Speaker distance setting on Denon 5800 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-27-2000, 06:15 PM - Thread Starter
Newjack's Avatar
I got a Denon AVR-5800 for Christmas. It sounds great in my 5.1 setup but I'm interested in using the extra 2 channels. All the info I've read on surround back channel placement suggests putting them behind the main listening position. Unfortunately my couch is up against the back wall of the room so I'll have to put them directly above my head. In the 5800 setup menu should I set the surround back channel distance to how high above my head the speakers are or should I set it to 0" since there not even a foot behind me? I hope this makes sense....LOLOL
Newjack is offline
post #2 of 2 Old 12-27-2000, 09:01 PM
emcclure's Avatar
Yes, zero would be the answer for that placement. Can you pull your couch out from the wall several feet? Things would sound more accurate coming from behind you rather than above you. Call the carpenters...
Erin McClure
emcclure is offline
Closed Thread Receivers, Amps, and Processors
