"Official" Audyssey thread (FAQ in post #51779) - Page 586 - AVS Forum | Home Theater Discussions And Reviews
 3471Likes
Old 08-18-2009, 06:21 PM
kjgarrison's Avatar
Originally Posted by dewd View Post
I like these discussions. I think a few more days reading this thread and I will be able to take (and pass) the professor's course at USC.
I know you were joking, but I'd bet that the course is waaaaay more "computationally demanding" than anything we have seen posted here.
kjgarrison is offline
Old 08-18-2009, 06:24 PM
Wireless member
pepar's Avatar
Quoted: 925 Post(s)
Liked: 505
And probably all . . Greek, too.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
Old 08-18-2009, 06:33 PM
counsil's Avatar
Look what I found on eBay...
http://cgi.ebay.com/Audyssey-MultEQ-...d=p3286.c0.m14
Never argue with an idiot; they drag you down to their level and beat you with experience.
Counsil Basement HT
counsil is offline
Old 08-18-2009, 07:51 PM
Brucemck2's Avatar
Quoted: 67 Post(s)
Liked: 35
Will the outboard Pro unit properly equalize/integrate two (or more) subs?
Is there something unique/different about the multiple sub routines in the outboard sub only AS-EQ1 unit?
Brucemck2 is offline
Old 08-18-2009, 08:07 PM
Kal Rubinson's Avatar
Quoted: 685 Post(s)
Liked: 468
Originally Posted by indigon View Post
I understand. I will probably test both methods.
How about my other question. How should I set the sub volume? Individually to 75 Db or with equal gain up to 75 Db?
Thanks for you help.
Not sure. It would seem that you can just set the two equal and let Audyssey do the rest.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Old 08-18-2009, 08:24 PM
Myron_H's Avatar
Quoted: 33 Post(s)
Can Audyssey be turned on for playback of Compact Discs? I have a PS3 and Onkyo 607 and it turns off when playing CD's.
Myron_H is offline
Old 08-18-2009, 08:37 PM
audyssey's Avatar
Hi Bruce,
I assume you mean the Audyssey Sub Equalizer. Yes, it will properly equalize and integrate two subwoofers. The core algorithm is the same as in the AS-EQ1. The Sub Equalizer is intended for the installer market and requires the separate Audyssey Pro installer kit. It can also support two zones (two subs in different rooms).
Chris
Join me for Audyssey Tech Talk on Facebook here.
Follow me @ChrisAudyssey on Twitter here.
audyssey is offline
Old 08-18-2009, 08:39 PM
audyssey's Avatar
Hi Myron,
No, we don't support these antiquated two-channel formats Sorry, couldn't resist...
This must be an input setting in the Onkyo for that source that you need to change.
Chris
audyssey is offline
Old 08-18-2009, 08:40 PM
counsil's Avatar
The price has already gone up appx $100 since I posted this (and hit count has roughly doubled). I wonder why?
Counsil Basement HT
counsil is offline
Old 08-18-2009, 08:52 PM
Brucemck2's Avatar
Quoted: 67 Post(s)
Liked: 35
Apologies for being unclear. I'm asking whether the eight channel Sound Equalizer does as good a job integrating multiple subs in a single room as the AS-EQ1 does?
Old 08-18-2009, 08:59 PM
audyssey's Avatar
The Sound Equalizer doesn't yet have the firmware to integrate multiple subs. It is intended for 5.1 + 2.0 or 7.1 systems.
Chris
audyssey is offline
Old 08-18-2009, 09:20 PM
kriktsemaj99's Avatar
Quoted: 643 Post(s)
Liked: 361
What's your setting on the PS3 for "Audio CD Output Frequency"? The PS3 can upsample CDs to 176.4kHz, which might cause Audyssey to be bypassed on your receiver.
kriktsemaj99 is offline
Old 08-18-2009, 09:42 PM
Myron_H's Avatar
Quoted: 33 Post(s)
The PS3 gives me two options: (48kHz) and (44.1/88.2/176.4kHz). I had it on the second option (44.1kHz) which I thought was correct, since it is the CD data rate. But Audyssey turns off. I then tried 48kHz and Audyssey stays on. Is there a way to keep Audyssey turned on with the other data rates? I played a few tracks, and it definitely sounds better now with Audyssey turned ON.
Myron_H is offline
Old 08-18-2009, 09:46 PM
bluesky636's Avatar
I don't know much about FIR filters, but I have two FUR filters that take up a lot of space on my home theater floor. Now if I could just get them to stop snoring during the movie .....
It would be nice if I could store multiple correction curves (No dogs, one for each dog, two dogs) as the frequency response changes quite noticably depending on which one is in the room.
bluesky636 is offline
Old 08-18-2009, 09:57 PM
kjgarrison's Avatar
So Chris, will this work or will a license key have to be purchased to make it work? Can a license key be purchased separately from the hardware?
Old 08-18-2009, 10:09 PM
audyssey's Avatar
As with all Pro Audyssey kits, a license key is required for each device that is calibrated. The license key is tied to the serial number of the device. Also, the software in this kit is from 3 years ago so one would have to purchase v. 3 to be up-to-date with what Audyssey offers today in the installer program.
Chris
audyssey is offline
Old 08-18-2009, 10:18 PM
Nuclear Waste's Avatar
Hi All,
The Audyssey sub setting is giving me some problems. I was hoping someone here may have solved something similar, or be an expert on this.
My setup:
Integra DTC-9.8
Emotiva MPS-1 running the 7 non-sub channels (those channels calibrate just fine)
Axiom Epic 80-600 7.1 (so that's an Axiom EP600 sub)
EP600:
Connected to DTC-9.8 using XLR cable
Settings = Phase = 0, Trim = Flat, Crossover = Bypassed.
So here's what happens:
- I have the volume on the EP600 set to where it just kicks in to be audible (this is at maybe 10% of the entire range of the volume control - very, very low)
- When I run Audyssey setup, the DTC-9.8 reports -15.0 dB (that's the max on the 9.8)
- If I turn the volume on the EP600 down just a gazillionth of an inch and re-run Audyssey setup, the sub section of the test becomes no longer audible and reports +12 dB (the other extreme)
- If I turn the volume on the EP600 up just a gazillionth of an inch and retest, I get -15.0 dB again.
Possibilities in my brain:
Sub is too much of a beast for this space?
Volume knob isn't functioning properly? (Unlikely - it does go louder and softer through its entire range except for that lowest 10% or so)
Hopefully it's something else that I'm missing. I hope it's just something stupid.
Any ideas on how I can get this thing set at a good, (not -15.0 dB) level?
Nuke
Nuclear Waste is offline
Old 08-18-2009, 10:31 PM
jlachanc's Avatar
I doubt it.
Possible.
FWIW, I had the EP600 and the amp malfunctioned. I returned the amp for an exchange and got the newer amp version. The newer version 'fixed' the issue with the overly sensitive volume control that you describe.
My build thread
jlachanc is offline
Old 08-18-2009, 10:38 PM
Thanks, man. I'll give Axiom a call tomorrow and see if I might be able to swap that out. Just figuring out a possible culprit for this gives me some hope!
Old 08-18-2009, 10:48 PM
Mike_WI's Avatar
Quoted: 131 Post(s)
Liked: 80
Just curious if the Audyssey concept can (or is being) be applied to larger areas such as concert halls or arenas?
I realize room/structure treatments before designing those are most important, but just curious about the technology and modelling.
Mike
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & output x1 cards} - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520]
HT Details: link
Mike_WI is offline
Old 08-18-2009, 10:52 PM
jlachanc's Avatar
Good luck. Not sure how willing they will be to swap out a 'functioning' amp...
My build thread
jlachanc is offline
Old 08-18-2009, 11:09 PM
rollerotr's Avatar
After running MultEQ on my Marantz sr6003, the following settings occur: front and center small, surround large (5.1 system), sub LPF/HPF 180!!
My speakers are 5 matched Tannoy 5" dual concentrics with a published frequency response of 80-22K. The sub is a Quad L-ite 10", 300 WRMS, published frequency of response of 25-95hz!!
Can someone shed some light on how, why, and what this means...and maybe what do do?
Bruce
rollerotr is offline
Old 08-18-2009, 11:12 PM
Mike_WI's Avatar
Quoted: 131 Post(s)
Liked: 80
Bruce
Bruce -
Welcome to AVS.
Have you looked at the post #1 in this thread, especially the FAQ?
Any specific questions?
If your implied question is why does Audyssey not see/suggest full range for your L/R speakers, it is because the sub may handle that area better.
Mike
HT Details: link
Mike_WI is offline
Old 08-18-2009, 11:42 PM
Quoted: 925 Post(s)
Liked: 492
Bruce
Where are your mains and how large is your room? If they're out from the wall, or the room is large, then Audyssey got it right.
The Tannoy Arenas are great little speakers, but there's only so much a 5.25" basket, 4" cone driver can do down low before unacceptable levels of distortion set it.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
Old 08-19-2009, 01:15 AM
a1bert's Avatar
Originally Posted by bluesky636 View Post
Dude, do you have any idea who you are trying to argue with?
Yes, I _did_ notice. I was doubly surprised by the carelessness that Anti-mode was put into "no time domain" category, but further discussion explained how that could happen. He knows his stuff, but there are more than two ways to skin a cat.
a1bert is offline
Old 08-19-2009, 01:39 AM
HDTVChallenged's Avatar
Liked: 215
The only thing you can really do, is disable the 176.4kHz output (in the HDMI Audio Setup) from the PS3. The Onkyo doesn't have the horsepower to run Audyssey @ 176.4kHz.
HDTVChallenged is offline
Old 08-19-2009, 06:55 AM
Quoted: 643 Post(s)
Liked: 361
It's unfortunate that this lack of processing power in receivers is breaking an important feature of HDMI where the source device is supposed to be able to determine automatically the best format to send. In the case of PS3 CD output, 176.4kHz without Audyssey is surely worse than 88.2kHz (or even 44.1) with Audyssey. It's not just a problem for Audyssey-enabled receivers either, although some will automatically downsample and keep the selected processing enabled when they run out of processing power, rather than turn off processing.
Old 08-19-2009, 07:50 AM
Brucemck2's Avatar
Quoted: 67 Post(s)
Liked: 35
If I'm running 7.2 any reason to not add an AS-EQ1 downstream from the Sound Equalizer? Or, am I better off simply running the two subs as one mono sub off the Sound Equalizer directly?
Old 08-19-2009, 07:51 AM
Wireless member
pepar's Avatar
Quoted: 925 Post(s)
Liked: 505
Bruce, what are the crossovers for the main speakers (to the sub channel)? The LPF on LFE is not what you seem to think it is, and it *should* be high.
edit: After re-reading I see that the surrounds have no crossovers in which case I would set them to 80Hz. What are LCR crossed at?
further edit: Ignore published specs.
pepar is offline
Old 08-19-2009, 07:56 AM
Wireless member
pepar's Avatar
Quoted: 925 Post(s)
Liked: 505
So, after further discussion, "carelessness" probably isn't a fair characterization? But then you referred to the subject of FIR and IIR as a "holy war" so methinks that you are inclined to hyperbole.
pepar is offline
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
