What's the difference between DTS-HD and DTS-HD Master Audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-30-2007, 02:54 AM - Thread Starter
saraphines's Avatar
Someone said that the DTS-HD is compressed and the DTS-HD Master Audio is uncompressed. What's more, the icons of the DTS-HD and DTS-HD Master Audio are different, is there anyone could tell me the difference between them? Thx a lot.
saraphines is offline
post #2 of 9 Old 04-30-2007, 03:15 AM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
Both codecs are compressed. DTS-HD HR is lossy, whereas DTS-HD MA is lossless. Not many people are going to be able to tell you the general audible difference between the two, because no hardware player currently decodes the lossless layer of DTS-HD MA tracks.
Here's more info on the two codecs and how they are specified for the Blu-Ray and HD DVD formats. Logos are also shown on this page.
MSmith83 is offline
post #3 of 9 Old 04-30-2007, 08:44 AM
Jack Gilvey's Avatar
Quoted: 35 Post(s)
Liked: 34
Both codecs are compressed and loseless. The only difference is the bitrate. The current maximum bitrate of DTS-HD MA for blu-ray is 24.5Mbps while DTS-HD for blu-ray is 6Mbps.
DTS HD HR is lossless? Doesn't sound right.
Jack Gilvey
SVS Customer Service
Jack Gilvey is offline
post #4 of 9 Old 04-30-2007, 08:46 AM - Thread Starter
saraphines's Avatar
Thanks so much, you both had made me more clearly about the two codes.
post #5 of 9 Old 04-30-2007, 08:50 AM
metfoo's Avatar
what about dts-hr core? is that the same as dts-hd?
metfoo is offline
post #6 of 9 Old 04-30-2007, 09:59 AM
hanwiz's Avatar
You're right. DTS HD looks like lossy after I calculated the true bitrate which should be 18M or more to be loseless.-_-.
hanwiz is offline
post #7 of 9 Old 04-30-2007, 10:14 AM
dicey's Avatar
This is incorrect. DTS-HD HR is lossy, but it supports a higher maximum bitrate than standard DTS (1.5Mbps vs. 3Mbps~HD-DVD or 6Mbpd~BD) and supports up to 7.1 channels instead of "only" 6.1(DTS-ES).
DTS-HD MA is effectively uncompessed but uses a 2:1 data compession ratio along with metadata to allow the signal to be uncompressed during decoding. This method achieves identical results to that of LPCM but at half the bitrate, and is practically identical to the methods used for DD TrueHD and MLP on DVD-A.
You are all WEIRDOS! - Sam the Eagle
dicey is offline
post #8 of 9 Old 04-30-2007, 01:56 PM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
Why in the hell did you quote me on this? Look at my post. I clearly stated that DTS-HD HR is lossy. Don't put words in my mouth. The other poster got that information from somewhere else.
MSmith83 is offline
post #9 of 9 Old 04-30-2007, 03:31 PM
dicey's Avatar
D'oh!
We all f**k up every now and then! Sorry, bro. Since both your comment and the mystery quote start with the same words, I just assumed that it came from you. But guess what, this time I just made an 'ass' out of 'me'!
dicey is offline
