re-ran Audyssey and all is well.
DBaker is offline
Old 02-22-2008, 03:42 PM
matnick2127's Avatar
Chris,
I am planning to purchase the Sound Equalizer however I noticed that the unit has analog I/O. I also understand that the unit is placed between the source (ie DVD player and the receiver). Currently I have the DVD recorder going to the receiver through HDMI. I presume if I purchase the Equalizer, the DVD recorder will be plugged into the Preamp and the preamp to the Equalizer. I know the Equalizer enhances the sound but will it be compromised because I won't be using HDMI anymore. Will I have to replace my HDMI cables? Maybe I am missing something entirely. Could you explain how the setup is?
matnick2127 is offline
Old 02-22-2008, 03:46 PM
Nordo's Avatar
Great to see a happy ending. Your system of elimination worked well. Another person may have spent weeks of frustration trying to work out what was wrong, including returning the receiver, returning the centre, smashing holes in the wall with his head, etc
Nordo is offline
Old 02-22-2008, 04:46 PM
Quoted: 257 Post(s)
Liked: 249
Originally Posted by matnick2127 View Post
Chris,
The SEQ is intended to be inserted between the preamp and the power amp. For users of modern AVRs, the situation is complicated by the use of HDMI and the common lack of a mch analog tape loop.
What AVR are you using? You might be better off simply buying a new AVR with Audyssey MultEQ XT built in and with the capability of using AudysseyPro software.
Kal Rubinson
Old 02-22-2008, 05:05 PM
Kal,
I am using the Onkyo TX-SR705. It has Audyssey MultEQ built in and I have used it to calibrate my system, however, I have read that the SEQ is much better than what the AVR companies put into their units.
Old 02-22-2008, 05:16 PM
jmohler6's Avatar
Audessey with the Onkyo 905.
1 - Should I set the volume level to some particular level or does the volume settign not matter when running Audessey.
2 - My sub does not have phase adjustment. Does Audessey compensate subwoofer phase.
jmohler6 is offline
Old 02-22-2008, 05:38 PM
Quoted: 257 Post(s)
Liked: 249
Kal,
I do not think it makes sense, financially or operationally, to put a $2500 EQ on a $600 AVR. I would sooner invest in one of the other Onkyo AVRs with the AudysseyPro option. You can buy one of these, with its additional features and greater power and AudysseyPro, for less than the SEQ.
Kal Rubinson
Old 02-22-2008, 05:47 PM
I guess I did not know how the SEQ worked. For $2500 I thought this was an addition to my system that would have enhanced the sound using the current receiver I have. Is the AudysseyPro option comparable to the SEQ. How does the Pro option work?
Old 02-22-2008, 05:49 PM
Quoted: 257 Post(s)
Liked: 249
I suggest you read this thread or consult the Audyssey website.
Kal Rubinson
Old 02-22-2008, 05:57 PM
Thanks I will. Do you know if Onkyo has a receiver with the Pro option. I checked their website and did not find one. I know Denon has come out with this option.
Old 02-22-2008, 05:59 PM
audyssey's Avatar
Post 1530 has some info on the differences between the SEQ and the built-in MultEQ found in receivers. Kal's comments are spot on. The SEQ is really not meant to integrate with a receiver. It's intended for systems with separate components. One reason for the higher price is the high cost of the ADCs and DACs that are required to make this as transparent as possible in an analog insert path.
Chris
Chris
audyssey is offline
Old 02-22-2008, 06:00 PM
audyssey's Avatar
That info is available here:
http://www.audyssey.com/products/index.html
Chris
Chris
audyssey is offline
Old 02-22-2008, 06:03 PM
audyssey's Avatar
The volume setting is ignored during the calibration. Yes, Audyssey compensates for subwoofer phase by measuring the time delay between the sub and each speaker.
Chris
PS. It's Audyssey not Audessey
Chris
audyssey is offline
Old 02-22-2008, 06:47 PM
Chris
Thanks Chris but what do I look for. I have an Onkyo 705 which has MultEQ XT. Do you know if I can use the Pro software with this receiver?
Old 02-22-2008, 07:38 PM
Quoted: 257 Post(s)
Liked: 249
Go to the website and look for the list of AudysseyPro-compatible devices.
Kal Rubinson
Old 02-22-2008, 07:56 PM
movieguy2001's Avatar
I just ran the Audyssey XT calibration using 8 points on my denon 4308ci and got an error message that my front right and left speakers were out of phase. I re-ran the calibration several times (turning off my projector) and only got the error until I switched the wiring on my front speakers. I find this a little odd because I checked the cabling and I have run the polarity correctly from the receiver when I get the error.
What makes this odder still is that I previously had a denon 4806 and never got the out of phase error on it. Any idea why I might be seeing this? Is this something I should be concerned about? My final calibration run was done with the polarity backwards on the front speakers, but with no errors during calibration.
movieguy2001 is offline
Old 02-22-2008, 08:04 PM
sdurani's Avatar
Quoted: 2338 Post(s)
Liked: 1423
Have you considered changing the name to Audessey MultiEQ, just to make it easier on others?
Sanjay
Sanjay
sdurani is offline
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
