Pioneer Elite 84TXSi 12v Trigger Error - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-19-2007, 01:00 PM - Thread Starter
Monty Williams's Avatar
I recently added a Bryston 9BSST to my family room entertainment system and relegated a 84TXSi to 'pre/pro' duties. I cut the end off and stripped 1/4" wire off of a mono miniplug and connected it to the 12v trigger switch on the Bryston, plugging the other end into the 12 v trigger out on the 84. I went into the 84's setup menu and enabled the 12v trigger option to "Main" for all inputs. However, regardless of what I do, the 84 displays "12v Trigger Error" for all inputs even after cycling the receiver and Bryston (manually) on and off several times. I have the Bryston's input set for a 4 second delay to prevent any surges.
I have an Anthem Statement D2 pre/pro in front of a Bryston 6BSST and a pair of 4BSST's down in my HT, setup the same way and it works flawlessly.
Any ideas?
Monty Williams is offline
post #2 of 3 Old 05-21-2007, 05:45 PM
masterstyx's Avatar
I am experiencing the same problem. I'm trying to trigger a 12V relay... with no success. Did you ever fix this problem?
masterstyx is offline
post #3 of 3 Old 01-25-2013, 10:22 PM
dozer95667's Avatar
me too.
lol I know this is an old thread- it is the first one I could find when I did a search. So I just went to the hassle to get a converter to turn a mini plug to a micro plug, and set it up to turn on my parasound amp... and I just get the message "12V trigger error" on my Pioneer Elite SC-61
What gives?
dozer95667 is offline
