The Amazing Tag McLaren AV32R-EX pre/pro...all the right stuff! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-27-2000, 06:36 PM - Thread Starter
Central Scrutinizer
Bob Sorel's Avatar
Quoted: 191 Post(s)
Liked: 149
Every once in awhile in the audio world a piece of equipment comes along that is so incredible that it deserves special mention among a plethora of mediocre components, and the new THX EX equipped Tag McLaren AV32R is one such piece. Never since I first got my Dynaudio speakers has any single component made such a huge improvement in the overall sound quality of my system, a fact that I never would have believed just a few short years ago. I was one of those people that used to think that electronics were all basically the same and that bits were just bits, but after just over a week of owning my new Tag pre/pro, my opinions have been changed forever.
First off, let me thank Buzz Goddard, president of Tag McLaren Audio, for all his help in making it possible to own such a fine piece. I met with Buzz in person in his Norwood office and was a little apprehensive about meeting one of the most respected people in the audio world, but his casual, friendly demeanor relaxed me within a few minutes, opening me up to a thoroughly enjoyable learning experience. Buzz is one of those few people who truly is the epitome of knowledgeable people, as opposed to people who think they are knowledgeable....no airs, no attitude, no stuffiness....just a warm, down to earth, truly intelligent and educated person who shares the same passion as the rest of us here - the perfection of audio.
For those of you who don't know Buzz's history, he joined Lexicon (I think it was in the mid 80's, but don't quote me on this) and was responsible for putting together the consumer line of high end audio pre/pros, beginning with the CP-1, right through the DC-1, DC-2, and MC-1, and even the yet to be announced new model from Lexicon. Basically he headed the entire development team for all of those products and was the single most important factor in bringing these great products to the public. Anyone who has dealt with the Lexicon pre/pros is fully aware of the vast knowledge that Buzz brought with him when he teamed up with Tag McLaren, but as Buzz himself stated, the level of workmanship, attention to detail, and manufacturing sophistication that this company already had attained required little "fixing up" at all.
Already aware of the abilities of the AV32R, I mapped out my equipment connections on paper before I installed it into my rack. Although the Tag uses generic labels such as "md" and "dab" for the 2 optical digital connectors, and "cd", "ld", and "dvd" for the coaxial digital connects, the software made it a simple task to relabel them any way I wanted, so I chose to use the actual manufacturer and model names to describe my inputs. Also, the software allows the user to link any video input (both s-video and/or composite) to any audio input (both analog and /or digital), giving total flexibility in setting up the Tag. The software wizard walked me through the entire setup procedure for both the essential and convenience portions in less than an hour from start to finish, with a minimum of hassle or confusion...very, very smart design!
The software is loaded with features and conveniences, all of which contribute to the ease of use of this great unit. There are too many features to list here, so I'll just touch on a couple of my personal favorites. The first one is the ability to to engage or disengage the use of bass management on any input and/or processing mode. For example, my Dynaudio speakers are all the "bass limited" bookshelf type that require the use of a subwoofer for optimum bass response, so no matter what mode or input I am using, I want my bass management facilities to be available. Other people who own floor standing, full range mains might want to use only the mains when playing 2 channel music, bypassing the bass management, while I specifically need my subwoofer present in this mode, and this simple but necessary feature was unavailable in my old flagship receiver, the Yamaha RX-V1 (specifically when processing 24/96 material).
Another feature that made life a lot more pleasant for me was the built in subwoofer limiting, a feature that can be switched in or out at the user's discretion and adjusted to the exact level, in db's, that is required. Since I use a 550 WPC amp to power my 2 subs, in my old setup I had 2 choices, either set my LFE level so that the peaks would not bottom out my subs at high listening levels, resulting in poor bass performance at low levels, or set the LFE level so that the system was balanced at low levels, resulting in severe bottoming at higher levels. Either way I went was a compromise, but with the Tag I can have the best of both worlds. My LFE level is set at +3db to the rest of my system (my setting of preference), but the limiting feature clamps the power at the high SPL's, saving my sub from damage in the few spots where it is necessary. This results in a LFE level that is perfect 99.9% of the time, with only the extreme peaks clamped in output, saving my precious subs in the process.
These are just 2 of the many features present this fine software supports. Speaker time alignment, level matching and orientation, subwoofer usage and bass management, default processing modes, input sensitivity matching, THX processing defaults, DTS low frequency shift, center and subwoofer level offsets, front panel dimming and level controls, and control links to other Tag McLaren equipment are just some examples of the extensive set of control options available. This unit is the easiest to set up and use, yet most powerful piece of gear I have ever had the pleasure of owning.
Now it's time for the good stuff!
So you are probably thinking to yourself "Bob, this all somewhat interesting, but a lot of high end equipment has tons of features and flexibility. What makes this pre/pro so special?" Well let me tell you, the sound of this unit is to die for! This is what I meant when I said it has "The Right Stuff!" I have been playing music on this new beast of mine for countless hours on end, and the more I listen to it, the more I appreciate it.
What does it do that is so impressive? First of all, the sound is rock solid. This is a quality that I find very hard to describe, but the best analogy I can give is that if you label a lot of high end pre/pros as being as solid as "wood", then this unit is "cast iron". There are no holes in the sound, no muddying of the individual instruments, but rather it produces a solidified, inpenetrable wall of sound that is perfect from top to bottom, yet it handles "airy" material with a decidedly delicate touch, sort of like I would describe as a ballet dancing pro football offensive end - a graceful "brute" of a person.
As impressive as it is on first listen, it is the continued listening that blows me away. It's not what the Tag does to music, it's what it doesn't do. It doesn't color the sound, it doesn't emphasize this or that, it doesn't do anything wrong! With every piece of gear I have ever listened to, I eventually found something that I didn't like about the way that it handled sound. Some units were muddy in the mid bass, some just made it difficult to place the instruments within the sound stage, some just didn't produce the sibilance of a triangle just right, et cetera, et cetera, et cetera. The Tag McLaren reproduces every sound perfectly! I have listened to a large part of my music collection and have virtually heard things I have never heard before, but were there all along. I am a classically trained trombonist (of about 30 years), so I have a pretty good idea of what musical instruments are supposed to sound like. The AV32R is the first pre/pro I have owned that accurately reproduces every instrument I have heard on it....period!
Along with its musical accuracy, the Tag's ability to distinctly represent every sound is another earmark of this wonderful unit. Even my old RX-V1, with its superior preamp stage, is no match for the Tag in clarity and separation. What formerly sounded like a blend of instruments has now transformed itself to reveal the individual voicings and melody lines played by each individual instrument As a musician I tend to spend a considerable amount of time analyzing melody lines and chordal structure, and now my ears are able to identify exactly what is going on in a musical piece, where before I would struggle to identify the individual notes and chords.
The AV32R has few DSP modes available, but every one of them is tasteful and useful. The Dolby Digital and DTS modes can be used in 5.1, 6.1, or 7.1 configurations, and the decoding is absolutely impeccable, second to none. The user has a choice of forcing the 6.1 or 7.1 matrixed configurations, or staying with the 5.1 versions on most material and just engaging the 6.1 or 7.1 THX EX modes when it is flagged by the content. Also, for music, there are the TMS (Tag McLaren Surround?) 5 and 7 channel modes, which are very tastefully implemented, just adding ambience to the center and surround channels while leaving the mains intact, staying with the philosophy of "If it ain't broke, don't fix it!". DTS discrete ES and Dolbly Pro Logic II are announced software upgrades that I plan on purchasing as soon as they are available.
I would be less than honest with you to say that the Tag couldn't stand a couple of improvements, be they minor ones, but I feel I should at least express my concerns. Right now I have a standing compatibility issue with the sound card in my HTPC, the DC pro 24/96, but Digital Connection and Tag McLaren are both working with me to resolve this problem as quickly and decisively as possible. I will post more information about this issue as it progresses. The AV32R has never had any problems with any consumer level hardware, so this is most likely an isolated case and should not be of any concern for the vast majority of users.
I have 2 other suggestions that I would like to express to Tag McLaren (don't we all have something else we would like?). First, there is a muting relay which is used to silence the output in the event that no signal is present, which produces a small "clicking" sound, and I would like to see the relay eliminated and a silent switch used in its place. Second, I would like a second set of analog audio outputs available to me. The Tag has just one pair, which I am using for my S-Video VCR, and I could use another pair to connect to my cassette deck (No, I don't listen to cassettes in my home system, but I do like to make tapes to listen to in my car).
Enough of my complaints http://www.avsforum.com/ubb/smile.gif I can't and won't compare this unit to other high end units, as I don't feel the need to judge other products, but I can certainly tell you for sure that this is one of the best, if not the best pre/pro available today. Out of all the gear I have bought in my life, this is my very favorite, and will not be replaced in the foreseeable future. I will answer as many questions about this unit as I can, and I have informed Buzz about these threads (I have posted in 4 forums just because I am so excited about this unit), so he has been invited to field any technical questions that may arise. Thanks for reading this and I hope you get a chance to hear one of these wonderful units for yourself. I promise, you won't be disappointed!
Bob Sorel
Nothing is what I want - a true Zen saying.
Marantz AV7005 pre/pro cheap
Bob Sorel is offline
post #2 of 8 Old 12-28-2000, 11:46 AM
Free's Avatar
Thanks again for the review Bob (I thanked you already in the other forum)
I was wondering just what made you choose the AVR32 over the Lexicon MC1? Did you compare the two side by side?
Also are you using Tag's 5 channel amp or is that not out yet?
Phil
Phil
Free is offline
post #3 of 8 Old 12-28-2000, 03:12 PM - Thread Starter
Central Scrutinizer
Bob Sorel's Avatar
Quoted: 191 Post(s)
Liked: 149
Hi Phil,
No, I never got a chance to compare the 2 units side by side under the same set of circumstances, but I did get a chance to audition both the DC-2 and MC-1 units at the same time and I feel that they are both excellent processors as well. Which is the best processor? The answer to that question would require a multiple unit "blind" test over an extended period of time in the same room, connected to the same external components, speakers, etc., very carefully level matched. Even then it would be a matter of personal opinion as to which one is best, as they all possess slightly different sonic strengths and weaknesses. Actually, I would be happy to own any of them, though at this point I do believe that the AV32R is the very best sounding unit I have heard to date. If I were to compare the sonic qualities of the Tag to other high end manufacturers, I would say that the Krell HTS is the most similar in overall sonic characteristics, though I did not get to spend a great deal of time with the HTS. I do not have the vast experience with pre/pros that a lot of the other members here have, so I have not heard a lot of the other high end units, such as Theta and Meridian (as they are generally out of my price range), so I can not meaningfully comment on them. I simply wanted to alert everyone that the Tag McLaren AV32R should be on your list if you are in the market for a high end pre/pro!
As far as the Tag 100X5R amp is concerned, I have not dared listen to it as yet, as my pocketbook is sufficiently depleted for now. I won't be appearing on "Lifestyles of the Rich and Aimless" next week (but I'm working on it http://www.avsforum.com/ubb/smile.gif ), so my next audio purchase will be some time away. Right now I have to settle for my 4 Crest Audio 450 WPC stereo pro amps that power my system, which are quite excellent actually, but there might be room for improvement in the future, I guess. How much better can it get? http://www.avsforum.com/ubb/biggrin.gif
post #4 of 8 Old 12-30-2000, 11:32 AM
aerialman's Avatar
Bob,
thanks for the detailed review. I hope I can hear this pre/pro some day. Seems like its one of the best ones out there. Enjoy, and happy holidays
- Jerry
aerialman is offline
post #5 of 8 Old 12-30-2000, 01:40 PM
RickS's Avatar
Bob,
Thanks for that great review!!! The last time you did a review on those Gemini's you cost me a bit of cash. http://www.avsforum.com/ubb/wink.gif But, now I have to find out were I can listen to the 32 in Canada. http://www.avsforum.com/ubb/smile.gif
The Home Theater
Rick
RickS is offline
post #6 of 8 Old 12-30-2000, 04:03 PM - Thread Starter
Central Scrutinizer
Bob Sorel's Avatar
Quoted: 191 Post(s)
Liked: 149
Thanks Jerry and Rick!
And Rick, since you own the Gemini's, I just had to tell you this: Every time I have upgraded the electronics in my system, the Gemini's just keep sounding better and better! I figured that better electronics would expose some weaknesses in the Dyne's, but just the opposite is true. I have owned these great speakers for about 6 months now and I am just discovering how truly incredible they are!! They are even more awesome than I had ever suspected, and a perfect mate for the AV32R. This is a match made in heaven!
post #7 of 8 Old 12-30-2000, 05:11 PM
RickS's Avatar
Bob,
I'm very happy with the Dynaudio speaker's with two SVS 20-39's. I'm using a Denon 5800 as a pre /pro and a Cinepro 3k6II for power. I will be looking very closely the TM AV32R when the DTS-ES decrete is available. I checked there site and noticed there are no Canadian dealers so, it will probably be the buy it before I listen to it senerio for me again. I see the retail price is 4.5K what do you think street will be? If you want e-mail me.
Rick
The Home Theater
Rick
RickS is offline
post #8 of 8 Old 12-30-2000, 09:20 PM - Thread Starter
Central Scrutinizer
Bob Sorel's Avatar
Quoted: 191 Post(s)
Liked: 149
I just got an email from Dr. Udo Zucker, in response to my concern about the muting relays. He wrote:
You will be pleased to hear that we are trying to reduce the number of mute relay clicks in a future software release.
The AV32R uses 5/7 mute relays as this is the only way of 'muting' without affecting the audio quality. All high-end products are doing this. Alternatively we could use transistors but they tend to affect the sound as they are not perfect switches.
We are working on a software version where the user can decide whether he wants the relays to work always or only in specific cases. The disadvantage: you might sometimes (when incorrect digital data is sent [during switching from one sound format to another-as DVDs often do]) get a short 'digital burst'.
I would say that Dr. Zucker has come up with a viable solution for me (and others) and I am looking forward to the next version of the software with great anticipation. This is typical of the great attitude towards the consumer that is displayed by TAG McLaren, and just one more reason that I have become a faithful customer.
Closed Thread Receivers, Amps, and Processors
