"Official" Audyssey thread (FAQ in post #51779) - Page 691 - AVS Forum | Home Theater Discussions And Reviews
 3470Likes
Old 11-19-2009, 02:15 PM
Wireless member
pepar's Avatar
Quoted: 916 Post(s)
Liked: 503
Paraphrasing Kal, in a perfect world, implementation of any given target curve, i.e. the red line, will result in a system response that mimics it exactly. Or am I missing what you are asking?
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
Old 11-19-2009, 02:24 PM
Kal Rubinson's Avatar
Quoted: 683 Post(s)
Liked: 464
Sure.
I think so.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Old 11-19-2009, 02:27 PM
LarryChanin's Avatar
Originally Posted by audyssey View Post
Hi Larry,
Any modifications you make with the blue adjustment points will be applied to all red curves.
Hi Chris,
Please forgive me bringing this up again, but I felt compelled to go back to the source of my confusion quoted below.
Originally Posted by orologio View Post
My bug is that when I modify the audyssey curve to my preference, like raising the top end a little, the flat curve is also correspondingly modified by raising the same top end making it way too bright and unuseble.
Here orologio states he has a problem with the flat curve being rendered unusable by modifying a selected curve.
Your response to him didn't correct orologic's statement as being incorrect, but rather seemed to reinforce his concern.
Your response was:
Hi, unfortunately it's not possible to save two curves with different tweaks for each one. The tweaks in MultEQ Pro are applied to all curves.
Can someone modify a reference curve and then select a THX listening mode on an Onkyo device and be confident that the Flat target curve is still flat after editing a reference curve?
Larry
LarryChanin is offline
Old 11-19-2009, 03:14 PM
uzun's Avatar
I have an Integra 9.8 prepro that features MultEQXT correction, but does not allow me to select the response curve (I would prefer "FLAT" for music). Can anyone suggest a listening mode (for 2 channel sources) that would use the Audyssey room correction settings, but won't feature the high frequency rolloff present in the default audyssey curve? On receivers/prepros like this is there a way to optimize music listening while enjoying the benefits of room correction?
uzun is offline
Old 11-19-2009, 03:33 PM
rnrgagne's Avatar
Quoted: 49 Post(s)
Liked: 57
Chris,
I'm wondering if there's anything in future "Pro" plans to facilitate a sub 300hz only EQ option per speaker group, maybe a curve editor feature? (Sort of like Denon's L/R Bypass option but a L/R +300hz bypass.)
rnrgagne is offline
Old 11-19-2009, 04:26 PM
streetsmart88's Avatar
Originally Posted by jchong View Post
I'm having some issues with my Audyssey mic (that came with the Onkyo 876). I've run Audyssey many times over the last few months (usually when I tweak or change something) and it's run flawlessly.
Today I ran it again, did the first pass and 2nd pass fine (going through all 5.1 positions in each pass). When it came to the 3rd pass, it gave me a "speaker detect error" after testing the FL speaker. Retried and same error.
So I unplugged the mic, then plugged it back in and reran Audyssey. Did first pass fine, but in the 2nd pass it gave me a "speaker detect error" after testing the FL speaker. Retried and same error. After this, I unplugged and replugged the mic and in the first pass the "speaker detect error" came in. Retries from then was a no go and I just keep getting the "speaker detect error".
So I then took the Audyssey mic from the AS-EQ1 (which looks identical to the Audyssey mic from the Onkyo 876) and tried that. It worked fine and I did a quick 3 position run and saved the settings. Just as an experiment, I tried again with my original Audyssey mic and got the "speaker detect error" - so obviously something is wrong with my original Audyssey mic from the Onkyo 876.
Questions:
1. Anybody else had their AVR's Audyssey mic die on them?
2. Is the AS-EQ1 Audyssey mic identical to the Onkyo 876 Audyssey mic? I noticed the Audyssey settings are different with the AS-EQ1 Audyssey mic, e.g. level trims are 2.5 dB lower. Speaker config is also different, now the LCR and surrounds are 'full band' previously it was 60 Hz.
Answers:
1. Yes, my mic once died and I determined that there was a discontinuity in the wire. Therefore, I changed the wire and the problem was solved. Of course, you will need a tester and then a soldering gun.
2. According to Chris K., if the AVR mic is the newer model (tower type as opposed to the older puck type), it's the same as the AS-EQ1 mic. Therefore, they are interchangeable. Keep in mind that these mics have a plus/minus 2db tolerance so you will get variations between mics.
Mark
streetsmart88 is offline
Old 11-19-2009, 04:53 PM
bluesky636's Avatar
THX Music or play with the treble control.
bluesky636 is offline
Old 11-19-2009, 05:54 PM
Roger Dressler's Avatar
Quoted: 1523 Post(s)
Liked: 711
Originally Posted by Kal Rubinson View Post
We are not starting with a blank page but with one of the default/standard curves. Let's say that this curve is flat up to 5KHz as in Pepar's example and rolls off to be -5dB at 20KHz. If unmodified and the world is perfect, implementation of this will result in a system response that mimics it exactly.
If I make a handle (blue point) at 20KHz and move it to +3dB, I get a new curve which is flat to 5KHz and up at +3dB at 20KHz. Right?
No. The red curve will move up by 3 dB from its original -5dB point, for a result of -2 dB. It will be seen in the altered red curve, so what you see in the red curve is what you will get.
Or is it, counterintuitively, -2dB at 20KHz because the blue curve is applied to the red curve and the result is the combination of their effects?
These are very different outcomes and, to me, the former is more useful and more predictable (I see what I get). I apologize for being so pedantic but the messages traded so far have been less than completely transparent to me.
I don't see it as counterintuitive in that the red curve does in fact display the WYSIWYG EQ curve. And, If you click thru the other preset curve options, HF Rolloff1, HF Rolloff2, or SMPTE202, each of their red curves will reflect the same delta offsets defined by your blue line. The differences each option provides will thus be fully maintained, even though you defined a modification curve.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
Old 11-19-2009, 07:21 PM
Quoted: 683 Post(s)
Liked: 464
Well, I will have to take another look as that is what I remembered was the way it worked. I haven't done an EQ in a month or so but will do one this weekend.
Somehow, the verbal descriptions offered in this thread confused me. Sorry to have made a big deal of it.
Kal Rubinson
Old 11-19-2009, 07:42 PM
audyssey's Avatar
Originally Posted by rnrgagne View Post
Chris,
Nope. I am aware of the evangelism on this subject, but our own research and that of BBC researchers in the 1960s shows that full range correction is needed. We are trying to convince Denon to remove the L/R Bypass option, but have not yet succeeded...
Chris
Join me for Audyssey Tech Talk on Facebook here.
Follow me @ChrisAudyssey on Twitter here.
audyssey is offline
Old 11-19-2009, 07:52 PM
audyssey's Avatar
Hi Larry,
The answer is no. Any mods you make will be applied to the Reference and Flat curves.
Chris
audyssey is offline
Old 11-19-2009, 08:32 PM
Liked: 711
My replies are based only on what Chris posted. I have not had the pleasure of first-hand experience with Audyssey Pro. If I got it wrong, I hope will Chris will smack some sense into me.
Old 11-19-2009, 09:02 PM
Quoted: 683 Post(s)
Liked: 464
It's all in the wording. For some reason, yours gave me more clarity than did Chris'. In any case, I will be doing a setup this weekend (new speakers) and the results will tell me what I want.
Kal Rubinson
Old 11-20-2009, 12:58 AM
Invictus 14's Avatar
Hiya guys
This is off topic but I am asking you guys cause of the massive experience in this thread, and you guys answer way faster than any other forums or groups I am in. I have just received an australian pay tv set top box its Hi defention with an HDMI out it has 140 odd channels about 20 of them are HD channels movies,sport etc and the rest are standard def. If I leave my source upscale to 1080p to cover the standard def upscaling of most of the channels will this double process when I watch a HD Channel. Actually thinking out loud the Hd channels may only be 720p but I did watch one movie Hd channel and to be honest it was blu ray quality. With my current upscale settings. Once again sorry for going off topic but you guys are great and am interested in your feedback from experiences with pay tv in your countries. I can go source through or upscale to 1080p. Thanks guys I appreciate it.
Justin from Aus
Cheers!
Justin
Invictus 14 is offline
Old 11-20-2009, 04:44 AM
jchong's Avatar
Liked: 32
Originally Posted by streetsmart88 View Post
Answers:
Mark
Thanks for the reply Mark.
1. I'm sending my mic back to the Onkyo distributor for a replacement.
2. Yes mine is the newer tower type Audyssey mic. It looks exactly the same as the AS-EQ1 mic. Glad to know they are interchangeable. Yeah, I recall reading about the +/- 2 dB tolerance. That would explain the trim difference, but I wonder why with the AS-EQ1 mic my AVR sets my speakers to 'full band'?
jchong is offline
Old 11-20-2009, 05:54 AM
SoundofMind's Avatar
Liked: 166
Originally Posted by Invictus 14 View Post
This is off topic...
Why no, Audyssey is all about improving PQ.
Justin, this is not a simple question. It is a video signal chain issue and depends on many factors we shouldn't get into here. These include the specifics of the cable box output modes, the capabilities of your display, whether your video is going through the AVR, and the video settings in each component. If your display or AVR has a forum, that would be a good place to start. For ex., these are common topics on the Denon and Onkyo AVR threads.
Yes, I still like playing with Dalis.
SoundofMind is offline
Old 11-20-2009, 06:53 AM
Oledurt's Avatar
Quoted: 201 Post(s)
Liked: 288
Quick question...I use a tx-sr875 with Audyssey built in. I use it and I love it. The Onkyo is a THX receiver, and I use MK Sound THX speakers and an SVS sub.
I do not use THX modes for movies as I prefer the audyssey curve over the THX re-eq. When I run Audyssey it sets my crossovers on some speakers to 150 hz. Since I am running THX speakers my understanding is I should reset the crossovers down to 80hz.
I understand that audyssey only corrects down to the crossover freq it found was optimal. Since it is not finding 80hz as the sweet spot on some of my speakers am I losing out on some of the audyssey correction?
Oledurt is offline
Old 11-20-2009, 07:33 AM
Liked: 166
Originally Posted by Oledurt View Post
Quick question...I use a tx-sr875 with Audyssey built in. I use it and I love it. The Onkyo is a THX receiver, and I use MK Sound THX speakers and an SVS sub. I do not use THX modes for movies as I prefer the audyssey curve over the THX re-eq. When I run Audyssey it sets my crossovers on some speakers to 150 hz. Since I am running THX speakers my understanding is I should reset the crossovers down to 80hz.
Follow the Guide recommendations and listen with the autosetup recommended xover. Doesn't it sound great? Do not fret, you're missing nothing, the xover is selected based on the speaker's measured performance in the room, all freqs are corrected and all is as it should be. Now, if you reset from 120 to 80 you lose the corrections on that band and make your speaker and AVR work harder. But if that sounds better to you, do it. AFAIK the THX designation has no particular bearing on this matter.
Old 11-20-2009, 08:55 AM
The blue curve is not a target curve. It represents the adjustments that will be applied to the red target curve. The curve that will be applied to the filters is always the red curve. In the example above, a boost has been applied to the standard Audyssey HF rolloff 1 curve to bring it closer to flat.
Hi Chris,
Thanks for your previous response.
I realize that the purpose of the blue curve is to adjust the selected reference target curves, but since it starts out at flat, and all adjustments are applied to all curves including the Flat curve, then isn't it also correct that the blue curve is a good representation of the changes made to the Flat target curve?
Thanks again.
Larry
Old 11-20-2009, 08:58 AM
sterryo's Avatar
after reading the very well done Audyssey Guide, I have a couple questions regarding measuring on 2 tiers where the back tier is raised higher than the front tier.
1. is it preference to place the first position in the center of listening area(between the rows) or in the primary listening seat?
2. should the microphone height be averaged between the 2 heights or at actual ear level but raised for the second tier?
thank you very much in advance for any responses!!!
sterryo is offline
Old 11-20-2009, 09:03 AM
audyssey's Avatar
Hi Larry,
Yes, that's true.
Chris
audyssey is offline
errivera's Avatar
Is it okay to use a different mic with a flatter frequency response to try to obtain better resolution or more consistent results such as the Earthworks M30, Audix TR40 or even the dbx RTA Analyzer Microphone? I've been tempted to try this but wanted a little input before proceeding.
errivera is offline
Old 11-20-2009, 09:06 AM
audyssey's Avatar
No. You will get much worse results if you do that. The calibration curve for the Audyssey mic is built in to the software and so it will be applied to any other mic that you connect. BTW, the mics that you mention are not flat on their own. They also require a correction curve in order to give you good measurements.
Chris
audyssey is offline
Old 11-20-2009, 09:11 AM
Wireless member
pepar's Avatar
Quoted: 916 Post(s)
Liked: 503
Hiya guys
Justin from Aus
You will want the best scaler in the video chain to do the upscaling/deinterlacing. Here in the US at least, that is almost never the TV box.
pepar is offline
Old 11-20-2009, 09:16 AM
Oledurt's Avatar
Quoted: 201 Post(s)
Liked: 288
Thanks so much for your reply. I recalibrated my system using Audyssey this time keeping all settings it came up with and it does indeed sound better. The tone of the speakers sounds a bit fuller and darker quite pleasing. I love my THX speakers and they do sound awesome and now they sound even better with the Audyssey room correction.
In my opinion THX is good at doing what it was designed to do set some high standards for equipment, crossovers etc...but the THX recomended settings etc seem to be the past Audyssey really is the future.
Oledurt is offline
Old 11-20-2009, 09:25 AM
Wireless member
pepar's Avatar
Quoted: 916 Post(s)
Liked: 503
You have an even number of seats? If so and there is a space on the centerline of the center channel, then yes I would make that space mic position #1. After that I would measure where the heads of people sitting in the seats would be. The qualifier is that the mic must "see" all of the speakers and positioned so that it will not get reflections off of the seat (back). For me, that last proviso is met in part because I have soft cloth seat covering ... as opposed to leather or faux leather.
pepar is offline
Old 11-20-2009, 09:34 AM
rnrgagne's Avatar
Quoted: 49 Post(s)
Liked: 57
Thanks for that Chris, my own practical experience is that Audyssey's greatest benefit is what it does in the bottom end. I've tried the L/R bypass with 2 channel material since I upgraded my mains to Paradigm S8v.3's and ended up going back to Audyssey. I didn't pick up on much if any difference in the top end but I prefer the Audyssey improved bottom end, which is what prompted my question.
I would think the "evangelists" must be a fair chunk of Denon's consumer base if they don't want to remove it...
rnrgagne is offline
Old 11-20-2009, 09:37 AM
audyssey's Avatar
Sure. It's certainly true that the biggest problems in small rooms are in the lower end of the spectrum. And with really good speakers and proper amounts of room treatments, the higher frequencies can be dealt with so that there is less for MultEQ to do. It is designed to only correct where needed.
Chris
audyssey is offline
Old 11-20-2009, 09:41 AM
sterryo's Avatar
then keep the mic at same height and be sure to it is unobstructed?
thx
sterryo is offline
Old 11-20-2009, 09:44 AM
Wireless member
pepar's Avatar
Quoted: 916 Post(s)
Liked: 503
thx
yes.
pepar is offline
Audyssey , Receivers Amplifiers , Kef Kht1005 2se 5 1 Subwoofer Satellite System With C4 Subwoofer Gloss White , 5 6 7 1 7 2 Or 8 1 8 2 One Or Two Subwoofer Compatible 16 Banana Post 2 Rca Speaker Wall Plate For H
